path: root/fs/btrfs/disk-io.c
2015-03-06btrfs: fix leak of path in btrfs_find_itemDavid Sterba
commit 381cf6587f8a8a8e981bc0c1aaaa8859b51dc756 upstream. If btrfs_find_item is called with NULL path it allocates one locally but does not free it. Affected paths are inserting an orphan item for a file and for a subvol root. Move the path allocation to the callers. Fixes: 3f870c289900 ("btrfs: expand btrfs_find_item() to include find_orphan_item functionality") Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06btrfs: set proper message level for skinny metadataDavid Sterba
commit 5efa0490cc94aee06cd8d282683e22a8ce0a0026 upstream. This has been confusing people for too long, the message is really just informative. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08Btrfs: fix fs corruption on transaction abort if device supports discardFilipe Manana
commit 678886bdc6378c1cbd5072da2c5a3035000214e3 upstream. When we abort a transaction we iterate over all the ranges marked as dirty in fs_info->freed_extents[0] and fs_info->freed_extents[1], clear them from those trees, add them back (unpin) to the free space caches and, if the fs was mounted with "-o discard", perform a discard on those regions. Also, after adding the regions to the free space caches, a fitrim ioctl call can see those ranges in a block group's free space cache and perform a discard on the ranges, so the same issue can happen without "-o discard" as well. This causes corruption, affecting one or multiple btree nodes (in the worst case leaving the fs unmountable) because some of those ranges (the ones in the fs_info->pinned_extents tree) correspond to btree nodes/leafs that are referred by the last committed super block - breaking the rule that anything that was committed by a transaction is untouched until the next transaction commits successfully. I ran into this while running in a loop (for several hours) the fstest that I recently submitted: [PATCH] fstests: add btrfs test to stress chunk allocation/removal and fstrim The corruption always happened when a transaction aborted and then fsck complained like this: _check_btrfs_filesystem: filesystem on /dev/sdc is inconsistent *** fsck.btrfs output *** Check tree block failed, want=94945280, have=0 Check tree block failed, want=94945280, have=0 Check tree block failed, want=94945280, have=0 Check tree block failed, want=94945280, have=0 Check tree block failed, want=94945280, have=0 read block failed check_tree_block Couldn't open file system In this case 94945280 corresponded to the root of a tree. Using frace what I observed was the following sequence of steps happened: 1) transaction N started, fs_info->pinned_extents pointed to fs_info->freed_extents[0]; 2) node/eb 94945280 is created; 3) eb is persisted to disk; 4) transaction N commit starts, fs_info->pinned_extents now points to fs_info->freed_extents[1], and transaction N completes; 5) transaction N + 1 starts; 6) eb is COWed, and btrfs_free_tree_block() called for this eb; 7) eb range (94945280 to 94945280 + 16Kb) is added to fs_info->pinned_extents (fs_info->freed_extents[1]); 8) Something goes wrong in transaction N + 1, like hitting ENOSPC for example, and the transaction is aborted, turning the fs into readonly mode. The stack trace I got for example: [112065.253935] [<ffffffff8140c7b6>] dump_stack+0x4d/0x66 [112065.254271] [<ffffffff81042984>] warn_slowpath_common+0x7f/0x98 [112065.254567] [<ffffffffa0325990>] ? __btrfs_abort_transaction+0x50/0x10b [btrfs] [112065.261674] [<ffffffff810429e5>] warn_slowpath_fmt+0x48/0x50 [112065.261922] [<ffffffffa032949e>] ? btrfs_free_path+0x26/0x29 [btrfs] [112065.262211] [<ffffffffa0325990>] __btrfs_abort_transaction+0x50/0x10b [btrfs] [112065.262545] [<ffffffffa036b1d6>] btrfs_remove_chunk+0x537/0x58b [btrfs] [112065.262771] [<ffffffffa033840f>] btrfs_delete_unused_bgs+0x1de/0x21b [btrfs] [112065.263105] [<ffffffffa0343106>] cleaner_kthread+0x100/0x12f [btrfs] (...) [112065.264493] ---[ end trace dd7903a975a31a08 ]--- [112065.264673] BTRFS: error (device sdc) in btrfs_remove_chunk:2625: errno=-28 No space left [112065.264997] BTRFS info (device sdc): forced readonly 9) The clear kthread sees that the BTRFS_FS_STATE_ERROR bit is set in fs_info->fs_state and calls btrfs_cleanup_transaction(), which in turn calls btrfs_destroy_pinned_extent(); 10) Then btrfs_destroy_pinned_extent() iterates over all the ranges marked as dirty in fs_info->freed_extents[], and for each one it calls discard, if the fs was mounted with "-o discard", and adds the range to the free space cache of the respective block group; 11) btrfs_trim_block_group(), invoked from the fitrim ioctl code path, sees the free space entries and performs a discard; 12) After an umount and mount (or fsck), our eb's location on disk was full of zeroes, and it should have been untouched, because it was marked as dirty in the fs_info->pinned_extents tree, and therefore used by the trees that the last committed superblock points to. Fix this by not performing a discard and not adding the ranges to the free space caches - it's useless from this point since the fs is now in readonly mode and we won't write free space caches to disk anymore (otherwise we would leak space) nor any new superblock. By not adding the ranges to the free space caches, it prevents other code paths from allocating that space and write to it as well, therefore being safer and simpler. This isn't a new problem, as it's been present since 2011 (git commit acce952b0263825da32cf10489413dec78053347). Signed-off-by: Filipe Manana <fdmanana@suse.com> Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30Btrfs: make sure there are not any read requests before stopping workersWang Shilong
commit de348ee022175401e77d7662b7ca6e231a94e3fd upstream. In close_ctree(), after we have stopped all workers,there maybe still some read requests(for example readahead) to submit and this *maybe* trigger an oops that user reported before: kernel BUG at fs/btrfs/async-thread.c:619! By hacking codes, i can reproduce this problem with one cpu available. We fix this potential problem by invalidating all btree inode pages before stopping all workers. Thanks to Miao for pointing out this problem. Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com> Reviewed-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26Btrfs: skip submitting barrier for missing deviceHidetoshi Seto
commit f88ba6a2a44ee98e8d59654463dc157bb6d13c43 upstream. I got an error on v3.13: BTRFS error (device sdf1) in write_all_supers:3378: errno=-5 IO failure (errors while submitting device barriers.) how to reproduce: > mkfs.btrfs -f -d raid1 /dev/sdf1 /dev/sdf2 > wipefs -a /dev/sdf2 > mount -o degraded /dev/sdf1 /mnt > btrfs balance start -f -sconvert=single -mconvert=single -dconvert=single /mnt The reason of the error is that barrier_all_devices() failed to submit barrier to the missing device. However it is clear that we cannot do anything on missing device, and also it is not necessary to care chunks on the missing device. This patch stops sending/waiting barrier if device is missing. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "We have a small collection of fixes in my for-linus branch. The big thing that stands out is a revert of a new ioctl. Users haven't shipped yet in btrfs-progs, and Dave Sterba found a better way to export the information" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: use right clone root offset for compressed extents btrfs: fix null pointer deference at btrfs_sysfs_add_one+0x105 Btrfs: unset DCACHE_DISCONNECTED when mounting default subvol Btrfs: fix max_inline mount option Btrfs: fix a lockdep warning when cleaning up aborted transaction Revert "btrfs: add ioctl to export size of global metadata reservation"
2014-02-14Btrfs: fix a lockdep warning when cleaning up aborted transactionLiu Bo
Given now we have 2 spinlock for management of delayed refs, CONFIG_DEBUG_SPINLOCK=y helped me find this, [ 4723.413809] BUG: spinlock wrong CPU on CPU#1, btrfs-transacti/2258 [ 4723.414882] lock: 0xffff880048377670, .magic: dead4ead, .owner: btrfs-transacti/2258, .owner_cpu: 2 [ 4723.417146] CPU: 1 PID: 2258 Comm: btrfs-transacti Tainted: G W O 3.12.0+ #4 [ 4723.421321] Call Trace: [ 4723.421872] [<ffffffff81680fe7>] dump_stack+0x54/0x74 [ 4723.422753] [<ffffffff81681093>] spin_dump+0x8c/0x91 [ 4723.424979] [<ffffffff816810b9>] spin_bug+0x21/0x26 [ 4723.425846] [<ffffffff81323956>] do_raw_spin_unlock+0x66/0x90 [ 4723.434424] [<ffffffff81689bf7>] _raw_spin_unlock+0x27/0x40 [ 4723.438747] [<ffffffffa015da9e>] btrfs_cleanup_one_transaction+0x35e/0x710 [btrfs] [ 4723.443321] [<ffffffffa015df54>] btrfs_cleanup_transaction+0x104/0x570 [btrfs] [ 4723.444692] [<ffffffff810c1b5d>] ? trace_hardirqs_on_caller+0xfd/0x1c0 [ 4723.450336] [<ffffffff810c1c2d>] ? trace_hardirqs_on+0xd/0x10 [ 4723.451332] [<ffffffffa015e5ee>] transaction_kthread+0x22e/0x270 [btrfs] [ 4723.452543] [<ffffffffa015e3c0>] ? btrfs_cleanup_transaction+0x570/0x570 [btrfs] [ 4723.457833] [<ffffffff81079efa>] kthread+0xea/0xf0 [ 4723.458990] [<ffffffff81079e10>] ? kthread_create_on_node+0x140/0x140 [ 4723.460133] [<ffffffff81692aac>] ret_from_fork+0x7c/0xb0 [ 4723.460865] [<ffffffff81079e10>] ? kthread_create_on_node+0x140/0x140 [ 4723.496521] ------------[ cut here ]------------ ---------------------------------------------------------------------- The reason is that we get to call cond_resched_lock(&head_ref->lock) while still holding @delayed_refs->lock. So it's different with __btrfs_run_delayed_refs(), where we do drop-acquire dance before and after actually processing delayed refs. Here we don't drop the lock, others are not able to add new delayed refs to head_ref, so cond_resched_lock(&head_ref->lock) is not necessary here. Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "Filipe is fixing compile and boot problems with our crc32c rework, and Josef has disabled snapshot aware defrag for now. As the number of snapshots increases, we're hitting OOM. For the short term we're disabling things until a bigger fix is ready" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: use late_initcall instead of module_init Btrfs: use btrfs_crc32c everywhere instead of libcrc32c Btrfs: disable snapshot aware defrag for now
2014-02-03Btrfs: use btrfs_crc32c everywhere instead of libcrc32cFilipe David Borba Manana
After the commit titled "Btrfs: fix btrfs boot when compiled as built-in", LIBCRC32C requirement was removed from btrfs' Kconfig. This made it not possible to build a kernel with btrfs enabled (either as module or built-in) if libcrc32c is not enabled as well. So just replace all uses of libcrc32c with the equivalent function in btrfs hash.h - btrfs_crc32c. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs updates from Chris Mason: "This is a pretty big pull, and most of these changes have been floating in btrfs-next for a long time. Filipe's properties work is a cool building block for inheriting attributes like compression down on a per inode basis. Jeff Mahoney kicked in code to export filesystem info into sysfs. Otherwise, lots of performance improvements, cleanups and bug fixes. Looks like there are still a few other small pending incrementals, but I wanted to get the bulk of this in first" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (149 commits) Btrfs: fix spin_unlock in check_ref_cleanup Btrfs: setup inode location during btrfs_init_inode_locked Btrfs: don't use ram_bytes for uncompressed inline items Btrfs: fix btrfs_search_slot_for_read backwards iteration Btrfs: do not export ulist functions Btrfs: rework ulist with list+rb_tree Btrfs: fix memory leaks on walking backrefs failure Btrfs: fix send file hole detection leading to data corruption Btrfs: add a reschedule point in btrfs_find_all_roots() Btrfs: make send's file extent item search more efficient Btrfs: fix to catch all errors when resolving indirect ref Btrfs: fix protection between walking backrefs and root deletion btrfs: fix warning while merging two adjacent extents Btrfs: fix infinite path build loops in incremental send btrfs: undo sysfs when open_ctree() fails Btrfs: fix snprintf usage by send's gen_unique_name btrfs: fix defrag 32-bit integer overflow btrfs: sysfs: list the NO_HOLES feature btrfs: sysfs: don't show reserved incompat feature btrfs: call permission checks earlier in ioctls and return EPERM ...
2014-01-28btrfs: undo sysfs when open_ctree() failsAnand Jain
reproducer: mkfs.btrfs -f /dev/sdb &&\ mount /dev/sdb /btrfs &&\ btrfs dev add -f /dev/sdc /btrfs &&\ umount /btrfs &&\ wipefs -a /dev/sdc &&\ mount -o degraded /dev/sdb /btrfs //above mount fails so try with RO mount -o degraded,ro /dev/sdb /btrfs ------ sysfs: cannot create duplicate filename '/fs/btrfs/3f48c79e-5ed0-4e87-b189-86e749e503f4' :: dump_stack+0x49/0x5e warn_slowpath_common+0x87/0xb0 warn_slowpath_fmt+0x41/0x50 strlcat+0x69/0x80 sysfs_warn_dup+0x87/0xa0 sysfs_add_one+0x40/0x50 create_dir+0x76/0xc0 sysfs_create_dir_ns+0x7a/0xc0 kobject_add_internal+0xad/0x220 kobject_add_varg+0x38/0x60 kobject_init_and_add+0x53/0x70 mutex_lock+0x11/0x40 __free_pages+0x25/0x30 free_pages+0x41/0x50 selinux_sb_copy_data+0x14e/0x1e0 mount_fs+0x3e/0x1a0 vfs_kern_mount+0x71/0x120 do_mount+0x3f7/0x980 SyS_mount+0x8b/0xe0 system_call_fastpath+0x16/0x1b ------ further 'modprobe -r btrfs' fails as well Signed-off-by: Anand Jain <anand.jain@oracle.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: fix extent state leak on transaction abortionLiu Bo
When transaction is aborted, we fail to commit transaction, instead we do cleanup work. After that when we umount btrfs, we get to free fs roots' log trees respectively, but that happens after we unpin extents, so those extents pinned by freeing log trees will remain in memory and lead to the leak. Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28btrfs: Add noinode_cache mount optionQu Wenruo
Add noinode_cache mount option for btrfs. Since inode map cache involves all the btrfs_find_free_ino/return_ino things and if just trigger the mount_opt, an inode number get from inode map cache will not returned to inode map cache. To keep the find and return inode both in the same behavior, a new bit in mount_opt, CHANGE_INODE_CACHE, is introduced for this idea. CHANGE_INODE_CACHE is set/cleared in remounting, and the original INODE_MAP_CACHE is set/cleared according to CHANGE_INODE_CACHE after a success transaction. Since find/return inode is all done between btrfs_start_transaction and btrfs_commit_transaction, this will keep consistent behavior. Also noinode_cache mount option will not stop the caching_kthread. Cc: David Sterba <dsterba@suse.cz> Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Qu Wenruo <quwenruo@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: throttle delayed refs betterJosef Bacik
On one of our gluster clusters we noticed some pretty big lag spikes. This turned out to be because our transaction commit was taking like 3 minutes to complete. This is because we have like 30 gigs of metadata, so our global reserve would end up being the max which is like 512 mb. So our throttling code would allow a ridiculous amount of delayed refs to build up and then they'd all get run at transaction commit time, and for a cold mounted file system that could take up to 3 minutes to run. So fix the throttling to be based on both the size of the global reserve and how long it takes us to run delayed refs. This patch tracks the time it takes to run delayed refs and then only allows 1 seconds worth of outstanding delayed refs at a time. This way it will auto-tune itself from cold cache up to when everything is in memory and it no longer has to go to disk. This makes our transaction commits take much less time to run. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: attach delayed ref updates to delayed ref headsJosef Bacik
Currently we have two rb-trees, one for delayed ref heads and one for all of the delayed refs, including the delayed ref heads. When we process the delayed refs we have to hold onto the delayed ref lock for all of the selecting and merging and such, which results in quite a bit of lock contention. This was solved by having a waitqueue and only one flusher at a time, however this hurts if we get a lot of delayed refs queued up. So instead just have an rb tree for the delayed ref heads, and then attach the delayed ref updates to an rb tree that is per delayed ref head. Then we only need to take the delayed ref lock when adding new delayed refs and when selecting a delayed ref head to process, all the rest of the time we deal with a per delayed ref head lock which will be much less contentious. The locking rules for this get a little more complicated since we have to lock up to 3 things to properly process delayed refs, but I will address that problem later. For now this passes all of xfstests and my overnight stress tests. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: only fua the first superblock when writting supersWang Shilong
We only intent to fua the first superblock in every device from comments, fix it. Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: convert printk to btrfs_ and fix BTRFS prefixFrank Holton
Convert all applicable cases of printk and pr_* to the btrfs_* macros. Fix all uses of the BTRFS prefix. Signed-off-by: Frank Holton <fholton@gmail.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: move the extent buffer radix tree into the fs_infoJosef Bacik
I need to create a fake tree to test qgroups and I don't want to have to setup a fake btree_inode. The fact is we only use the radix tree for the fs_info, so everybody else who allocates an extent_io_tree is just wasting the space anyway. This patch moves the radix tree and its lock into btrfs_fs_info so there is less stuff I have to fake to do qgroup sanity tests. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28btrfs: expand btrfs_find_item() to include find_orphan_item functionalityKelley Nielsen
This is the third step in bootstrapping the btrfs_find_item interface. The function find_orphan_item(), in orphan.c, is similar to the two functions already replaced by the new interface. It uses two parameters, which are already present in the interface, and is nearly identical to the function brought in in the previous patch. Replace the two calls to find_orphan_item() with calls to btrfs_find_item(), with the defined objectid and type that was used internally by find_orphan_item(), a null path, and a null key. Add a test for a null path to btrfs_find_item, and if it passes, allocate and free the path. Finally, remove find_orphan_item(). Signed-off-by: Kelley Nielsen <kelleynnn@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28btrfs: remove unused variables from disk-io.cValentina Giusti
Remove unused variables: * tree from csum_dirty_buffer, * tree from btree_readpage_end_io_hook, * tree from btree_writepages, * bytenr from btrfs_create_tree, * fs_info from end_workqueue_fn. Signed-off-by: Valentina Giusti <valentina.giusti@microon.de> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28btrfs: publish per-super attributes in sysfsJeff Mahoney
This patch adds per-super attributes to sysfs. It doesn't publish any attributes yet, but does the proper lifetime handling as well as the basic infrastructure to add new attributes. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-01-28Btrfs: introduce a head ref rbtreeLiu Bo
The way how we process delayed refs is 1) get a bunch of head refs, 2) pick up one head ref, 3) go one node back for any delayed ref updates. The head ref is also linked in the same rbtree as the delayed ref is, so in 1) stage, we have to walk one by one including not only head refs, but delayed refs. When we have a great number of delayed refs pending to process, this'll cost time a lot. Here we introduce a head ref specific rbtree, it only has head refs, so troubles go away. Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <clm@fb.com>
2013-12-03block: fixup for generic bio chainingKent Overstreet
btrfs bits got lost in the rebase Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Chris Mason <clm@fb.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-23block: Convert various code to bio_for_each_segment()Kent Overstreet
With immutable biovecs we don't want code accessing bi_io_vec directly - the uses this patch changes weren't incorrect since they all own the bio, but it makes the code harder to audit for no good reason - also, this will help with multipage bvecs later. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Chris Mason <chris.mason@fusionio.com> Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-11-20Btrfs: avoid heavy operations in btrfs_commit_superLiu Bo
The 'git blame' history shows that, the old transaction commit code has to do twice to ensure roots are updated and we have to flush metadata and super block manually, however, right now all of these can be handled well inside the transaction commit code without extra efforts. And the error handling part remains same with the current code, -- 'return to caller once we get error'. This saves us a transaction commit and a flush of super block, which are both heavy operations according to ftrace output analysis. Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11btrfs: Remove useless variable in write_ctree_super()Rashika
The function write_ctree_super() in disk-io.c uses variable ret to return the result of function write_all_supers(). Since, this variable serves no purpose, hence the patch removes it and returns the call of the called function. Reviewed-by: Zach Brown <zab@redhat.com> Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11btrfs: Use WARN_ON()'s return value in place of WARN_ON(1)Dulshani Gunawardhana
Use WARN_ON()'s return value in place of WARN_ON(1) for cleaner source code that outputs a more descriptive warnings. Also fix the styling warning of redundant braces that came up as a result of this fix. Signed-off-by: Dulshani Gunawardhana <dulshani.gunawardhana89@gmail.com> Reviewed-by: Zach Brown <zab@redhat.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11btrfs: Add helper function for free_root_pointers()Rashika
The function free_root_pointers() in disk-io.h contains redundant code. Therefore, this patch adds a helper function free_root_extent_buffers() to free_root_pointers() to eliminate redundancy. Reviewed-by: Zach Brown <zab@redhat.com> Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: remove scrub_super_lock holding in btrfs_sync_log()Wang Shilong
Originally, we introduced scrub_super_lock to synchronize tree log code with scrubbing super. However we can replace scrub_super_lock with device_list_mutex, because writing super will hold this mutex, this will reduce an extra lock holding when writing supers in sync log code. Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11btrfs: remove fs/btrfs/compat.hZach Brown
fs/btrfs/compat.h only contained trivial macro wrappers of drop_nlink() and inc_nlink(). This doesn't belong in mainline. Signed-off-by: Zach Brown <zab@redhat.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: Simplify the logic in alloc_extent_buffer() for existing extent ↵Chandra Seetharaman
buffer case alloc_extent_buffer() uses radix_tree_lookup() when radix_tree_insert() fails with EEXIST. That part of the code is very similar to the code in find_extent_buffer(). This patch replaces radix_tree_lookup() and surrounding code in alloc_extent_buffer() with find_extent_buffer(). Note that radix_tree_lookup() does not need to be protected by tree->buffer_lock. It is protected by eb->refs. While at it, this patch - changes the other usage of radix_tree_lookup() in alloc_extent_buffer() with find_extent_buffer() to reduce redundancy. - removes the unused argument 'len' to find_extent_buffer(). Signed-Off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Zach Brown <zab@redhat.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: stop all workers after we free block groupsJosef Bacik
Stefan was hitting a panic in the async worker stuff because we had outstanding read bios while we were stopping the worker threads. You could reproduce this easily if you mount -o nospace_cache and ran generic/273. This is because the caching thread stuff is still going and we were stopping all the worker threads. We need to stop the workers after this work is done, and the free block groups code will wait for all the caching threads to stop first so we don't run into this problem. With this patch we no longer panic. Thanks, Cc: stable@vger.kernel.org Reported-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: free up block groups after everythingJosef Bacik
If we abort a transaction we will do the tree log cleanup at unmount, but this happens after we free up the block groups. This makes all the leak detection warnings go off because we think we've leaked space but in reality we just haven't cleaned it up yet. So instead do the block group cleanup stuff after free'ing the fs roots so we don't get these warnings. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: do not free the dirty bytes from the trans block rsv on cleanupJosef Bacik
The transactions should be cleaning up their reservations on failure, this just causes us to have warnings on unmount because we go negative by free'ing reservations that have already been free'ed. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: improve inode hash function/inode lookupFilipe David Borba Manana
Currently the hash value used for adding an inode to the VFS's inode hash table consists of the plain inode number, which is a 64 bits integer. This results in hash table buckets (hlist_head lists) with too many elements for at least 2 important scenarios: 1) When we have many subvolumes. Each subvolume has its own btree where its files and directories are added to, and each has its own objectid (inode number) namespace. This means that if we have N subvolumes, and all have inode number X associated to a file or directory, the corresponding inodes all map to the same hash table entry, resulting in a bucket (hlist_head list) with N elements; 2) On 32 bits machines. Th VFS hash values are unsigned longs, which are 32 bits wide on 32 bits machines, and the inode (objectid) numbers are 64 bits unsigned integers. We simply cast the inode numbers to hash values, which means that for all inodes with the same 32 bits lower half, the same hash bucket is used for all of them. For example, all inodes with a number (objectid) between 0x0000_0000_ffff_ffff and 0xffff_ffff_ffff_ffff will end up in the same hash table bucket. This change ensures the inode's hash value depends both on the objectid (inode number) and its subvolume's (btree root) objectid. For 32 bits machines, this change gives better entropy by making the hash value depend on both the upper and lower 32 bits of the 64 bits hash previously computed. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11btrfs: remove unused parameter from btrfs_header_fsidRoss Kirk
Remove unused parameter, 'eb'. Unused since introduction in 5f39d397dfbe140a14edecd4e73c34ce23c4f9ee Updated to be rebased against current upstream and correct diff supplied this time! Signed-off-by: Ross Kirk <ross.kirk@gmail.com> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: fix two use-after-free bugs with transaction cleanupJosef Bacik
I was noticing the slab redzone stuff going off every once and a while during transaction aborts. This was caused by two things 1) We would walk the pending snapshots and set their error to -ECANCELED. We don't need to do this, the snapshot stuff waits for a transaction commit and if there is a problem we just free our pending snapshot object and exit. Doing this was causing us to touch the pending snapshot object after the thing had already been freed. 2) We were freeing the transaction manually with wanton disregard for it's use_count reference counter. To fix this I cleaned up the transaction freeing loop to either wait for the transaction commit to finish if it was in the middle of that (since it will be cleaned and freed up there) or to do the cleanup oursevles. I also moved the global "kill all things dirty everywhere" stuff outside of the transaction cleanup loop since that only needs to be done once. With this patch I'm no longer seeing slab corruption because of use after frees. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: don't delete ordered roots from list during cleanupJosef Bacik
During transaction cleanup after an abort we are just removing roots from the ordered roots list which is incorrect. We have a BUG_ON() to make sure that the root is still part of the ordered roots list when we put our ordered extent which we were tripping in this case. So do like we do everywhere else and just move it to the tail of the ordered roots list and allow the normal cleanup to take care of stuff. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: cleanup transaction on abortJosef Bacik
If we abort not during a transaction commit we won't clean up anything until we unmount. Unfortunately if we abort in the middle of writing out an ordered extent we won't clean it up and if somebody is waiting on that ordered extent they will wait forever. To fix this just make the transaction kthread call the cleanup transaction stuff if it notices theres an error, and make btrfs_end_transaction wake up the transaction kthread if there is an error. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: add a sanity test for btrfs_split_itemJosef Bacik
While looking at somebodys corruption I became completely convinced that btrfs_split_item was broken, so I wrote this test to verify that it was working as it was supposed to. Thankfully it appears to be working as intended, so just add this test to make sure nobody breaks it in the future. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: eliminate the exceptional root_tree refs=0Stefan Behrens
The fact that btrfs_root_refs() returned 0 for the tree_root caused bugs in the past, therefore it is set to 1 with this patch and (hopefully) all affected code is adapted to this change. I verified this change by temporarily adding WARN_ON() checks everywhere where btrfs_root_refs() is used, checking whether the logic of the code is changed by btrfs_root_refs() returning 1 instead of 0 for root->root_key.objectid == BTRFS_ROOT_TREE_OBJECTID. With these added checks, I ran the xfstests './check -g auto'. The two roots chunk_root and log_root_tree that are only referenced by the superblock and the log_roots below the log_root_tree still have btrfs_root_refs() == 0, only the tree_root is changed. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-10-10Btrfs: fix oops caused by the space balance and dead rootsMiao Xie
When doing space balance and subvolume destroy at the same time, we met the following oops: kernel BUG at fs/btrfs/relocation.c:2247! RIP: 0010: [<ffffffffa04cec16>] prepare_to_merge+0x154/0x1f0 [btrfs] Call Trace: [<ffffffffa04b5ab7>] relocate_block_group+0x466/0x4e6 [btrfs] [<ffffffffa04b5c7a>] btrfs_relocate_block_group+0x143/0x275 [btrfs] [<ffffffffa0495c56>] btrfs_relocate_chunk.isra.27+0x5c/0x5a2 [btrfs] [<ffffffffa0459871>] ? btrfs_item_key_to_cpu+0x15/0x31 [btrfs] [<ffffffffa048b46a>] ? btrfs_get_token_64+0x7e/0xcd [btrfs] [<ffffffffa04a3467>] ? btrfs_tree_read_unlock_blocking+0xb2/0xb7 [btrfs] [<ffffffffa049907d>] btrfs_balance+0x9c7/0xb6f [btrfs] [<ffffffffa049ef84>] btrfs_ioctl_balance+0x234/0x2ac [btrfs] [<ffffffffa04a1e8e>] btrfs_ioctl+0xd87/0x1ef9 [btrfs] [<ffffffff81122f53>] ? path_openat+0x234/0x4db [<ffffffff813c3b78>] ? __do_page_fault+0x31d/0x391 [<ffffffff810f8ab6>] ? vma_link+0x74/0x94 [<ffffffff811250f5>] vfs_ioctl+0x1d/0x39 [<ffffffff811258c8>] do_vfs_ioctl+0x32d/0x3e2 [<ffffffff811259d4>] SyS_ioctl+0x57/0x83 [<ffffffff813c3bfa>] ? do_page_fault+0xe/0x10 [<ffffffff813c73c2>] system_call_fastpath+0x16/0x1b It is because we returned the error number if the reference of the root was 0 when doing space relocation. It was not right here, because though the root was dead(refs == 0), but the space it held still need be relocated, or we could not remove the block group. So in this case, we should return the root no matter it is dead or not. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-21Btrfs: add the missing mutex unlock in write_all_supers()Stefan Behrens
The BUG() was replaced by btrfs_error() and return -EIO with the patch "get rid of one BUG() in write_all_supers()", but the missing mutex_unlock() was overlooked. The 0-DAY kernel build service from Intel reported the missing unlock which was found by the coccinelle tool: fs/btrfs/disk-io.c:3422:2-8: preceding lock on line 3374 Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-21btrfs: add lockdep and tracing annotations for uuid treeDavid Sterba
Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: don't use an async starter for most of our workersJosef Bacik
We only need an async starter if we can't make a GFP_NOFS allocation in our current path. This is the case for the endio stuff since it happens in IRQ context, but things like the caching thread workers and the delalloc flushers we can easily make this allocation and start threads right away. Also change the worker count for the caching thread pool. Traditionally we limited this to 2 since we took read locks while caching, but nowadays we do this lockless so there's no reason to limit the number of caching threads. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: fix for patch "cleanup: don't check the same thing twice"Stefan Behrens
Mitch Harder noticed that the patch 3c64a1a mentioned in the subject line was causing a kernel BUG() on snapshot deletion. The patch was wrong. It did not handle cached roots correctly. The check for root_refs == 0 was removed everywhere where btrfs_read_fs_root_no_name() had been used to retrieve the root, because this check was already dealt with in btrfs_read_fs_root_no_name(). But in the case when the root was found in the cache, there was no such check. This patch adds the missing check in the case where the root is found in the cache. Reported-by: Mitch Harder <mitch.harder@sabayonlinux.org> Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Reviewed-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: get rid of one BUG() in write_all_supers()Stefan Behrens
The second round uses btrfs_error() and return -EIO, the first round can handle write errors the same way. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: fix race between removing a dev and writing sbsFilipe David Borba Manana
This change fixes an issue when removing a device and writing all super blocks run simultaneously. Here's the steps necessary for the issue to happen: 1) disk-io.c:write_all_supers() gets a number of N devices from the super_copy, so it will not panic if it fails to write super blocks for N - 1 devices; 2) Then it tries to acquire the device_list_mutex, but blocks because volumes.c:btrfs_rm_device() got it first; 3) btrfs_rm_device() removes the device from the list, then unlocks the mutex and after the unlock it updates the number of devices in super_copy to N - 1. 4) write_all_supers() finally acquires the mutex, iterates over all the devices in the list and gets N - 1 errors, that is, it failed to write super blocks to all the devices; 5) Because write_all_supers() thinks there are a total of N devices, it considers N - 1 errors to be ok, and therefore won't panic. So this change just makes sure that write_all_supers() reads the number of devices from super_copy after it acquires the device_list_mutex. Conversely, it changes btrfs_rm_device() to update the number of devices in super_copy before it releases the device list mutex. The code path to add a new device (volumes.c:btrfs_init_new_device), already has the right behaviour: it updates the number of devices in super_copy while holding the device_list_mutex. The only code path that doesn't lock the device list mutex before updating the number of devices in the super copy is disk-io.c:next_root_backup(), called by open_ctree() during mount time where concurrency issues can't happen. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: Make btrfs_header_chunk_tree_uuid() return unsigned longGeert Uytterhoeven
Internally, btrfs_header_chunk_tree_uuid() calculates an unsigned long, but casts it to a pointer, while all callers cast it to unsigned long again. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-09-01Btrfs: Make btrfs_header_fsid() return unsigned longGeert Uytterhoeven
Internally, btrfs_header_fsid() calculates an unsigned long, but casts it to a pointer, while all callers cast it to unsigned long again. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
