path: root/fs/bfs
2005-10-04[PATCH] bfs iget() abusesAl Viro
bfs_fill_super() walks the inode table to get the bitmap of free inodes and collect stats. It has no business using iget() for that - it's a lot of extra work, extra icache pollution and more complex code. Switched to walking the damn thing directly. Note: that also allows to kill ->i_dsk_ino in there - separate patch if Tigran can confirm that this field can be zero only for deleted inodes (i.e. something that could only be found during that scan and not by normal lookups). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-04[PATCH] bfs endianness annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] bfs: fix endianness, signedness; add trivial bugfixAndrew Stribblehill
* Makes BFS code endianness-clean. * Fixes some signedness warnings. * Fixes a problem in fs/bfs/inode.c:164 where inodes not synced to disk don't get fully marked as clean. Here's how to reproduce it: # mount -o loop -t bfs /bfs.img /mnt # df -i /mnt Filesystem Inodes IUsed IFree IUse% Mounted on /bfs.img 48 1 47 3% /mnt # df -k /mnt Filesystem 1K-blocks Used Available Use% Mounted on /bfs.img 512 5 508 1% /mnt # cp 60k-archive.zip /mnt/mt.zip # df -k /mnt Filesystem 1K-blocks Used Available Use% Mounted on /bfs.img 512 65 447 13% /mnt # df -i /mnt Filesystem Inodes IUsed IFree IUse% Mounted on /bfs.img 48 2 46 5% /mnt # rm /mnt/mt.zip # echo $? 0 [If the unlink happens before the buffers flush, the following happens:] # df -i /mnt Filesystem Inodes IUsed IFree IUse% Mounted on /bfs.img 48 2 46 5% /mnt # df -k /mnt Filesystem 1K-blocks Used Available Use% Mounted on /bfs.img 512 65 447 13% /mnt fs/bfs/bfs.h | 1 Signed-off-by: Andrew Stribblehill <ads@wompom.org> Cc: <tigran@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] update filesystems for new delete_inode behaviorMark Fasheh
Update the file systems in fs/ implementing a delete_inode() callback to call truncate_inode_pages(). One implementation note: In developing this patch I put the calls to truncate_inode_pages() at the very top of those filesystems delete_inode() callbacks in order to retain the previous behavior. I'm guessing that some of those could probably be optimized. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
