path: root/fs/btrfs/ordered-data.c
2008-09-25Btrfs: Fixes for 2.6.18 enterprise kernelsChris Mason
2.6.18 seems to get caught in an infinite loop when cancel_rearming_delayed_workqueue is called more than once, so this switches to cancel_delayed_work, which is arguably more correct. Also, balance_dirty_pages can run into problems with 2.6.18 based kernels because it doesn't have the per-bdi dirty limits. This avoids calling balance_dirty_pages on the btree inode unless there is actually something to balance, which is a good optimization in general. Finally there's a compile fix for ordered-data.h Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Btrfs: Throttle file_write when data=ordered is flushing the inodeChris Mason
2008-09-25Btrfs: Fix data=ordered vs wait_on_inode deadlock on older kernelsChris Mason
Using ilookup5 during data=ordered writeback could deadlock on I_LOCK. This saves a pointer to the inode instead. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2008-09-25Btrfs: Run igrab on data=ordered inodes to prevent deadlocks during writeoutChris Mason
2008-09-25Rework btrfs_drop_inode to avoid schedulingChris Mason
2008-09-25Btrfs: Add data=ordered supportChris Mason
This forces file data extents down the disk along with the metadata that references them. The current implementation is fairly simple, and just writes out all of the dirty pages in an inode before the commit. Signed-off-by: Chris Mason <chris.mason@oracle.com>
