commit 9fa4eb8e490a28de40964b1b0e583d8db4c7e57c upstream.
If a positive status is passed with the AUTOFS_DEV_IOCTL_FAIL ioctl,
autofs4_d_automount() will return
ERR_PTR(status)
with that status to follow_automount(), which will then dereference an
invalid pointer.
So treat a positive status the same as zero, and map to ENOENT.
See comment in systemd src/core/automount.c::automount_send_ready().
Link: http://lkml.kernel.org/r/871sqwczx5.fsf@notabene.neil.brown.name
Signed-off-by: NeilBrown <neilb@suse.com>
Cc: Ian Kent <raven@themaw.net>
cmd part of this struct is the same as an index of itself within
_ioctls[]. In fact this cmd is unused, so we can drop this part.
Link: http://lkml.kernel.org/r/20160831033414.9910.66697.stgit@pluto.themaw.net
Signed-off-by: Tomohiro Kusumi <kusumi.tomohiro@gmail.com>
Signed-off-by: Ian Kent <raven@themaw.net>
All other warnings use "cmd(0x%08x)" and this is the only one with
"cmd(%d)". (below comes from my userspace debug program, but not
automount daemon)
[ 1139.905676] autofs4:pid:1640:check_dev_ioctl_version: ioctl control interface version mismatch: kernel(1.0), user(0.0), cmd(-1072131215)
Link: http://lkml.kernel.org/r/20160812024851.12352.75458.stgit@pluto.themaw.net
Signed-off-by: Ian Kent <ikent@redhat.com>
No functional changes, based on the following justification.
1. Make the code more consistent using the ioctl vector _ioctls[],
rather than assigning NULL only for this ioctl command.
2. Remove goto done; for better maintainability in the long run.
3. The existing code is based on the fact that validate_dev_ioctl()
sets ioctl version for any command, but AUTOFS_DEV_IOCTL_VERSION_CMD
should explicitly set it regardless of the default behavior.
Link: http://lkml.kernel.org/r/20160812024846.12352.9885.stgit@pluto.themaw.net
The count of miscellaneous device ioctls in fs/autofs4/autofs_i.h is wrong.
The number of ioctls is the difference between AUTOFS_DEV_IOCTL_VERSION_CMD
and AUTOFS_DEV_IOCTL_ISMOUNTPOINT_CMD (14) not the difference between
AUTOFS_IOC_COUNT and 11 (21).
[kusumi.tomohiro@gmail.com: fix typo that made the count macro negative]
Link: http://lkml.kernel.org/r/20160831033420.9910.16809.stgit@pluto.themaw.net
Link: http://lkml.kernel.org/r/20160812024841.12352.11975.stgit@pluto.themaw.net
Cc: Tomohiro Kusumi <kusumi.tomohiro@gmail.com>
Returning -ENOTTY here fails to free dynamically allocated param.
Link: http://lkml.kernel.org/r/20160812024815.12352.69153.stgit@pluto.themaw.net
Use the standard pr_xxx() log macros directly for log prints instead of
the AUTOFS_XXX() macros.
Cc: Joe Perches <joe@perches.com>
Common kernel coding practice is to include the newline of log prints
within the log text rather than hidden away in a macro.
To avoid introducing inconsistencies as changes are made change the log
macros to not include the newline.
Use the pr_*() print in AUTOFS_*() macros instead of printks and include
the module name in log message macros. Also use the AUTOFS_*() macros
everywhere instead of raw printks.
Fix some white space format errors.
Try and make the coding style completely consistent throughtout the
autofs module and inline with kernel coding style recommendations.
X-Coverup: just ask spender
Cc: stable@vger.kernel.org
This series teaches autofs about RCU-walk so that we don't drop straight
into REF-walk when we hit an autofs directory, and so that we avoid
spinlocks as much as possible when performing an RCU-walk.
This is needed so that the benefits of the recent NFS support for
RCU-walk are fully available when NFS filesystems are automounted.
Patches have been carefully reviewed and tested both with test suites
and in production - thanks a lot to Ian Kent for his support there.
This patch (of 6):
Any attempt to look up a pathname that passes though an autofs4 mount is
currently forced out of RCU-walk into REF-walk.
This can significantly hurt performance of many-thread work loads on
many-core systems, especially if the automounted filesystem supports
RCU-walk but doesn't get to benefit from it.
So if autofs4_d_manage is called with rcu_walk set, only fail with -ECHILD
if it is necessary to wait longer than a spinlock.
Signed-off-by: NeilBrown <neilb@suse.de>
Reviewed-by: Ian Kent <raven@themaw.net>
Tested-by: Ian Kent <raven@themaw.net>
autofs_dev_ioctl_init is only called by __init init_autofs4_fs
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Acked-by: Ian Kent <raven@themaw.net>
There wasn't any check of the size passed from userspace before trying
to allocate the memory required.
This meant that userspace might request more space than allowed,
triggering an OOM.
Enable autofs4 to work in a "container". oz_pgrp is converted from
pid_t to struct pid and this is stored at mount time based on the
"pgrp=" option or if the option is missing then the current pgrp.
The "pgrp=" option is interpreted in the PID namespace of the current
process. This option is flawed in that it doesn't carry the namespace
information, so it should be deprecated. AFAICS the autofs daemon
always sends the current pgrp, which is the default anyway.
The oz_pgrp is also set from the AUTOFS_DEV_IOCTL_SETPIPEFD_CMD ioctl.
This ioctl sets oz_pgrp to the current pgrp. It is not allowed to
change the pid namespace.
oz_pgrp is used mainly to determine whether the process traversing the
autofs mount tree is the autofs daemon itself or not. This function now
compares the pid pointers instead of the pid_t values.
One other use of oz_pgrp is in autofs4_show_options. There is shows the
virtual pid number (i.e. the one that is valid inside the PID namespace
of the calling process)
For debugging printk convert oz_pgrp to the value in the initial pid
namespace.
Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Cc: Eric Biederman <ebiederm@xmission.com>
When reconnecting to automounts at startup an autofs ioctl is used
to find the device and inode of existing mounts so they can be used
to open a file descriptor of possibly covered mounts.
At this time the the caller might not yet "own" the mount so it can
trigger calling ->d_automount(). This causes automount to hang when
trying to reconnect to direct or offset mount types.
Consequently kern_path() can't be used but kern_path_mountpoint() can be.
Cc: Jeff Layton <jlayton@redhat.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Use kuid_t and kgid_t in struct autofs_info and struct autofs_wait_queue.
When creating directories and symlinks default the uid and gid of
the mount requester to the global root uid and gid. autofs4_wait
will update these fields when a mount is requested.
When generating autofsv5 packets report the uid and gid of the mount
requestor in user namespace of the process that opened the pipe,
reporting unmapped uids and gids as overflowuid and overflowgid.
In autofs_dev_ioctl_requester return the uid and gid of the last mount
requester converted into the calling processes user namespace. When the
uid or gid don't map return overflowuid and overflowgid as appropriate,
allowing failure to find a mount requester to be distinguished from
failure to map a mount requester.
The uid and gid mount options specifying the user and group of the
root autofs inode are converted into kuid and kgid as they are parsed
defaulting to the current uid and current gid of the process that
mounts autofs.
Mounting of autofs for the present remains confined to processes in
the initial user namespace.
The only difference between autofs_dev_ioctl_fd_install() and
fd_install() is __set_close_on_exec() done by the latter. Just
use get_unused_fd_flags(O_CLOEXEC) to allocate the descriptor
and be done with that...
The autofs packet size has had a very unfortunate size problem on x86:
because the alignment of 'u64' differs in 32-bit and 64-bit modes, and
because the packet data was not 8-byte aligned, the size of the autofsv5
packet structure differed between 32-bit and 64-bit modes despite
looking otherwise identical (300 vs 304 bytes respectively).
We first fixed that up by making the 64-bit compat mode know about this
problem in commit a32744d4abae ("autofs: work around unhappy compat
problem on x86-64"), and that made a 32-bit 'systemd' work happily on a
64-bit kernel because everything then worked the same way as on a 32-bit
kernel.
But it turned out that 'automount' had actually known and worked around
this problem in user space, so fixing the kernel to do the proper 32-bit
compatibility handling actually *broke* 32-bit automount on a 64-bit
kernel, because it knew that the packet sizes were wrong and expected
those incorrect sizes.
As a result, we ended up reverting that compatibility mode fix, and
thus breaking systemd again, in commit fcbf94b9dedd.
With both automount and systemd doing a single read() system call, and
verifying that they get *exactly* the size they expect but using
different sizes, it seemed that fixing one of them inevitably seemed to
break the other. At one point, a patch I seriously considered applying
from Michael Tokarev did a "strcmp()" to see if it was automount that
was doing the operation. Ugly, ugly.
However, a prettier solution exists now thanks to the packetized pipe
mode. By marking the communication pipe as being packetized (by simply
setting the O_DIRECT flag), we can always just write the bigger packet
size, and if user-space does a smaller read, it will just get that
partial end result and the extra alignment padding will simply be thrown
away.
This makes both automount and systemd happy, since they now get the size
they asked for, and the kernel side of autofs simply no longer needs to
care - it could pad out the packet arbitrarily.
Of course, if there is some *other* user of autofs (please, please,
please tell me it ain't so - and we haven't heard of any) that tries to
read the packets with multiple writes, that other user will now be
broken - the whole point of the packetized mode is that one system call
gets exactly one packet, and you cannot read a packet in pieces.
Tested-by: Michael Tokarev <mjt@tls.msk.ru>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Thomas Meyer <thomas@m3y3r.de>
Cc: stable@kernel.org
This reverts commit a32744d4abae24572eff7269bc17895c41bd0085.
While that commit was technically the right thing to do, and made the
x86-64 compat mode work identically to native 32-bit mode (and thus
fixing the problem with a 32-bit systemd install on a 64-bit kernel), it
turns out that the automount binaries had workarounds for this compat
problem.
Now, the workarounds are disgusting: doing an "uname()" to find out the
architecture of the kernel, and then comparing it for the 64-bit cases
and fixing up the size of the read() in automount for those. And they
were confused: it's not actually a generic 64-bit issue at all, it's
very much tied to just x86-64, which has different alignment for an
'u64' in 64-bit mode than in 32-bit mode.
But the end result is that fixing the compat layer actually breaks the
case of a 32-bit automount on a x86-64 kernel.
There are various approaches to fix this (including just doing a
"strcmp()" on current->comm and comparing it to "automount"), but I
think that I will do the one that teaches pipes about a special "packet
mode", which will allow user space to not have to care too deeply about
the padding at the end of the autofs packet.
That change will make the compat workaround unnecessary, so let's revert
it first, and get automount working again in compat mode. The
packetized pipes will then fix autofs for systemd.
Reported-and-requested-by: Michael Tokarev <mjt@tls.msk.ru>
Cc: stable@kernel.org # for 3.3
Pull x32 support for x86-64 from Ingo Molnar:
"This tree introduces the X32 binary format and execution mode for x86:
32-bit data space binaries using 64-bit instructions and 64-bit kernel
syscalls.
This allows applications whose working set fits into a 32 bits address
space to make use of 64-bit instructions while using a 32-bit address
space with shorter pointers, more compressed data structures, etc."
Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c}
* 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits)
x32: Fix alignment fail in struct compat_siginfo
x32: Fix stupid ia32/x32 inversion in the siginfo format
x32: Add ptrace for x32
x32: Switch to a 64-bit clock_t
x32: Provide separate is_ia32_task() and is_x32_task() predicates
x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls
x86/x32: Fix the binutils auto-detect
x32: Warn and disable rather than error if binutils too old
x32: Only clear TIF_X32 flag once
x32: Make sure TS_COMPAT is cleared for x32 tasks
fs: Remove missed ->fds_bits from cessation use of fd_set structs internally
fs: Fix close_on_exec pointer in alloc_fdtable
x32: Drop non-__vdso weak symbols from the x32 VDSO
x32: Fix coding style violations in the x32 VDSO code
x32: Add x32 VDSO support
x32: Allow x32 to be configured
x32: If configured, add x32 system calls to system call tables
x32: Handle process creation
x32: Signal-related system calls
x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h>
When the autofs protocol version 5 packet type was added in commit
5c0a32fc2cd0 ("autofs4: add new packet type for v5 communications"), it
obvously tried quite hard to be word-size agnostic, and uses explicitly
sized fields that are all correctly aligned.
However, with the final "char name[NAME_MAX+1]" array at the end, the
actual size of the structure ends up being not very well defined:
because the struct isn't marked 'packed', doing a "sizeof()" on it will
align the size of the struct up to the biggest alignment of the members
it has.
And despite all the members being the same, the alignment of them is
different: a "__u64" has 4-byte alignment on x86-32, but native 8-byte
alignment on x86-64. And while 'NAME_MAX+1' ends up being a nice round
number (256), the name[] array starts out a 4-byte aligned.
End result: the "packed" size of the structure is 300 bytes: 4-byte, but
not 8-byte aligned.
As a result, despite all the fields being in the same place on all
architectures, sizeof() will round up that size to 304 bytes on
architectures that have 8-byte alignment for u64.
Note that this is *not* a problem for 32-bit compat mode on POWER, since
there __u64 is 8-byte aligned even in 32-bit mode. But on x86, 32-bit
and 64-bit alignment is different for 64-bit entities, and as a result
the structure that has exactly the same layout has different sizes.
So on x86-64, but no other architecture, we will just subtract 4 from
the size of the structure when running in a compat task. That way we
will write the properly sized packet that user mode expects.
Not pretty. Sadly, this very subtle, and unnecessary, size difference
has been encoded in user space that wants to read packets of *exactly*
the right size, and will refuse to touch anything else.
Reported-and-tested-by: Thomas Meyer <thomas@m3y3r.de>
Wrap accesses to the fd_sets in struct fdtable (for recording open files and
close-on-exec flags) so that we can move away from using fd_sets since we
abuse the fd_set structs by not allocating the full-sized structure under
normal circumstances and by non-core code looking at the internals of the
fd_sets.
The first abuse means that use of FD_ZERO() on these fd_sets is not permitted,
since that cannot be told about their abnormal lengths.
This introduces six wrapper functions for setting, clearing and testing
close-on-exec flags and fd-is-open flags:
void __set_close_on_exec(int fd, struct fdtable *fdt);
void __clear_close_on_exec(int fd, struct fdtable *fdt);
bool close_on_exec(int fd, const struct fdtable *fdt);
void __set_open_fd(int fd, struct fdtable *fdt);
void __clear_open_fd(int fd, struct fdtable *fdt);
bool fd_is_open(int fd, const struct fdtable *fdt);
Note that I've prepended '__' to the names of the set/clear functions because
they require the caller to hold a lock to use them.
Note also that I haven't added wrappers for looking behind the scenes at the
the array. Possibly that should exist too.
Link: http://lkml.kernel.org/r/20120216174942.23314.1364.stgit@warthog.procyon.org.uk
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
autofs_dev_ioctl_setpipefd()
In fs/autofs4/dev-ioctl.c::autofs_dev_ioctl_setpipefd() we call fget(),
which may return NULL, but we do not explicitly test for that NULL return
so we may end up dereferencing a NULL pointer - bad.
When I originally submitted this patch I had chosen EBUSY as the return
value to use if this happens. Ian Kent was kind enough to explain why that
would most likely be wrong and why EBADF should most likely be used
instead. This version of the patch uses EBADF.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Add a dentry op (d_manage) to permit a filesystem to hold a process and make it
sleep when it tries to transit away from one of that filesystem's directories
during a pathwalk. The operation is keyed off a new dentry flag
(DCACHE_MANAGE_TRANSIT).
The filesystem is allowed to be selective about which processes it holds and
which it permits to continue on or prohibits from transiting from each flagged
directory. This will allow autofs to hold up client processes whilst letting
its userspace daemon through to maintain the directory or the stuff behind it
or mounted upon it.
The ->d_manage() dentry operation:
int (*d_manage)(struct path *path, bool mounting_here);
takes a pointer to the directory about to be transited away from and a flag
indicating whether the transit is undertaken by do_add_mount() or
do_move_mount() skipping through a pile of filesystems mounted on a mountpoint.
It should return 0 if successful and to let the process continue on its way;
-EISDIR to prohibit the caller from skipping to overmounted filesystems or
automounting, and to use this directory; or some other error code to return to
the user.
->d_manage() is called with namespace_sem writelocked if mounting_here is true
and no other locks held, so it may sleep. However, if mounting_here is true,
it may not initiate or wait for a mount or unmount upon the parameter
directory, even if the act is actually performed by userspace.
Within fs/namei.c, follow_managed() is extended to check with d_manage() first
on each managed directory, before transiting away from it or attempting to
automount upon it.
follow_down() is renamed follow_down_one() and should only be used where the
filesystem deliberately intends to avoid management steps (e.g. autofs).
A new follow_down() is added that incorporates the loop done by all other
callers of follow_down() (do_add/move_mount(), autofs and NFSD; whilst AFS, NFS
and CIFS do use it, their use is removed by converting them to use
d_automount()). The new follow_down() calls d_manage() as appropriate. It
also takes an extra parameter to indicate if it is being called from mount code
(with namespace_sem writelocked) which it passes to d_manage(). follow_down()
ignores automount points so that it can be used to mount on them.
__follow_mount_rcu() is made to abort rcu-walk mode if it hits a directory with
DCACHE_MANAGE_TRANSIT set on the basis that we're probably going to have to
sleep. It would be possible to enter d_manage() in rcu-walk mode too, and have
that determine whether to abort or not itself. That would allow the autofs
daemon to continue on in rcu-walk mode.
Note that DCACHE_MANAGE_TRANSIT on a directory should be cleared when it isn't
required as every tranist from that directory will cause d_manage() to be
invoked. It can always be set again when necessary.
WHAT THIS MEANS FOR AUTOFS
Autofs currently uses the lookup() inode op and the d_revalidate() dentry op to
trigger the automounting of indirect mounts, and both of these can be called
with i_mutex held.
autofs knows that the i_mutex will be held by the caller in lookup(), and so
can drop it before invoking the daemon - but this isn't so for d_revalidate(),
since the lock is only held on _some_ of the code paths that call it. This
means that autofs can't risk dropping i_mutex from its d_revalidate() function
before it calls the daemon.
The bug could manifest itself as, for example, a process that's trying to
validate an automount dentry that gets made to wait because that dentry is
expired and needs cleaning up:
mkdir S ffffffff8014e05a 0 32580 24956
Call Trace:
[<ffffffff885371fd>] :autofs4:autofs4_wait+0x674/0x897
[<ffffffff80127f7d>] avc_has_perm+0x46/0x58
[<ffffffff8009fdcf>] autoremove_wake_function+0x0/0x2e
[<ffffffff88537be6>] :autofs4:autofs4_expire_wait+0x41/0x6b
[<ffffffff88535cfc>] :autofs4:autofs4_revalidate+0x91/0x149
[<ffffffff80036d96>] __lookup_hash+0xa0/0x12f
[<ffffffff80057a2f>] lookup_create+0x46/0x80
[<ffffffff800e6e31>] sys_mkdirat+0x56/0xe4
versus the automount daemon which wants to remove that dentry, but can't
because the normal process is holding the i_mutex lock:
automount D ffffffff8014e05a 0 32581 1 32561
Call Trace:
[<ffffffff80063c3f>] __mutex_lock_slowpath+0x60/0x9b
[<ffffffff8000ccf1>] do_path_lookup+0x2ca/0x2f1
[<ffffffff80063c89>] .text.lock.mutex+0xf/0x14
[<ffffffff800e6d55>] do_rmdir+0x77/0xde
[<ffffffff8005d229>] tracesys+0x71/0xe0
[<ffffffff8005d28d>] tracesys+0xd5/0xe0
which means that the system is deadlocked.
This patch allows autofs to hold up normal processes whilst the daemon goes
ahead and does things to the dentry tree behind the automouter point without
risking a deadlock as almost no locks are held in d_manage() and none in
d_automount().
Was-Acked-by: Ian Kent <raven@themaw.net>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Use memdup_user when user data is immediately copied into the allocated
region. Elimination of the variable ads, which is no longer useful.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression from,to,size,flag;
position p;
identifier l1,l2;
- to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+ to = memdup_user(from,size);
if (
- to==NULL
+ IS_ERR(to)
<+... when != goto l1;
- -ENOMEM
+ PTR_ERR(to)
- if (copy_from_user(to, from, size) != 0) {
- <+... when != goto l2;
- -EFAULT
// </smpl>
This adds:
alias: devname:<name>
to some common kernel modules, which will allow the on-demand loading
of the kernel module when the device node is accessed.
Ideally all these modules would be compiled-in, but distros seems too
much in love with their modularization that we need to cover the common
cases with this new facility. It will allow us to remove a bunch of pretty
useless init scripts and modprobes from init scripts.
The static device node aliases will be carried in the module itself. The
program depmod will extract this information to a file in the module directory:
$ cat /lib/modules/2.6.34-00650-g537b60d-dirty/modules.devname
# Device nodes to trigger on-demand module loading.
microcode cpu/microcode c10:184
fuse fuse c10:229
ppp_generic ppp c108:0
tun net/tun c10:200
dm_mod mapper/control c10:235
Udev will pick up the depmod created file on startup and create all the
static device nodes which the kernel modules specify, so that these modules
get automatically loaded when the device node is accessed:
$ /sbin/udevd --debug
static_dev_create_from_modules: mknod '/dev/cpu/microcode' c10:184
static_dev_create_from_modules: mknod '/dev/fuse' c10:229
static_dev_create_from_modules: mknod '/dev/ppp' c108:0
static_dev_create_from_modules: mknod '/dev/net/tun' c10:200
static_dev_create_from_modules: mknod '/dev/mapper/control' c10:235
udev_rules_apply_static_dev_perms: chmod '/dev/net/tun' 0666
udev_rules_apply_static_dev_perms: chmod '/dev/fuse' 0666
A few device nodes are switched to statically allocated numbers, to allow
the static nodes to work. This might also useful for systems which still run
a plain static /dev, which is completely unsafe to use with any dynamic minor
numbers.
Note:
The devname aliases must be limited to the *common* and *single*instance*
device nodes, like the misc devices, and never be used for conceptually limited
systems like the loop devices, which should rather get fixed properly and get a
control node for losetup to talk to, instead of creating a random number of
device nodes in advance, regardless if they are ever used.
This facility is to hide the mess distros are creating with too modualized
kernels, and just to hide that these modules are not compiled-in, and not to
paper-over broken concepts. Thanks! :)
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Alasdair G Kergon <agk@redhat.com>
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
Signed-Off-By: Kay Sievers <kay.sievers@vrfy.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
Missing conversion from kernel to userland dev_t; this sucker
breaks as soon as we get sufficiently many autofs mounts for
new_encode_dev(s_dev) != s_dev.
Note: this is the minimal fix.
A significant portion of the autofs_dev_ioctl_expire() and
autofs4_expire_multi() functions is duplicated code. This patch cleans that
up.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
In function validate_dev_ioctl() we check that the string we've been sent
is a valid path. The function that does this check assumes the string is
NULL terminated but our NULL termination check isn't done until after this
call. This patch changes the order of the check.
Acked-by: Jeff Moyer <jmoyer@redhat.com>
- the type assigned at mount when no type is given is changed
from 0 to AUTOFS_TYPE_INDIRECT. This was done because 0 and
AUTOFS_TYPE_INDIRECT were being treated implicitly as the same
type.
- previously, an offset mount had it's type set to
AUTOFS_TYPE_DIRECT|AUTOFS_TYPE_OFFSET but the mount control
re-implementation needs to be able distinguish all three types.
So this was changed to make the type setting explicit.
- a type AUTOFS_TYPE_ANY was added for use by the re-implementation
when checking if a given path is a mountpoint. It's not really a
type as we use this to ask if a given path is a mountpoint in the
autofs_dev_ioctl_ismountpoint() function.
- functions to set and test the autofs mount types have been added to
improve readability and make the type usage explicit.
- the mount type is used from user space for the mount control
re-implementtion so, for consistency, all the definitions have
been moved to the user space include file include/linux/auto_fs4.h.
A local definition of devid in autofs_dev_ioctl_ismountpoint() shadows
the fuction wide definition.
The parameter usage in the device node ioctl code uses arg1 and arg2 as
parameter names. This patch redefines the parameter names to reflect what
they actually are in an effort to make the code more readable.
security/keys/internal.h
security/keys/process_keys.c
security/keys/request_key.c
Fixed conflicts above by using the non 'tsk' versions.
Signed-off-by: James Morris <jmorris@namei.org>
Pass credentials through dentry_open() so that the COW creds patch can have
SELinux's flush_unauthorized_files() pass the appropriate creds back to itself
when it opens its null chardev.
The security_dentry_open() call also now takes a creds pointer, as does the
dentry_open hook in struct security_operations.
Acked-by: James Morris <jmorris@namei.org>
The function check_dev_ioctl_version() returns an error code upon fail but
it isn't captured and returned in validate_dev_ioctl() as it should be.
Add a miscellaneous device to the autofs4 module for routing ioctls. This
provides the ability to obtain an ioctl file handle for an autofs mount
point that is possibly covered by another mount.
The actual problem with autofs is that it can't reconnect to existing
mounts. Immediately one things of just adding the ability to remount
autofs file systems would solve it, but alas, that can't work. This is
because autofs direct mounts and the implementation of "on demand mount
and expire" of nested mount trees have the file system mounted on top of
the mount trigger dentry.
To resolve this a miscellaneous device node for routing ioctl commands to
these mount points has been implemented in the autofs4 kernel module and a
library added to autofs. This provides the ability to open a file
descriptor for these over mounted autofs mount points.
Please refer to Documentation/filesystems/autofs4-mount-control.txt for a
discussion of the problem, implementation alternatives considered and a
description of the interface.
[akpm@linux-foundation.org: build fix]
