commit 867bfa4a5fcee66f2b25639acae718e8b28b25a5 upstream.
load_flat_shared_library() is broken: It only calls load_flat_file() if
prepare_binprm() returns zero, but prepare_binprm() returns the number of
bytes read - so this only happens if the file is empty.
Instead, call into load_flat_file() if the number of bytes read is
non-negative. (Even if the number of bytes is zero - in that case,
load_flat_file() will see nullbytes and return a nice -ENOEXEC.)
In addition, remove the code related to bprm creds and stop using
prepare_binprm() - this code is loading a library, not a main executable,
and it only actually uses the members "buf", "file" and "filename" of the
linux_binprm struct. Instead, call kernel_read() directly.
Link: http://lkml.kernel.org/r/20190524201817.16509-1-jannh@google.com
Fixes: 287980e49ffc ("remove lots of IS_ERR_VALUE abuses")
Signed-off-by: Jann Horn <jannh@google.com>
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Greg Ungerer <gerg@linux-m68k.org>
Cc: <stable@vger.kernel.org>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Pull more set_fs removal from Al Viro:
"Christoph's 'use kernel_read and friends rather than open-coding
set_fs()' series"
* 'work.set_fs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: unexport vfs_readv and vfs_writev
fs: unexport vfs_read and vfs_write
fs: unexport __vfs_read/__vfs_write
lustre: switch to kernel_write
gadget/f_mass_storage: stop messing with the address limit
mconsole: switch to kernel_read
btrfs: switch write_buf to kernel_write
net/9p: switch p9_fd_read to kernel_write
mm/nommu: switch do_mmap_private to kernel_read
serial2002: switch serial2002_tty_write to kernel_{read/write}
fs: make the buf argument to __kernel_write a void pointer
fs: fix kernel_write prototype
fs: fix kernel_read prototype
fs: move kernel_read to fs/read_write.c
fs: move kernel_write to fs/read_write.c
autofs4: switch autofs4_write to __kernel_write
ashmem: switch to ->read_iter
decompress_exec()
Omit extra messages for a memory allocation failure in this function.
This issue was detected by using the Coccinelle software.
Link: http://lkml.kernel.org/r/f92aac79-b05e-321a-1a19-d38c7159ee9c@users.sourceforge.net
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Use proper ssize_t and size_t types for the return value and count
argument, move the offset last and make it an in/out argument like
all other read/write helpers, and make the buf argument a void pointer
to get rid of lots of casts in the callers.
The cred_prepared bprm flag has a misleading name. It has nothing to do
with the bprm_prepare_cred hook, and actually tracks if bprm_set_creds has
been called. Rename this flag and improve its comment.
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Casey Schaufler <casey@schaufler-ca.com>
Acked-by: John Johansen <john.johansen@canonical.com>
Acked-by: James Morris <james.l.morris@oracle.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Acked-by: Serge Hallyn <serge@hallyn.com>
Several variables had their types changed from unsigned long to u32, but
the printk()-style format to print them wasn't updated, leading to:
fs/binfmt_flat.c: In function ‘load_flat_file’:
fs/binfmt_flat.c:577: warning: format ‘%ld’ expects type ‘long int’, but argument 3 has type ‘u32’
Fixes: 468138d78510688f ("binfmt_flat: flat_{get,put}_addr_from_rp() should be able to fail")
on MMU targets EFAULT is possible here. Make both return 0 or error,
passing what used to be the return value of flat_get_addr_from_rp()
by reference.
<linux/sched/task_stack.h>
We are going to split <linux/sched/task_stack.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/task_stack.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Let's take the simple and obvious approach by decompressing the binary
into a kernel buffer and then copying it to user space. Those who are
looking for top performance on an MMU system are unlikely to choose this
executable format anyway.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Reviewed-by: Greg Ungerer <gerg@linux-m68k.org>
Signed-off-by: Greg Ungerer <gerg@linux-m68k.org>
Not much else to do at this point except for the different stack setups.
This is needed on systems with a MMU. This also gets rid of the
strangest C code I've seen lateli i.e. an integer indexed with a
pointer value within square brackets. That really looked backwards.
Relocs are fixed up in place in user space memory. The appropriate
accessors are required for this code to work with an active MMU.
The architecture specific handlers flat_get_addr_from_rp() and
flat_put_addr_at_rp() for ARM and M68K are adjusted with separate
patches. SuperH and Xtensa are left out as they doesn't implement
__get_user_unaligned() and __put_user_unaligned() yet. The other
architectures that use BFLT don't have any MMU.
In addition to better code clarity, this brings proper usage of
user memory accessors everywhere the stack is touched. This is essential
for making this work on MMU systems.
This gets rid of the rather ugly, open coded and suboptimal copy code.
Remove excessive casts, do some code grouping, fix most important
checkpatch.pl complaints, etc.
No functional changes.
Most users of IS_ERR_VALUE() in the kernel are wrong, as they
pass an 'int' into a function that takes an 'unsigned long'
argument. This happens to work because the type is sign-extended
on 64-bit architectures before it gets converted into an
unsigned type.
However, anything that passes an 'unsigned short' or 'unsigned int'
argument into IS_ERR_VALUE() is guaranteed to be broken, as are
8-bit integers and types that are wider than 'unsigned long'.
Andrzej Hajda has already fixed a lot of the worst abusers that
were causing actual bugs, but it would be nice to prevent any
users that are not passing 'unsigned long' arguments.
This patch changes all users of IS_ERR_VALUE() that I could find
on 32-bit ARM randconfig builds and x86 allmodconfig. For the
moment, this doesn't change the definition of IS_ERR_VALUE()
because there are probably still architecture specific users
elsewhere.
Almost all the warnings I got are for files that are better off
using 'if (err)' or 'if (err < 0)'.
The only legitimate user I could find that we get a warning for
is the (32-bit only) freescale fman driver, so I did not remove
the IS_ERR_VALUE() there but changed the type to 'unsigned long'.
For 9pfs, I just worked around one user whose calling conventions
are so obscure that I did not dare change the behavior.
I was using this definition for testing:
#define IS_ERR_VALUE(x) ((unsigned long*)NULL == (typeof (x)*)NULL && \
unlikely((unsigned long long)(x) >= (unsigned long long)(typeof(x))-MAX_ERRNO))
which ends up making all 16-bit or wider types work correctly with
the most plausible interpretation of what IS_ERR_VALUE() was supposed
to return according to its users, but also causes a compile-time
warning for any users that do not pass an 'unsigned long' argument.
I suggested this approach earlier this year, but back then we ended
up deciding to just fix the users that are obviously broken. After
the initial warning that caused me to get involved in the discussion
(fs/gfs2/dir.c) showed up again in the mainline kernel, Linus
asked me to send the whole thing again.
[ Updated the 9p parts as per Al Viro - Linus ]
Cc: Andrzej Hajda <a.hajda@samsung.com>
Link: https://lkml.org/lkml/2016/1/7/363
Link: https://lkml.org/lkml/2016/5/27/486
Acked-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> # For nvmem part
old_reloc() is only used in this file, make it static.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
switch binfmts that use ->read() to that (and to kernel_read()
in several cases in binfmt_flat - sure, it's nommu, but still,
doing ->read() into kmalloc'ed buffer...)
This is a preparatory patch for the introduction of NT_SIGINFO elf note.
With this patch we pass "siginfo_t *siginfo" instead of "int signr" to
do_coredump() and put it into coredump_params. It will be used by the
next patch. Most changes are simple s/signr/siginfo->si_signo/.
Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Cc: Amerigo Wang <amwang@redhat.com>
Cc: "Jonathan M. Foote" <jmfoote@cert.org>
Cc: Roland McGrath <roland@hack.frob.com>
Cc: Pedro Alves <palves@redhat.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
This continues the theme started with vm_brk() and vm_munmap():
vm_mmap() does the same thing as do_mmap(), but additionally does the
required VM locking.
This uninlines (and rewrites it to be clearer) do_mmap(), which sadly
duplicates it in mm/mmap.c and mm/nommu.c. But that way we don't have
to export our internal do_mmap_pgoff() function.
Some day we hopefully don't have to export do_mmap() either, if all
modular users can become the simpler vm_mmap() instead. We're actually
very close to that already, with the notable exception of the (broken)
use in i810, and a couple of stragglers in binfmt_elf.
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker:
"Fix up files in fs/ and lib/ dirs to only use module.h if they really
need it.
These are trivial in scope vs the work done previously. We now have
things where any few remaining cleanups can be farmed out to arch or
subsystem maintainers, and I have done so when possible. What is
remaining here represents the bits that don't clearly lie within a
single arch/subsystem boundary, like the fs dir and the lib dir.
Some duplicate includes arising from overlapping fixes from
independent subsystem maintainer submissions are also quashed."
Fix up trivial conflicts due to clashes with other include file cleanups
(including some due to the previous bug.h cleanup pull).
* tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
lib: reduce the use of module.h wherever possible
fs: reduce the use of module.h wherever possible
includecheck: delete any duplicate instances of module.h
Just don't pass NULL to it - nobody does, anyway.
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map
them onto including export.h -- or if the file isn't even
using those, then just delete the include. Fix up any implicit
include dependencies that were being masked by module.h along
the way.
Fix binfmt_flag's load_flat_shared_library() to initialise bprm correctly.
Currently, prepare_binprm() is called with only .filename .file and .cred
fields set in bprm, but the .cred_prepared and .per_clear fields at least need
initialising.
Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Signed-off-by: James Morris <jmorris@namei.org>
The recent commit 1f0ce8b3dd667dca7 ("mm: Move ARCH_SLAB_MINALIGN and
ARCH_KMALLOC_MINALIGN to <linux/slab_def.h>") which moved the
ARCH_SLAB_MINALIGN default into the global header inadvertently broke FLAT
for a bunch of systems. Blackfin systems now fail on any FLAT exec with:
Unable to read code+data+bss, errno 14 When your /init is a FLAT binary,
obviously this can be annoying ;).
This stems from the alignment usage in the FLAT loader. The behavior
before was that FLAT would default to ARCH_SLAB_MINALIGN only if it was
defined, and this was only defined by arches when they wanted a larger
alignment value. Otherwise it'd default to pointer alignment. Arguably,
this is kind of hokey that the FLAT is semi-abusing defines it shouldn't.
So let's merge the two alignment requirements so the floor is never 0.
Cc: David McCullough <davidm@snapgear.com>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: David Woodhouse <David.Woodhouse@intel.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
The data chunk is mmaped with 'len' which remains unchanged, so use that
when unmapping in the error path rather than trying to recalculate (and
incorrectly so) the value used originally.
Acked-by: David McCullough <davidm@snapgear.com>
Acked-by: Greg Ungerer <gerg@uclinux.org>
The stack and data have different alignment requirements, so don't force
them to wear the same shoe. Increase the data alignment to match that
which the elf2flt linker script has always been using: 0x20 bytes. Not
only does this bring the kernel loader in line with the toolchain, but it
also fixes a swath of gcc tests which try to force larger alignment values
but randomly fail when the FLAT loader fails to deliver.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Tested-by: Michal Simek <monstr@monstr.eu>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Jie Zhang <jie@codesourcery.com>
This patch fixes a cosmetic error in printk. Text segment and data/bss
segment are allocated from two different areas. It is not meaningful to
give the diff between them in the error reporting messages.
Signed-off-by: Jun Sun <jsun@junsun.net>
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
Make sure compiler won't do weird things with limits. E.g. fetching them
twice may return 2 different values after writable limits are implemented.
I.e. either use rlimit helpers added in commit 3e10e716abf3 ("resource:
add helpers for fetching rlimits") or ACCESS_ONCE if not applicable.
'flush_old_exec()' is the point of no return when doing an execve(), and
it is pretty badly misnamed. It doesn't just flush the old executable
environment, it also starts up the new one.
Which is very inconvenient for things like setting up the new
personality, because we want the new personality to affect the starting
of the new environment, but at the same time we do _not_ want the new
personality to take effect if flushing the old one fails.
As a result, the x86-64 '32-bit' personality is actually done using this
insane "I'm going to change the ABI, but I haven't done it yet" bit
(TIF_ABI_PENDING), with SET_PERSONALITY() not actually setting the
personality, but just the "pending" bit, so that "flush_thread()" can do
the actual personality magic.
This patch in no way changes any of that insanity, but it does split the
'flush_old_exec()' function up into a preparatory part that can fail
(still called flush_old_exec()), and a new part that will actually set
up the new exec environment (setup_new_exec()). All callers are changed
to trivially comply with the new world order.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: stable@kernel.org
Introduce coredump parameter data structure (struct coredump_params) to
simplify binfmt->core_dump() arguments.
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Suggested-by: Ingo Molnar <mingo@elte.hu>
Cc: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
Cc: Roland McGrath <roland@redhat.com>
There is a common macro now for testing mixed pointer/errno values, so use
that rather than handling the casts ourself.
Acked-by: David McCullough <david_mccullough@securecomputing.com>
The new credentials code broke load_flat_shared_library() as it now uses
an uninitialized cred pointer.
Reported-by: Bernd Schmidt <bernds_cb1@t-online.de>
Tested-by: Bernd Schmidt <bernds_cb1@t-online.de>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: <stable@kernel.org>
The flat loader uses an architecture's flat_stack_align() to align the
stack but assumes word-alignment is enough for the data sections.
However, on the Xtensa S6000 we have registers up to 128bit width
which can be used from userspace and therefor need userspace stack and
data-section alignment of at least this size.
This patch drops flat_stack_align() and uses the same alignment that
is required for slab caches, ARCH_SLAB_MINALIGN, or wordsize if it's
not defined by the architecture.
It also fixes m32r which was obviously kaput, aligning an
uninitialized stack entry instead of the stack pointer.
Signed-off-by: Oskar Schirmer <os@emlix.com>
Cc: Bryan Wu <cooloney@kernel.org>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Signed-off-by: Johannes Weiner <jw@emlix.com>
Acked-by: Mike Frysinger <vapier.adi@gmail.com>
Stop the FLAT binfmt from attempting to expand the userspace stack and brk
segments to fill the space actually allocated for it. The space allocated may
be rounded up by mmap(), and may be wasted.
However, finding out how much space we actually obtained uses the contentious
kobjsize() function which we'd like to get rid of as it doesn't necessarily
work for all slab allocators.
Tested-by: Mike Frysinger <vapier.adi@gmail.com>
Make execve() take advantage of copy-on-write credentials, allowing it to set
up the credentials in advance, and then commit the whole lot after the point
of no return.
This patch and the preceding patches have been tested with the LTP SELinux
testsuite.
This patch makes several logical sets of alteration:
(1) execve().
The credential bits from struct linux_binprm are, for the most part,
replaced with a single credentials pointer (bprm->cred). This means that
all the creds can be calculated in advance and then applied at the point
of no return with no possibility of failure.
I would like to replace bprm->cap_effective with:
cap_isclear(bprm->cap_effective)
but this seems impossible due to special behaviour for processes of pid 1
(they always retain their parent's capability masks where normally they'd
be changed - see cap_bprm_set_creds()).
The following sequence of events now happens:
(a) At the start of do_execve, the current task's cred_exec_mutex is
locked to prevent PTRACE_ATTACH from obsoleting the calculation of
creds that we make.
(a) prepare_exec_creds() is then called to make a copy of the current
task's credentials and prepare it. This copy is then assigned to
bprm->cred.
This renders security_bprm_alloc() and security_bprm_free()
unnecessary, and so they've been removed.
(b) The determination of unsafe execution is now performed immediately
after (a) rather than later on in the code. The result is stored in
bprm->unsafe for future reference.
(c) prepare_binprm() is called, possibly multiple times.
(i) This applies the result of set[ug]id binaries to the new creds
attached to bprm->cred. Personality bit clearance is recorded,
but now deferred on the basis that the exec procedure may yet
fail.
(ii) This then calls the new security_bprm_set_creds(). This should
calculate the new LSM and capability credentials into *bprm->cred.
This folds together security_bprm_set() and parts of
security_bprm_apply_creds() (these two have been removed).
Anything that might fail must be done at this point.
(iii) bprm->cred_prepared is set to 1.
bprm->cred_prepared is 0 on the first pass of the security
calculations, and 1 on all subsequent passes. This allows SELinux
in (ii) to base its calculations only on the initial script and
not on the interpreter.
(d) flush_old_exec() is called to commit the task to execution. This
performs the following steps with regard to credentials:
(i) Clear pdeath_signal and set dumpable on certain circumstances that
may not be covered by commit_creds().
(ii) Clear any bits in current->personality that were deferred from
(c.i).
(e) install_exec_creds() [compute_creds() as was] is called to install the
new credentials. This performs the following steps with regard to
credentials:
(i) Calls security_bprm_committing_creds() to apply any security
requirements, such as flushing unauthorised files in SELinux, that
must be done before the credentials are changed.
This is made up of bits of security_bprm_apply_creds() and
security_bprm_post_apply_creds(), both of which have been removed.
This function is not allowed to fail; anything that might fail
must have been done in (c.ii).
(ii) Calls commit_creds() to apply the new credentials in a single
assignment (more or less). Possibly pdeath_signal and dumpable
should be part of struct creds.
(iii) Unlocks the task's cred_replace_mutex, thus allowing
PTRACE_ATTACH to take place.
(iv) Clears The bprm->cred pointer as the credentials it was holding
are now immutable.
(v) Calls security_bprm_committed_creds() to apply any security
alterations that must be done after the creds have been changed.
SELinux uses this to flush signals and signal handlers.
(f) If an error occurs before (d.i), bprm_free() will call abort_creds()
to destroy the proposed new credentials and will then unlock
cred_replace_mutex. No changes to the credentials will have been
made.
(2) LSM interface.
A number of functions have been changed, added or removed:
(*) security_bprm_alloc(), ->bprm_alloc_security()
(*) security_bprm_free(), ->bprm_free_security()
Removed in favour of preparing new credentials and modifying those.
(*) security_bprm_apply_creds(), ->bprm_apply_creds()
(*) security_bprm_post_apply_creds(), ->bprm_post_apply_creds()
Removed; split between security_bprm_set_creds(),
security_bprm_committing_creds() and security_bprm_committed_creds().
(*) security_bprm_set(), ->bprm_set_security()
Removed; folded into security_bprm_set_creds().
(*) security_bprm_set_creds(), ->bprm_set_creds()
New. The new credentials in bprm->creds should be checked and set up
as appropriate. bprm->cred_prepared is 0 on the first call, 1 on the
second and subsequent calls.
(*) security_bprm_committing_creds(), ->bprm_committing_creds()
(*) security_bprm_committed_creds(), ->bprm_committed_creds()
New. Apply the security effects of the new credentials. This
includes closing unauthorised files in SELinux. This function may not
fail. When the former is called, the creds haven't yet been applied
to the process; when the latter is called, they have.
The former may access bprm->cred, the latter may not.
(3) SELinux.
SELinux has a number of changes, in addition to those to support the LSM
interface changes mentioned above:
(a) The bprm_security_struct struct has been removed in favour of using
the credentials-under-construction approach.
(c) flush_unauthorized_files() now takes a cred pointer and passes it on
to inode_has_perm(), file_has_perm() and dentry_open().
Acked-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
There are off-by-one errors in decompress_exec() when calculating the length of
optional "original file name" and "comment" fields: the "ret" index is not
incremented when terminating '\0' character is reached. The check of the buffer
overflow (after an "extra-field" length was taken into account) is also fixed.
I've encountered this off-by-one error when tried to reuse
gzip-header-parsing part of the decompress_exec() function. There was an
"original file name" field in the payload (with miscalculated length) and
zlib_inflate() returned Z_DATA_ERROR. But after the fix similar to this
one all worked fine.
Signed-off-by: Volodymyr G Lukiianyk <volodymyrgl@gmail.com>
Acked-by: Greg Ungerer <gerg@snapgear.com>
This provides a FLAT_PLAT_INIT() arch hook for platforms that need to set
up specific register state prior to calling in to the process, as per
ELF_PLAT_INIT().
Signed-off-by: Takashi YOSHII <yoshii.takashi@renesas.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
