path: root/fs/block_dev.c
2009-11-03Merge branch 'for-linus' into for-2.6.33Jens Axboe
Conflicts: block/cfq-iosched.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-29blkdev: flush disk cache on ->fsyncChristoph Hellwig
Currently there is no barrier support in the block device code. That means we cannot guarantee any sort of data integerity when using the block device node with dis kwrite caches enabled. Using the raw block device node is a typical use case for virtualization (and I assume databases, too). This patch changes block_fsync to issue a cache flush and thus make fsync on block device nodes actually useful. Note that in mainline we would also need to add such code to the ->aio_write method for O_SYNC handling, but assuming that Jan's patch series for the O_SYNC rewrite goes in it will also call into ->fsync for 2.6.32. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-26block: use after free bug in __blkdev_getNeil Brown
commit 0762b8bde9729f10f8e6249809660ff2ec3ad735 (from 14 months ago) introduced a use-after-free bug which has just recently started manifesting in my md testing. I tried git bisect to find out what caused the bug to start manifesting, and it could have been the recent change to blk_unregister_queue (48c0d4d4c04) but the results were inconclusive. This patch certainly fixes my symptoms and looks correct as the two calls are now in the same order as elsewhere in that function. Signed-off-by: NeilBrown <neilb@suse.de> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-24freeze_bdev: grab active reference to frozen superblocksChristoph Hellwig
Currently we held s_umount while a filesystem is frozen, despite that we might return to userspace and unlock it from a different process. Instead grab an active reference to keep the file system busy and add an explicit check for frozen filesystems in remount and reject the remount instead of blocking on s_umount. Add a new get_active_super helper to super.c for use by freeze_bdev that grabs an active reference to a superblock from a given block device. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-24freeze_bdev: kill bd_mount_semChristoph Hellwig
Now that we have the freeze count there is not much reason for bd_mount_sem anymore. The actual freeze/thaw operations are serialized using the bd_fsfreeze_mutex, and the only other place we take bd_mount_sem is get_sb_bdev which tries to prevent mounting a filesystem while the block device is frozen. Instead of add a check for bd_fsfreeze_count and return -EBUSY if a filesystem is frozen. While that is a change in user visible behaviour a failing mount is much better for this case rather than having the mount process stuck uninterruptible for a long time. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16fs: remove bdev->bd_inode_backing_dev_infoJens Axboe
It has been unused since it was introduced in: commit 520808bf20e90fdbdb320264ba7dd5cf9d47dcac Author: Andrew Morton <akpm@osdl.org> Date: Fri May 21 00:46:17 2004 -0700 [PATCH] block device layer: separate backing_dev_info infrastructure So lets just kill it. Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-14vfs: Rename generic_file_aio_write_nolockChristoph Hellwig
generic_file_aio_write_nolock() is now used only by block devices and raw character device. Filesystems should use __generic_file_aio_write() in case generic_file_aio_write() doesn't suit them. So rename the function to blkdev_aio_write() and move it to fs/blockdev.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-07-29PM / Hibernate: Replace bdget call with simple atomic_inc of i_countAlan Jenkins
Create bdgrab(). This function copies an existing reference to a block_device. It is safe to call from any context. Hibernation code wishes to copy a reference to the active swap device. Right now it calls bdget() under a spinlock, but this is wrong because bdget() can sleep. It doesn't need a full bdget() because we already hold a reference to active swap devices (and the spinlock protects against swapoff). Fixes http://bugzilla.kernel.org/show_bug.cgi?id=13827 Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-11vfs: Rename fsync_super() to sync_filesystem() (version 4)Jan Kara
Rename the function so that it better describe what it really does. Also remove the unnecessary include of buffer_head.h. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11vfs: Make sys_sync() use fsync_super() (version 4)Jan Kara
It is unnecessarily fragile to have two places (fsync_super() and do_sync()) doing data integrity sync of the filesystem. Alter __fsync_super() to accommodate needs of both callers and use it. So after this patch __fsync_super() is the only place where we gather all the calls needed to properly send all data on a filesystem to disk. Nice bonus is that we get a complete livelock avoidance and write_supers() is now only used for periodic writeback of superblocks. sync_blockdevs() introduced a couple of patches ago is gone now. [build fixes folded] Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11vfs: Make __fsync_super() a static function (version 4)Jan Kara
__fsync_super() does the same thing as fsync_super(). So change the only caller to use fsync_super() and make __fsync_super() static. This removes unnecessarily duplicated call to sync_blockdev() and prepares ground for the changes to __fsync_super() in the following patches. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11Merge branch 'for-linus' of git://linux-arm.org/linux-2.6Linus Torvalds
* 'for-linus' of git://linux-arm.org/linux-2.6: kmemleak: Add the corresponding MAINTAINERS entry kmemleak: Simple testing module for kmemleak kmemleak: Enable the building of the memory leak detector kmemleak: Remove some of the kmemleak false positives kmemleak: Add modules support kmemleak: Add kmemleak_alloc callback from alloc_large_system_hash kmemleak: Add the vmalloc memory allocation/freeing hooks kmemleak: Add the slub memory allocation/freeing hooks kmemleak: Add the slob memory allocation/freeing hooks kmemleak: Add the slab memory allocation/freeing hooks kmemleak: Add documentation on the memory leak detector kmemleak: Add the base support Manual conflict resolution (with the slab/earlyboot changes) in: drivers/char/vt.c init/main.c mm/slab.c
2009-06-11kmemleak: Remove some of the kmemleak false positivesCatalin Marinas
There are allocations for which the main pointer cannot be found but they are not memory leaks. This patch fixes some of them. For more information on false positives, see Documentation/kmemleak.txt. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-06-04Revert "block: implement blkdev_readpages"Jens Axboe
This reverts commit db2dbb12dc47a50c7a4c5678f526014063e486f6. It apparently causes problems with partition table read-ahead on archs with large page sizes. Until that problem is diagnosed further, just drop the readpages support on block devices. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28block: implement blkdev_readpagesJeff Moyer
Doing a proper block dev ->readpages() speeds up the crazy dump(8) approach of using interleaved process IO. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-01Cleanup after commit 585d3bc06f4ca57f975a5a1f698f65a45ea66225Al Viro
fsync_bdev() export and a bunch of stubs for !CONFIG_BLOCK case had been left behind Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27fs: move bdev code out of buffer.cNick Piggin
Move some block device related code out from buffer.c and put it in block_dev.c. I'm trying to move non-buffer_head code out of buffer.c Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-09filesystem freeze: implement generic freeze featureTakashi Sato
The ioctls for the generic freeze feature are below. o Freeze the filesystem int ioctl(int fd, int FIFREEZE, arg) fd: The file descriptor of the mountpoint FIFREEZE: request code for the freeze arg: Ignored Return value: 0 if the operation succeeds. Otherwise, -1 o Unfreeze the filesystem int ioctl(int fd, int FITHAW, arg) fd: The file descriptor of the mountpoint FITHAW: request code for unfreeze arg: Ignored Return value: 0 if the operation succeeds. Otherwise, -1 Error number: If the filesystem has already been unfrozen, errno is set to EINVAL. [akpm@linux-foundation.org: fix CONFIG_BLOCK=n] Signed-off-by: Takashi Sato <t-sato@yk.jp.nec.com> Signed-off-by: Masayuki Hamaguchi <m-hamaguchi@ys.jp.nec.com> Cc: <xfs-masters@oss.sgi.com> Cc: <linux-ext4@vger.kernel.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Alasdair G Kergon <agk@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (57 commits) jbd2: Fix oops in jbd2_journal_init_inode() on corrupted fs ext4: Remove "extents" mount option block: Add Kconfig help which notes that ext4 needs CONFIG_LBD ext4: Make printk's consistently prefixed with "EXT4-fs: " ext4: Add sanity checks for the superblock before mounting the filesystem ext4: Add mount option to set kjournald's I/O priority jbd2: Submit writes to the journal using WRITE_SYNC jbd2: Add pid and journal device name to the "kjournald2 starting" message ext4: Add markers for better debuggability ext4: Remove code to create the journal inode ext4: provide function to release metadata pages under memory pressure ext3: provide function to release metadata pages under memory pressure add releasepage hooks to block devices which can be used by file systems ext4: Fix s_dirty_blocks_counter if block allocation failed with nodelalloc ext4: Init the complete page while building buddy cache ext4: Don't allow new groups to be added during block allocation ext4: mark the blocks/inode bitmap beyond end of group as used ext4: Use new buffer_head flag to check uninit group bitmaps initialization ext4: Fix the race between read_inode_bitmap() and ext4_new_inode() ext4: code cleanup ...
2009-01-09md: make devices disappear when they are no longer needed.NeilBrown
Currently md devices, once created, never disappear until the module is unloaded. This is essentially because the gendisk holds a reference to the mddev, and the mddev holds a reference to the gendisk, this a circular reference. If we drop the reference from mddev to gendisk, then we need to ensure that the mddev is destroyed when the gendisk is destroyed. However it is not possible to hook into the gendisk destruction process to enable this. So we drop the reference from the gendisk to the mddev and destroy the gendisk when the mddev gets destroyed. However this has a complication. Between the call __blkdev_get->get_gendisk->kobj_lookup->md_probe and the call __blkdev_get->md_open there is no obvious way to hold a reference on the mddev any more, so unless something is done, it will disappear and gendisk will be destroyed prematurely. Also, once we decide to destroy the mddev, there will be an unlockable moment before the gendisk is unlinked (blk_unregister_region) during which a new reference to the gendisk can be created. We need to ensure that this reference can not be used. i.e. the ->open must fail. So: 1/ in md_probe we set a flag in the mddev (hold_active) which indicates that the array should be treated as active, even though there are no references, and no appearance of activity. This is cleared by md_release when the device is closed if it is no longer needed. This ensures that the gendisk will survive between md_probe and md_open. 2/ In md_open we check if the mddev we expect to open matches the gendisk that we did open. If there is a mismatch we return -ERESTARTSYS and modify __blkdev_get to retry from the top in that case. In the -ERESTARTSYS sys case we make sure to wait until the old gendisk (that we succeeded in opening) is really gone so we loop at most once. Some udev configurations will always open an md device when it first appears. If we allow an md device that was just created by an open to disappear on an immediate close, then this can race with such udev configurations and result in an infinite loop the device being opened and closed, then re-open due to the 'ADD' even from the first open, and then close and so on. So we make sure an md device, once created by an open, remains active at least until some md 'ioctl' has been made on it. This means that all normal usage of md devices will allow them to disappear promptly when not needed, but the worst that an incorrect usage will do it cause an inactive md device to be left in existence (it can easily be removed). As an array can be stopped by writing to a sysfs attribute echo clear > /sys/block/mdXXX/md/array_state we need to use scheduled work for deleting the gendisk and other kobjects. This allows us to wait for any pending gendisk deletion to complete by simply calling flush_scheduled_work(). Signed-off-by: NeilBrown <neilb@suse.de>
2009-01-06fs: fix function param name in kernel-docRandy Dunlap
Fix function parameter name in kernel-doc: Warning(linux-2.6.28-git5//fs/block_dev.c:1272): No description found for parameter 'pathname' Warning(linux-2.6.28-git5//fs/block_dev.c:1272): Excess function parameter 'path' description in 'lookup_bdev' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-03add releasepage hooks to block devices which can be used by file systemsTheodore Ts'o
Implement blkdev_releasepage() to release the buffer_heads and pages after we release private data belonging to a mounted filesystem. Cc: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Cc: linux-fsdevel@vger.kernel.org Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-12-31fs/block_dev.c: __read_mostly improvement and sb_is_blkdev_sb utilizationDenis ChengRq
- iget5_locked in bdget really needs blockdev_superblock, instead of bd_mnt, so bd_mnt could be just a local variable; - blockdev_superblock really needs __read_mostly, while local var bd_mnt not; - make use of sb_is_blkdev_sb in bd_forget, instead of direct reference to blockdev_superblock. Signed-off-by: Denis ChengRq <crquan@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-04[PATCH 1/2] kill FMODE_NDELAY_NOWChristoph Hellwig
Update FMODE_NDELAY before each ioctl call so that we can kill the magic FMODE_NDELAY_NOW. It would be even better to do this directly in setfl(), but for that we'd need to have FMODE_NDELAY for all files, not just block special files. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-04[PATCH] clean up blkdev_get a little bitChristoph Hellwig
The way the bd_claim for the FMODE_EXCL case is implemented is rather confusing. Clean it up to the most logical style. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-11-06block: fix __blkdev_get() for removable devicesTejun Heo
Commit 0762b8bde9729f10f8e6249809660ff2ec3ad735 moved disk_get_part() in front of recursive get on the whole disk, which caused removable devices to try disk_get_part() before rescanning after a new media is inserted, which might fail legit open attempts or give the old partition. This patch fixes the problem by moving disk_get_part() after __blkdev_get() on the whole disk. This problem was spotted by Borislav Petkov. Signed-off-by: Tejun Heo <tj@kernel.org> Tested-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdevLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev: (66 commits) [PATCH] kill the rest of struct file propagation in block ioctls [PATCH] get rid of struct file use in blkdev_ioctl() BLKBSZSET [PATCH] get rid of blkdev_locked_ioctl() [PATCH] get rid of blkdev_driver_ioctl() [PATCH] sanitize blkdev_get() and friends [PATCH] remember mode of reiserfs journal [PATCH] propagate mode through swsusp_close() [PATCH] propagate mode through open_bdev_excl/close_bdev_excl [PATCH] pass fmode_t to blkdev_put() [PATCH] kill the unused bsize on the send side of /dev/loop [PATCH] trim file propagation in block/compat_ioctl.c [PATCH] end of methods switch: remove the old ones [PATCH] switch sr [PATCH] switch sd [PATCH] switch ide-scsi [PATCH] switch tape_block [PATCH] switch dcssblk [PATCH] switch dasd [PATCH] switch mtd_blkdevs [PATCH] switch mmc ...
2008-10-23[PATCH] assorted path_lookup() -> kern_path() conversionsAl Viro
more nameidata eviction Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] kill the rest of struct file propagation in block ioctlsAl Viro
Now we can switch blkdev_ioctl() block_device/mode Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] sanitize blkdev_get() and friendsAl Viro
* get rid of fake struct file/struct dentry in __blkdev_get() * merge __blkdev_get() and do_open() * get rid of flags argument of blkdev_get() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] propagate mode through open_bdev_excl/close_bdev_exclAl Viro
replace open_bdev_excl/close_bdev_excl with variants taking fmode_t. superblock gets the value used to mount it stored in sb->s_mode Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] pass fmode_t to blkdev_put()Al Viro
2008-10-21[PATCH] end of methods switch: remove the old onesAl Viro
2008-10-21[PATCH] beginning of methods conversionAl Viro
To keep the size of changesets sane we split the switch by drivers; to keep the damn thing bisectable we do the following: 1) rename the affected methods, add ones with correct prototypes, make (few) callers handle both. That's this changeset. 2) for each driver convert to new methods. *ALL* drivers are converted in this series. 3) kill the old (renamed) methods. Note that it _is_ a flagday; all in-tree drivers are converted and by the end of this series no trace of old methods remain. The only reason why we do that this way is to keep the damn thing bisectable and allow per-driver debugging if anything goes wrong. New methods: open(bdev, mode) release(disk, mode) ioctl(bdev, mode, cmd, arg) /* Called without BKL */ compat_ioctl(bdev, mode, cmd, arg) locked_ioctl(bdev, mode, cmd, arg) /* Called with BKL, legacy */ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] eliminate use of ->f_flags in block methodsAl Viro
store needed information in f_mode Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] introduce fmode_t, do annotationsAl Viro
2008-10-17block: fix current kernel-doc warningsRandy Dunlap
Fix block kernel-doc warnings: Warning(linux-2.6.27-git4//fs/block_dev.c:1272): No description found for parameter 'path' Warning(linux-2.6.27-git4//block/blk-core.c:1021): No description found for parameter 'cpu' Warning(linux-2.6.27-git4//block/blk-core.c:1021): No description found for parameter 'part' Warning(/var/linsrc/linux-2.6.27-git4//block/genhd.c:544): No description found for parameter 'partno' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block_dev: fix kernel-doc in new functionsRandy Dunlap
Fix kernel-doc in new functions: Error(mmotm-2008-1002-1617//fs/block_dev.c:895): duplicate section name 'Description' Error(mmotm-2008-1002-1617//fs/block_dev.c:924): duplicate section name 'Description' Warning(mmotm-2008-1002-1617//fs/block_dev.c:1282): No description found for parameter 'pathname' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> cc: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09Call flush_disk() after detecting an online resize.Andrew Patterson
We call flush_disk() to make sure the buffer cache for the disk is flushed after a disk resize. There are two resize cases, growing and shrinking. Given that users can shrink/then grow a disk before revalidate_disk() is called, we treat the grow case identically to shrinking. We need to flush the buffer cache after an online shrink because, as James Bottomley puts it, The two use cases for shrinking I can see are 1. planned: the fs is already shrunk to within the new boundaries and all data is relocated, so invalidate is fine (any dirty buffers that might exist in the shrunk region are there only because they were relocated but not yet written to their original location). 2. unplanned: In this case, the fs is probably toast, so whether we invalidate or not isn't going to make a whole lot of difference; it's still going to try to read or write from sectors beyond the new size and get I/O errors. Immediately invalidating shrunk disks will cause errors for outstanding I/Os for reads/write beyond the new end of the disk to be generated earlier then if we waited for the normal buffer cache operation. It also removes a potential security hole where we might keep old data around from beyond the end of the shrunk disk if the disk was not invalidated. Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09Added flush_disk to factor out common buffer cache flushing code.Andrew Patterson
We need to be able to flush the buffer cache for for more than just when a disk is changed, so we factor out common cache flush code in check_disk_change() to an internal flush_disk() routine. This routine will then be used for both disk changes and disk resizes (in a later patch). Include the disk name in the text indicating that there are busy inodes on the device and increase the KERN severity of the message. Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09Adjust block device size after an online resize of a disk.Andrew Patterson
The revalidate_disk routine now checks if a disk has been resized by comparing the gendisk capacity to the bdev inode size. If they are different (usually because the disk has been resized underneath the kernel) the bdev inode size is adjusted to match the capacity. Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09Wrapper for lower-level revalidate_disk routines.Andrew Patterson
This is a wrapper for the lower-level revalidate_disk call-backs such as sd_revalidate_disk(). It allows us to perform pre and post operations when calling them. We will use this wrapper in a later patch to adjust block device sizes after an online resize (a _post_ operation). Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: always set bdev->bd_partTejun Heo
Till now, bdev->bd_part is set only if the bdev was for parts other than part0. This patch makes bdev->bd_part always set so that code paths don't have to differenciate common handling. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: move holder_dir from disk to part0Tejun Heo
Move disk->holder_dir to part0->holder_dir. Kill now mostly superflous bdev_get_holder(). While at it, kill superflous kobject_get/put() around holder_dir, slave_dir and cmd_filter creation and collapse disk_sysfs_add_subdirs() into register_disk(). These serve no purpose but obfuscating the code. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: introduce partition 0Tejun Heo
genhd and partition code handled disk and partitions separately. All information about the whole disk was in struct genhd and partitions in struct hd_struct. However, the whole disk (part0) and other partitions have a lot in common and the data structures end up having good number of common fields and thus separate code paths doing the same thing. Also, the partition array was indexed by partno - 1 which gets pretty confusing at times. This patch introduces partition 0 and makes the partition array indexed by partno. Following patches will unify the handling of disk and parts piece-by-piece. This patch also implements disk_partitionable() which tests whether a disk is partitionable. With coming dynamic partition array change, the most common usage of disk_max_parts() will be testing whether a disk is partitionable and the number of max partitions will become much less important. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: implement and use {disk|part}_to_dev()Tejun Heo
Implement {disk|part}_to_dev() and use them to access generic device instead of directly dereferencing {disk|part}->dev. To make sure no user is left behind, rename generic devices fields to __dev. This is in preparation of unifying partition 0 handling with other partitions. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: fix disk->part[] dereferencing raceTejun Heo
disk->part[] is protected by its matching bdev's lock. However, non-critical accesses like collecting stats and printing out sysfs and proc information used to be performed without any locking. As partitions can come and go dynamically, partitions can go away underneath those non-critical accesses. As some of those accesses are writes, this theoretically can lead to silent corruption. This patch fixes the race by using RCU for the partition array and dev reference counter to hold partitions. * Rename disk->part[] to disk->__part[] to make sure no one outside genhd layer proper accesses it directly. * Use RCU for disk->__part[] dereferencing. * Implement disk_{get|put}_part() which can be used to get and put partitions from gendisk respectively. * Iterators are implemented to help iterate through all partitions safely. * Functions which require RCU readlock are marked with _rcu suffix. * Use disk_put_part() in __blkdev_put() instead of directly putting the contained kobject. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: don't depend on consecutive minor spaceTejun Heo
* Implement disk_devt() and part_devt() and use them to directly access devt instead of computing it from ->major and ->first_minor. Note that all references to ->major and ->first_minor outside of block layer is used to determine devt of the disk (the part0) and as ->major and ->first_minor will continue to represent devt for the disk, converting these users aren't strictly necessary. However, convert them for consistency. * Implement disk_max_parts() to avoid directly deferencing genhd->minors. * Update bdget_disk() such that it doesn't assume consecutive minor space. * Move devt computation from register_disk() to add_disk() and make it the only one (all other usages use the initially determined value). These changes clean up the code and will help disk->part dereference fix and extended block device numbers. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
