path: root/fs/binfmt_flat.c
2009-08-07flat: fix uninitialized ptr with shared libsLinus Torvalds
The new credentials code broke load_flat_shared_library() as it now uses an uninitialized cred pointer. Reported-by: Bernd Schmidt <bernds_cb1@t-online.de> Tested-by: Bernd Schmidt <bernds_cb1@t-online.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: David Howells <dhowells@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-29flat: fix data sections alignmentOskar Schirmer
The flat loader uses an architecture's flat_stack_align() to align the stack but assumes word-alignment is enough for the data sections. However, on the Xtensa S6000 we have registers up to 128bit width which can be used from userspace and therefor need userspace stack and data-section alignment of at least this size. This patch drops flat_stack_align() and uses the same alignment that is required for slab caches, ARCH_SLAB_MINALIGN, or wordsize if it's not defined by the architecture. It also fixes m32r which was obviously kaput, aligning an uninitialized stack entry instead of the stack pointer. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Oskar Schirmer <os@emlix.com> Cc: David Howells <dhowells@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <cooloney@kernel.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Johannes Weiner <jw@emlix.com> Acked-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08FLAT: Don't attempt to expand the userspace stack to fill the space allocatedDavid Howells
Stop the FLAT binfmt from attempting to expand the userspace stack and brk segments to fill the space actually allocated for it. The space allocated may be rounded up by mmap(), and may be wasted. However, finding out how much space we actually obtained uses the contentious kobjsize() function which we'd like to get rid of as it doesn't necessarily work for all slab allocators. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org>
2008-11-14CRED: Make execve() take advantage of copy-on-write credentialsDavid Howells
Make execve() take advantage of copy-on-write credentials, allowing it to set up the credentials in advance, and then commit the whole lot after the point of no return. This patch and the preceding patches have been tested with the LTP SELinux testsuite. This patch makes several logical sets of alteration: (1) execve(). The credential bits from struct linux_binprm are, for the most part, replaced with a single credentials pointer (bprm->cred). This means that all the creds can be calculated in advance and then applied at the point of no return with no possibility of failure. I would like to replace bprm->cap_effective with: cap_isclear(bprm->cap_effective) but this seems impossible due to special behaviour for processes of pid 1 (they always retain their parent's capability masks where normally they'd be changed - see cap_bprm_set_creds()). The following sequence of events now happens: (a) At the start of do_execve, the current task's cred_exec_mutex is locked to prevent PTRACE_ATTACH from obsoleting the calculation of creds that we make. (a) prepare_exec_creds() is then called to make a copy of the current task's credentials and prepare it. This copy is then assigned to bprm->cred. This renders security_bprm_alloc() and security_bprm_free() unnecessary, and so they've been removed. (b) The determination of unsafe execution is now performed immediately after (a) rather than later on in the code. The result is stored in bprm->unsafe for future reference. (c) prepare_binprm() is called, possibly multiple times. (i) This applies the result of set[ug]id binaries to the new creds attached to bprm->cred. Personality bit clearance is recorded, but now deferred on the basis that the exec procedure may yet fail. (ii) This then calls the new security_bprm_set_creds(). This should calculate the new LSM and capability credentials into *bprm->cred. This folds together security_bprm_set() and parts of security_bprm_apply_creds() (these two have been removed). Anything that might fail must be done at this point. (iii) bprm->cred_prepared is set to 1. bprm->cred_prepared is 0 on the first pass of the security calculations, and 1 on all subsequent passes. This allows SELinux in (ii) to base its calculations only on the initial script and not on the interpreter. (d) flush_old_exec() is called to commit the task to execution. This performs the following steps with regard to credentials: (i) Clear pdeath_signal and set dumpable on certain circumstances that may not be covered by commit_creds(). (ii) Clear any bits in current->personality that were deferred from (c.i). (e) install_exec_creds() [compute_creds() as was] is called to install the new credentials. This performs the following steps with regard to credentials: (i) Calls security_bprm_committing_creds() to apply any security requirements, such as flushing unauthorised files in SELinux, that must be done before the credentials are changed. This is made up of bits of security_bprm_apply_creds() and security_bprm_post_apply_creds(), both of which have been removed. This function is not allowed to fail; anything that might fail must have been done in (c.ii). (ii) Calls commit_creds() to apply the new credentials in a single assignment (more or less). Possibly pdeath_signal and dumpable should be part of struct creds. (iii) Unlocks the task's cred_replace_mutex, thus allowing PTRACE_ATTACH to take place. (iv) Clears The bprm->cred pointer as the credentials it was holding are now immutable. (v) Calls security_bprm_committed_creds() to apply any security alterations that must be done after the creds have been changed. SELinux uses this to flush signals and signal handlers. (f) If an error occurs before (d.i), bprm_free() will call abort_creds() to destroy the proposed new credentials and will then unlock cred_replace_mutex. No changes to the credentials will have been made. (2) LSM interface. A number of functions have been changed, added or removed: (*) security_bprm_alloc(), ->bprm_alloc_security() (*) security_bprm_free(), ->bprm_free_security() Removed in favour of preparing new credentials and modifying those. (*) security_bprm_apply_creds(), ->bprm_apply_creds() (*) security_bprm_post_apply_creds(), ->bprm_post_apply_creds() Removed; split between security_bprm_set_creds(), security_bprm_committing_creds() and security_bprm_committed_creds(). (*) security_bprm_set(), ->bprm_set_security() Removed; folded into security_bprm_set_creds(). (*) security_bprm_set_creds(), ->bprm_set_creds() New. The new credentials in bprm->creds should be checked and set up as appropriate. bprm->cred_prepared is 0 on the first call, 1 on the second and subsequent calls. (*) security_bprm_committing_creds(), ->bprm_committing_creds() (*) security_bprm_committed_creds(), ->bprm_committed_creds() New. Apply the security effects of the new credentials. This includes closing unauthorised files in SELinux. This function may not fail. When the former is called, the creds haven't yet been applied to the process; when the latter is called, they have. The former may access bprm->cred, the latter may not. (3) SELinux. SELinux has a number of changes, in addition to those to support the LSM interface changes mentioned above: (a) The bprm_security_struct struct has been removed in favour of using the credentials-under-construction approach. (c) flush_unauthorized_files() now takes a cred pointer and passes it on to inode_has_perm(), file_has_perm() and dentry_open(). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-16uclinux: fix gzip header parsing in binfmt_flat.cVolodymyr G. Lukiianyk
There are off-by-one errors in decompress_exec() when calculating the length of optional "original file name" and "comment" fields: the "ret" index is not incremented when terminating '\0' character is reached. The check of the buffer overflow (after an "extra-field" length was taken into account) is also fixed. I've encountered this off-by-one error when tried to reuse gzip-header-parsing part of the decompress_exec() function. There was an "original file name" field in the payload (with miscalculated length) and zlib_inflate() returned Z_DATA_ERROR. But after the fix similar to this one all worked fine. Signed-off-by: Volodymyr G Lukiianyk <volodymyrgl@gmail.com> Acked-by: Greg Ungerer <gerg@snapgear.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-11binfmt_flat: Stub in a FLAT_PLAT_INIT().Takashi YOSHII
This provides a FLAT_PLAT_INIT() arch hook for platforms that need to set up specific register state prior to calling in to the process, as per ELF_PLAT_INIT(). Signed-off-by: Takashi YOSHII <yoshii.takashi@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-26tracehook: execRoland McGrath
This moves all the ptrace hooks related to exec into tracehook.h inlines. This also lifts the calls for tracing out of the binfmt load_binary hooks into search_binary_handler() after it calls into the binfmt module. This change has no effect, since all the binfmt modules' load_binary functions did the call at the end on success, and now search_binary_handler() does it immediately after return if successful. We consolidate the repeated code, and binfmt modules no longer need to import ptrace_notify(). Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06nommu: fix ksize() abusePekka Enberg
The nommu binfmt code uses ksize() for pointers returned from do_mmap() which is wrong. This converts the call-sites to use the nommu specific kobjsize() function which works as expected. Cc: Christoph Lameter <clameter@sgi.com> Cc: Matt Mackall <mpm@selenic.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29procfs task exe symlinkMatt Helsley
The kernel implements readlink of /proc/pid/exe by getting the file from the first executable VMA. Then the path to the file is reconstructed and reported as the result. Because of the VMA walk the code is slightly different on nommu systems. This patch avoids separate /proc/pid/exe code on nommu systems. Instead of walking the VMAs to find the first executable file-backed VMA we store a reference to the exec'd file in the mm_struct. That reference would prevent the filesystem holding the executable file from being unmounted even after unmapping the VMAs. So we track the number of VM_EXECUTABLE VMAs and drop the new reference when the last one is unmapped. This avoids pinning the mounted filesystem. [akpm@linux-foundation.org: improve comments] [yamamoto@valinux.co.jp: fix dup_mmap] Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: David Howells <dhowells@redhat.com> Cc:"Eric W. Biederman" <ebiederm@xmission.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29make BINFMT_FLAT a boolAdrian Bunk
I have not yet seen anyone saying he has a reasonable use case for using BINFMT_FLAT modular on his embedded device. Considering that fs/binfmt_flat.c even lacks a MODULE_LICENSE() I really doubt there is any, and this patch therefore makes BINFMT_FLAT a bool. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Bryan Wu <cooloney.lkml@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14FLAT binaries: drop BINFMT_FLAT bad header magic warningMike Frysinger
The warning issued by fs/binfmt_flat.c when the format handler is given a non-FLAT and non-script executable is annoying to say the least when working with FDPIC ELF objects. If you build a kernel that supports both FLAT and FDPIC ELFs on no-mmu, every time you execute an FDPIC ELF, the kernel spits out this message. While I understand a lot of newcomers to the no-mmu world screw up generation of FLAT binaries, this warning is not usable for systems that support more than just FLAT. Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Bernd Schmidt <bernds_cb1@t-online.de> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: remove unnecessary inclusions of {asm, linux}/a.out.hDavid Howells
Remove now unnecessary inclusions of {asm,linux}/a.out.h. [akpm@linux-foundation.org: fix alpha build] Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17binfmt_flat: warning fixesAndrew Morton
Fix this lot: fs/binfmt_flat.c: In function `decompress_exec': fs/binfmt_flat.c:293: warning: label `out' defined but not used fs/binfmt_flat.c: In function `load_flat_file': fs/binfmt_flat.c:462: warning: unsigned int format, long int arg (arg 3) fs/binfmt_flat.c:462: warning: unsigned int format, long int arg (arg 4) fs/binfmt_flat.c:518: warning: comparison of distinct pointer types lacks a cast fs/binfmt_flat.c:549: warning: passing arg 1 of `ksize' makes pointer from integer without a cast fs/binfmt_flat.c:601: warning: passing arg 1 of `ksize' makes pointer from integer without a cast fs/binfmt_flat.c: In function `load_flat_binary': fs/binfmt_flat.c:116: warning: 'dummy' might be used uninitialized in this function Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17core_pattern: ignore RLIMIT_CORE if core_pattern is a pipeNeil Horman
For some time /proc/sys/kernel/core_pattern has been able to set its output destination as a pipe, allowing a user space helper to receive and intellegently process a core. This infrastructure however has some shortcommings which can be enhanced. Specifically: 1) The coredump code in the kernel should ignore RLIMIT_CORE limitation when core_pattern is a pipe, since file system resources are not being consumed in this case, unless the user application wishes to save the core, at which point the app is restricted by usual file system limits and restrictions. 2) The core_pattern code should be able to parse and pass options to the user space helper as an argv array. The real core limit of the uid of the crashing proces should also be passable to the user space helper (since it is overridden to zero when called). 3) Some miscellaneous bugs need to be cleaned up (specifically the recognition of a recursive core dump, should the user mode helper itself crash. Also, the core dump code in the kernel should not wait for the user mode helper to exit, since the same context is responsible for writing to the pipe, and a read of the pipe by the user mode helper will result in a deadlock. This patch: Remove the check of RLIMIT_CORE if core_pattern is a pipe. In the event that core_pattern is a pipe, the entire core will be fed to the user mode helper. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Cc: <martin.pitt@ubuntu.com> Cc: <wwoods@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-03binfmt_flat: checkpatch fixing minimum support for the blackfin relocationsAndrew Morton
Cc: Bernd Schmidt <bernd.schmidt@analog.com> Cc: David McCullough <davidm@snapgear.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Miles Bader <miles.bader@necel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-10-03Binfmt_flat: Add minimum support for the Blackfin relocationsBernd Schmidt
Add minimum support for the Blackfin relocations, since we don't have enough space in each reloc. The idea is to store a value with one relocation so that subsequent ones can access it. Actually, this patch is required for Blackfin. Currently if BINFMT_FLAT is enabled, git-tree kernel will fail to compile. Signed-off-by: Bernd Schmidt <bernd.schmidt@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: David McCullough <davidm@snapgear.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Miles Bader <miles.bader@necel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-06-08nommu: report correct errno in messageGreg Ungerer
Report the correct errno for out of memory debug output in binfmt_flat.c Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[PATCH] uclinux: correctly remap bin_fmtflat exe allocated mem regionsGreg Ungerer
remap() the region we get from mmap() to mark the fact that we are using all of the available slack space. Any slack space is used to form a simple brk region, and potentially more stack space than requested at load time. Any searches of the vma chain may well fail looking for stack (and especially arg) addresses if the remaping is not done. The simplest example is /proc/<pid>/cmdline, since the args are pretty much always at the top of the data/bss/stack region. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] uclinux: use PER_LINUX_32BIT in binfmt_flatMalcolm Parsons
binfmt_flat.c calls set_personality with PER_LINUX as the personality. On the arm architecture this results in the program running in 26bit usermode. PER_LINUX_32BIT should be used instead. This doesn't affect other architectures that use binfmt_flat. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-21[PATCH] binfmt_flat: don't check for EMFILEAndrew Morton
Bernd Schmidt points out that binfmt_flat is now leaving the exec file open while the application runs. This offsets all the application's fd numbers. We should have closed the file within exec(), not at exit()-time. But there doesn't seem to be a lot of point in doing all this just to avoid going over RLIMIT_NOFILE by one fd for a few microseconds. So take the EMFILE checking out again. This will cause binfmt_flat to again fail LTP's exec-should-return-EMFILE-when-fdtable-is-full test. That test appears to be wrong anyway - Open Group specs say nothing about exec() returning EMFILE. Cc: Bernd Schmidt <bernd.schmidt@analog.com> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] flat binary loader doesn't check fd table fullLuke Yang
In binfmt_flat.c, the flat binary loader should check file descriptor table and install the fd on the file. Convert the function to single-exit and fix this bug. Signed-off-by: "Luke Yang" <luke.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] uclinux: delay binfmt_flat traceGreg Ungerer
Modify the initial trace output (which is based on flags in the binary header) so that it is not done until after the magic number check. This may well not be a flat format binary, so the flags could be invalid. (Prime example, running a script). Changes prompted by patches from Stuart Hughs. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] dump_thread() cleanupakpm@osdl.org
) From: Adrian Bunk <bunk@stusta.de> - create one common dump_thread() prototype in kernel.h - dump_thread() is only used in fs/binfmt_aout.c and can therefore be removed on all architectures where CONFIG_BINFMT_AOUT is not available Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: mm_init set_mm_countersHugh Dickins
How is anon_rss initialized? In dup_mmap, and by mm_alloc's memset; but that's not so good if an mm_counter_t is a special type. And how is rss initialized? By set_mm_counter, all over the place. Come on, we just need to initialize them both at once by set_mm_counter in mm_init (which follows the memcpy when forking). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-02[PATCH] uclinux: use MAP_PRIVATE when mmaping code regions in flat binary loaderGreg Ungerer
Use MAP_PRIVATE when calling mmap to get memory for the code region. The flat loader was using MAP_SHARED, but underlying changes to the MMUless mmap means this is now wrong. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-06[PATCH] binfmt_flat mmap flag fixYoshinori Sato
Make sure that binfmt_flat passes the correct flags into do_mmap(). nommu's validate_mmap_request() will simple return -EINVAL if we try and pass it a flags value of zero. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
