git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (33 commits)
AppArmor: kill unused macros in lsm.c
AppArmor: cleanup generated files correctly
KEYS: Add an iovec version of KEYCTL_INSTANTIATE
KEYS: Add a new keyctl op to reject a key with a specified error code
KEYS: Add a key type op to permit the key description to be vetted
KEYS: Add an RCU payload dereference macro
AppArmor: Cleanup make file to remove cruft and make it easier to read
SELinux: implement the new sb_remount LSM hook
LSM: Pass -o remount options to the LSM
SELinux: Compute SID for the newly created socket
SELinux: Socket retains creator role and MLS attribute
SELinux: Auto-generate security_is_socket_class
TOMOYO: Fix memory leak upon file open.
Revert "selinux: simplify ioctl checking"
selinux: drop unused packet flow permissions
selinux: Fix packet forwarding checks on postrouting
selinux: Fix wrong checks for selinux_policycap_netpeer
selinux: Fix check for xfrm selinux context algorithm
ima: remove unnecessary call to ima_must_measure
IMA: remove IMA imbalance checking
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (57 commits)
tidy the trailing symlinks traversal up
Turn resolution of trailing symlinks iterative everywhere
simplify link_path_walk() tail
Make trailing symlink resolution in path_lookupat() iterative
update nd->inode in __do_follow_link() instead of after do_follow_link()
pull handling of one pathname component into a helper
fs: allow AT_EMPTY_PATH in linkat(), limit that to CAP_DAC_READ_SEARCH
Allow passing O_PATH descriptors via SCM_RIGHTS datagrams
readlinkat(), fchownat() and fstatat() with empty relative pathnames
Allow O_PATH for symlinks
New kind of open files - "location only".
ext4: Copy fs UUID to superblock
ext3: Copy fs UUID to superblock.
vfs: Export file system uuid via /proc/<pid>/mountinfo
unistd.h: Add new syscalls numbers to asm-generic
x86: Add new syscalls for x86_64
x86: Add new syscalls for x86_32
fs: Remove i_nlink check from file system link callback
fs: Don't allow to create hardlink for deleted file
vfs: Add open by file handle support
Now that VFS check for inode->i_nlink == 0 and returns proper
error, remove similar check from file system
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
The exportfs encode handle function should return the minimum required
handle size. This helps user to find out the handle size by passing 0
handle size in the first step and then redoing to the call again with
the returned handle size value.
Acked-by: Serge Hallyn <serue@us.ibm.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable:
Btrfs: break out of shrink_delalloc earlier
btrfs: fix not enough reserved space
btrfs: fix dip leak
Btrfs: make sure not to return overlapping extents to fiemap
Btrfs: deal with short returns from copy_from_user
Btrfs: fix regressions in copy_from_user handling
Josef had changed shrink_delalloc to exit after three shrink
attempts, which wasn't quite enough because new writers could
race in and steal free space.
But it also fixed deadlocks and stalls as we tried to recover
delalloc reservations. The code was tweaked to loop 1024
times, and would reset the counter any time a small amount
of progress was made. This was too drastic, and with a
lot of writers we can end up stuck in shrink_delalloc forever.
The shrink_delalloc loop is fairly complex because the caller is looping
too, and the caller will go ahead and force a transaction commit to make
sure we reclaim space.
This reworks things to exit shrink_delalloc when we've forced some
writeback and the delalloc reservations have gone down. This means
the writeback has not just started but has also finished at
least some of the metadata changes required to reclaim delalloc
space.
If we've got this wrong, we're returning ENOSPC too early, which
is a big improvement over the current behavior of hanging the machine.
Test 224 in xfstests hammers on this nicely, and with 1000 writers
trying to fill a 1GB drive we get our first ENOSPC at 93% full. The
other writers are able to continue until we get 100%.
This is a worst case test for btrfs because the 1000 writers are doing
small IO, and the small FS size means we don't have a lot of room
for metadata chunks.
Signed-off-by: Chris Mason <chris.mason@oracle.com>
btrfs_link() will insert 3 items(inode ref, dir name item and dir index item)
into the b+ tree and update 2 items(its inode, and parent's inode) in the b+
tree. So we should reserve space for these 5 items, not 3 items.
Reported-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com>
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
The btrfs DIO code leaks dip structs when dip->csums allocation
fails; bio->bi_end_io isn't set at the point where the free_ordered
branch is consequently taken, thus bio_endio doesn't call the function
which would free it in the normal case. Fix.
Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com>
Acked-by: Miao Xie <miaox@cn.fujitsu.com>
The btrfs fiemap code was incorrectly returning duplicate or overlapping
extents in some cases. cp was blindly trusting this result and we would
end up with a destination file that was bigger than the original because
some bytes were copied twice.
The fix here adjusts our offsets to make sure we're always moving
forward in the fiemap results.
When copy_from_user is only able to copy some of the bytes we requested,
we may end up creating a partially up to date page. To avoid garbage in
the page, we need to treat a partial copy as a zero length copy.
This makes the rest of the file_write code drop the page and
retry the whole copy instead of marking the partially up to
date page as dirty.
cc: stable@kernel.org
Commit 914ee295af418e936ec20a08c1663eaabe4cd07a fixed deadlocks in
btrfs_file_write where we would catch page faults on pages we had
locked.
But, there were a few problems:
1) The x86-32 iov_iter_copy_from_user_atomic code always fails to copy
data when the amount to copy is more than 4K and the offset to start
copying from is not page aligned. The result was btrfs_file_write
looping forever retrying the iov_iter_copy_from_user_atomic
We deal with this by changing btrfs_file_write to drop down to single
page copies when iov_iter_copy_from_user_atomic starts returning failure.
2) The btrfs_file_write code was leaking delalloc reservations when
iov_iter_copy_from_user_atomic returned zero. The looping above would
result in the entire filesystem running out of delalloc reservations and
constantly trying to flush things to disk.
3) btrfs_file_write will lock down page cache pages, make sure
any writeback is finished, do the copy_from_user and then release them.
Before the loop runs we check the first and last pages in the write to
see if they are only being partially modified. If the start or end of
the write isn't aligned, we make sure the corresponding pages are
up to date so that we don't introduce garbage into the file.
With the copy_from_user changes, we're allowing the VM to reclaim the
pages after a partial update from copy_from_user, but we're not
making sure the page cache page is up to date when we loop around to
resume the write.
We deal with this by pushing the up to date checks down into the page
prep code. This fits better with how the rest of file_write works.
Reported-by: Mitch Harder <mitch.harder@sabayonlinux.org>
Btrfs: fix fiemap bugs with delalloc
Btrfs: set FMODE_EXCL in btrfs_device->mode
Btrfs: make btrfs_rm_device() fail gracefully
Btrfs: Avoid accessing unmapped kernel address
Btrfs: Fix BTRFS_IOC_SUBVOL_SETFLAGS ioctl
Btrfs: allow balance to explicitly allocate chunks as it relocates
Btrfs: put ENOSPC debugging under a mount option
The Btrfs fiemap code wasn't properly returning delalloc extents,
so applications that trust fiemap to decide if there are holes in the
file see holes instead of delalloc.
This reworks the btrfs fiemap code, adding a get_extent helper that
searches for delalloc ranges and also adding a helper for extent_fiemap
that skips past holes in the file.
This fixes a bug introduced in d4d77629, where the device added online
(and therefore initialized via btrfs_init_new_device()) would be left
with the positive bdev->bd_holders after unmount. Since d4d77629 we no
longer OR FMODE_EXCL explicitly on blkdev_put(), set it in
btrfs_device->mode.
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
If shrinking done as part of the online device removal fails add that
device back to the allocation list and increment the rw_devices counter.
This fixes two bugs:
1) we could have a perfectly good device out of alloc list for no good
reason;
2) in the btrfs consisting of two devices, failure in btrfs_rm_device()
could lead to a situation where it was impossible to remove any of the
devices because of the "unable to remove the only writeable device"
error.
When decompressing a chunk of data, we'll copy the data out to
a working buffer if the data is stored in more than one page,
otherwise we'll use the mapped page directly to avoid memory
copy.
In the latter case, we'll end up accessing the kernel address
after we've unmapped the page in a corner case.
Reported-by: Juan Francisco Cantero Hurtado <iam@juanfra.info>
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
- Check user-specified flags correctly
- Check the inode owership
- Search root item in root tree but not fs tree
Reported-by: Dan Rosenberg <drosenberg@vsecurity.com>
Btrfs device shrinking and balancing ends up reallocating all the blocks
in order to allow COW to move them to new destinations. It is somewhat
awkward in terms of ENOSPC because most of the enospc code is built
around the idea that some operation on a reference counted tree triggers
allocations in the non-reference counted trees.
This commit changes the balancing code to deal with enospc by trying to
allocate a new chunk. If that allocation succeeds, we go ahead and
retry whatever failed due to enospc.
ENOSPC in btrfs is getting to the point where the extra debugging isn't
required. I've put it under mount -o enospc_debug just in case someone
is having difficult problems.
Btrfs: check return value of alloc_extent_map()
Btrfs - Fix memory leak in btrfs_init_new_device()
btrfs: prevent heap corruption in btrfs_ioctl_space_info()
Btrfs: Fix balance panic
Btrfs: don't release pages when we can't clear the uptodate bits
Btrfs: fix page->private races
I add the check on the return value of alloc_extent_map() to several places.
In addition, alloc_extent_map() returns only the address or NULL.
Therefore, check by IS_ERR() is unnecessary. So, I remove IS_ERR() checking.
Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com>
Memory allocated by calling kstrdup() should be freed.
Commit bf5fc093c5b625e4259203f1cee7ca73488a5620 refactored
btrfs_ioctl_space_info() and introduced several security issues.
space_args.space_slots is an unsigned 64-bit type controlled by a
possibly unprivileged caller. The comparison as a signed int type
allows providing values that are treated as negative and cause the
subsequent allocation size calculation to wrap, or be truncated to 0.
By providing a size that's truncated to 0, kmalloc() will return
ZERO_SIZE_PTR. It's also possible to provide a value smaller than the
slot count. The subsequent loop ignores the allocation size when
copying data in, resulting in a heap overflow or write to ZERO_SIZE_PTR.
The fix changes the slot count type and comparison typecast to u64,
which prevents truncation or signedness errors, and also ensures that we
don't copy more data than we've allocated in the subsequent loop. Note
that zero-size allocations are no longer possible since there is already
an explicit check for space_args.space_slots being 0 and truncation of
this value is no longer an issue.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Signed-off-by: Josef Bacik <josef@redhat.com>
Reviewed-by: Josef Bacik <josef@redhat.com>
Mark the cloned backref_node as checked in clone_backref_node()
Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
Btrfs tracks uptodate state in an rbtree as well as in the
page bits. This is supposed to enable us to use block sizes other than
the page size, but there are a few parts still missing before that
completely works.
But, our readpage routine trusts this additional range based tracking
of uptodateness, much in the same way the buffer head up to date bits
are trusted for the other filesystems.
The problem is that sometimes we need to allocate memory in order to
split records in the rbtree, even when we are just clearing bits. This
can be difficult when our clearing function is called GFP_ATOMIC, which
can happen in the releasepage path.
So, what happens today looks like this:
releasepage called with GFP_ATOMIC
btrfs_releasepage calls clear_extent_bit
clear_extent_bit fails to allocate ram, leaving the up to date bit set
btrfs_releasepage returns success
The end result is the page being gone, but btrfs thinking the range is
up to date. Later on if someone tries to read that same page, the
btrfs readpage code will return immediately thinking the page is already
up to date.
This commit fixes things to fail the releasepage when we can't clear the
extent state bits. It covers both data pages and metadata tree blocks.
There is a race where btrfs_releasepage can drop the
page->private contents just as alloc_extent_buffer is setting
up pages for metadata. Because of how the Btrfs page flags work,
this results in us skipping the crc on the page during IO.
This patch sovles the race by waiting until after the extent buffer
is inserted into the radix tree before it sets page private.
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (33 commits)
Btrfs: Fix page count calculation
btrfs: Drop __exit attribute on btrfs_exit_compress
btrfs: cleanup error handling in btrfs_unlink_inode()
Btrfs: exclude super blocks when we read in block groups
Btrfs: make sure search_bitmap finds something in remove_from_bitmap
btrfs: fix return value check of btrfs_start_transaction()
btrfs: checking NULL or not in some functions
Btrfs: avoid uninit variable warnings in ordered-data.c
Btrfs: catch errors from btrfs_sync_log
Btrfs: make shrink_delalloc a little friendlier
Btrfs: handle no memory properly in prepare_pages
Btrfs: do error checking in btrfs_del_csums
Btrfs: use the global block reserve if we cannot reserve space
Btrfs: do not release more reserved bytes to the global_block_rsv than we need
Btrfs: fix check_path_shared so it returns the right value
btrfs: check return value of btrfs_start_ioctl_transaction() properly
btrfs: fix return value check of btrfs_join_transaction()
fs/btrfs/inode.c: Add missing IS_ERR test
btrfs: fix missing break in switch phrase
btrfs: fix several uncheck memory allocations
take offset of start position into account when calculating page count.
As this function is called in some error paths while not
removing the module, the __exit attribute prevents the kernel
image from linking when btrfs is compiled in statically.
Signed-off-by: Alexey Charkov <alchark@gmail.com>
When btrfs_alloc_path() fails, btrfs_free_path() need not be called.
Therefore, it changes the branch ahead.
This has been resulting in a BUT_ON(ret) after btrfs_reserve_extent in
btrfs_cow_file_range. The reason is we don't actually calculate the bytes_super
for a block group until we go to cache it, which means that the space_info can
hand out reservations for space that it doesn't actually have, and we can run
out of data space. This is also a problem if you are using space caching since
we don't ever calculate bytes_super for the block groups. So instead everytime
we read a block group call exclude_super_stripes, which calculates the
bytes_super for the block group so it can be left out of the space_info. Then
whenever caching completes we just call free_excluded_extents so that the super
excluded extents are freed up. Also if we are unmounting and we hit any block
groups that haven't been cached we still need to call free_excluded_extents to
make sure things are cleaned up properly. Thanks,
Reported-by: Arne Jansen <sensille@gmx.net>
When we're cleaning up the tree log we need to be able to remove free space from
the block group. The problem is if that free space spans bitmaps we would not
find the space since we're looking for too many bytes. So make sure the amount
of bytes we search for is limited to either the number of bytes we want, or the
number of bytes left in the bitmap. This was tested by a user who was hitting
the BUG() after search_bitmap. With this patch he can now mount his fs.
Thanks,
SELinux would like to implement a new labeling behavior of newly created
inodes. We currently label new inodes based on the parent and the creating
process. This new behavior would also take into account the name of the
new object when deciding the new label. This is not the (supposed) full path,
just the last component of the path.
This is very useful because creating /etc/shadow is different than creating
/etc/passwd but the kernel hooks are unable to differentiate these
operations. We currently require that userspace realize it is doing some
difficult operation like that and than userspace jumps through SELinux hoops
to get things set up correctly. This patch does not implement new
behavior, that is obviously contained in a seperate SELinux patch, but it
does pass the needed name down to the correct LSM hook. If no such name
exists it is fine to pass NULL.
Signed-off-by: Eric Paris <eparis@redhat.com>
The error check of btrfs_start_transaction() is added, and the mistake
of the error check on several places is corrected.
Because NULL is returned when the memory allocation fails,
it is checked whether it is NULL.
This one isn't really an uninit variable, but for pretty
obscure reasons. Let's make it clearly correct.
btrfs_sync_log returns -EAGAIN when we need full transaction commits
instead of small log commits, but sometimes we were dropping the return
value.
In practice, we check for this a few different ways, but this is still a
bug that can leave off full log commits when we really need them.
Xfstests 224 will just sit there and spin for ever until eventually we give up
flushing delalloc and exit. On my box this took several hours. I could not
interrupt this process either, even though we use INTERRUPTIBLE. So do 2 things
1) Keep us from looping over and over again without reclaiming anything
2) If we get interrupted exit the loop
I tested this and the test now exits in a reasonable amount of time, and can be
interrupted with ctrl+c. Thanks,
Instead of doing a BUG_ON(1) in prepare_pages if grab_cache_page() fails, just
loop through the pages we've already grabbed and unlock and release them, then
return -ENOMEM like we should. Thanks,
Got a report of a box panicing because we got a NULL eb in read_extent_buffer.
His fs was borked and btrfs_search_path returned EIO, but we don't check for
errors so the box paniced. Yes I know this will just make something higher up
the stack panic, but that's a problem for future Josef. Thanks,
We call use_block_rsv right before we make an allocation in order to make sure
we have enough space. Now normally people have called btrfs_start_transaction()
with the appropriate amount of space that we need, so we just use some of that
pre-reserved space and move along happily. The problem is where people use
btrfs_join_transaction(), which doesn't actually reserve any space. So we try
and reserve space here, but we cannot flush delalloc, so this forces us to
return -ENOSPC when in reality we have plenty of space. The most common symptom
is seeing a bunch of "couldn't dirty inode" messages in syslog. With
xfstests 224 we end up falling back to start_transaction and then doing all the
flush delalloc stuff which causes to hang for a very long time.
So instead steal from the global reserve, which is what this is meant for
anyway. With this patch and the other 2 I have sent xfstests 224 now passes
successfully. Thanks,
When we do btrfs_block_rsv_release, if global_block_rsv is not full we will
release all the extra bytes to global_block_rsv, even if it's only a little
short of the amount of space that we need to reserve. This causes us to starve
ourselves of reservable space during the transaction which will force us to
shrink delalloc bytes and commit the transaction more often than we should. So
instead just add the amount of bytes we need to add to the global reserve so
reserved == size, and then add the rest back into the space_info for general
use. Thanks,
When running xfstests 224 I kept getting ENOSPC when trying to remove the files,
and this is because we were returning ret from check_path_shared while it was
uninitalized, which isn't right. Fix this to return 0 properly, and now
xfstests 224 doesn't freak out when it tries to clean itself up. Thanks,
btrfs_start_ioctl_transaction() returns ERR_PTR(), not NULL.
So, it is necessary to use IS_ERR() to check the return value.
The error check of btrfs_join_transaction()/btrfs_join_transaction_nolock()
is added, and the mistake of the error check in several places is
corrected.
For more stable Btrfs, I think that we should reduce BUG_ON().
But, I think that long time is necessary for this.
So, I propose this patch as a short-term solution.
With this patch:
- To more stable Btrfs, the part that should be corrected is clarified.
- The panic isn't done by the NULL pointer reference etc. (even if
BUG_ON() is increased temporarily)
- The error code is returned in the place where the error can be easily
returned.
As a long-term plan:
- BUG_ON() is reduced by using the forced-readonly framework, etc.
After the conditional that precedes the following code, inode may be an
ERR_PTR value. This can eg result from a memory allocation failure via the
call to btrfs_iget, and thus does not imply that root is different than
sub_root. Thus, an IS_ERR check is added to ensure that there is no
dereference of inode in this case.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r@
identifier f;
f(...) { ... return ERR_PTR(...); }
identifier r.f, fld;
expression x;
statement S1,S2;
x = f(...)
... when != IS_ERR(x)
if (IS_ERR(x) ||...) S1 else S2
*x->fld
// </smpl>
There is a missing break in switch, fix it.
Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com>
To make btrfs more stable, add several missing necessary memory allocation
checks, and when no memory, return proper errno.
We've checked that some of those -ENOMEM errors will be returned to
userspace, and some will be catched by BUG_ON() in the upper callers,
and none will be ignored silently.
