path: root/fs/bio-integrity.c
2009-01-30block: Remove obsolete BUG_ONMartin K. Petersen
Now that bio_vecs are no longer cleared in bvec_alloc_bs() the following BUG_ON must go. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-01-30block: Don't verify integrity metadata on read errorMartin K. Petersen
If we get an I/O error on a read request there is no point in doing a verify pass on the integrity buffer. Adjust the completion path accordingly. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29bio: allow individual slabs in the bio_setJens Axboe
Instead of having a global bio slab cache, add a reference to one in each bio_set that is created. This allows for personalized slabs in each bio_set, so that they can have bios of different sizes. This means we can personalize the bios we return. File systems may want to embed the bio inside another structure, to avoid allocation more items (and stuffing them in ->bi_private) after the get a bio. Or we may want to embed a number of bio_vecs directly at the end of a bio, to avoid doing two allocations to return a bio. This is now possible. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: Introduce integrity data ownership flagMartin K. Petersen
A filesystem might supply its own integrity metadata. Introduce a flag that indicates whether the filesystem or the block layer owns the integrity buffer. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: revert part of d7533ad0e132f92e75c1b2eb7c26387b25a583c1Jens Axboe
We need bdev_get_integrity() to support the pending md/dm patches. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: cleanup some of the integrity stuff in blkdev.hJens Axboe
Don't put functions that are only used in fs/bio-integrity.c in blkdev.h, it's much cleaner to just keep it in there. Also kill completely unused bdev_get_tag_size() Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-28bio-integrity: remove EXPORT_SYMBOL for bio_integrity_init_slab()Yoichi Yuasa
I got section mismatch message about bio_integrity_init_slab(). WARNING: fs/built-in.o(__ksymtab+0xb60): Section mismatch in reference from the variable __ksymtab_bio_integrity_init_slab to the function .init.text:bio_integrity_init_slab() The symbol bio_integrity_init_slab is exported and annotated __init Fix this by removing the __init annotation of bio_integrity_init_slab or drop the export. It only call from init_bio(). The EXPORT_SYMBOL() can be removed. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-03block: integrity checkpatch cleanupsJens Axboe
> 80 char lines and that sort of thing. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: Block layer data integrity supportMartin K. Petersen
Some block devices support verifying the integrity of requests by way of checksums or other protection information that is submitted along with the I/O. This patch implements support for generating and verifying integrity metadata, as well as correctly merging, splitting and cloning bios and requests that have this extra information attached. See Documentation/block/data-integrity.txt for more information. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
