path: root/fs/btrfs/relocation.c
2011-07-27Merge branch 'integration' into for-linusChris Mason
2011-07-27Btrfs: use find_or_create_page instead of grab_cache_pageJosef Bacik
grab_cache_page will use mapping_gfp_mask(), which for all inodes is set to GFP_HIGHUSER_MOVABLE. So instead use find_or_create_page in all cases where we need GFP_NOFS so we don't deadlock. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-06-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: avoid delayed metadata items during commits btrfs: fix uninitialized return value btrfs: fix wrong reservation when doing delayed inode operations btrfs: Remove unused sysfs code btrfs: fix dereference of ERR_PTR value Btrfs: fix relocation races Btrfs: set no_trans_join after trying to expand the transaction Btrfs: protect the pending_snapshots list with trans_lock Btrfs: fix path leakage on subvol deletion Btrfs: drop the delalloc_bytes check in shrink_delalloc Btrfs: check the return value from set_anon_super
2011-06-17Btrfs: fix relocation racesChris Mason
The recent commit to get rid of our trans_mutex introduced some races with block group relocation. The problem is that relocation needs to do some record keeping about each root, and it was relying on the transaction mutex to coordinate things in subtle ways. This fix adds a mutex just for the relocation code and makes sure it doesn't have a big impact on normal operations. The race is really fixed in btrfs_record_root_in_trans, which is where we step back and wait for the relocation code to finish accounting setup. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-06-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (25 commits) btrfs: fix uninitialized variable warning btrfs: add helper for fs_info->closing Btrfs: add mount -o inode_cache btrfs: scrub: add explicit plugging btrfs: use btrfs_ino to access inode number Btrfs: don't save the inode cache if we are deleting this root btrfs: false BUG_ON when degraded Btrfs: don't save the inode cache in non-FS roots Btrfs: make sure we don't overflow the free space cache crc page Btrfs: fix uninit variable in the delayed inode code btrfs: scrub: don't reuse bios and pages Btrfs: leave spinning on lookup and map the leaf Btrfs: check for duplicate entries in the free space cache Btrfs: don't try to allocate from a block group that doesn't have enough space Btrfs: don't always do readahead Btrfs: try not to sleep as much when doing slow caching Btrfs: kill BTRFS_I(inode)->block_group Btrfs: don't look at the extent buffer level 3 times in a row Btrfs: map the node block when looking for readahead targets Btrfs: set range_start to the right start in count_range_bits ...
2011-05-28Merge branch 'for-chris' ofChris Mason
git://git.kernel.org/pub/scm/linux/kernel/git/josef/btrfs-work into for-linus Conflicts: fs/btrfs/disk-io.c fs/btrfs/extent-tree.c fs/btrfs/free-space-cache.c fs/btrfs/inode.c fs/btrfs/transaction.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (58 commits) Btrfs: use the device_list_mutex during write_dev_supers Btrfs: setup free ino caching in a more asynchronous way btrfs scrub: don't coalesce pages that are logically discontiguous Btrfs: return -ENOMEM in clear_extent_bit Btrfs: add mount -o auto_defrag Btrfs: using rcu lock in the reader side of devices list Btrfs: drop unnecessary device lock Btrfs: fix the race between remove dev and alloc chunk Btrfs: fix the race between reading and updating devices Btrfs: fix bh leak on __btrfs_open_devices path Btrfs: fix unsafe usage of merge_state Btrfs: allocate extent state and check the result properly fs/btrfs: Add missing btrfs_free_path Btrfs: check return value of btrfs_inc_extent_ref() Btrfs: return error to caller if read_one_inode() fails Btrfs: BUG_ON is deleted from the caller of btrfs_truncate_item & btrfs_extend_item Btrfs: return error code to caller when btrfs_del_item fails Btrfs: return error code to caller when btrfs_previous_item fails btrfs: fix typo 'testeing' -> 'testing' btrfs: typo: 'btrfS' -> 'btrfs' ...
2011-05-23Btrfs: don't always do readaheadJosef Bacik
Our readahead is sort of sloppy, and really isn't always needed. For example if ls is doing a stating ls (which is the default) it's going to stat in non-disk order, so if say you have a directory with a stupid amount of files, readahead is going to do nothing but waste time in the case of doing the stat. Taking the unconditional readahead out made my test go from 57 minutes to 36 minutes. This means that everywhere we do loop through the tree we want to make sure we do set path->reada properly, so I went through and found all of the places where we loop through the path and set reada to 1. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-05-23Btrfs: kill trans_mutexJosef Bacik
We use trans_mutex for lots of things, here's a basic list 1) To serialize trans_handles joining the currently running transaction 2) To make sure that no new trans handles are started while we are committing 3) To protect the dead_roots list and the transaction lists Really the serializing trans_handles joining is not too hard, and can really get bogged down in acquiring a reference to the transaction. So replace the trans_mutex with a trans_lock spinlock and use it to do the following 1) Protect fs_info->running_transaction. All trans handles have to do is check this, and then take a reference of the transaction and keep on going. 2) Protect the fs_info->trans_list. This doesn't get used too much, basically it just holds the current transactions, which will usually just be the currently committing transaction and the currently running transaction at most. 3) Protect the dead roots list. This is only ever processed by splicing the list so this is relatively simple. 4) Protect the fs_info->reloc_ctl stuff. This is very lightweight and was using the trans_mutex before, so this is a pretty straightforward change. 5) Protect fs_info->no_trans_join. Because we don't hold the trans_lock over the entirety of the commit we need to have a way to block new people from creating a new transaction while we're doing our work. So we set no_trans_join and in join_transaction we test to see if that is set, and if it is we do a wait_on_commit. 6) Make the transaction use count atomic so we don't need to take locks to modify it when we're dropping references. 7) Add a commit_lock to the transaction to make sure multiple people trying to commit the same transaction don't race and commit at the same time. 8) Make open_ioctl_trans an atomic so we don't have to take any locks for ioctl trans. I have tested this with xfstests, but obviously it is a pretty hairy change so lots of testing is greatly appreciated. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-05-23Btrfs: take away the num_items argument from btrfs_join_transactionJosef Bacik
I keep forgetting that btrfs_join_transaction() just ignores the num_items argument, which leads me to sending pointless patches and looking stupid :). So just kill the num_items argument from btrfs_join_transaction and btrfs_start_ioctl_transaction, since neither of them use it. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-05-23Merge branch 'for-chris' of ↵Chris Mason
git://git.kernel.org/pub/scm/linux/kernel/git/arne/btrfs-unstable-arne into inode_numbers Conflicts: fs/btrfs/Makefile fs/btrfs/ctree.h fs/btrfs/volumes.h Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-22Merge branch 'cleanups' of git://repo.or.cz/linux-2.6/btrfs-unstable into ↵Chris Mason
inode_numbers Conflicts: fs/btrfs/extent-tree.c fs/btrfs/free-space-cache.c fs/btrfs/inode.c fs/btrfs/tree-log.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-21Merge branch 'ino-alloc' of git://repo.or.cz/linux-btrfs-devel into ↵Chris Mason
inode_numbers Conflicts: fs/btrfs/free-space-cache.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-05-12btrfs: scrubArne Jansen
This adds an initial implementation for scrub. It works quite straightforward. The usermode issues an ioctl for each device in the fs. For each device, it enumerates the allocated device chunks. For each chunk, the contained extents are enumerated and the data checksums fetched. The extents are read sequentially and the checksums verified. If an error occurs (checksum or EIO), a good copy is searched for. If one is found, the bad copy will be rewritten. All enumerations happen from the commit roots. During a transaction commit, the scrubs get paused and afterwards continue from the new roots. This commit is based on the series originally posted to linux-btrfs with some improvements that resulted from comments from David Sterba, Ilya Dryomov and Jan Schmidt. Signed-off-by: Arne Jansen <sensille@gmx.net>
2011-05-10treewide: fix a few typos in commentsJustin P. Mattock
- kenrel -> kernel - whetehr -> whether - ttt -> tt - sss -> ss Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-06btrfs: remove all unused functionsDavid Sterba
Remove static and global declarations and/or definitions. Reduces size of btrfs.ko by ~3.4kB. text data bss dec hex filename 402081 7464 200 409745 64091 btrfs.ko.base 398620 7144 200 405964 631cc btrfs.ko.remove-all Signed-off-by: David Sterba <dsterba@suse.cz>
2011-05-02btrfs: drop unused parameter from btrfs_release_pathDavid Sterba
parameter tree root it's not used since commit 5f39d397dfbe140a14edecd4e73c34ce23c4f9ee ("Btrfs: Create extent_buffer interface for large blocksizes") Signed-off-by: David Sterba <dsterba@suse.cz>
2011-05-02btrfs: drop gfp parameter from alloc_extent_mapDavid Sterba
pass GFP_NOFS directly to kmem_cache_alloc Signed-off-by: David Sterba <dsterba@suse.cz>
2011-05-02btrfs: drop unused argument from extent_io_tree_initDavid Sterba
all callers pass GFP_NOFS, but the GFP mask argument is not used in the function; GFP_ATOMIC is passed to radix tree initialization and it's the only correct one, since we're using the preload/insert mechanism of radix tree. Let's drop the gfp mask from btrfs function, this will not change behaviour. Signed-off-by: David Sterba <dsterba@suse.cz>
2011-05-02btrfs: unify checking of IS_ERR and nullDavid Sterba
use IS_ERR_OR_NULL when possible, done by this coccinelle script: @ match @ identifier id; @@ ( - BUG_ON(IS_ERR(id) || !id); + BUG_ON(IS_ERR_OR_NULL(id)); | - IS_ERR(id) || !id + IS_ERR_OR_NULL(id) | - !id || IS_ERR(id) + IS_ERR_OR_NULL(id) ) Signed-off-by: David Sterba <dsterba@suse.cz>
2011-04-25Btrfs: Always use 64bit inode numberLi Zefan
There's a potential problem in 32bit system when we exhaust 32bit inode numbers and start to allocate big inode numbers, because btrfs uses inode->i_ino in many places. So here we always use BTRFS_I(inode)->location.objectid, which is an u64 variable. There are 2 exceptions that BTRFS_I(inode)->location.objectid != inode->i_ino: the btree inode (0 vs 1) and empty subvol dirs (256 vs 2), and inode->i_ino will be used in those cases. Another reason to make this change is I'm going to use a special inode to save free ino cache, and the inode number must be > (u64)-256. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
2011-04-25Btrfs: Cache free inode numbers in memoryLi Zefan
Currently btrfs stores the highest objectid of the fs tree, and it always returns (highest+1) inode number when we create a file, so inode numbers won't be reclaimed when we delete files, so we'll run out of inode numbers as we keep create/delete files in 32bits machines. This fixes it, and it works similarly to how we cache free space in block cgroups. We start a kernel thread to read the file tree. By scanning inode items, we know which chunks of inode numbers are free, and we cache them in an rb-tree. Because we are searching the commit root, we have to carefully handle the cross-transaction case. The rb-tree is a hybrid extent+bitmap tree, so if we have too many small chunks of inode numbers, we'll use bitmaps. Initially we allow 16K ram of extents, and a bitmap will be used if we exceed this threshold. The extents threshold is adjusted in runtime. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
2011-03-28Btrfs: check return value of read_tree_block()Tsutomu Itoh
This patch is checking return value of read_tree_block(), and if it is NULL, error processing. Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-03-17Btrfs: handle errors in btrfs_orphan_cleanupJosef Bacik
If we cannot truncate an inode for some reason we will never delete the orphan item associated with that inode, which means that we will loop forever in btrfs_orphan_cleanup. Instead of doing this just return error so we fail to mount. It sucks, but hey it's better than hanging. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-02-16Btrfs: allow balance to explicitly allocate chunks as it relocatesChris Mason
Btrfs device shrinking and balancing ends up reallocating all the blocks in order to allow COW to move them to new destinations. It is somewhat awkward in terms of ENOSPC because most of the enospc code is built around the idea that some operation on a reference counted tree triggers allocations in the non-reference counted trees. This commit changes the balancing code to deal with enospc by trying to allocate a new chunk. If that allocation succeeds, we go ahead and retry whatever failed due to enospc. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-02-14Btrfs: Fix balance panicYan, Zheng
Mark the cloned backref_node as checked in clone_backref_node() Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-02-01btrfs: fix return value check of btrfs_start_transaction()Tsutomu Itoh
The error check of btrfs_start_transaction() is added, and the mistake of the error check on several places is corrected. Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-01-28btrfs: fix return value check of btrfs_join_transaction()Tsutomu Itoh
The error check of btrfs_join_transaction()/btrfs_join_transaction_nolock() is added, and the mistake of the error check in several places is corrected. For more stable Btrfs, I think that we should reduce BUG_ON(). But, I think that long time is necessary for this. So, I propose this patch as a short-term solution. With this patch: - To more stable Btrfs, the part that should be corrected is clarified. - The panic isn't done by the NULL pointer reference etc. (even if BUG_ON() is increased temporarily) - The error code is returned in the place where the error can be easily returned. As a long-term plan: - BUG_ON() is reduced by using the forced-readonly framework, etc. Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-10-29Btrfs: Fix variables set but not read (bugs found by gcc 4.6)Andi Kleen
These are all the cases where a variable is set, but not read which are really bugs. - Couple of incorrect error handling fixed. - One incorrect use of a allocation policy - Some other things Still needs more review. Found by gcc 4.6's new warnings. [akpm@linux-foundation.org: fix build. Might have been bitrot] Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-10-29Merge branch 'bug-fixes' of ↵Chris Mason
git://git.kernel.org/pub/scm/linux/kernel/git/josef/btrfs-work Conflicts: fs/btrfs/extent-tree.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-10-28Btrfs: create special free space cache inodeJosef Bacik
In order to save free space cache, we need an inode to hold the data, and we need a special item to point at the right inode for the right block group. So first, create a special item that will point to the right inode, and the number of extent entries we will have and the number of bitmaps we will have. We truncate and pre-allocate space everytime to make sure it's uptodate. This feature will be turned on as soon as you mount with -o space_cache, however it is safe to boot into old kernels, they will just generate the cache the old fashion way. When you boot back into a newer kernel we will notice that we modified and not the cache and automatically discard the cache. Signed-off-by: Josef Bacik <josef@redhat.com>
2010-10-22Btrfs: rework how we reserve metadata bytesJosef Bacik
With multi-threaded writes we were getting ENOSPC early because somebody would come in, start flushing delalloc because they couldn't make their reservation, and in the meantime other threads would come in and use the space that was getting freed up, so when the original thread went to check to see if they had space they didn't and they'd return ENOSPC. So instead if we have some free space but not enough for our reservation, take the reservation and then start doing the flushing. The only time we don't take reservations is when we've already overcommitted our space, that way we don't have people who come late to the party way overcommitting ourselves. This also moves all of the retrying and flushing code into reserve_metdata_bytes so it's all uniform. This keeps my fs_mark test from returning -ENOSPC as soon as it starts and actually lets me fill up the disk. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2010-06-11Btrfs: Fix null dereference in relocation.cYan, Zheng
Fix a potential null dereference in relocation.c Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Acked-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-05-25Btrfs: Metadata ENOSPC handling for balanceYan, Zheng
This patch adds metadata ENOSPC handling for the balance code. It is consisted by following major changes: 1. Avoid COW tree leave in the phrase of merging tree. 2. Handle interaction with snapshot creation. 3. make the backref cache can live across transactions. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-05-25Btrfs: Pre-allocate space for data relocationYan, Zheng
Pre-allocate space for data relocation. This can detect ENOPSC condition caused by fragmentation of free space. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-05-25Btrfs: Integrate metadata reservation with start_transactionYan, Zheng
Besides simplify the code, this change makes sure all metadata reservation for normal metadata operations are released after committing transaction. Changes since V1: Add code that check if unlink and rmdir will free space. Add ENOSPC handling for clone ioctl. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-05-25Btrfs: Introduce contexts for metadata reservationYan, Zheng
Introducing metadata reseravtion contexts has two major advantages. First, it makes metadata reseravtion more traceable. Second, it can reclaim freed space and re-add them to the itself after transaction committed. Besides add btrfs_block_rsv structure and related helper functions, This patch contains following changes: Move code that decides if freed tree block should be pinned into btrfs_free_tree_block(). Make space accounting more accurate, mainly for handling read only block groups. Signed-off-by: Chris Mason <chris.mason@oracle.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-15Btrfs: cache the extent state everywhere we possibly can V2Josef Bacik
This patch just goes through and fixes everybody that does lock_extent() blah unlock_extent() to use lock_extent_bits() blah unlock_extent_cached() and pass around a extent_state so we only have to do the searches once per function. This gives me about a 3 mb/s boots on my random write test. I have not converted some things, like the relocation and ioctl's, since they aren't heavily used and the relocation stuff is in the middle of being re-written. I also changed the clear_extent_bit() to only unset the cached state if we are clearing EXTENT_LOCKED and related stuff, so we can do things like this lock_extent_bits() clear delalloc bits unlock_extent_cached() without losing our cached state. I tested this thoroughly and turned on LEAK_DEBUG to make sure we weren't leaking extent states, everything worked out fine. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: change how we mount subvolumesJosef Bacik
This work is in preperation for being able to set a different root as the default mounting root. There is currently a problem with how we mount subvolumes. We cannot currently mount a subvolume of a subvolume, you can only mount subvolumes/snapshots of the default subvolume. So say you take a snapshot of the default subvolume and call it snap1, and then take a snapshot of snap1 and call it snap2, so now you have / /snap1 /snap1/snap2 as your available volumes. Currently you can only mount / and /snap1, you cannot mount /snap1/snap2. To fix this problem instead of passing subvolid=<name> you must pass in subvolid=<treeid>, where <treeid> is the tree id that gets spit out via the subvolume listing you get from the subvolume listing patches (btrfs filesystem list). This allows us to mount /, /snap1 and /snap1/snap2 as the root volume. In addition to the above, we also now read the default dir item in the tree root to get the root key that it points to. For now this just points at what has always been the default subvolme, but later on I plan to change it to point at whatever root you want to be the new default root, so you can just set the default mount and not have to mount with -o subvolid=<treeid>. I tested this out with the above scenario and it worked perfectly. Thanks, mount -o subvol operates inside the selected subvolid. For example: mount -o subvol=snap1,subvolid=256 /dev/xxx /mnt /mnt will have the snap1 directory for the subvolume with id 256. mount -o subvol=snap /dev/xxx /mnt /mnt will be the snap directory of whatever the default subvolume is. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-08Btrfs: use RB_ROOT to intialize rb_trees instead of setting rb_node to NULLEric Paris
btrfs inialize rb trees in quite a number of places by settin rb_node = NULL; The problem with this is that 17d9ddc72fb8bba0d4f678 in the linux-next tree adds a new field to that struct which needs to be NULL for the new rbtree library code to work properly. This patch uses RB_ROOT as the intializer so all of the relevant fields will be NULL'd. Without the patch I get a panic. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-02-04Btrfs: remove BUG_ON() due to mounting bad filesystemMiao Xie
Mounting a bad filesystem caused a BUG_ON(). The following is steps to reproduce it. # mkfs.btrfs /dev/sda2 # mount /dev/sda2 /mnt # mkfs.btrfs /dev/sda1 /dev/sda2 (the program says that /dev/sda2 was mounted, and then exits. ) # umount /mnt # mount /dev/sda1 /mnt At the third step, mkfs.btrfs exited in the way of make filesystem. So the initialization of the filesystem didn't finish. So the filesystem was bad, and it caused BUG_ON() when mounting it. But BUG_ON() should be called by the wrong code, not user's operation, so I think it is a bug of btrfs. This patch fixes it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-17Btrfs, fix memory leaks in error pathsJiri Slaby
Stanse found 2 memory leaks in relocate_block_group and __btrfs_map_block. cluster and multi are not freed/assigned on all paths. Fix that. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: linux-btrfs@vger.kernel.org Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-12-17Btrfs: Add delayed iputYan, Zheng
iput() can trigger new transactions if we are dropping the final reference, so calling it in btrfs_commit_transaction may end up deadlock. This patch adds delayed iput to avoid the issue. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-12-17Btrfs: Make truncate(2) more ENOSPC friendlyYan, Zheng
truncating and deleting regular files are unbound operations, so it's not good to do them in a single transaction. This patch makes btrfs_truncate and btrfs_delete_inode start a new transaction after all items in a tree leaf are deleted. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-12-17Btrfs: Avoid orphan inodes cleanup while replaying logYan, Zheng
We do log replay in a single transaction, so it's not good to do unbound operations. This patch cleans up orphan inodes cleanup after replaying the log. It also avoids doing other unbound operations such as truncating a file during replaying log. These unbound operations are postponed to the orphan inode cleanup stage. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-05Btrfs: fix deadlock on async thread startupChris Mason
The btrfs async worker threads are used for a wide variety of things, including processing bio end_io functions. This means that when the endio threads aren't running, the rest of the FS isn't able to do the final processing required to clear PageWriteback. The endio threads also try to exit as they become idle and start more as the work piles up. The problem is that starting more threads means kthreadd may need to allocate ram, and that allocation may wait until the global number of writeback pages on the system is below a certain limit. The result of that throttling is that end IO threads wait on kthreadd, who is waiting on IO to end, which will never happen. This commit fixes the deadlock by handing off thread startup to a dedicated thread. It also fixes a bug where the on-demand thread creation was creating far too many threads because it didn't take into account threads being started by other procs. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-09-24Btrfs: relocate file extents in clustersYan, Zheng
The extent relocation code copy file extents one by one when relocating data block group. This is inefficient if file extents are small. This patch makes the relocation code copy file extents in clusters. So we can can make better use of read-ahead. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-09-21Btrfs: add snapshot/subvolume destroy ioctlYan, Zheng
This patch adds snapshot/subvolume destroy ioctl. A subvolume that isn't being used and doesn't contains links to other subvolumes can be destroyed. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
