commit 221af7f87b97431e3ee21ce4b0e77d5411cf1549 upstream.
'flush_old_exec()' is the point of no return when doing an execve(), and
it is pretty badly misnamed. It doesn't just flush the old executable
environment, it also starts up the new one.
Which is very inconvenient for things like setting up the new
personality, because we want the new personality to affect the starting
of the new environment, but at the same time we do _not_ want the new
personality to take effect if flushing the old one fails.
As a result, the x86-64 '32-bit' personality is actually done using this
insane "I'm going to change the ABI, but I haven't done it yet" bit
(TIF_ABI_PENDING), with SET_PERSONALITY() not actually setting the
personality, but just the "pending" bit, so that "flush_thread()" can do
the actual personality magic.
This patch in no way changes any of that insanity, but it does split the
'flush_old_exec()' function up into a preparatory part that can fail
(still called flush_old_exec()), and a new part that will actually set
up the new exec environment (setup_new_exec()). All callers are changed
to trivially comply with the new world order.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Introduce a helper function elf_note_info_init() to help fill_note_info()
to do initializations, also fix the potential memory leaks.
[akpm@linux-foundation.org: remove NUM_NOTES]
Signed-off-by: WANG Cong <amwang@redhat.com>
Cc: Roland McGrath <roland@redhat.com>
In preparation for the next patch, add a simple get_dump_page(addr)
interface for the CONFIG_ELF_CORE dumpers to use, instead of calling
get_user_pages() directly. They're not interested in errors: they
just want to use holes as much as possible, to save space and make
sure that the data is aligned where the headers said it would be.
Oh, and don't use that horrid DUMP_SEEK(off) macro!
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Minchan Kim <minchan.kim@gmail.com>
In fs/binfmt_elf.c, load_elf_interp() calls padzero() for .bss even if
the PT_LOAD has no PROT_WRITE and no .bss. This generates EFAULT.
Here is a small test case. (Yes, there are other, useful PT_INTERP
which have only .text and no .data/.bss.)
----- ptinterp.S
_start: .globl _start
nop
int3
$ gcc -m32 -nostartfiles -nostdlib -o ptinterp ptinterp.S
$ gcc -m32 -Wl,--dynamic-linker=ptinterp -o hello hello.c
$ ./hello
Segmentation fault # during execve() itself
After applying the patch:
$ ./hello
Trace trap # user-mode execution after execve() finishes
If the ELF headers are actually self-inconsistent, then dying is fine.
But having no PROT_WRITE segment is perfectly normal and correct if
there is no segment with p_memsz > p_filesz (i.e. bss). John Reiser
suggested checking for PROT_WRITE in the bss logic. I think it makes
most sense to simply apply the bss logic only when there is bss.
This patch looks less trivial than it is due to some reindentation.
It just moves the "if (last_bss > elf_bss) {" test up to include the
partial-page bss logic as well as the more-pages bss logic.
Reported-by: John Reiser <jreiser@bitwagon.com>
Signed-off-by: Roland McGrath <roland@redhat.com>
Check before use it.
Acked-by: Roland McGrath <roland@redhat.com>
Acked-by: James Morris <jmorris@namei.org>
With ELF, at generating coredump, some more headers other than used
vmas are added.
When max_map_count == 65536, a core generated by following kinds of
code can be unreadable because the number of ELF's program header is
written in 16bit in Ehdr (please see elf.h) and the number overflows.
... = mmap(); (munmap, mprotect, etc...)
if (failed)
abort();
This can happen in mmap/munmap/mprotect/etc...which calls split_vma().
I think 65536 is not safe as _default_ and reduce it to 65530 is good
for avoiding unexpected corrupted core.
Anyway, max_map_count can be enlarged by sysctl if a user is brave..
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Jakub Jelinek <jakub@redhat.com>
In theory it is not safe to dereference ->parent/real_parent without
tasklist or rcu lock, we can race with re-parenting.
... since we don't tell anyone which descriptor does the file get.
We used to, but only in case of ELF binary with a.out loader and
that stuff has been gone for a while.
The elf_core_dump() code does its work with set_fs(KERNEL_DS) in force,
so vma_dump_size() needs to switch back with set_fs(USER_DS) to safely
use get_user() for a normal user-space address.
Checking for VM_READ optimizes out the case where get_user() would fail
anyway. The vm_file check here was already superfluous given the control
flow earlier in the function, so that is a cleanup/optimization unrelated
to other changes but an obvious and trivial one.
Reported-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
While discussing[1] the need for glibc to have access to random bytes
during program load, it seems that an earlier attempt to implement
AT_RANDOM got stalled. This implements a random 16 byte string, available
to every ELF program via a new auxv AT_RANDOM vector.
[1] http://sourceware.org/ml/libc-alpha/2008-10/msg00006.html
Ulrich said:
glibc needs right after startup a bit of random data for internal
protections (stack canary etc). What is now in upstream glibc is that we
always unconditionally open /dev/urandom, read some data, and use it. For
every process startup. That's slow.
The solution is to provide a limited amount of random data to the
starting process in the aux vector. I suggested 16 bytes and this is
what the patch implements. If we need only 16 bytes or less we use the
data directly. If we need more we'll use the 16 bytes to see a PRNG.
This avoids the costly /dev/urandom use and it allows the kernel to use
the most adequate source of random data for this purpose. It might not
be the same pool as that for /dev/urandom.
Concerns were expressed about the depletion of the randomness pool. But
this patch doesn't make the situation worse, it doesn't deplete entropy
more than happens now.
Signed-off-by: Kees Cook <kees.cook@canonical.com>
Cc: Ulrich Drepper <drepper@redhat.com>
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (85 commits)
[S390] provide documentation for hvc_iucv kernel parameter.
[S390] convert ctcm printks to dev_xxx and pr_xxx macros.
[S390] convert zfcp printks to pr_xxx macros.
[S390] convert vmlogrdr printks to pr_xxx macros.
[S390] convert zfcp dumper printks to pr_xxx macros.
[S390] convert cpu related printks to pr_xxx macros.
[S390] convert qeth printks to dev_xxx and pr_xxx macros.
[S390] convert sclp printks to pr_xxx macros.
[S390] convert iucv printks to dev_xxx and pr_xxx macros.
[S390] convert ap_bus printks to pr_xxx macros.
[S390] convert dcssblk and extmem printks messages to pr_xxx macros.
[S390] convert monwriter printks to pr_xxx macros.
[S390] convert s390 debug feature printks to pr_xxx macros.
[S390] convert monreader printks to pr_xxx macros.
[S390] convert appldata printks to pr_xxx macros.
[S390] convert setup printks to pr_xxx macros.
[S390] convert hypfs printks to pr_xxx macros.
[S390] convert time printks to pr_xxx macros.
[S390] convert cpacf printks to pr_xxx macros.
[S390] convert cio printks to pr_xxx macros.
arch_setup_additional_pages currently gets two arguments, the binary
format descripton and an indication if the process uses an executable
stack or not. The second argument is not used by anybody, it could
be removed without replacement.
What actually does make sense is to pass an indication if the process
uses the elf interpreter or not. The glibc code will not use anything
from the vdso if the process does not use the dynamic linker, so for
statically linked binaries the architecture backend can choose not
to map the vdso.
Make execve() take advantage of copy-on-write credentials, allowing it to set
up the credentials in advance, and then commit the whole lot after the point
of no return.
This patch and the preceding patches have been tested with the LTP SELinux
testsuite.
This patch makes several logical sets of alteration:
(1) execve().
The credential bits from struct linux_binprm are, for the most part,
replaced with a single credentials pointer (bprm->cred). This means that
all the creds can be calculated in advance and then applied at the point
of no return with no possibility of failure.
I would like to replace bprm->cap_effective with:
cap_isclear(bprm->cap_effective)
but this seems impossible due to special behaviour for processes of pid 1
(they always retain their parent's capability masks where normally they'd
be changed - see cap_bprm_set_creds()).
The following sequence of events now happens:
(a) At the start of do_execve, the current task's cred_exec_mutex is
locked to prevent PTRACE_ATTACH from obsoleting the calculation of
creds that we make.
(a) prepare_exec_creds() is then called to make a copy of the current
task's credentials and prepare it. This copy is then assigned to
bprm->cred.
This renders security_bprm_alloc() and security_bprm_free()
unnecessary, and so they've been removed.
(b) The determination of unsafe execution is now performed immediately
after (a) rather than later on in the code. The result is stored in
bprm->unsafe for future reference.
(c) prepare_binprm() is called, possibly multiple times.
(i) This applies the result of set[ug]id binaries to the new creds
attached to bprm->cred. Personality bit clearance is recorded,
but now deferred on the basis that the exec procedure may yet
fail.
(ii) This then calls the new security_bprm_set_creds(). This should
calculate the new LSM and capability credentials into *bprm->cred.
This folds together security_bprm_set() and parts of
security_bprm_apply_creds() (these two have been removed).
Anything that might fail must be done at this point.
(iii) bprm->cred_prepared is set to 1.
bprm->cred_prepared is 0 on the first pass of the security
calculations, and 1 on all subsequent passes. This allows SELinux
in (ii) to base its calculations only on the initial script and
not on the interpreter.
(d) flush_old_exec() is called to commit the task to execution. This
performs the following steps with regard to credentials:
(i) Clear pdeath_signal and set dumpable on certain circumstances that
may not be covered by commit_creds().
(ii) Clear any bits in current->personality that were deferred from
(c.i).
(e) install_exec_creds() [compute_creds() as was] is called to install the
new credentials. This performs the following steps with regard to
credentials:
(i) Calls security_bprm_committing_creds() to apply any security
requirements, such as flushing unauthorised files in SELinux, that
must be done before the credentials are changed.
This is made up of bits of security_bprm_apply_creds() and
security_bprm_post_apply_creds(), both of which have been removed.
This function is not allowed to fail; anything that might fail
must have been done in (c.ii).
(ii) Calls commit_creds() to apply the new credentials in a single
assignment (more or less). Possibly pdeath_signal and dumpable
should be part of struct creds.
(iii) Unlocks the task's cred_replace_mutex, thus allowing
PTRACE_ATTACH to take place.
(iv) Clears The bprm->cred pointer as the credentials it was holding
are now immutable.
(v) Calls security_bprm_committed_creds() to apply any security
alterations that must be done after the creds have been changed.
SELinux uses this to flush signals and signal handlers.
(f) If an error occurs before (d.i), bprm_free() will call abort_creds()
to destroy the proposed new credentials and will then unlock
cred_replace_mutex. No changes to the credentials will have been
made.
(2) LSM interface.
A number of functions have been changed, added or removed:
(*) security_bprm_alloc(), ->bprm_alloc_security()
(*) security_bprm_free(), ->bprm_free_security()
Removed in favour of preparing new credentials and modifying those.
(*) security_bprm_apply_creds(), ->bprm_apply_creds()
(*) security_bprm_post_apply_creds(), ->bprm_post_apply_creds()
Removed; split between security_bprm_set_creds(),
security_bprm_committing_creds() and security_bprm_committed_creds().
(*) security_bprm_set(), ->bprm_set_security()
Removed; folded into security_bprm_set_creds().
(*) security_bprm_set_creds(), ->bprm_set_creds()
New. The new credentials in bprm->creds should be checked and set up
as appropriate. bprm->cred_prepared is 0 on the first call, 1 on the
second and subsequent calls.
(*) security_bprm_committing_creds(), ->bprm_committing_creds()
(*) security_bprm_committed_creds(), ->bprm_committed_creds()
New. Apply the security effects of the new credentials. This
includes closing unauthorised files in SELinux. This function may not
fail. When the former is called, the creds haven't yet been applied
to the process; when the latter is called, they have.
The former may access bprm->cred, the latter may not.
(3) SELinux.
SELinux has a number of changes, in addition to those to support the LSM
interface changes mentioned above:
(a) The bprm_security_struct struct has been removed in favour of using
the credentials-under-construction approach.
(c) flush_unauthorized_files() now takes a cred pointer and passes it on
to inode_has_perm(), file_has_perm() and dentry_open().
Acked-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
Use RCU to access another task's creds and to release a task's own creds.
This means that it will be possible for the credentials of a task to be
replaced without another task (a) requiring a full lock to read them, and (b)
seeing deallocated memory.
Wrap current->cred and a few other accessors to hide their actual
implementation.
Separate the task security context from task_struct. At this point, the
security data is temporarily embedded in the task_struct with two pointers
pointing to it.
Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in
entry.S via asm-offsets.
With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com>
* 'v28-timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (36 commits)
fix documentation of sysrq-q really
Fix documentation of sysrq-q
timer_list: add base address to clock base
timer_list: print cpu number of clockevents device
timer_list: print real timer address
NOHZ: restart tick device from irq_enter()
NOHZ: split tick_nohz_restart_sched_tick()
NOHZ: unify the nohz function calls in irq_enter()
timers: fix itimer/many thread hang, fix
timers: fix itimer/many thread hang, v3
ntp: improve adjtimex frequency rounding
timekeeping: fix rounding problem during clock update
ntp: let update_persistent_clock() sleep
hrtimer: reorder struct hrtimer to save 8 bytes on 64bit builds
posix-timers: lock_timer: make it readable
posix-timers: lock_timer: kill the bogus ->it_id check
posix-timers: kill ->it_sigev_signo and ->it_sigev_value
posix-timers: sys_timer_create: cleanup the error handling
posix-timers: move the initialization of timer->sigq from send to create path
posix-timers: sys_timer_create: simplify and s/tasklist/rcu/
Fix trivial conflicts due to sysrq-q description clahes in
Documentation/sysrq.txt and drivers/char/sysrq.c
Presently hugepage's vma has a VM_RESERVED flag in order not to be
swapped. But a VM_RESERVED vma isn't core dumped because this flag is
often used for some kernel vmas (e.g. vmalloc, sound related).
Thus hugepages are never dumped and it can't be debugged easily. Many
developers want hugepages to be included into core-dump.
However, We can't read generic VM_RESERVED area because this area is often
IO mapping area. then these area reading may change device state. it is
definitly undesiable side-effect.
So adding a hugepage specific bit to the coredump filter is better. It
will be able to hugepage core dumping and doesn't cause any side-effect to
any i/o devices.
In additional, libhugetlb use hugetlb private mapping pages as anonymous
page. Then, hugepage private mapping pages should be core dumped by
default.
Then, /proc/[pid]/core_dump_filter has two new bits.
- bit 5 mean hugetlb private mapping pages are dumped or not. (default: yes)
- bit 6 mean hugetlb shared mapping pages are dumped or not. (default: no)
I tested by following method.
% ulimit -c unlimited
% ./crash_hugepage 50
% ./crash_hugepage 50 -p
% ls -lh
% gdb ./crash_hugepage core
% echo 0x43 > /proc/self/coredump_filter
% ls -lh
#include <stdlib.h>
#include <stdio.h>
#include <unistd.h>
#include <sys/mman.h>
#include <string.h>
#include "hugetlbfs.h"
int main(int argc, char** argv){
char* p;
int ch;
int mmap_flags = MAP_SHARED;
int fd;
int nr_pages;
while((ch = getopt(argc, argv, "p")) != -1) {
switch (ch) {
case 'p':
mmap_flags &= ~MAP_SHARED;
mmap_flags |= MAP_PRIVATE;
break;
default:
/* nothing*/
break;
argc -= optind;
argv += optind;
if (argc == 0){
printf("need # of pages\n");
exit(1);
nr_pages = atoi(argv[0]);
if (nr_pages < 2) {
printf("nr_pages must >2\n");
exit(1);
fd = hugetlbfs_unlinked_fd();
p = mmap(NULL, nr_pages * gethugepagesize(),
PROT_READ|PROT_WRITE, mmap_flags, fd, 0);
sleep(2);
*(p + gethugepagesize()) = 1; /* COW */
sleep(2);
/* crash! */
*(int*)0 = 1;
return 0;
Reviewed-by: Kawai Hidehiro <hidehiro.kawai.ez@hitachi.com>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: William Irwin <wli@holomorphy.com>
Cc: Adam Litke <agl@us.ibm.com>
'timers/ntp', 'timers/posixtimers' and 'timers/debug' into v28-timers-for-linus
The SET_PERSONALITY macro is always called with a second argument of 0.
Remove the ibcs argument and the various tests to set the PER_SVR4
personality.
Overview
This patch reworks the handling of POSIX CPU timers, including the
ITIMER_PROF, ITIMER_VIRT timers and rlimit handling. It was put together
with the help of Roland McGrath, the owner and original writer of this code.
The problem we ran into, and the reason for this rework, has to do with using
a profiling timer in a process with a large number of threads. It appears
that the performance of the old implementation of run_posix_cpu_timers() was
at least O(n*3) (where "n" is the number of threads in a process) or worse.
Everything is fine with an increasing number of threads until the time taken
for that routine to run becomes the same as or greater than the tick time, at
which point things degrade rather quickly.
This patch fixes bug 9906, "Weird hang with NPTL and SIGPROF."
Code Changes
This rework corrects the implementation of run_posix_cpu_timers() to make it
run in constant time for a particular machine. (Performance may vary between
one machine and another depending upon whether the kernel is built as single-
or multiprocessor and, in the latter case, depending upon the number of
running processors.) To do this, at each tick we now update fields in
signal_struct as well as task_struct. The run_posix_cpu_timers() function
uses those fields to make its decisions.
We define a new structure, "task_cputime," to contain user, system and
scheduler times and use these in appropriate places:
struct task_cputime {
cputime_t utime;
cputime_t stime;
unsigned long long sum_exec_runtime;
This is included in the structure "thread_group_cputime," which is a new
substructure of signal_struct and which varies for uniprocessor versus
multiprocessor kernels. For uniprocessor kernels, it uses "task_cputime" as
a simple substructure, while for multiprocessor kernels it is a pointer:
struct thread_group_cputime {
struct task_cputime totals;
struct task_cputime *totals;
We also add a new task_cputime substructure directly to signal_struct, to
cache the earliest expiration of process-wide timers, and task_cputime also
replaces the it_*_expires fields of task_struct (used for earliest expiration
of thread timers). The "thread_group_cputime" structure contains process-wide
timers that are updated via account_user_time() and friends. In the non-SMP
case the structure is a simple aggregator; unfortunately in the SMP case that
simplicity was not achievable due to cache-line contention between CPUs (in
one measured case performance was actually _worse_ on a 16-cpu system than
the same test on a 4-cpu system, due to this contention). For SMP, the
thread_group_cputime counters are maintained as a per-cpu structure allocated
using alloc_percpu(). The timer functions update only the timer field in
the structure corresponding to the running CPU, obtained using per_cpu_ptr().
We define a set of inline functions in sched.h that we use to maintain the
thread_group_cputime structure and hide the differences between UP and SMP
implementations from the rest of the kernel. The thread_group_cputime_init()
function initializes the thread_group_cputime structure for the given task.
The thread_group_cputime_alloc() is a no-op for UP; for SMP it calls the
out-of-line function thread_group_cputime_alloc_smp() to allocate and fill
in the per-cpu structures and fields. The thread_group_cputime_free()
function, also a no-op for UP, in SMP frees the per-cpu structures. The
thread_group_cputime_clone_thread() function (also a UP no-op) for SMP calls
thread_group_cputime_alloc() if the per-cpu structures haven't yet been
allocated. The thread_group_cputime() function fills the task_cputime
structure it is passed with the contents of the thread_group_cputime fields;
in UP it's that simple but in SMP it must also safely check that tsk->signal
is non-NULL (if it is it just uses the appropriate fields of task_struct) and,
if so, sums the per-cpu values for each online CPU. Finally, the three
functions account_group_user_time(), account_group_system_time() and
account_group_exec_runtime() are used by timer functions to update the
respective fields of the thread_group_cputime structure.
Non-SMP operation is trivial and will not be mentioned further.
The per-cpu structure is always allocated when a task creates its first new
thread, via a call to thread_group_cputime_clone_thread() from copy_signal().
It is freed at process exit via a call to thread_group_cputime_free() from
cleanup_signal().
All functions that formerly summed utime/stime/sum_sched_runtime values from
from all threads in the thread group now use thread_group_cputime() to
snapshot the values in the thread_group_cputime structure or the values in
the task structure itself if the per-cpu structure hasn't been allocated.
Finally, the code in kernel/posix-cpu-timers.c has changed quite a bit.
The run_posix_cpu_timers() function has been split into a fast path and a
slow path; the former safely checks whether there are any expired thread
timers and, if not, just returns, while the slow path does the heavy lifting.
With the dedicated thread group fields, timers are no longer "rebalanced" and
the process_timer_rebalance() function and related code has gone away. All
summing loops are gone and all code that used them now uses the
thread_group_cputime() inline. When process-wide timers are set, the new
task_cputime structure in signal_struct is used to cache the earliest
expiration; this is checked in the fast path.
Performance
The fix appears not to add significant overhead to existing operations. It
generally performs the same as the current code except in two cases, one in
which it performs slightly worse (Case 5 below) and one in which it performs
very significantly better (Case 2 below). Overall it's a wash except in those
two cases.
I've since done somewhat more involved testing on a dual-core Opteron system.
Case 1: With no itimer running, for a test with 100,000 threads, the fixed
kernel took 1428.5 seconds, 513 seconds more than the unfixed system,
all of which was spent in the system. There were twice as many
voluntary context switches with the fix as without it.
Case 2: With an itimer running at .01 second ticks and 4000 threads (the most
an unmodified kernel can handle), the fixed kernel ran the test in
eight percent of the time (5.8 seconds as opposed to 70 seconds) and
had better tick accuracy (.012 seconds per tick as opposed to .023
seconds per tick).
Case 3: A 4000-thread test with an initial timer tick of .01 second and an
interval of 10,000 seconds (i.e. a timer that ticks only once) had
very nearly the same performance in both cases: 6.3 seconds elapsed
for the fixed kernel versus 5.5 seconds for the unfixed kernel.
With fewer threads (eight in these tests), the Case 1 test ran in essentially
the same time on both the modified and unmodified kernels (5.2 seconds versus
5.8 seconds). The Case 2 test ran in about the same time as well, 5.9 seconds
versus 5.4 seconds but again with much better tick accuracy, .013 seconds per
tick versus .025 seconds per tick for the unmodified kernel.
Since the fix affected the rlimit code, I also tested soft and hard CPU limits.
Case 4: With a hard CPU limit of 20 seconds and eight threads (and an itimer
running), the modified kernel was very slightly favored in that while
it killed the process in 19.997 seconds of CPU time (5.002 seconds of
wall time), only .003 seconds of that was system time, the rest was
user time. The unmodified kernel killed the process in 20.001 seconds
of CPU (5.014 seconds of wall time) of which .016 seconds was system
time. Really, though, the results were too close to call. The results
were essentially the same with no itimer running.
Case 5: With a soft limit of 20 seconds and a hard limit of 2000 seconds
(where the hard limit would never be reached) and an itimer running,
the modified kernel exhibited worse tick accuracy than the unmodified
kernel: .050 seconds/tick versus .028 seconds/tick. Otherwise,
performance was almost indistinguishable. With no itimer running this
test exhibited virtually identical behavior and times in both cases.
In times past I did some limited performance testing. those results are below.
On a four-cpu Opteron system without this fix, a sixteen-thread test executed
in 3569.991 seconds, of which user was 3568.435s and system was 1.556s. On
the same system with the fix, user and elapsed time were about the same, but
system time dropped to 0.007 seconds. Performance with eight, four and one
thread were comparable. Interestingly, the timer ticks with the fix seemed
more accurate: The sixteen-thread test with the fix received 149543 ticks
for 0.024 seconds per tick, while the same test without the fix received 58720
for 0.061 seconds per tick. Both cases were configured for an interval of
0.01 seconds. Again, the other tests were comparable. Each thread in this
test computed the primes up to 25,000,000.
I also did a test with a large number of threads, 100,000 threads, which is
impossible without the fix. In this case each thread computed the primes only
up to 10,000 (to make the runtime manageable). System time dominated, at
1546.968 seconds out of a total 2176.906 seconds (giving a user time of
629.938s). It received 147651 ticks for 0.015 seconds per tick, still quite
accurate. There is obviously no comparable test without the fix.
Signed-off-by: Frank Mayhar <fmayhar@google.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
This moves all the ptrace hooks related to exec into tracehook.h inlines.
This also lifts the calls for tracing out of the binfmt load_binary hooks
into search_binary_handler() after it calls into the binfmt module. This
change has no effect, since all the binfmt modules' load_binary functions
did the call at the end on success, and now search_binary_handler() does
it immediately after return if successful. We consolidate the repeated
code, and binfmt modules no longer need to import ptrace_notify().
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Reviewed-by: Ingo Molnar <mingo@elte.hu>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (34 commits)
powerpc: Wireup new syscalls
Move update_mmu_cache() declaration from tlbflush.h to pgtable.h
powerpc/pseries: Remove kmalloc call in handling writes to lparcfg
powerpc/pseries: Update arch vector to indicate support for CMO
ibmvfc: Add support for collaborative memory overcommit
ibmvscsi: driver enablement for CMO
ibmveth: enable driver for CMO
ibmveth: Automatically enable larger rx buffer pools for larger mtu
powerpc/pseries: Verify CMO memory entitlement updates with virtual I/O
powerpc/pseries: vio bus support for CMO
powerpc/pseries: iommu enablement for CMO
powerpc/pseries: Add CMO paging statistics
powerpc/pseries: Add collaborative memory manager
powerpc/pseries: Utilities to set firmware page state
powerpc/pseries: Enable CMO feature during platform setup
powerpc/pseries: Split retrieval of processor entitlement data into a helper routine
powerpc/pseries: Add memory entitlement capabilities to /proc/ppc64/lparcfg
powerpc/pseries: Split processor entitlement retrieval and gathering to helper routines
powerpc/pseries: Remove extraneous error reporting for hcall failures in lparcfg
powerpc: Fix compile error with binutils 2.15
Fixed up conflict in arch/powerpc/platforms/52xx/Kconfig manually.
Kill the nasty rcu_read_lock() + do_each_thread() loop, use the list
encoded in mm->core_state instead, s/GFP_ATOMIC/GFP_KERNEL/.
This patch allows futher cleanups in binfmt_elf.c, in particular we can
kill the parallel info->threads list.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
linux_binfmt->core_dump() runs before the process does exit_aio(), this
means that we can hit the kernel thread which shares the same ->mm.
Afaics, nothing really bad can happen, but perhaps it makes sense to fix
this minor bug.
It is sad we have to iterate over all threads in system and use
GFP_ATOMIC. Hopefully we can kill theses ugly do_each_thread()s, but this
needs some nontrivial changes in mm_struct and do_coredump.
Some IBM POWER-based platforms have the ability to run in a
mode which mostly appears to the OS as a different processor from the
actual hardware. For example, a Power6 system may appear to be a
Power5+, which makes the AT_PLATFORM value "power5+". This means that
programs are restricted to the ISA supported by Power5+;
Power6-specific instructions are treated as illegal.
However, some applications (virtual machines, optimized libraries) can
benefit from knowledge of the underlying CPU model. A new aux vector
entry, AT_BASE_PLATFORM, will denote the actual hardware. For
example, on a Power6 system in Power5+ compatibility mode, AT_PLATFORM
will be "power5+" and AT_BASE_PLATFORM will be "power6". The idea is
that AT_PLATFORM indicates the instruction set supported, while
AT_BASE_PLATFORM indicates the underlying microarchitecture.
If the architecture has defined ELF_BASE_PLATFORM, copy that value to
the user stack in the same manner as ELF_PLATFORM.
Signed-off-by: Nathan Lynch <ntl@pobox.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
The Linux kernel puts the filename argument of execve() into the new
address space. Many developers are surprised to learn this. Those who
know and could use it, object "But it's not documented."
Those who want to use it dislike the expression
(char *)(1+ strlen(env[-1+ n_env]) + env[-1+ n_env])
because it requires locating the last original environment variable,
and assumes that the filename follows the characters.
This patch documents the insertion of the filename, and makes it easier
to find by adding a new tag AT_EXECFN in the ElfXX_auxv_t; see <elf.h>.
In many cases readlink("/proc/self/exe",) gives the same answer. But if
all the original pages get unmapped, then the kernel erases the symlink
for /proc/self/exe. This can happen when a program decompressor does a
good job of cleaning up after uncompressing directly to memory, so that
the address space of the target program looks the same as if compression
had never happened. One example is http://upx.sourceforge.net .
One notable use of the underlying concept (what path containED the
executable) is glibc expanding $ORIGIN in DT_RUNPATH. In practice for
the near term, it may be a good idea for user-mode code to use both
/proc/self/exe and AT_EXECFN as fall-back methods for each other.
/proc/self/exe can fail due to unmapping, AT_EXECFN can fail because it
won't be present on non-new systems. The auxvec or {AT_EXECFN}.d_val
also can get overwritten, although in nearly all cases this would be the
result of a bug.
The runtime cost is one NEW_AUX_ENT using two words of stack space. The
underlying value is maintained already as bprm->exec; setup_arg_pages()
in fs/exec.c slides it for stack_shift, etc.
Signed-off-by: John Reiser <jreiser@BitWagon.com>
In commit d20894a23708c2af75966534f8e4dedb46d48db2 ("Remove a.out
interpreter support in ELF loader"), Andi removed support for a.out
interpreters from the ELF loader, which was only ever needed for the
transition from a.out to ELF.
This removes the last traces of that support, in particular the
inclusion of <linux/a.out.h>.
Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
create_elf_tables() returns 0 on success. But when strnlen_user() "fails",
it returns 0 directly. So this is wrong.
Signed-off-by: WANG Cong <wangcong@zeuux.org>
In kmalloc failing path, we shouldn't free pointers in 'info',
because the struct 'info' is uninitilized when kmalloc is called.
And when kmalloc returns NULL, it's needless to kfree it.
Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi>
Fix these sparse warings:
fs/binfmt_elf.c:1749:29: warning: symbol 'tmp' shadows an earlier one
fs/binfmt_elf.c:1734:28: originally declared here
fs/binfmt_elf.c:2009:26: warning: symbol 'vma' shadows an earlier one
fs/binfmt_elf.c:1892:24: originally declared here
[akpm@linux-foundation.org: chose better variable name]
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
This patch does simplify fill_elf_header function by setting
to zero the whole elf header first. So we fillup the fields
we really need only.
before:
11735 80 0 11815 2e27 fs/binfmt_elf.o
after:
11710 80 0 11790 2e0e fs/binfmt_elf.o
viola, 25 bytes of text is freed
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com>
* unshare_files() can fail; doing it after irreversible actions is wrong
and de_thread() is certainly irreversible.
* since we do it unconditionally anyway, we might as well do it in do_execve()
and save ourselves the PITA in binfmt handlers, etc.
* while we are at it, binfmt_som actually leaked files_struct on failure.
As a side benefit, unshare_files(), put_files_struct() and reset_files_struct()
become unexported.
This makes the user_regset-based core dump code call user_regset writeback
hooks when available. This is necessary groundwork to allow IA64 to set
CORE_DUMP_USE_REGSET.
Cc: Shaohua Li <shaohua.li@intel.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Following the deprecation schedule the a.out ELF interpreter support
is removed now with this patch. a.out ELF interpreters were an transition
feature for moving a.out systems to ELF, but they're unlikely to be still
needed. Pure a.out systems will still work of course. This allows to
simplify the hairy ELF loader.
Signed-off-by: Andi Kleen <ak@suse.de>
Suppress A.OUT library support if CONFIG_ARCH_SUPPORTS_AOUT is not set.
Not all architectures support the A.OUT binfmt, so the ELF binfmt should not
be permitted to go looking for A.OUT libraries to load in such a case. Not
only that, but under such conditions A.OUT core dumps are not produced either.
To make this work, this patch also does the following:
(1) Makes the existence of the contents of linux/a.out.h contingent on
CONFIG_ARCH_SUPPORTS_AOUT.
(2) Renames dump_thread() to aout_dump_thread() as it's only called by A.OUT
core dumping code.
(3) Moves aout_dump_thread() into asm/a.out-core.h and makes it inline. This
is then included only where needed. This means that this bit of arch
code will be stored in the appropriate A.OUT binfmt module rather than
the core kernel.
(4) Drops A.OUT support for Blackfin (according to Mike Frysinger it's not
needed) and FRV.
This patch depends on the previous patch to move STACK_TOP[_MAX] out of
asm/a.out.h and into asm/processor.h as they're required whether or not A.OUT
format is available.
[jdike@addtoit.com: uml: re-remove accidentally restored code]
Cc: <linux-arch@vger.kernel.org>
Signed-off-by: Jeff Dike <jdike@linux.intel.com>
based on similar patch from: Pavel Machek <pavel@ucw.cz>
Introduce CONFIG_COMPAT_BRK. If disabled then the kernel is free
(but not obliged to) randomize the brk area.
Heap randomization breaks ancient binaries, so we keep COMPAT_BRK
enabled by default.
s/litle/little
Signed-off-by: Ohad Ben-Cohen <ohad@bencohen.org>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
ibcs2 support has never been supported on 2.6 kernels as far as I know,
and if it has it must have been an external patch. Anyways, if anybody
applies an external patch they could as well readd the ibcs checking
code to the ELF loader in the same patch. But there is no reason to
keep this code running in all Linux kernels. This will save at least
two strcmps each ELF execution.
No deprecation period because it could not have been used anyway.
This modifies the ELF core dump code under #ifdef CORE_DUMP_USE_REGSET.
It changes nothing when this macro is not defined. When it's #define'd
by some arch header (e.g. asm/elf.h), the arch must support the
user_regset (linux/regset.h) interface for reading thread state.
This provides an alternate version of note segment writing that is based
purely on the user_regset interfaces. When CORE_DUMP_USE_REGSET is set,
the arch need not define macros such as ELF_CORE_COPY_REGS and ELF_ARCH.
All that information is taken from the user_regset data structures.
The core dumps come out exactly the same if arch's definitions for its
user_regset details are correct.
This pulls out the code for writing the notes segment of an ELF core dump
into separate functions. This cleanly isolates into one cluster of
functions everything that deals with the note formats and the hooks into
arch code to fill them. The top-level elf_core_dump function itself now
deals purely with the generic ELF format and the memory segments.
This only moves code around into functions that can be inlined away.
It should not change any behavior at all.
#39: FILE: arch/ia64/ia32/binfmt_elf32.c:229:
+elf32_map (struct file *filep, unsigned long addr, struct elf_phdr *eppnt, int prot, int type, unsigned long unused)
WARNING: no space between function name and open parenthesis '('
WARNING: line over 80 characters
#67: FILE: arch/x86/kernel/sys_x86_64.c:80:
+ new_begin = randomize_range(*begin, *begin + 0x02000000, 0);
ERROR: use tabs not spaces
#110: FILE: arch/x86/kernel/sys_x86_64.c:185:
+ ^I mm->cached_hole_size = 0;$
#111: FILE: arch/x86/kernel/sys_x86_64.c:186:
+ ^I^Imm->free_area_cache = mm->mmap_base;$
#112: FILE: arch/x86/kernel/sys_x86_64.c:187:
+ ^I}$
#141: FILE: arch/x86/kernel/sys_x86_64.c:216:
+ ^I^I/* remember the largest hole we saw so far */$
#142: FILE: arch/x86/kernel/sys_x86_64.c:217:
+ ^I^Iif (addr + mm->cached_hole_size < vma->vm_start)$
#143: FILE: arch/x86/kernel/sys_x86_64.c:218:
+ ^I^I mm->cached_hole_size = vma->vm_start - addr;$
#157: FILE: arch/x86/kernel/sys_x86_64.c:232:
+ ^Imm->free_area_cache = TASK_UNMAPPED_BASE;$
ERROR: need a space before the open parenthesis '('
#291: FILE: arch/x86/mm/mmap_64.c:101:
+ } else if(mmap_is_legacy()) {
WARNING: braces {} are not necessary for single statement blocks
#302: FILE: arch/x86/mm/mmap_64.c:112:
+ if (current->flags & PF_RANDOMIZE) {
+ mm->mmap_base += ((long)rnd) << PAGE_SHIFT;
#314: FILE: fs/binfmt_elf.c:48:
+static unsigned long elf_map (struct file *, unsigned long, struct elf_phdr *, int, int, unsigned long);
#429: FILE: fs/binfmt_elf.c:438:
+ eppnt, elf_prot, elf_type, total_size);
ERROR: need space after that ',' (ctx:VxV)
#480: FILE: fs/binfmt_elf.c:939:
+ elf_prot, elf_flags,0);
total: 9 errors, 7 warnings, 461 lines checked
Your patch has style problems, please review. If any of these errors
are false positives report them to the maintainer, see
CHECKPATCH in MAINTAINERS.
Please run checkpatch prior to sending patches
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: Jiri Kosina <jkosina@suse.cz>
main executable of (specially compiled/linked -pie/-fpie) ET_DYN binaries
onto a random address (in cases in which mmap() is allowed to perform a
randomization).
The code has been extraced from Ingo's exec-shield patch
http://people.redhat.com/mingo/exec-shield/
[akpm@linux-foundation.org: fix used-uninitialsied warning]
[kamezawa.hiroyu@jp.fujitsu.com: fixed ia32 ELF on x86_64 handling]
Randomize the location of the heap (brk) for i386 and x86_64. The range is
randomized in the range starting at current brk location up to 0x02000000
offset for both architectures. This, together with
pie-executable-randomization.patch and
pie-executable-randomization-fix.patch, should make the address space
randomization on i386 and x86_64 complete.
Arjan says:
This is known to break older versions of some emacs variants, whose dumper
code assumed that the last variable declared in the program is equal to the
start of the dynamically allocated memory region.
(The dumper is the code where emacs effectively dumps core at the end of it's
compilation stage; this coredump is then loaded as the main program during
normal use)
iirc this was 5 years or so; we found this way back when I was at RH and we
first did the security stuff there (including this brk randomization). It
wasn't all variants of emacs, and it got fixed as a result (I vaguely remember
that emacs already had code to deal with it for other archs/oses, just
ifdeffed wrongly).
It's a rare and wrong assumption as a general thing, just on x86 it mostly
happened to be true (but to be honest, it'll break too if gcc does
something fancy or if the linker does a non-standard order). Still its
something we should at least document.
Note 2: afaik it only broke the emacs *build*. I'm not 100% sure about that
(it IS 5 years ago) though.
[ akpm@linux-foundation.org: deuglification ]
The pr_ppid field reported in core dumps should match what
getppid() would have returned to that process, regardless of
whether a debugger is attached.
This is the largest patch in the set. Make all (I hope) the places where
the pid is shown to or get from user operate on the virtual pids.
The idea is:
- all in-kernel data structures must store either struct pid itself
or the pid's global nr, obtained with pid_nr() call;
- when seeking the task from kernel code with the stored id one
should use find_task_by_pid() call that works with global pids;
- when showing pid's numerical value to the user the virtual one
should be used, but however when one shows task's pid outside this
task's namespace the global one is to be used;
- when getting the pid from userspace one need to consider this as
the virtual one and use appropriate task/pid-searching functions.
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: nuther build fix]
[akpm@linux-foundation.org: yet nuther build fix]
[akpm@linux-foundation.org: remove unneeded casts]
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Cc: Paul Menage <menage@google.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
The set of functions process_session, task_session, process_group and
task_pgrp is confusing, as the names can be mixed with each other when looking
at the code for a long time.
The proposals are to
* equip the functions that return the integer with _nr suffix to
represent that fact,
* and to make all functions work with task (not process) by making
the common prefix of the same name.
For monotony the routines signal_session() and set_signal_session() are
replaced with task_session_nr() and set_task_session(), especially since they
are only used with the explicit task->signal dereference.
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
Acked-by: Serge E. Hallyn <serue@us.ibm.com>
Cc: Kirill Korotaev <dev@openvz.org>
Cc: Cedric Le Goater <clg@fr.ibm.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Currently arch_align_stack() is used by fs/binfmt_elf.c to randomize
stack pointer inside a page. But this happens only if ELF_PLATFORM
symbol is defined.
ELF_PLATFORM is normally set if the architecture wants ld.so to load
implementation specific libraries for optimization. And currently a
lot of architectures just yield this symbol to NULL.
This is the case for MIPS architecture where ELF_PLATFORM is NULL but
arch_align_stack() has been redefined to do stack inside page
randomization. So in this case no randomization is actually done.
This patch breaks this dependency which seems to be useless and allows
platforms such MIPS to do the randomization.
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com>
include/asm-powerpc/elf.h has 6 entries in ARCH_DLINFO. fs/binfmt_elf.c
has 14 unconditional NEW_AUX_ENT entries and 2 conditional NEW_AUX_ENT
entries. So in the worst case, saved_auxv does not get an AT_NULL entry at
the end.
The saved_auxv array must be terminated with an AT_NULL entry. Make the
size of mm_struct->saved_auxv arch dependend, based on the number of
ARCH_DLINFO entries.
Signed-off-by: Olaf Hering <olh@suse.de>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
