path: root/fs/btrfs/extent-tree.c
2011-08-21Btrfs: fix 64 bit divide problemJosef Bacik
This fixes a regression introduced by commit cdcb725c05fe ("Btrfs: check if there is enough space for balancing smarter"). We can't do 64-bit divides on 32-bit architectures. In cases where we need to divide/multiply by 2 we should just left/right shift respectively, and in cases where theres N number of devices use do_div. Also make the counters u64 to match up with rw_devices. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Acked-and-tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-16Btrfs: forced readonly when btrfs_drop_snapshot() failsTsutomu Itoh
The filesystem turns readonly instead of returning the error to the caller when detected error in btrfs_drop_snapshot(). and, because the caller doesn't check the error, the function type is changed to 'void'. Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: check if there is enough space for balancing smarterliubo
When checking if there is enough space for balancing a block group, since we do not take raid types into consideration, we do not account corrent amounts of space that we needed. This makes us do some extra work before we get ENOSPC. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: detect wether a device supports discardJosef Bacik
We have a problem where if a user specifies discard but doesn't actually support it we will return EOPNOTSUPP from btrfs_discard_extent. This is a problem because this gets called (in a fashion) from the tree log recovery code, which has a nice little BUG_ON(ret) after it, which causes us to fail the tree log replay. So instead detect wether our devices support discard when we're adding them and then don't issue discards if we know that the device doesn't support it. And just for good measure set ret = 0 in btrfs_issue_discard just in case we still get EOPNOTSUPP so we don't screw anybody up like this again. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-01Btrfs: don't print the leaf if we had an errorJosef Bacik
In __btrfs_free_extent we will print the leaf if we fail to find the extent we wanted, but the problem is if we get an error we won't have a leaf so often this leads to a NULL pointer dereference and we lose the error that actually occurred. So only print the leaf if ret > 0, which means we didn't find the item we were looking for but we didn't error either. This way the error is preserved. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-01Btrfs: fix oops while writing data to SSD partitionsliubo
Here I have a two SSD-partitions btrfs, and they are defaultly set to "data=raid0, metadata=raid1", then I try to fill my btrfs partition till "No space left on device", via "dd if=/dev/zero of=/mnt/btrfs/tmp". I get an oops panic from kernel BUG at fs/btrfs/extent-tree.c:5199!, which refers to find_free_extent's BUG_ON(index != get_block_group_index(block_group)); In SSD mode, in order to find enough space to alloc, we may check the block_group cache which has been checked sometime before, but the index is not updated, where it hits the BUG_ON. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Acked-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-01Btrfs: Protect the readonly flag of block groupWuBo
The access for ro in btrfs_block_group_cache should be protected because of the racy lock in relocation. Signed-off-by: Wu Bo <wu.bo@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-01Btrfs: return error to caller when btrfs_unlink() failesTsutomu Itoh
When btrfs_unlink_inode() and btrfs_orphan_add() in btrfs_unlink() are error, the error code is returned to the caller instead of BUG_ON(). Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-01Merge branch 'alloc_path' of ↵Chris Mason
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/btrfs-error-handling into for-linus
2011-07-27Btrfs: make sure reserve_metadata_bytes doesn't leak out strange errorsChris Mason
The btrfs transaction code will return any errors that come from reserve_metadata_bytes. We need to make sure we don't return funny things like 1 or EAGAIN. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-07-27Btrfs: make a lockdep class for each rootChris Mason
This patch was originally from Tejun Heo. lockdep complains about the btrfs locking because we sometimes take btree locks from two different trees at the same time. The current classes are based only on level in the btree, which isn't enough information for lockdep to figure out if the lock is safe. This patch makes a class for each type of tree, and lumps all the FS trees that actually have files and directories into the same class. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-07-27Btrfs: switch the btrfs tree locks to reader/writerChris Mason
The btrfs metadata btree is the source of significant lock contention, especially in the root node. This commit changes our locking to use a reader/writer lock. The lock is built on top of rw spinlocks, and it extends the lock tracking to remember if we have a read lock or a write lock when we go to blocking. Atomics count the number of blocking readers or writers at any given time. It removes all of the adaptive spinning from the old code and uses only the spinning/blocking hints inside of btrfs to decide when it should continue spinning. In read heavy workloads this is dramatically faster. In write heavy workloads we're still faster because of less contention on the root node lock. We suffer slightly in dbench because we schedule more often during write locks, but all other benchmarks so far are improved. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-07-27Btrfs: fix BUG_ON() caused by ENOSPC when relocating spaceMiao Xie
When we balanced the chunks across the devices, BUG_ON() in __finish_chunk_alloc() was triggered. ------------[ cut here ]------------ kernel BUG at fs/btrfs/volumes.c:2568! [SNIP] Call Trace: [<ffffffffa049525e>] btrfs_alloc_chunk+0x8e/0xa0 [btrfs] [<ffffffffa04546b0>] do_chunk_alloc+0x330/0x3a0 [btrfs] [<ffffffffa045c654>] btrfs_reserve_extent+0xb4/0x1f0 [btrfs] [<ffffffffa045c86b>] btrfs_alloc_free_block+0xdb/0x350 [btrfs] [<ffffffffa048a8d8>] ? read_extent_buffer+0xd8/0x1d0 [btrfs] [<ffffffffa04476fd>] __btrfs_cow_block+0x14d/0x5e0 [btrfs] [<ffffffffa044660d>] ? read_block_for_search+0x14d/0x4d0 [btrfs] [<ffffffffa0447c9b>] btrfs_cow_block+0x10b/0x240 [btrfs] [<ffffffffa044dd5e>] btrfs_search_slot+0x49e/0x7a0 [btrfs] [<ffffffffa044f07d>] btrfs_insert_empty_items+0x8d/0xf0 [btrfs] [<ffffffffa045e973>] insert_with_overflow+0x43/0x110 [btrfs] [<ffffffffa045eb0d>] btrfs_insert_dir_item+0xcd/0x1f0 [btrfs] [<ffffffffa0489bd0>] ? map_extent_buffer+0xb0/0xc0 [btrfs] [<ffffffff812276ad>] ? rb_insert_color+0x9d/0x160 [<ffffffffa046cc40>] ? inode_tree_add+0xf0/0x150 [btrfs] [<ffffffffa0474801>] btrfs_add_link+0xc1/0x1c0 [btrfs] [<ffffffff811dacac>] ? security_inode_init_security+0x1c/0x30 [<ffffffffa04a28aa>] ? btrfs_init_acl+0x4a/0x180 [btrfs] [<ffffffffa047492f>] btrfs_add_nondir+0x2f/0x70 [btrfs] [<ffffffffa046af16>] ? btrfs_init_inode_security+0x46/0x60 [btrfs] [<ffffffffa0474ac0>] btrfs_create+0x150/0x1d0 [btrfs] [<ffffffff81159c63>] ? generic_permission+0x23/0xb0 [<ffffffff8115b415>] vfs_create+0xa5/0xc0 [<ffffffff8115ce6e>] do_last+0x5fe/0x880 [<ffffffff8115dc0d>] path_openat+0xcd/0x3d0 [<ffffffff8115e029>] do_filp_open+0x49/0xa0 [<ffffffff8116a965>] ? alloc_fd+0x95/0x160 [<ffffffff8114f0c7>] do_sys_open+0x107/0x1e0 [<ffffffff810bcc3f>] ? audit_syscall_entry+0x1bf/0x1f0 [<ffffffff8114f1e0>] sys_open+0x20/0x30 [<ffffffff81484ec2>] system_call_fastpath+0x16/0x1b [SNIP] RIP [<ffffffffa049444a>] __finish_chunk_alloc+0x20a/0x220 [btrfs] The reason is: Task1 Space balance task do_chunk_alloc() __finish_chunk_alloc() update device info in the chunk tree alloc system metadata block relocate system metadata block group set system metadata block group readonly, This block group is the only one that can allocate space. So there is no free space that can be allocated now. find no space and don't try to alloc new chunk, and then return ENOSPC BUG_ON() in __finish_chunk_alloc() was triggered. Fix this bug by allocating a new system metadata chunk before relocating the old one if we find there is no free space which can be allocated after setting the old block group to be read-only. Reported-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Tested-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-07-27Btrfs: fix enospc problems with delallocJosef Bacik
So I had this brilliant idea to use atomic counters for outstanding and reserved extents, but this turned out to be a bad idea. Consider this where we have 1 outstanding extent and 1 reserved extent Reserver Releaser atomic_dec(outstanding) now 0 atomic_read(outstanding)+1 get 1 atomic_read(reserved) get 1 don't actually reserve anything because they are the same atomic_cmpxchg(reserved, 1, 0) atomic_inc(outstanding) atomic_add(0, reserved) free reserved space for 1 extent Then the reserver now has no actual space reserved for it, and when it goes to finish the ordered IO it won't have enough space to do it's allocation and you get those lovely warnings. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-07-27Btrfs: don't flush delalloc arbitrarilyJosef Bacik
Kill the check to see if we have 512mb of reserved space in delalloc and shrink_delalloc if we do. This causes unexpected latencies and we have other logic to see if we need to throttle. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-07-27Btrfs: use a worker thread to do cachingJosef Bacik
A user reported a deadlock when copying a bunch of files. This is because they were low on memory and kthreadd got hung up trying to migrate pages for an allocation when starting the caching kthread. The page was locked by the person starting the caching kthread. To fix this we just need to use the async thread stuff so that the threads are already created and we don't have to worry about deadlocks. Thanks, Reported-by: Roman Mamedov <rm@romanrm.ru> Signed-off-by: Josef Bacik <josef@redhat.com>
2011-07-25btrfs: don't BUG_ON allocation errors in btrfs_drop_snapshotMark Fasheh
In addition to properly handling allocation failure from btrfs_alloc_path, I also fixed up the kzalloc error handling code immediately below it. Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2011-07-25btrfs: Don't BUG_ON alloc_path errors in find_next_chunkMark Fasheh
I also removed the BUG_ON from error return of find_next_chunk in init_first_rw_device(). It turns out that the only caller of init_first_rw_device() also BUGS on any nonzero return so no actual behavior change has occurred here. do_chunk_alloc() also needed an update since it calls btrfs_alloc_chunk() which can now return -ENOMEM. Instead of setting space_info->full on any error from btrfs_alloc_chunk() I catch and return every error value _except_ -ENOSPC. Thanks goes to Tsutomu Itoh for pointing that issue out. Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2011-07-14btrfs: don't BUG_ON btrfs_alloc_path() errorsMark Fasheh
This patch fixes many callers of btrfs_alloc_path() which BUG_ON allocation failure. All the sites that are fixed in this patch were checked by me to be fairly trivial to fix because of at least one of two criteria: - Callers of the function catch errors from it already so bubbling the error up will be handled. - Callers of the function might BUG_ON any nonzero return code in which case there is no behavior changed (but we still got to remove a BUG_ON) The following functions were updated: btrfs_lookup_extent, alloc_reserved_tree_block, btrfs_remove_block_group, btrfs_lookup_csums_range, btrfs_csum_file_blocks, btrfs_mark_extent_written, btrfs_inode_by_name, btrfs_new_inode, btrfs_symlink, insert_reserved_file_extent, and run_delalloc_nocow Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2011-07-11Btrfs: serialize flushers in reserve_metadata_bytesJosef Bacik
We keep having problems with early enospc, and that's because our method of making space is inherently racy. The problem is we can have one guy trying to make space for himself, and in the meantime people come in and steal his reservation. In order to stop this we make a waitqueue and put anybody who comes into reserve_metadata_bytes on that waitqueue if somebody is trying to make more space. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-07-11Btrfs: do transaction space reservation before joining the transactionJosef Bacik
We have to do weird things when handling enospc in the transaction joining code. Because we've already joined the transaction we cannot commit the transaction within the reservation code since it will deadlock, so we have to return EAGAIN and then make sure we don't retry too many times. Instead of doing this, just do the reservation the normal way before we join the transaction, that way we can do whatever we want to try and reclaim space, and then if it fails we know for sure we are out of space and we can return ENOSPC. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-06-25Btrfs: fix type mismatch in find_free_extent()Ilya Dryomov
data parameter should be u64 because a full-sized chunk flags field is passed instead of 0/1 for distinguishing data from metadata. All underlying functions expect u64. Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-06-13Btrfs: drop the delalloc_bytes check in shrink_delallocChris Mason
Even when delalloc_bytes is zero, we may need to sleep while waiting for delalloc space. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-06-08Btrfs: fix the allocator loop logicJosef Bacik
I was testing with empty_cluster = 0 to try and reproduce a problem and kept hitting early enospc panics. This was because our loop logic was a little confused. So this is what I did 1) Make the loop variable the ultimate decider on wether we should loop again isntead of checking to see if we had an uncached bg, empty size or empty cluster. 2) Increment loop before checking to see what we are on to make the loop definitions make more sense. 3) If we are on the chunk alloc loop don't set empty_size/empty_cluster to 0 unless we didn't actually allocate a chunk. If we did allocate a chunk we should be able to easily setup a new cluster so clearing empty_size/empty_cluster makes us less efficient. This kept me from hitting panics while trying to reproduce the other problem. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-06-08Btrfs: don't commit the transaction if we dont have enough pinned bytesJosef Bacik
I noticed when running an enospc test that we would get stuck committing the transaction in check_data_space even though we truly didn't have enough space. So check to see if bytes_pinned is bigger than num_bytes, if it's not don't commit the transaction. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-06-04btrfs: add helper for fs_info->closingDavid Sterba
wrap checking of filesystem 'closing' flag and fix a few missing memory barriers. Signed-off-by: David Sterba <dsterba@suse.cz>
2011-05-28Merge branch 'for-chris' ofChris Mason
git://git.kernel.org/pub/scm/linux/kernel/git/josef/btrfs-work into for-linus Conflicts: fs/btrfs/disk-io.c fs/btrfs/extent-tree.c fs/btrfs/free-space-cache.c fs/btrfs/inode.c fs/btrfs/transaction.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-23Merge branch 'cleanups_and_fixes' into inode_numbersChris Mason
Conflicts: fs/btrfs/tree-log.c fs/btrfs/volumes.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-23Btrfs: BUG_ON is deleted from the caller of btrfs_truncate_item & ↵Tsutomu Itoh
btrfs_extend_item Currently, btrfs_truncate_item and btrfs_extend_item returns only 0. So, the check by BUG_ON in the caller is unnecessary. Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-23btrfs: don't spin in shrink_delalloc if there is nothing to freeSergei Trofimovich
Observed as a large delay when --mixed filesystem is filled up. Test example: 1. create tiny --mixed FS: $ dd if=/dev/zero of=2G.img seek=$((2048 * 1024 * 1024 - 1)) count=1 bs=1 $ mkfs.btrfs --mixed 2G.img $ mount -oloop 2G.img /mnt/ut/ 2. Try to fill it up: $ dd if=/dev/urandom of=10M.file bs=10240 count=1024 $ seq 1 256 | while read file_no; do echo $file_no; time cp 10M.file ${file_no}.copy; done Up to '200.copy' it goes fast, but when disk fills-up each -ENOSPC message takes 3 seconds to pop-up _every_ ENOSPC (and in usermode linux it's even more: 30-60 seconds!). (Maybe, time depends on kernel's timer resolution). No IO, no CPU load, just rescheduling. Some debugging revealed busy spinning in shrink_delalloc. Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org> Reviewed-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-23Btrfs: don't try to allocate from a block group that doesn't have enough spaceJosef Bacik
If we have a very large filesystem, we can spend a lot of time in find_free_extent just trying to allocate from empty block groups. So instead check to see if the block group even has enough space for the allocation, and if not go on to the next block group. Signed-off-by: Josef Bacik <josef@redhat.com>
2011-05-23Btrfs: don't always do readaheadJosef Bacik
Our readahead is sort of sloppy, and really isn't always needed. For example if ls is doing a stating ls (which is the default) it's going to stat in non-disk order, so if say you have a directory with a stupid amount of files, readahead is going to do nothing but waste time in the case of doing the stat. Taking the unconditional readahead out made my test go from 57 minutes to 36 minutes. This means that everywhere we do loop through the tree we want to make sure we do set path->reada properly, so I went through and found all of the places where we loop through the path and set reada to 1. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-05-23Btrfs: try not to sleep as much when doing slow cachingJosef Bacik
When the fs is super full and we unmount the fs, we could get stuck in this thing where unmount is waiting for the caching kthread to make progress and the caching kthread keeps scheduling because we're in the middle of a commit. So instead just let the caching kthread keep going and only yeild if need_resched(). This makes my horrible umount case go from taking up to 10 minutes to taking less than 20 seconds. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-05-23Btrfs: kill BTRFS_I(inode)->block_groupJosef Bacik
Originally this was going to be used as a way to give hints to the allocator, but frankly we can get much better hints elsewhere and it's not even used at all for anything usefull. In addition to be completely useless, when we initialize an inode we try and find a freeish block group to set as the inodes block group, and with a completely full 40gb fs this takes _forever_, so I imagine with say 1tb fs this is just unbearable. So just axe the thing altoghether, we don't need it and it saves us 8 bytes in the inode and saves us 500 microseconds per inode lookup in my testcase. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-05-23Btrfs: fix how we do space reservation for truncateJosef Bacik
The ceph guys keep running into problems where we have space reserved in our orphan block rsv when freeing it up. This is because they tend to do snapshots alot, so their truncates tend to use a bunch of space, so when we go to do things like update the inode we have to steal reservation space in order to make the reservation happen. This happens because truncate can use as much space as it freaking feels like, but we still have to hold space for removing the orphan item and updating the inode, which will definitely always happen. So in order to fix this we need to split all of the reservation stuf up. So with this patch we have 1) The orphan block reserve which only holds the space for deleting our orphan item when everything is over. 2) The truncate block reserve which gets allocated and used specifically for the space that the truncate will use on a per truncate basis. 3) The transaction will always have 1 item's worth of data reserved so we can update the inode normally. Hopefully this will make the ceph problem go away. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-05-23Btrfs: kill trans_mutexJosef Bacik
We use trans_mutex for lots of things, here's a basic list 1) To serialize trans_handles joining the currently running transaction 2) To make sure that no new trans handles are started while we are committing 3) To protect the dead_roots list and the transaction lists Really the serializing trans_handles joining is not too hard, and can really get bogged down in acquiring a reference to the transaction. So replace the trans_mutex with a trans_lock spinlock and use it to do the following 1) Protect fs_info->running_transaction. All trans handles have to do is check this, and then take a reference of the transaction and keep on going. 2) Protect the fs_info->trans_list. This doesn't get used too much, basically it just holds the current transactions, which will usually just be the currently committing transaction and the currently running transaction at most. 3) Protect the dead roots list. This is only ever processed by splicing the list so this is relatively simple. 4) Protect the fs_info->reloc_ctl stuff. This is very lightweight and was using the trans_mutex before, so this is a pretty straightforward change. 5) Protect fs_info->no_trans_join. Because we don't hold the trans_lock over the entirety of the commit we need to have a way to block new people from creating a new transaction while we're doing our work. So we set no_trans_join and in join_transaction we test to see if that is set, and if it is we do a wait_on_commit. 6) Make the transaction use count atomic so we don't need to take locks to modify it when we're dropping references. 7) Add a commit_lock to the transaction to make sure multiple people trying to commit the same transaction don't race and commit at the same time. 8) Make open_ioctl_trans an atomic so we don't have to take any locks for ioctl trans. I have tested this with xfstests, but obviously it is a pretty hairy change so lots of testing is greatly appreciated. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-05-23Btrfs: take away the num_items argument from btrfs_join_transactionJosef Bacik
I keep forgetting that btrfs_join_transaction() just ignores the num_items argument, which leads me to sending pointless patches and looking stupid :). So just kill the num_items argument from btrfs_join_transaction and btrfs_start_ioctl_transaction, since neither of them use it. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-05-22Merge branch 'cleanups' of git://repo.or.cz/linux-2.6/btrfs-unstable into ↵Chris Mason
inode_numbers Conflicts: fs/btrfs/extent-tree.c fs/btrfs/free-space-cache.c fs/btrfs/inode.c fs/btrfs/tree-log.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-22Merge branch 'delayed_inode' into inode_numbersChris Mason
Conflicts: fs/btrfs/inode.c fs/btrfs/ioctl.c fs/btrfs/transaction.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-21btrfs: implement delayed inode items operationMiao Xie
Changelog V5 -> V6: - Fix oom when the memory load is high, by storing the delayed nodes into the root's radix tree, and letting btrfs inodes go. Changelog V4 -> V5: - Fix the race on adding the delayed node to the inode, which is spotted by Chris Mason. - Merge Chris Mason's incremental patch into this patch. - Fix deadlock between readdir() and memory fault, which is reported by Itaru Kitayama. Changelog V3 -> V4: - Fix nested lock, which is reported by Itaru Kitayama, by updating space cache inode in time. Changelog V2 -> V3: - Fix the race between the delayed worker and the task which does delayed items balance, which is reported by Tsutomu Itoh. - Modify the patch address David Sterba's comment. - Fix the bug of the cpu recursion spinlock, reported by Chris Mason Changelog V1 -> V2: - break up the global rb-tree, use a list to manage the delayed nodes, which is created for every directory and file, and used to manage the delayed directory name index items and the delayed inode item. - introduce a worker to deal with the delayed nodes. Compare with Ext3/4, the performance of file creation and deletion on btrfs is very poor. the reason is that btrfs must do a lot of b+ tree insertions, such as inode item, directory name item, directory name index and so on. If we can do some delayed b+ tree insertion or deletion, we can improve the performance, so we made this patch which implemented delayed directory name index insertion/deletion and delayed inode update. Implementation: - introduce a delayed root object into the filesystem, that use two lists to manage the delayed nodes which are created for every file/directory. One is used to manage all the delayed nodes that have delayed items. And the other is used to manage the delayed nodes which is waiting to be dealt with by the work thread. - Every delayed node has two rb-tree, one is used to manage the directory name index which is going to be inserted into b+ tree, and the other is used to manage the directory name index which is going to be deleted from b+ tree. - introduce a worker to deal with the delayed operation. This worker is used to deal with the works of the delayed directory name index items insertion and deletion and the delayed inode update. When the delayed items is beyond the lower limit, we create works for some delayed nodes and insert them into the work queue of the worker, and then go back. When the delayed items is beyond the upper bound, we create works for all the delayed nodes that haven't been dealt with, and insert them into the work queue of the worker, and then wait for that the untreated items is below some threshold value. - When we want to insert a directory name index into b+ tree, we just add the information into the delayed inserting rb-tree. And then we check the number of the delayed items and do delayed items balance. (The balance policy is above.) - When we want to delete a directory name index from the b+ tree, we search it in the inserting rb-tree at first. If we look it up, just drop it. If not, add the key of it into the delayed deleting rb-tree. Similar to the delayed inserting rb-tree, we also check the number of the delayed items and do delayed items balance. (The same to inserting manipulation) - When we want to update the metadata of some inode, we cached the data of the inode into the delayed node. the worker will flush it into the b+ tree after dealing with the delayed insertion and deletion. - We will move the delayed node to the tail of the list after we access the delayed node, By this way, we can cache more delayed items and merge more inode updates. - If we want to commit transaction, we will deal with all the delayed node. - the delayed node will be freed when we free the btrfs inode. - Before we log the inode items, we commit all the directory name index items and the delayed inode update. I did a quick test by the benchmark tool[1] and found we can improve the performance of file creation by ~15%, and file deletion by ~20%. Before applying this patch: Create files: Total files: 50000 Total time: 1.096108 Average time: 0.000022 Delete files: Total files: 50000 Total time: 1.510403 Average time: 0.000030 After applying this patch: Create files: Total files: 50000 Total time: 0.932899 Average time: 0.000019 Delete files: Total files: 50000 Total time: 1.215732 Average time: 0.000024 [1] http://marc.info/?l=linux-btrfs&m=128212635122920&q=p3 Many thanks for Kitayama-san's help! Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Reviewed-by: David Sterba <dave@jikos.cz> Tested-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Tested-by: Itaru Kitayama <kitayama@cl.bb4u.ne.jp> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-21Merge branch 'ino-alloc' of git://repo.or.cz/linux-btrfs-devel into ↵Chris Mason
inode_numbers Conflicts: fs/btrfs/free-space-cache.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-14Btrfs: fix easily get into ENOSPC in mixed caseliubo
When a btrfs disk is created by mixed data & metadata option, it will have no pure data or pure metadata space info. In btrfs's for-linus branch, commit 78b1ea13838039cd88afdd62519b40b344d6c920 (Btrfs: fix OOPS of empty filesystem after balance) initializes space infos at the very beginning. The problem is this initialization does not take the mixed case into account, which will cause btrfs will easily get into ENOSPC in mixed case. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-06btrfs: remove old unused commented out codeDavid Sterba
Remove code which has been #if0-ed out for a very long time and does not seem to be related to current codebase anymore. Signed-off-by: David Sterba <dsterba@suse.cz>
2011-05-02btrfs: Document a mutex lock/unlock sequenceDavid Sterba
2011-05-02btrfs: drop unused parameter from btrfs_release_pathDavid Sterba
parameter tree root it's not used since commit 5f39d397dfbe140a14edecd4e73c34ce23c4f9ee ("Btrfs: Create extent_buffer interface for large blocksizes") Signed-off-by: David Sterba <dsterba@suse.cz>
2011-05-02btrfs: drop gfp parameter from alloc_extent_mapDavid Sterba
pass GFP_NOFS directly to kmem_cache_alloc Signed-off-by: David Sterba <dsterba@suse.cz>
2011-05-02btrfs: make functions static when possibleDavid Sterba
2011-04-25Btrfs: check return value of kmalloc()Tsutomu Itoh
The check on the return value of kmalloc() is added to some places. Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-04-25Btrfs: Support reading/writing on disk free ino cacheLi Zefan
This is similar to block group caching. We dedicate a special inode in fs tree to save free ino cache. At the very first time we create/delete a file after mount, the free ino cache will be loaded from disk into memory. When the fs tree is commited, the cache will be written back to disk. To keep compatibility, we check the root generation against the generation of the special inode when loading the cache, so the loading will fail if the btrfs filesystem was mounted in an older kernel before. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
2011-04-25Btrfs: Always use 64bit inode numberLi Zefan
There's a potential problem in 32bit system when we exhaust 32bit inode numbers and start to allocate big inode numbers, because btrfs uses inode->i_ino in many places. So here we always use BTRFS_I(inode)->location.objectid, which is an u64 variable. There are 2 exceptions that BTRFS_I(inode)->location.objectid != inode->i_ino: the btree inode (0 vs 1) and empty subvol dirs (256 vs 2), and inode->i_ino will be used in those cases. Another reason to make this change is I'm going to use a special inode to save free ino cache, and the inode number must be > (u64)-256. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
