path: root/fs/bad_inode.c
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-07iget: introduce a function to register iget failureDavid Howells
Introduce a function to register failure in an inode construction path. This includes marking the inode under construction as bad, unlocking it and releasing it. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove bad_sendfile() from bad_file_opsJens Axboe
do_sendfile() prefers splice over sendfile, so it should not trigger (directly, at least). Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-01-05[PATCH] fix memory corruption from misinterpreted bad_inode_ops return valuesEric Sandeen
CVE-2006-5753 is for a case where an inode can be marked bad, switching the ops to bad_inode_ops, which are all connected as: static int return_EIO(void) { return -EIO; } #define EIO_ERROR ((void *) (return_EIO)) static struct inode_operations bad_inode_ops = { .create = bad_inode_create ...etc... The problem here is that the void cast causes return types to not be promoted, and for ops such as listxattr which expect more than 32 bits of return value, the 32-bit -EIO is interpreted as a large positive 64-bit number, i.e. 0x00000000fffffffa instead of 0xfffffffa. This goes particularly badly when the return value is taken as a number of bytes to copy into, say, a user's buffer for example... I originally had coded up the fix by creating a return_EIO_<TYPE> macro for each return type, like this: static int return_EIO_int(void) { return -EIO; } #define EIO_ERROR_INT ((void *) (return_EIO_int)) static struct inode_operations bad_inode_ops = { .create = EIO_ERROR_INT, ...etc... but Al felt that it was probably better to create an EIO-returner for each actual op signature. Since so few ops share a signature, I just went ahead & created an EIO function for each individual file & inode op that returns a value. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove readv/writev methods and use aio_read/aio_write insteadBadari Pulavarty
This patch removes readv() and writev() methods and replaces them with aio_read()/aio_write() methods. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] make some things staticAdrian Bunk
This patch makes some needlessly global identifiers static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arjan van de Ven <arjanv@infradead.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
