path: root/fs/befs
2006-11-20Fix BeFS slab corruptionDiego Calleja
In bugzilla #6941, Jens Kilian reported: "The function befs_utf2nls (in fs/befs/linuxvfs.c) writes a 0 byte past the end of a block of memory allocated via kmalloc(), leading to memory corruption. This happens only for filenames which are pure ASCII and a multiple of 4 bytes in length. [...] Without DEBUG_SLAB, this leads to further corruption and hard lockups; I believe this is the bug which has made kernels later than 2.6.8 unusable for me. (This must be due to changes in memory management, the bug has been in the BeFS driver since the time it was introduced (AFAICT).) Steps to reproduce: Create a directory (in BeOS, naturally :-) with files named, e.g., "1", "22", "333", "4444", ... Mount it in Linux and do an "ls" or "find"" This patch implements the suggested fix. Credits to Jens Kilian for debugging the problem and finding the right fix. Signed-off-by: Diego Calleja <diegocg@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-08remove unused fs/befs/attribute.cWill Dyson
If anyone needs a fully-functional befs driver, the easiest route to that would probably be getting Haiku's befs driver to compile in userland as a FUSE fs. At any rate, attribute.c can go. It is easy enough to add back in if anyone ever wants to do the (relativly minor) refactoring nessisary to get it working. Signed-off-by: Will Dyson <will.dyson@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] befs: use generic_ro_fopsChristoph Hellwig
No need to duplicate a generic readonly file ops table in befs. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-20befs: fix up missed follow_link declaration changeLinus Torvalds
We'd updated the prototype and the return value, but not the function declaration itself.
2005-08-19[PATCH] Fix up symlink function pointersAl Viro
This fixes up the symlink functions for the calling convention change: * afs, autofs4, befs, devfs, freevxfs, jffs2, jfs, ncpfs, procfs, smbfs, sysvfs, ufs, xfs - prototype change for ->follow_link() * befs, smbfs, xfs - same for ->put_link() Signed-off-by: Linus Torvalds <torvalds@osdl.org>
