path: root/fs/buffer.c
2011-06-16vfs: Fix data corruption after failed write in __block_write_begin()Jan Kara
I've got a report of a file corruption from fsxlinux on ext3. The important operations to the page were: mapwrite to a hole partial write to the page read - found the page zeroed from the end of the normal write The culprit seems to be that if get_block() fails in __block_write_begin() (e.g. transient ENOSPC in ext3), the function does ClearPageUptodate(page). Thus when we retry the write, the logic in __block_write_begin() thinks zeroing of the page is needed and overwrites old data. In fact, I don't see why we should ever need to zero the uptodate bit here - either the page was uptodate when we entered __block_write_begin() and it should stay so when we leave it, or it was not uptodate and noone had right to set it uptodate during __block_write_begin() so it remains !uptodate when we leave as well. So just remove clearing of the bit. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-28fs: block_page_mkwrite should wait for writeback to finishDarrick J. Wong
For filesystems such as nilfs2 and xfs that use block_page_mkwrite, modify that function to wait for pending writeback before allowing the page to become writable. This is needed to stabilize pages during writeback for those two filesystems. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem: xen: cleancache shim to Xen Transcendent Memory ocfs2: add cleancache support ext4: add cleancache support btrfs: add cleancache support ext3: add cleancache support mm/fs: add hooks to support cleancache mm: cleancache core ops functions and config fs: add field to superblock to support cleancache mm/fs: cleancache documentation Fix up trivial conflict in fs/btrfs/extent_io.c due to includes
2011-05-26mm/fs: add hooks to support cleancacheDan Magenheimer
This fourth patch of eight in this cleancache series provides the core hooks in VFS for: initializing cleancache per filesystem; capturing clean pages reclaimed by page cache; attempting to get pages from cleancache before filesystem read; and ensuring coherency between pagecache, disk, and cleancache. Note that the placement of these hooks was stable from 2.6.18 to 2.6.38; a minor semantic change was required due to a patchset in 2.6.39. All hooks become no-ops if CONFIG_CLEANCACHE is unset, or become a check of a boolean global if CONFIG_CLEANCACHE is set but no cleancache "backend" has claimed cleancache_ops. Details and a FAQ can be found in Documentation/vm/cleancache.txt [v8: minchan.kim@gmail.com: adapt to new remove_from_page_cache function] Signed-off-by: Chris Mason <chris.mason@oracle.com> Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Jan Beulich <JBeulich@novell.com> Cc: Andreas Dilger <adilger@sun.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Nitin Gupta <ngupta@vflare.org>
2011-05-26vfs: Block mmapped writes while the fs is frozenJan Kara
We should not allow file modification via mmap while the filesystem is frozen. So block in block_page_mkwrite() while the filesystem is frozen. We cannot do the blocking wait in __block_page_mkwrite() since e.g. ext4 will want to call that function with transaction started in some cases and that would deadlock. But we can at least do the non-blocking reliable check in __block_page_mkwrite() which is the hardest part anyway. We have to check for frozen filesystem with the page marked dirty and under page lock with which we then return from ->page_mkwrite(). Only that way we cannot race with writeback done by freezing code - either we mark the page dirty after the writeback has started, see freezing in progress and block, or writeback will wait for our page lock which is released only when the fault is done and then writeback will writeout and writeprotect the page again. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: Create __block_page_mkwrite() helper passing error values backJan Kara
Create __block_page_mkwrite() helper which does all what block_page_mkwrite() does except that it passes back errors from __block_write_begin / block_commit_write calls. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fs: simplify iget & friends fs: pull inode->i_lock up out of writeback_single_inode fs: rename inode_lock to inode_hash_lock fs: move i_wb_list out from under inode_lock fs: move i_sb_list out from under inode_lock fs: remove inode_lock from iput_final and prune_icache fs: Lock the inode LRU list separately fs: factor inode disposal fs: protect inode->i_state with inode->i_lock autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd() autofs4 - remove autofs4_lock autofs4 - fix d_manage() return on rcu-walk autofs4 - fix autofs4_expire_indirect() traversal autofs4 - fix dentry leak in autofs4_expire_direct() autofs4 - reinstate last used update on access vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
2011-03-24fs: protect inode->i_state with inode->i_lockDave Chinner
Protect inode state transitions and validity checks with the inode->i_lock. This enables us to make inode state transitions independently of the inode_lock and is the first step to peeling away the inode_lock from the code. This requires that __iget() is done atomically with i_state checks during list traversals so that we don't race with another thread marking the inode I_FREEING between the state check and grabbing the reference. Also remove the unlock_new_inode() memory barrier optimisation required to avoid taking the inode_lock when clearing I_NEW. Simplify the code by simply taking the inode->i_lock around the state change and wakeup. Because the wakeup is no longer tricky, remove the wake_up_inode() function and open code the wakeup where necessary. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-17fs: make fsync_buffers_list() plugJens Axboe
It used WRITE_SYNC_PLUG before and potentially submits a batch of IO, so lets enable plugging for this case. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: kill off REQ_UNPLUGJens Axboe
With the plugging now being explicitly controlled by the submitter, callers need not pass down unplugging hints to the block layer. If they want to unplug, it's because they manually plugged on their own - in which case, they should just unplug at will. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-17fs: Use this_cpu_inc_return in buffer.cChristoph Lameter
__this_cpu_inc can create a single instruction with the same effect as the _get_cpu_var(..)++ construct in buffer.c. Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Christoph Hellwig <hch@lst.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-12-17fs: Use this_cpu_xx operations in buffer.cChristoph Lameter
Optimize various per cpu area operations through these new percpu operations. These operations avoid address calculations through the use of segment prefixes and multiple memory references through RMW instructions etc. Reduces code size: Before: christoph@linux-2.6$ size fs/buffer.o text data bss dec hex filename 19169 80 28 19277 4b4d fs/buffer.o After: christoph@linux-2.6$ size fs/buffer.o text data bss dec hex filename 19138 80 28 19246 4b2e fs/buffer.o V3->V4: - Move the use of this_cpu_inc_return into a later patch so that this one can go in without percpu infrastructure changes. Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Christoph Hellwig <hch@lst.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits) split invalidate_inodes() fs: skip I_FREEING inodes in writeback_sb_inodes fs: fold invalidate_list into invalidate_inodes fs: do not drop inode_lock in dispose_list fs: inode split IO and LRU lists fs: switch bdev inode bdi's correctly fs: fix buffer invalidation in invalidate_list fsnotify: use dget_parent smbfs: use dget_parent exportfs: use dget_parent fs: use RCU read side protection in d_validate fs: clean up dentry lru modification fs: split __shrink_dcache_sb fs: improve DCACHE_REFERENCED usage fs: use percpu counter for nr_dentry and nr_dentry_unused fs: simplify __d_free fs: take dcache_lock inside __d_path fs: do not assign default i_ino in new_inode fs: introduce a per-cpu last_ino allocator new helper: ihold() ...
2010-10-26fs/buffer.c: remove duplicated assignment to b_privateNamhyung Kim
bh->b_private is initialized within init_buffer(), thus this assignment is redundant. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26writeback: remove nonblocking/encountered_congestion referencesWu Fengguang
This removes more dead code that was somehow missed by commit 0d99519efef (writeback: remove unused nonblocking and congestion checks). There are no behavior change except for the removal of two entries from one of the ext4 tracing interface. The nonblocking checks in ->writepages are no longer used because the flusher now prefer to block on get_request_wait() than to skip inodes on IO congestion. The latter will lead to more seeky IO. The nonblocking checks in ->writepage are no longer used because it's redundant with the WB_SYNC_NONE check. We no long set ->nonblocking in VM page out and page migration, because a) it's effectively redundant with WB_SYNC_NONE in current code b) it's old semantic of "Don't get stuck on request queues" is mis-behavior: that would skip some dirty inodes on congestion and page out others, which is unfair in terms of LRU age. Inspired by Christoph Hellwig. Thanks! Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: David Howells <dhowells@redhat.com> Cc: Sage Weil <sage@newdream.net> Cc: Steve French <sfrench@samba.org> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25fs/buffer.c: call __block_write_begin() if we have pageNamhyung Kim
If we have the appropriate page already, call __block_write_begin() directly instead of releasing and regrabbing it inside of block_write_begin(). Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs/buffer.c: remove duplicated assignment on b_privateNamhyung Kim
bh->b_private is initialized within init_buffer(), thus the assignment should be redundant. Remove it. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: kill block_prepare_writeChristoph Hellwig
__block_write_begin and block_prepare_write are identical except for slightly different calling conventions. Convert all callers to the __block_write_begin calling conventions and drop block_prepare_write. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-09-10block: remove the BH_Eopnotsupp flagChristoph Hellwig
This flag was only set for barrier buffers, which we don't submit anymore. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-18remove SWRITE* I/O typesChristoph Hellwig
These flags aren't real I/O types, but tell ll_rw_block to always lock the buffer instead of giving up on a failed trylock. Instead add a new write_dirty_buffer helper that implements this semantic and use it from the existing SWRITE* callers. Note that the ll_rw_block code had a bug where it didn't promote WRITE_SYNC_PLUG properly, which this patch fixes. In the ufs code clean up the helper that used to call ll_rw_block to mirror sync_dirty_buffer, which is the function it implements for compound buffers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-18kill BH_Ordered flagChristoph Hellwig
Instead of abusing a buffer_head flag just add a variant of sync_dirty_buffer which allows passing the exact type of write flag required. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of block_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to block_write_begin. While we're at it also remove several unused arguments to block_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09introduce __block_write_beginChristoph Hellwig
Split up the block_write_begin implementation - __block_write_begin is a new trivial wrapper for block_prepare_write that always takes an already allocated page and can be either called from block_write_begin or filesystem code that already has a page allocated. Remove the handling of already allocated pages from block_write_begin after switching all callers that do it to __block_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of cont_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to cont_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of nobh_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the only remaining caller and rename the non-truncating version to nobh_write_begin. Get rid of the superflous file argument to it while we're at it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27fs: introduce new truncate sequencenpiggin@suse.de
Introduce a new truncate calling sequence into fs/mm subsystems. Rather than setattr > vmtruncate > truncate, have filesystems call their truncate sequence from ->setattr if filesystem specific operations are required. vmtruncate is deprecated, and truncate_pagecache and inode_newsize_ok helpers introduced previously should be used. simple_setattr is introduced for simple in-ram filesystems to implement the new truncate sequence. Eventually all filesystems should be converted to implement a setattr, and the default code in notify_change should go away. simple_setsize is also introduced to perform just the ATTR_SIZE portion of simple_setattr (ie. changing i_size and trimming pagecache). To implement the new truncate sequence: - filesystem specific manipulations (eg freeing blocks) must be done in the setattr method rather than ->truncate. - vmtruncate can not be used by core code to trim blocks past i_size in the event of write failure after allocation, so this must be performed in the fs code. - convert usage of helpers block_write_begin, nobh_write_begin, cont_write_begin, and *blockdev_direct_IO* to use _newtrunc postfixed variants. These avoid calling vmtruncate to trim blocks (see previous). - inode_setattr should not be used. generic_setattr is a new function to be used to copy simple attributes into the generic inode. - make use of the better opportunity to handle errors with the new sequence. Big problem with the previous calling sequence: the filesystem is not called until i_size has already changed. This means it is not allowed to fail the call, and also it does not know what the previous i_size was. Also, generic code calling vmtruncate to truncate allocated blocks in case of error had no good way to return a meaningful error (or, for example, atomically handle block deallocation). Cc: Christoph Hellwig <hch@lst.de> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (69 commits) fix handling of offsets in cris eeprom.c, get rid of fake on-stack files get rid of home-grown mutex in cris eeprom.c switch ecryptfs_write() to struct inode *, kill on-stack fake files switch ecryptfs_get_locked_page() to struct inode * simplify access to ecryptfs inodes in ->readpage() and friends AFS: Don't put struct file on the stack Ban ecryptfs over ecryptfs logfs: replace inode uid,gid,mode initialization with helper function ufs: replace inode uid,gid,mode initialization with helper function udf: replace inode uid,gid,mode init with helper ubifs: replace inode uid,gid,mode initialization with helper function sysv: replace inode uid,gid,mode initialization with helper function reiserfs: replace inode uid,gid,mode initialization with helper function ramfs: replace inode uid,gid,mode initialization with helper function omfs: replace inode uid,gid,mode initialization with helper function bfs: replace inode uid,gid,mode initialization with helper function ocfs2: replace inode uid,gid,mode initialization with helper function nilfs2: replace inode uid,gid,mode initialization with helper function minix: replace inode uid,gid,mode init with helper ext4: replace inode uid,gid,mode init with helper ... Trivial conflict in fs/fs-writeback.c (mark bitfields unsigned)
2010-05-21new helper: iterate_supers()Al Viro
... and switch the simple "loop over superblocks and do something" loops to it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21Convert simple loops over superblocks to list_for_each_entry_safeAl Viro
2010-05-21Leave superblocks on s_list until the endAl Viro
We used to remove from s_list and s_instances at the same time. So let's *not* do the former and skip superblocks that have empty s_instances in the loops over s_list. The next step, of course, will be to get rid of rescan logics in those loops. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21buffer: make invalidate_bdev() drain all percpu LRU add cachesTejun Heo
invalidate_bdev() should release all page cache pages which are clean and not being used; however, if some pages are still in the percpu LRU add caches on other cpus, those pages are considered in used and don't get released. Fix it by calling lru_add_drain_all() before trying to invalidate pages. This problem was discovered while testing block automatic native capacity unlocking. Null pages which were read before automatic unlocking didn't get released by invalidate_bdev() and ended up interfering with partition scan after unlocking. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-12fs: buffer_head: remove kmem_cache constructor to reduce memory usage under slubRichard Kennedy
When using slub, having a kmem_cache constructor forces slub to add a free pointer to the size of the cached object, which can have a significant impact to the number of small objects that can fit into a slab. As buffer_head is relatively small and we can have large numbers of them, removing the constructor is a definite win. On x86_64 removing the constructor gives me 39 objects/slab, 3 more than without the patch. And on x86_32 73 objects/slab, which is 9 more. As alloc_buffer_head() already initializes each new object there is very little difference in actual code run. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Jens Axboe <jens.axboe@oracle.com> Acked-by: Nick Piggin <npiggin@suse.de> Cc: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-04Fix misspellings of "invocation" in comments.Adam Buchbinder
Some comments misspell "invocation"; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-25Merge branch 'writeback' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'writeback' of git://git.kernel.dk/linux-2.6-block: writeback: writeback_inodes_sb() should use bdi_start_writeback() writeback: don't delay inodes redirtied by a fast dirtier writeback: make the super_block pinning more efficient writeback: don't resort for a single super_block in move_expired_inodes() writeback: move inodes from one super_block together writeback: get rid to incorrect references to pdflush in comments writeback: improve readability of the wb_writeback() continue/break logic writeback: cleanup writeback_single_inode() writeback: kupdate writeback shall not stop when more io is possible writeback: stop background writeback when below background threshold writeback: balance_dirty_pages() shall write more than dirtied pages fs: Fix busyloop in wb_writeback()
2009-09-25writeback: get rid to incorrect references to pdflush in commentsJens Axboe
2009-09-24truncate: use new helpersnpiggin@suse.de
Update some fs code to make use of new helper functions introduced in the previous patch. Should be no significant change in behaviour (except CIFS now calls send_sig under i_lock, via inode_newsize_ok). Reviewed-by: Christoph Hellwig <hch@lst.de> Acked-by: Miklos Szeredi <miklos@szeredi.hu> Cc: linux-nfs@vger.kernel.org Cc: Trond.Myklebust@netapp.com Cc: linux-cifs-client@lists.samba.org Cc: sfrench@samba.org Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-23fs/buffer.c: clean up EXPORT* macrosH Hartley Sweeten
According to Documentation/CodingStyle the EXPORT* macro should follow immediately after the closing function brace line. Also, mark_buffer_async_write_endio() and do_thaw_all() are not used elsewhere so they should be marked as static. In addition, file_fsync() is actually in fs/sync.c so move the EXPORT* to that file. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-11writeback: switch to per-bdi threads for flushing dataJens Axboe
This gets rid of pdflush for bdi writeout and kupdated style cleaning. pdflush writeout suffers from lack of locality and also requires more threads to handle the same workload, since it has to work in a non-blocking fashion against each queue. This also introduces lumpy behaviour and potential request starvation, since pdflush can be starved for queue access if others are accessing it. A sample ffsb workload that does random writes to files is about 8% faster here on a simple SATA drive during the benchmark phase. File layout also seems a LOT more smooth in vmstat: r b swpd free buff cache si so bi bo in cs us sy id wa 0 1 0 608848 2652 375372 0 0 0 71024 604 24 1 10 48 42 0 1 0 549644 2712 433736 0 0 0 60692 505 27 1 8 48 44 1 0 0 476928 2784 505192 0 0 4 29540 553 24 0 9 53 37 0 1 0 457972 2808 524008 0 0 0 54876 331 16 0 4 38 58 0 1 0 366128 2928 614284 0 0 4 92168 710 58 0 13 53 34 0 1 0 295092 3000 684140 0 0 0 62924 572 23 0 9 53 37 0 1 0 236592 3064 741704 0 0 4 58256 523 17 0 8 48 44 0 1 0 165608 3132 811464 0 0 0 57460 560 21 0 8 54 38 0 1 0 102952 3200 873164 0 0 4 74748 540 29 1 10 48 41 0 1 0 48604 3252 926472 0 0 0 53248 469 29 0 7 47 45 where vanilla tends to fluctuate a lot in the creation phase: r b swpd free buff cache si so bi bo in cs us sy id wa 1 1 0 678716 5792 303380 0 0 0 74064 565 50 1 11 52 36 1 0 0 662488 5864 319396 0 0 4 352 302 329 0 2 47 51 0 1 0 599312 5924 381468 0 0 0 78164 516 55 0 9 51 40 0 1 0 519952 6008 459516 0 0 4 78156 622 56 1 11 52 37 1 1 0 436640 6092 541632 0 0 0 82244 622 54 0 11 48 41 0 1 0 436640 6092 541660 0 0 0 8 152 39 0 0 51 49 0 1 0 332224 6200 644252 0 0 4 102800 728 46 1 13 49 36 1 0 0 274492 6260 701056 0 0 4 12328 459 49 0 7 50 43 0 1 0 211220 6324 763356 0 0 0 106940 515 37 1 10 51 39 1 0 0 160412 6376 813468 0 0 0 8224 415 43 0 6 49 45 1 1 0 85980 6452 886556 0 0 4 113516 575 39 1 11 54 34 0 2 0 85968 6452 886620 0 0 0 1640 158 211 0 0 46 54 A 10 disk test with btrfs performs 26% faster with per-bdi flushing. A SSD based writeback test on XFS performs over 20% better as well, with the throughput being very stable around 1GB/sec, where pdflush only manages 750MB/sec and fluctuates wildly while doing so. Random buffered writes to many files behave a lot better as well, as does random mmap'ed writes. A separate thread is added to sync the super blocks. In the long term, adding sync_supers_bdi() functionality could get rid of this thread again. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-08-21Re-introduce page mapping check in mark_buffer_dirty()Linus Torvalds
In commit a8e7d49aa7be728c4ae241a75a2a124cdcabc0c5 ("Fix race in create_empty_buffers() vs __set_page_dirty_buffers()"), I removed a test for a NULL page mapping unintentionally when some of the code inside __set_page_dirty() was moved to the callers. That removal generally didn't matter, since a filesystem would serialize truncation (which clears the page mapping) against writing (which marks the buffer dirty), so locking at a higher level (either per-page or an inode at a time) should mean that the buffer page would be stable. And indeed, nothing bad seemed to happen. Except it turns out that apparently reiserfs does something odd when under load and writing out the journal, and we have a number of bugzilla entries that look similar: http://bugzilla.kernel.org/show_bug.cgi?id=13556 http://bugzilla.kernel.org/show_bug.cgi?id=13756 http://bugzilla.kernel.org/show_bug.cgi?id=13876 and it looks like reiserfs depended on that check (the common theme seems to be "data=journal", and a journal writeback during a truncate). I suspect reiserfs should have some additional locking, but in the meantime this should get us back to the pre-2.6.29 behavior. Pattern-pointed-out-by: Roland Kletzing <devzero@web.de> Cc: stable@kernel.org (2.6.29 and 2.6.30) Cc: Jeff Mahoney <jeffm@suse.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11Merge branch 'for-2.6.31' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.31' of git://git.kernel.dk/linux-2.6-block: (153 commits) block: add request clone interface (v2) floppy: fix hibernation ramdisk: remove long-deprecated "ramdisk=" boot-time parameter fs/bio.c: add missing __user annotation block: prevent possible io_context->refcount overflow Add serial number support for virtio_blk, V4a block: Add missing bounce_pfn stacking and fix comments Revert "block: Fix bounce limit setting in DM" cciss: decode unit attention in SCSI error handling code cciss: Remove no longer needed sendcmd reject processing code cciss: change SCSI error handling routines to work with interrupts enabled. cciss: separate error processing and command retrying code in sendcmd_withirq_core() cciss: factor out fix target status processing code from sendcmd functions cciss: simplify interface of sendcmd() and sendcmd_withirq() cciss: factor out core of sendcmd_withirq() for use by SCSI error handling code cciss: Use schedule_timeout_uninterruptible in SCSI error handling code block: needs to set the residual length of a bidi request Revert "block: implement blkdev_readpages" block: Fix bounce limit setting in DM Removed reference to non-existing file Documentation/PCI/PCI-DMA-mapping.txt ... Manually fix conflicts with tracing updates in: block/blk-sysfs.c drivers/ide/ide-atapi.c drivers/ide/ide-cd.c drivers/ide/ide-floppy.c drivers/ide/ide-tape.c include/trace/events/block.h kernel/trace/blktrace.c
2009-06-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (49 commits) ext4: Avoid corrupting the uninitialized bit in the extent during truncate ext4: Don't treat a truncation of a zero-length file as replace-via-truncate ext4: fix dx_map_entry to support 256k directory blocks ext4: truncate the file properly if we fail to copy data from userspace ext4: Avoid leaking blocks after a block allocation failure ext4: Change all super.c messages to print the device ext4: Get rid of EXTEND_DISKSIZE flag of ext4_get_blocks_handle() ext4: super.c whitespace cleanup jbd2: Fix minor typos in comments in fs/jbd2/journal.c ext4: Clean up calls to ext4_get_group_desc() ext4: remove unused function __ext4_write_dirty_metadata ext2: Fix memory leak in ext2_fill_super() in case of a failed mount ext3: Fix memory leak in ext3_fill_super() in case of a failed mount ext4: Fix memory leak in ext4_fill_super() in case of a failed mount ext4: down i_data_sem only for read when walking tree for fiemap ext4: Add a comprehensive block validity check to ext4_get_blocks() ext4: Clean up ext4_get_blocks() so it does not depend on bh_result->b_state ext4: Merge ext4_da_get_block_write() into mpage_da_map_blocks() ext4: Add BUG_ON debugging checks to noalloc_get_block_write() ext4: Add documentation to the ext4_*get_block* functions ...
2009-06-06Fix nobh_truncate_page() to not pass stack garbage to get_block()Theodore Ts'o
The nobh_truncate_page() function is used by ext2, exofs, and jfs. Of these three, only ext2 and jfs's get_block() function pays attention to bh->b_size --- which is normally always the filesystem blocksize except when the get_block() function is called by either mpage_readpage(), mpage_readpages(), or the direct I/O routines in fs/direct_io.c. Unfortunately, nobh_truncate_page() does not initialize map_bh before calling the filesystem-supplied get_block() function. So ext2 and jfs will try to calculate the number of blocks to map by taking stack garbage and shifting it left by inode->i_blkbits. This should be *mostly* harmless (except the filesystem will do some unnneeded work) unless the stack garbage is less than filesystem's blocksize, in which case maxblocks will be zero, and the attempt to find out whether or not the filesystem has a hole at a given logical block will fail, and the page cache entry might not get zero'ed out. Also if the stack garbage in in map_bh->state happens to have the BH_Mapped bit set, there could be an attempt to call readpage() on a non-existent page, which could cause nobh_truncate_page() to return an error when it should not. Fix this by initializing map_bh->state and map_bh->size. Fortunately, it's probably fairly unlikely that ext2 and jfs users mount with nobh these days. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: linux-fsdevel@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-02mm: close page_mkwrite racesNick Piggin
Change page_mkwrite to allow implementations to return with the page locked, and also change it's callers (in page fault paths) to hold the lock until the page is marked dirty. This allows the filesystem to have full control of page dirtying events coming from the VM. Rather than simply hold the page locked over the page_mkwrite call, we call page_mkwrite with the page unlocked and allow callers to return with it locked, so filesystems can avoid LOR conditions with page lock. The problem with the current scheme is this: a filesystem that wants to associate some metadata with a page as long as the page is dirty, will perform this manipulation in its ->page_mkwrite. It currently then must return with the page unlocked and may not hold any other locks (according to existing page_mkwrite convention). In this window, the VM could write out the page, clearing page-dirty. The filesystem has no good way to detect that a dirty pte is about to be attached, so it will happily write out the page, at which point, the filesystem may manipulate the metadata to reflect that the page is no longer dirty. It is not always possible to perform the required metadata manipulation in ->set_page_dirty, because that function cannot block or fail. The filesystem may need to allocate some data structure, for example. And the VM cannot mark the pte dirty before page_mkwrite, because page_mkwrite is allowed to fail, so we must not allow any window where the page could be written to if page_mkwrite does fail. This solution of holding the page locked over the 3 critical operations (page_mkwrite, setting the pte dirty, and finally setting the page dirty) closes out races nicely, preventing page cleaning for writeout being initiated in that window. This provides the filesystem with a strong synchronisation against the VM here. - Sage needs this race closed for ceph filesystem. - Trond for NFS (http://bugzilla.kernel.org/show_bug.cgi?id=12913). - I need it for fsblock. - I suspect other filesystems may need it too (eg. btrfs). - I have converted buffer.c to the new locking. Even simple block allocation under dirty pages might be susceptible to i_size changing under partial page at the end of file (we also have a buffer.c-side problem here, but it cannot be fixed properly without this patch). - Other filesystems (eg. NFS, maybe btrfs) will need to change their page_mkwrite functions themselves. [ This also moves page_mkwrite another step closer to fault, which should eventually allow page_mkwrite to be moved into ->fault, and thus avoiding a filesystem calldown and page lock/unlock cycle in __do_fault. ] [akpm@linux-foundation.org: fix derefs of NULL ->mapping] Cc: Sage Weil <sage@newdream.net> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-12vfs: Add BUG_ON for delayed and unwritten flags in submit_bh()Aneesh Kumar K.V
The BH_Delay and BH_Unwritten flags should never leak out to submit_bh(). So add some BUG_ON() checks to submit_bh so we can get a stack trace and determine how and why this might have happened. (Note that only XFS and ext4 use these buffer head flags, and XFS does not use submit_bh(). So this patch should only modify behavior for ext4.) Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-fsdevel@vger.kernel.org
2009-04-16Add block_write_full_page_endio for passing endio handlerChris Mason
block_write_full_page doesn't allow the caller to control what happens when the IO is over. This adds a new call named block_write_full_page_endio so the buffer head end_io handler can be provided by the caller. This will be used by the ext3 data=guarded mode to do i_size updates in a workqueue based end_io handler. end_buffer_async_write is also exported so it can be called to do the dirty work of managing page writeback for the higher level end_io handler. Signed-off-by: Chris Mason <chris.mason@oracle.com> Acked-by: Theodore Tso <tytso@mit.edu> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-15buffer: switch do_emergency_thaw() away from pdflush_operation()Jens Axboe
This is (again) a preparatory patch similar to commit a2a9537ac0b37a5da6fbe7e1e9cb06c524d2a9c4. It open codes a simple async way of executing do_thaw_all() out of context, so we can get rid of pdflush. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-08block_write_full_page: switch synchronous writes to use WRITE_SYNC_PLUGTheodore Ts'o
Now that we have a distinction between WRITE_SYNC and WRITE_SYNC_PLUG, use WRITE_SYNC_PLUG in __block_write_full_page() to avoid unplugging the block device I/O queue between each page that gets flushed out. Otherwise, when we run sync() or fsync() and we need to write out a large number of pages, the block device queue will get unplugged between for every page that is flushed out, which will be a pretty serious performance regression caused by commit a64c8610. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
