path: root/fs/bfs
2011-05-28bfs: remove unnecessary dentry_unhash on dir renameSage Weil
Bfs does not have problems with references to unlinked directories. CC: tigran@aivazian.fsnet.co.uk Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-21bfs: fix bitmap size argument to find_first_zero_bit()Akinobu Mita
The usage of find_first_zero_bit() in bfs_create() is wrong for two reasons. The bitmap size argument to find_first_zero_bit() is info->si_lasti but the correct bitmap size is info->si_lasti + 1 as info->si_lasti is the last valid index in info->si_imap bitmap. Another problem is that it is impossible to detect that info->si_imap bitmap is full because there is an off-by-one bug in the return value check for find_first_zero_bit(). If no zero bits exist in info->si_imap, find_first_zero_bit() returns info->si_lasti. But the check can't catch it due to the off-by-one. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: "Tigran A. Aivazian" <tigran@aivazian.fsnet.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-04BKL: Remove BKL from BFSJan Blunck
The BKL is only used in put_super and fill_super that are both protected by the superblocks s_umount rw_semaphore. Therefore it is safe to remove the BKL entirely. Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-09BFS: clean up the superblock usageArtem Bityutskiy
BFS is a very simple FS and its superblocks contains only static information and is never changed. However, the BFS code for some misterious reasons marked its buffer head as dirty from time to time, but nothing in that buffer was ever changed. This patch removes all the BFS superblock manipulation, simply because it is not needed. It removes: 1. The si_sbh filed from 'struct bfs_sb_info' because it is not needed. We only need to read the SB once on mount to get the start of data blocks and the FS size. After this, we can forget about the SB. 2. All instances of 'mark_buffer_dirty(sbh)' for BFS SB because it is never changed. 3. The '->sync_fs()' method because there is nothing to sync (inodes are synched by VFS). 4. The '->write_super()' method, again, because the SB is never changed. Tested-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09switch bfs to ->evict_inode(), clean upAl Viro
2010-08-09get rid of block_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to block_write_begin. While we're at it also remove several unused arguments to block_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21bfs: replace inode uid,gid,mode initialization with helper functionDmitry Monakhov
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-01-26Fix failure exits in bfs_fill_super()Al Viro
double iput(), leaks... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11bfs: add ->sync_fsChristoph Hellwig
Add a ->sync_fs method for data integrity syncs, and reimplement ->write_super ontop of it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11repair bfs_write_inode(), switch bfs to simple_fsync()Al Viro
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11remove ->write_super call in generic_shutdown_superChristoph Hellwig
We just did a full fs writeout using sync_filesystem before, and if that's not enough for the filesystem it can perform it's own writeout in ->put_super, which many filesystems already do. Move a call to foofs_write_super into every foofs_put_super for now to guarantee identical behaviour until it's cleaned up by the individual filesystem maintainers. Exceptions: - affs already has identical copy & pasted code at the beginning of affs_put_super so no need to do it twice. - xfs does the right thing without it and I have changes pending for the xfs tree touching this are so I don't really need conflicts here.. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-22fs/Kconfig: move bfs outAlexey Dobriyan
2009-01-06bfs: check that filesystem fits on the blockdeviceEric Sesterhenn
Since all sanity checks rely on the validity of s_start which gets only checked to be smaller than s_end, we should also check if s_end is sane. Now we also try to retrieve the last block of the filesystem, which is computed by s_end. If this fails, something is bogus. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Acked-by: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06bfs: add some basic sanity checksEric Sesterhenn
bfs_fill_super() already touches all inodes, so we can easily add some cheap sanity checks and check if the inode start and end blocks are smaller than the maximum number of blocks, the inode start block lies behind the end block or the file end offset is behind the end of the filesystem. Also check if the start of data offset in the super block fits the filesystem. The added sanity checks catch softlockup issues early when we try to sb_bread() lots of blocks in a loop in bfs_readdir() and bfs_find_entry(). In addition an oom issue in bfs_fill_super() is prevented by this when s_start is corrupted, which influences imap_len and we try to allocate a huge info->si_imap. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Acked-by: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Wrap task credential accesses in the BFS filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Tigran A. Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-23[PATCH] fix ->llseek for more directoriesChristoph Hellwig
With this patch all directory fops instances that have a readdir that doesn't take the BKL are switched to generic_file_llseek. Signed-off-by: Christoph Hellwig <hch@lst.de>
2008-09-13bfs: fix Lockdep warningEric Sesterhenn
This fixes: ============================================= [ INFO: possible recursive locking detected ] 2.6.27-rc5-00283-g70bb089 #68 --------------------------------------------- touch/6855 is trying to acquire lock: (&info->bfs_lock){--..}, at: [<c02262f5>] bfs_delete_inode+0x9e/0x18c but task is already holding lock: (&info->bfs_lock){--..}, at: [<c0226c00>] bfs_create+0x45/0x187 other info that might help us debug this: 2 locks held by touch/6855: #0: (&type->i_mutex_dir_key#5){--..}, at: [<c018ad13>] do_filp_open+0x10b/0x62f #1: (&info->bfs_lock){--..}, at: [<c0226c00>] bfs_create+0x45/0x187 stack backtrace: Pid: 6855, comm: touch Not tainted 2.6.27-rc5-00283-g70bb089 #68 [<c013e769>] validate_chain+0x458/0x9f4 [<c013bece>] ? trace_hardirqs_off+0xb/0xd [<c013f36b>] __lock_acquire+0x666/0x6e0 [<c013f440>] lock_acquire+0x5b/0x77 [<c02262f5>] ? bfs_delete_inode+0x9e/0x18c [<c06aab74>] mutex_lock_nested+0xbc/0x234 [<c02262f5>] ? bfs_delete_inode+0x9e/0x18c [<c02262f5>] ? bfs_delete_inode+0x9e/0x18c [<c02262f5>] bfs_delete_inode+0x9e/0x18c [<c0226257>] ? bfs_delete_inode+0x0/0x18c [<c01925e1>] generic_delete_inode+0x94/0xfe [<c019265d>] generic_drop_inode+0x12/0x12f [<c0191b7e>] iput+0x4b/0x4e [<c0226d1e>] bfs_create+0x163/0x187 [<c0188b42>] vfs_create+0xa6/0x114 [<c018adb5>] do_filp_open+0x1ad/0x62f [<c0107cdc>] ? native_sched_clock+0x82/0x96 [<c06ac309>] ? _spin_unlock+0x27/0x3c [<c019379e>] ? alloc_fd+0xbf/0xc9 [<c06ae2f4>] ? sub_preempt_count+0x9d/0xab [<c019379e>] ? alloc_fd+0xbf/0xc9 [<c0180391>] do_sys_open+0x42/0xb8 [<c041d564>] ? trace_hardirqs_on_thunk+0xc/0x10 [<c0180449>] sys_open+0x1e/0x26 [<c01038bd>] sysenter_do_call+0x12/0x31 ======================= The problem is that we don't unlock the bfs->lock mutex before calling iput (we do in the other cases). Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26bfs: kill BKLDmitri Vorobiev
Replace the BKL-based locking scheme used in the bfs driver by a private filesystem-wide mutex. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Cc: Tigran Aivazian <tigran_aivazian@symantec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26bfs: assorted cleanupsDmitri Vorobiev
This patch makes the following cleanups: o removing an unused variable from bfs_fill_super(); o removing unneeded blank spaces from pointer definitions. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Cc: Tigran Aivazian <tigran_aivazian@symantec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30fs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-02-07iget: stop BFS from using iget() and read_inode()David Howells
Stop the BFS filesystem from using iget() and read_inode(). Replace bfs_read_inode() with bfs_iget(), and call that instead of iget(). bfs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. bfs_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [kamalesh@linux.vnet.ibm.com: build fix] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05regression: bfs endianness bugAl Viro
BFS_FILEBLOCKS() expects struct bfs_inode * (on-disk data, with little- endian fields), not struct bfs_inode_info * (in-core stuff, with host- endian ones). It's a macro and fields with the right names are present in bfs_inode_info, so it compiles, but on big-endian host it gives bogus results. Introduced in commit f433dc56344cb72cc3de5ba0819021cec3aef807 ("Fixes to the BFS filesystem driver"). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14Fixes to the BFS filesystem driverDmitri Vorobiev
I found a few bugs in the BFS driver. Detailed description of the bugs as well as the steps to reproduce the errors are given in the kernel bugzilla. Please follow these links for more information: http://bugzilla.kernel.org/show_bug.cgi?id=9363 http://bugzilla.kernel.org/show_bug.cgi?id=9364 http://bugzilla.kernel.org/show_bug.cgi?id=9365 http://bugzilla.kernel.org/show_bug.cgi?id=9366 This patch fixes the bugs described above. Besides, the patch introduces coding style changes to make the BFS driver conform to the requirements specified for Linux kernel code. Finally, I made a few cosmetic changes such as removal of trivial debug output. Also, the patch removes the fields `si_lf_ioff' and `si_lf_sblk' of the in-core superblock structure. These fields are initialized but never actually used. If you are wondering why I need BFS, here is the answer: I am using this driver in the context of Linux kernel classes I am teaching in the Moscow State University and in the International Institute of Information Technology in Pune, India. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Cc: Tigran Aivazian <tigran@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16bfs: convert to new aopsNick Piggin
Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-13[PATCH] update Tigran's email addressesTigran Aivazian
As Adrian pointed out recently, there were still a couple of places where I should have fixed my email address. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert bfsJosef Sipek
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: unlink: monitor i_nlinkDave Hansen
When a filesystem decrements i_nlink to zero, it means that a write must be performed in order to drop the inode from the filesystem. We're shortly going to have keep filesystems from being remounted r/o between the time that this i_nlink decrement and that write occurs. So, add a little helper function to do the decrements. We'll tie into it in a bit to note when i_nlink hits zero. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
