[ Upstream commit dce30ca9e3b676fb288c33c1f4725a0621361185 ]
guard_bio_eod() can truncate a segment in bio to allow it to do IO on
odd last sectors of a device.
It already checks if the IO starts past EOD, but it does not consider
the possibility of an IO request starting within device boundaries can
contain more than one segment past EOD.
In such cases, truncated_bytes can be bigger than PAGE_SIZE, and will
underflow bvec->bv_len.
Fix this by checking if truncated_bytes is lower than PAGE_SIZE.
This situation has been found on filesystems such as isofs and vfat,
which doesn't check the device size before mount, if the device is
smaller than the filesystem itself, a readahead on such filesystem,
which spans EOD, can trigger this situation, leading a call to
zero_user() with a wrong size possibly corrupting memory.
I didn't see any crash, or didn't let the system run long enough to
check if memory corruption will be hit somewhere, but adding
instrumentation to guard_bio_end() to check truncated_bytes size, was
enough to see the error.
The following script can trigger the error.
MNT=/mnt
IMG=./DISK.img
DEV=/dev/loop0
mkfs.vfat $IMG
mount $IMG $MNT
cp -R /etc $MNT &> /dev/null
umount $MNT
losetup -D
losetup --find --show --sizelimit 16247280 $IMG
mount $DEV $MNT
find $MNT -type f -exec cat {} + >/dev/null
Kudos to Eric Sandeen for coming up with the reproducer above
Reviewed-by: Ming Lei <ming.lei@redhat.com>
Signed-off-by: Carlos Maiolino <cmaiolino@redhat.com>
[ Upstream commit 43636c804df0126da669c261fc820fb22f62bfc2 ]
When something let __find_get_block_slow() hit all_mapped path, it calls
printk() for 100+ times per a second. But there is no need to print same
message with such high frequency; it is just asking for stall warning, or
at least bloating log files.
[ 399.866302][T15342] __find_get_block_slow() failed. block=1, b_blocknr=8
[ 399.873324][T15342] b_state=0x00000029, b_size=512
[ 399.878403][T15342] device loop0 blocksize: 4096
[ 399.883296][T15342] __find_get_block_slow() failed. block=1, b_blocknr=8
[ 399.890400][T15342] b_state=0x00000029, b_size=512
[ 399.895595][T15342] device loop0 blocksize: 4096
[ 399.900556][T15342] __find_get_block_slow() failed. block=1, b_blocknr=8
[ 399.907471][T15342] b_state=0x00000029, b_size=512
[ 399.912506][T15342] device loop0 blocksize: 4096
This patch reduces frequency to up to once per a second, in addition to
concatenating three lines into one.
[ 399.866302][T15342] __find_get_block_slow() failed. block=1, b_blocknr=8, b_state=0x00000029, b_size=512, device loop0 blocksize: 4096
Cc: Dmitry Vyukov <dvyukov@google.com>
commit 93407472a21b82f39c955ea7787e5bc7da100642 upstream.
Replace all 1 << inode->i_blkbits and (1 << inode->i_blkbits) in fs
branch.
This patch also fixes multiple checkpatch warnings: WARNING: Prefer
'unsigned int' to bare use of 'unsigned'
Thanks to Andrew Morton for suggesting more appropriate function instead
of macro.
[geliangtang@gmail.com: truncate: use i_blocksize()]
Link: http://lkml.kernel.org/r/9c8b2cd83c8f5653805d43debde9fa8817e02fc4.1484895804.git.geliangtang@gmail.com
Link: http://lkml.kernel.org/r/1481319905-10126-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
The mapping_set_error() helper sets the correct AS_ flag for the mapping
so there is no reason to open code it. Use the helper directly.
[akpm@linux-foundation.org: be honest about conversion from -ENXIO to -EIO]
Link: http://lkml.kernel.org/r/20160912111608.2588-2-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
__getblk_slow() was exported to modules in commit 3b5e6454aaf6
("fs/buffer.c: support buffer cache allocations with gfp modifiers").
This seems to have been a mistake, as no users were introduced nor was
the function declared in a header. Change it back to 'static'.
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs
Pull xfs updates from Dave Chinner:
"The major addition is the new iomap based block mapping
infrastructure. We've been kicking this about locally for years, but
there are other filesystems want to use it too (e.g. gfs2). Now it
is fully working, reviewed and ready for merge and be used by other
filesystems.
There are a lot of other fixes and cleanups in the tree, but those are
XFS internal things and none are of the scale or visibility of the
iomap changes. See below for details.
I am likely to send another pull request next week - we're just about
ready to merge some new functionality (on disk block->owner reverse
mapping infrastructure), but that's a huge chunk of code (74 files
changed, 7283 insertions(+), 1114 deletions(-)) so I'm keeping that
separate to all the "normal" pull request changes so they don't get
lost in the noise.
Summary of changes in this update:
- generic iomap based IO path infrastructure
- generic iomap based fiemap implementation
- xfs iomap based Io path implementation
- buffer error handling fixes
- tracking of in flight buffer IO for unmount serialisation
- direct IO and DAX io path separation and simplification
- shortform directory format definition changes for wider platform
compatibility
- various buffer cache fixes
- cleanups in preparation for rmap merge
- error injection cleanups and fixes
- log item format buffer memory allocation restructuring to prevent
rare OOM reclaim deadlocks
- sparse inode chunks are now fully supported"
* tag 'xfs-for-linus-4.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs: (53 commits)
xfs: remove EXPERIMENTAL tag from sparse inode feature
xfs: bufferhead chains are invalid after end_page_writeback
xfs: allocate log vector buffers outside CIL context lock
libxfs: directory node splitting does not have an extra block
xfs: remove dax code from object file when disabled
xfs: skip dirty pages in ->releasepage()
xfs: remove __arch_pack
xfs: kill xfs_dir2_inou_t
xfs: kill xfs_dir2_sf_off_t
xfs: split direct I/O and DAX path
xfs: direct calls in the direct I/O path
xfs: stop using generic_file_read_iter for direct I/O
xfs: split xfs_file_read_iter into buffered and direct I/O helpers
xfs: remove s_maxbytes enforcement in xfs_file_read_iter
xfs: kill ioflags
xfs: don't pass ioflags around in the ioctl path
xfs: track and serialize in-flight async buffers against unmount
xfs: exclude never-released buffers from buftarg I/O accounting
xfs: don't reset b_retries to 0 on every failure
xfs: remove extraneous buffer flag changes
Pull block driver updates from Jens Axboe:
"This branch also contains core changes. I've come to the conclusion
that from 4.9 and forward, I'll be doing just a single branch. We
often have dependencies between core and drivers, and it's hard to
always split them up appropriately without pulling core into drivers
when that happens.
That said, this contains:
- separate secure erase type for the core block layer, from
Christoph.
- set of discard fixes, from Christoph.
- bio shrinking fixes from Christoph, as a followup up to the
op/flags change in the core branch.
- map and append request fixes from Christoph.
- NVMeF (NVMe over Fabrics) code from Christoph. This is pretty
exciting!
- nvme-loop fixes from Arnd.
- removal of ->driverfs_dev from Dan, after providing a
device_add_disk() helper.
- bcache fixes from Bhaktipriya and Yijing.
- cdrom subchannel read fix from Vchannaiah.
- set of lightnvm updates from Wenwei, Matias, Johannes, and Javier.
- set of drbd updates and fixes from Fabian, Lars, and Philipp.
- mg_disk error path fix from Bart.
- user notification for failed device add for loop, from Minfei.
- NVMe in general:
+ NVMe delay quirk from Guilherme.
+ SR-IOV support and command retry limits from Keith.
+ fix for memory-less NUMA node from Masayoshi.
+ use UINT_MAX for discard sectors, from Minfei.
+ cancel IO fixes from Ming.
+ don't allocate unused major, from Neil.
+ error code fixup from Dan.
+ use constants for PSDT/FUSE from James.
+ variable init fix from Jay.
+ fabrics fixes from Ming, Sagi, and Wei.
+ various fixes"
* 'for-4.8/drivers' of git://git.kernel.dk/linux-block: (115 commits)
nvme/pci: Provide SR-IOV support
nvme: initialize variable before logical OR'ing it
block: unexport various bio mapping helpers
scsi/osd: open code blk_make_request
target: stop using blk_make_request
block: simplify and export blk_rq_append_bio
block: ensure bios return from blk_get_request are properly initialized
virtio_blk: use blk_rq_map_kern
memstick: don't allow REQ_TYPE_BLOCK_PC requests
block: shrink bio size again
block: simplify and cleanup bvec pool handling
block: get rid of bio_rw and READA
block: don't ignore -EOPNOTSUPP blkdev_issue_write_same
block: introduce BLKDEV_DISCARD_ZERO to fix zeroout
NVMe: don't allocate unused nvme_major
nvme: avoid crashes when node 0 is memoryless node.
nvme: Limit command retries
loop: Make user notify for adding loop device failed
nvme-loop: fix nvme-loop Kconfig dependencies
nvmet: fix return value check in nvmet_subsys_alloc()
Pull core block updates from Jens Axboe:
- the big change is the cleanup from Mike Christie, cleaning up our
uses of command types and modified flags. This is what will throw
some merge conflicts
- regression fix for the above for btrfs, from Vincent
- following up to the above, better packing of struct request from
Christoph
- a 2038 fix for blktrace from Arnd
- a few trivial/spelling fixes from Bart Van Assche
- a front merge check fix from Damien, which could cause issues on
SMR drives
- Atari partition fix from Gabriel
- convert cfq to highres timers, since jiffies isn't granular enough
for some devices these days. From Jan and Jeff
- CFQ priority boost fix idle classes, from me
- cleanup series from Ming, improving our bio/bvec iteration
- a direct issue fix for blk-mq from Omar
- fix for plug merging not involving the IO scheduler, like we do for
other types of merges. From Tahsin
- expose DAX type internally and through sysfs. From Toshi and Yigal
* 'for-4.8/core' of git://git.kernel.dk/linux-block: (76 commits)
block: Fix front merge check
block: do not merge requests without consulting with io scheduler
block: Fix spelling in a source code comment
block: expose QUEUE_FLAG_DAX in sysfs
block: add QUEUE_FLAG_DAX for devices to advertise their DAX support
Btrfs: fix comparison in __btrfs_map_block()
block: atari: Return early for unsupported sector size
Doc: block: Fix a typo in queue-sysfs.txt
cfq-iosched: Charge at least 1 jiffie instead of 1 ns
cfq-iosched: Fix regression in bonnie++ rewrite performance
cfq-iosched: Convert slice_resid from u64 to s64
block: Convert fifo_time from ulong to u64
blktrace: avoid using timespec
block/blk-cgroup.c: Declare local symbols static
block/bio-integrity.c: Add #include "blk.h"
block/partition-generic.c: Remove a set-but-not-used variable
block: bio: kill BIO_MAX_SIZE
cfq-iosched: temporarily boost queue priority for idle classes
block: drbd: avoid to use BIO_MAX_SIZE
block: bio: remove BIO_MAX_SECTORS
These two are confusing leftover of the old world order, combining
values of the REQ_OP_ and REQ_ namespaces. For callers that don't
special case we mostly just replace bi_rw with bio_data_dir or
op_is_write, except for the few cases where a switch over the REQ_OP_
values makes more sense. Any check for READA is replaced with an
explicit check for REQ_RAHEAD. Also remove the READA alias for
REQ_RAHEAD.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Reviewed-by: Mike Christie <mchristi@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
gfs2 needs to be able to skip the check to see if a page is outside of
the file size when writing it out. gfs2 can get into a situation where
it needs to flush its in-memory log to disk while a truncate is in
progress. If the file being trucated has data journaling enabled, it is
possible that there are data blocks in the log that are past the end of
the file. gfs can't finish the log flush without either writing these
blocks out or revoking them. Otherwise, if the node crashed, it could
overwrite subsequent changes made by other nodes in the cluster when
it's journal was replayed.
Unfortunately, there is no way to add log entries to the log during a
flush. So gfs2 simply writes out the page instead. This situation can
only occur when the truncate code still has the file locked exclusively,
and hasn't marked this block as free in the metadata (which happens
later in truc_dealloc). After gfs2 writes this page out, the truncation
code will shortly invalidate it and write out any revokes if necessary.
In order to make this work, gfs2 needs to be able to skip the check for
writes outside the file size. Since the check exists in
block_write_full_page, this patch exports __block_write_full_page, which
doesn't have the check.
Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com>
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
Add infrastructure for multipage buffered writes. This is implemented
using an main iterator that applies an actor function to a range that
can be written.
This infrastucture is used to implement a buffered write helper, one
to zero file ranges and one to implement the ->page_mkwrite VM
operations. All of them borrow a fair amount of code from fs/buffers.
for now by using an internal version of __block_write_begin that
gets passed an iomap and builds the corresponding buffer head.
The file system is gets a set of paired ->iomap_begin and ->iomap_end
calls which allow it to map/reserve a range and get a notification
once the write code is finished with it.
Based on earlier code from Dave Chinner.
Reviewed-by: Bob Peterson <rpeterso@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
This has ll_rw_block users pass in the operation and flags separately,
so ll_rw_block can setup the bio op and bi_rw flags on the bio that
is submitted.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
This has submit_bh users pass in the operation and flags separately,
so submit_bh_wbc can setup the bio op and bi_rw flags on the bio that
is submitted.
This has callers of submit_bio/submit_bio_wait set the bio->bi_rw
instead of passing it in. This makes that use the same as
generic_make_request and how we set the other bio fields.
Fixed up fs/ext4/crypto.c
The allocator fast path looks up the first usable zone in a zonelist and
then get_page_from_freelist does the same job in the zonelist iterator.
This patch preserves the necessary information.
4.6.0-rc2 4.6.0-rc2
fastmark-v1r20 initonce-v1r20
Min alloc-odr0-1 364.00 ( 0.00%) 359.00 ( 1.37%)
Min alloc-odr0-2 262.00 ( 0.00%) 260.00 ( 0.76%)
Min alloc-odr0-4 214.00 ( 0.00%) 214.00 ( 0.00%)
Min alloc-odr0-8 186.00 ( 0.00%) 186.00 ( 0.00%)
Min alloc-odr0-16 173.00 ( 0.00%) 173.00 ( 0.00%)
Min alloc-odr0-32 165.00 ( 0.00%) 165.00 ( 0.00%)
Min alloc-odr0-64 161.00 ( 0.00%) 162.00 ( -0.62%)
Min alloc-odr0-128 159.00 ( 0.00%) 161.00 ( -1.26%)
Min alloc-odr0-256 168.00 ( 0.00%) 170.00 ( -1.19%)
Min alloc-odr0-512 180.00 ( 0.00%) 181.00 ( -0.56%)
Min alloc-odr0-1024 190.00 ( 0.00%) 190.00 ( 0.00%)
Min alloc-odr0-2048 196.00 ( 0.00%) 196.00 ( 0.00%)
Min alloc-odr0-4096 202.00 ( 0.00%) 202.00 ( 0.00%)
Min alloc-odr0-8192 206.00 ( 0.00%) 205.00 ( 0.49%)
Min alloc-odr0-16384 206.00 ( 0.00%) 205.00 ( 0.49%)
The benefit is negligible and the results are within the noise but each
cycle counts.
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Now that migration doesn't clear page->mem_cgroup of live pages anymore,
it's safe to make lock_page_memcg() and the memcg stat functions take
pages, and spare the callers from memcg objects.
[akpm@linux-foundation.org: fix warnings]
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Suggested-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Acked-by: Vladimir Davydov <vdavydov@virtuozzo.com>
These patches tag the page cache radix tree eviction entries with the
memcg an evicted page belonged to, thus making per-cgroup LRU reclaim
work properly and be as adaptive to new cache workingsets as global
reclaim already is.
This should have been part of the original thrash detection patch
series, but was deferred due to the complexity of those patches.
This patch (of 5):
So far the only sites that needed to exclude charge migration to
stabilize page->mem_cgroup have been per-cgroup page statistics, hence
the name mem_cgroup_begin_page_stat(). But per-cgroup thrash detection
will add another site that needs to ensure page->mem_cgroup lifetime.
Rename these locking functions to the more generic lock_page_memcg() and
unlock_page_memcg(). Since charge migration is a cgroup1 feature only,
we might be able to delete it at some point, and these now easy to
identify locking sites along with it.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
The function currently called "__block_page_mkwrite()" used to be called
"block_page_mkwrite()" until a wrapper for this function was added by:
commit 24da4fab5a61 ("vfs: Create __block_page_mkwrite() helper passing
error values back")
This wrapper, the current "block_page_mkwrite()", is currently unused.
__block_page_mkwrite() is used directly by ext4, nilfs2 and xfs.
Remove the unused wrapper, rename __block_page_mkwrite() back to
block_page_mkwrite() and update the comment above block_page_mkwrite().
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Reviewed-by: Jan Kara <jack@suse.com>
Cc: Jan Kara <jack@suse.com>
There are many places which use mapping_gfp_mask to restrict a more
generic gfp mask which would be used for allocations which are not
directly related to the page cache but they are performed in the same
context.
Let's introduce a helper function which makes the restriction explicit and
easier to track. This patch doesn't introduce any functional changes.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Call pre-defined helper bio_add_page() instead of open coding for
iterating through bi_io_vec[]. Doing that, it's possible to make some
parts in filesystems and mm/page_io.c simpler than before.
Acked-by: Dave Kleikamp <shaggy@kernel.org>
Cc: linux-fsdevel@vger.kernel.org
Signed-off-by: Kent Overstreet <kent.overstreet@gmail.com>
[dpark: add more description in commit message]
Signed-off-by: Dongsu Park <dpark@posteo.net>
Signed-off-by: Ming Lin <ming.l@ssi.samsung.com>
Some places use helpers now, others don't. We only have the 'is set'
helper, add helpers for setting and clearing flags too.
It was a bit of a mess of atomic vs non-atomic access. With
BIO_UPTODATE gone, we don't have any risk of concurrent access to the
flags. So relax the restriction and don't make any of them atomic. The
flags that do have serialization issues (reffed and chained), we
already handle those separately.
Currently we have two different ways to signal an I/O error on a BIO:
(1) by clearing the BIO_UPTODATE flag
(2) by returning a Linux errno value to the bi_end_io callback
The first one has the drawback of only communicating a single possible
error (-EIO), and the second one has the drawback of not beeing persistent
when bios are queued up, and are not passed along from child to parent
bio in the ever more popular chaining scenario. Having both mechanisms
available has the additional drawback of utterly confusing driver authors
and introducing bugs where various I/O submitters only deal with one of
them, and the others have to add boilerplate code to deal with both kinds
of error returns.
So add a new bi_error field to store an errno value directly in struct
bio and remove the existing mechanisms to clean all this up.
Reviewed-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: NeilBrown <neilb@suse.com>
Merge hickup on my part, due to a clash between the writeback
changes and the EOPNOTSUPP removal in _submit_bh().
As concurrent write sharing of an inode is expected to be very rare
and memcg only tracks page ownership on first-use basis severely
confining the usefulness of such sharing, cgroup writeback tracks
ownership per-inode. While the support for concurrent write sharing
of an inode is deemed unnecessary, an inode being written to by
different cgroups at different points in time is a lot more common,
and, more importantly, charging only by first-use can too readily lead
to grossly incorrect behaviors (single foreign page can lead to
gigabytes of writeback to be incorrectly attributed).
To resolve this issue, cgroup writeback detects the majority dirtier
of an inode and will transfer the ownership to it. To avoid
unnnecessary oscillation, the detection mechanism keeps track of
history and gives out the switch verdict only if the foreign usage
pattern is stable over a certain amount of time and/or writeback
attempts.
The detection mechanism has fairly low space and computation overhead.
It adds 8 bytes to struct inode (one int and two u16's) and minimal
amount of calculation per IO. The detection mechanism converges to
the correct answer usually in several seconds of IO time when there's
a clear majority dirtier. Even when there isn't, it can reach an
acceptable answer fairly quickly under most circumstances.
Please see wb_detach_inode() for more details.
This patch only implements detection. Following patches will
implement actual switching.
v2: wbc_account_io() now checks whether the wbc is associated with a
wb before dereferencing it. This can happen when pageout() is
writing pages directly without going through the usual writeback
path. As pageout() path is single-threaded, we don't want it to
be blocked behind a slow cgroup and ultimately want it to delegate
actual writing to the usual writeback path.
Cc: Jan Kara <jack@suse.cz>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Currently, for cgroup writeback, the IO submission paths directly
associate the bio's with the blkcg from inode_to_wb_blkcg_css();
however, it'd be necessary to keep more writeback context to implement
foreign inode writeback detection. wbc (writeback_control) is the
natural fit for the extra context - it persists throughout the
writeback of each inode and is passed all the way down to IO
submission paths.
This patch adds wbc_attach_and_unlock_inode(), wbc_detach_inode(), and
wbc_attach_fdatawrite_inode() which are used to associate wbc with the
inode being written back. IO submission paths now use wbc_init_bio()
instead of directly associating bio's with blkcg themselves. This
leaves inode_to_wb_blkcg_css() w/o any user. The function is removed.
wbc currently only tracks the associated wb (bdi_writeback). Future
patches will add more for foreign inode detection. The association is
established under i_lock which will be depended upon when migrating
foreign inodes to other wb's.
As currently, once established, inode to wb association never changes,
going through wbc when initializing bio's doesn't cause any behavior
changes.
v2: submit_blk_blkcg() now checks whether the wbc is associated with a
[__]block_write_full_page() is used to implement ->writepage in
various filesystems. All writeback logic is now updated to handle
cgroup writeback and the block cgroup to issue IOs for is encoded in
writeback_control and can be retrieved from the inode; however,
[__]block_write_full_page() currently ignores the blkcg indicated by
inode and issues all bio's without explicit blkcg association.
This patch adds submit_bh_blkcg() which associates the bio with the
specified blkio cgroup before issuing and uses it in
__block_write_full_page() so that the issued bio's are associated with
inode_to_wb_blkcg_css(inode).
v2: Updated for per-inode wb association.
When modifying PG_Dirty on cached file pages, update the new
MEM_CGROUP_STAT_DIRTY counter. This is done in the same places where
global NR_FILE_DIRTY is managed. The new memcg stat is visible in the
per memcg memory.stat cgroupfs file. The most recent past attempt at
this was http://thread.gmane.org/gmane.linux.kernel.cgroups/8632
The new accounting supports future efforts to add per cgroup dirty
page throttling and writeback. It also helps an administrator break
down a container's memory usage and provides evidence to understand
memcg oom kills (the new dirty count is included in memcg oom kill
messages).
The ability to move page accounting between memcg
(memory.move_charge_at_immigrate) makes this accounting more
complicated than the global counter. The existing
mem_cgroup_{begin,end}_page_stat() lock is used to serialize move
accounting with stat updates.
Typical update operation:
memcg = mem_cgroup_begin_page_stat(page)
if (TestSetPageDirty()) {
mem_cgroup_update_page_stat(memcg)
mem_cgroup_end_page_stat(memcg)
Summary of mem_cgroup_end_page_stat() overhead:
- Without CONFIG_MEMCG it's a no-op
- With CONFIG_MEMCG and no inter memcg task movement, it's just
rcu_read_lock()
- With CONFIG_MEMCG and inter memcg task movement, it's
rcu_read_lock() + spin_lock_irqsave()
A memcg parameter is added to several routines because their callers
now grab mem_cgroup_begin_page_stat() which returns the memcg later
needed by for mem_cgroup_update_page_stat().
Because mem_cgroup_begin_page_stat() may disable interrupts, some
adjustments are needed:
- move __mark_inode_dirty() from __set_page_dirty() to its caller.
__mark_inode_dirty() locking does not want interrupts disabled.
- use spin_lock_irqsave(tree_lock) rather than spin_lock_irq() in
__delete_from_page_cache(), replace_page_cache_page(),
invalidate_complete_page2(), and __remove_mapping().
8925147 1774832 1785856 12485835 be84cb vmlinux-!CONFIG_MEMCG-before
8925339 1774832 1785856 12486027 be858b vmlinux-!CONFIG_MEMCG-after
+192 text bytes
8965977 1784992 1785856 12536825 bf4bf9 vmlinux-CONFIG_MEMCG-before
8966750 1784992 1785856 12537598 bf4efe vmlinux-CONFIG_MEMCG-after
+773 text bytes
Performance tests run on v4.0-rc1-36-g4f671fe2f952. Lower is better for
all metrics, they're all wall clock or cycle counts. The read and write
fault benchmarks just measure fault time, they do not include I/O time.
* CONFIG_MEMCG not set:
baseline patched
kbuild 1m25.030000(+-0.088% 3 samples) 1m25.426667(+-0.120% 3 samples)
dd write 100 MiB 0.859211561 +-15.10% 0.874162885 +-15.03%
dd write 200 MiB 1.670653105 +-17.87% 1.669384764 +-11.99%
dd write 1000 MiB 8.434691190 +-14.15% 8.474733215 +-14.77%
read fault cycles 254.0(+-0.000% 10 samples) 253.0(+-0.000% 10 samples)
write fault cycles 2021.2(+-3.070% 10 samples) 1984.5(+-1.036% 10 samples)
* CONFIG_MEMCG=y root_memcg:
baseline patched
kbuild 1m25.716667(+-0.105% 3 samples) 1m25.686667(+-0.153% 3 samples)
dd write 100 MiB 0.855650830 +-14.90% 0.887557919 +-14.90%
dd write 200 MiB 1.688322953 +-12.72% 1.667682724 +-13.33%
dd write 1000 MiB 8.418601605 +-14.30% 8.673532299 +-15.00%
read fault cycles 266.0(+-0.000% 10 samples) 266.0(+-0.000% 10 samples)
write fault cycles 2051.7(+-1.349% 10 samples) 2049.6(+-1.686% 10 samples)
* CONFIG_MEMCG=y non-root_memcg:
baseline patched
kbuild 1m26.120000(+-0.273% 3 samples) 1m25.763333(+-0.127% 3 samples)
dd write 100 MiB 0.861723964 +-15.25% 0.818129350 +-14.82%
dd write 200 MiB 1.669887569 +-13.30% 1.698645885 +-13.27%
dd write 1000 MiB 8.383191730 +-14.65% 8.351742280 +-14.52%
read fault cycles 265.7(+-0.172% 10 samples) 267.0(+-0.000% 10 samples)
write fault cycles 2070.6(+-1.512% 10 samples) 2084.4(+-2.148% 10 samples)
As expected anon page faults are not affected by this patch.
tj: Updated to apply on top of the recent cancel_dirty_page() changes.
Signed-off-by: Sha Zhengju <handai.szj@gmail.com>
Signed-off-by: Greg Thelen <gthelen@google.com>
cancel_dirty_page() had some issues and b9ea25152e56 ("page_writeback:
clean up mess around cancel_dirty_page()") replaced it with
account_page_cleaned() which makes the caller responsible for clearing
the dirty bit; unfortunately, the planned changes for cgroup writeback
support requires synchronization between dirty bit manipulation and
stat updates. While we can open-code such synchronization in each
account_page_cleaned() callsite, that's gonna be unnecessarily awkward
and verbose.
This patch revives cancel_dirty_page() but in a more restricted form.
All it does is TestClearPageDirty() followed by account_page_cleaned()
invocation if the page was dirty. This helper covers all
account_page_cleaned() usages except for __delete_from_page_cache()
which is a special case anyway and left alone. As this leaves no
module user for account_page_cleaned(), EXPORT_SYMBOL() is dropped
from it.
This patch just revives cancel_dirty_page() as a trivial wrapper to
replace equivalent usages and doesn't introduce any functional
changes.
Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Remove unneeded variable used to store return value.
Generated by: scripts/coccinelle/misc/returnvar.cocci
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Julia Lawall <julia.lawall@lip6.fr>
Since the big barrier rewrite/removal in 2007 we never fail FLUSH or
FUA requests, which means we can remove the magic BIO_EOPNOTSUPP flag
to help propagating those to the buffer_head layer.
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
This patch replaces cancel_dirty_page() with a helper function
account_page_cleaned() which only updates counters. It's called from
truncate_complete_page() and from try_to_free_buffers() (hack for ext3).
Page is locked in both cases, page-lock protects against concurrent
dirtiers: see commit 2d6d7f982846 ("mm: protect set_page_dirty() from
ongoing truncation").
Delete_from_page_cache() shouldn't be called for dirty pages, they must
be handled by caller (either written or truncated). This patch treats
final dirty accounting fixup at the end of __delete_from_page_cache() as
a debug check and adds WARN_ON_ONCE() around it. If something removes
dirty pages without proper handling that might be a bug and unwritten
data might be lost.
Hugetlbfs has no dirty pages accounting, ClearPageDirty() is enough
here.
cancel_dirty_page() in nfs_wb_page_cancel() is redundant. This is
helper for nfs_invalidate_page() and it's called only in case complete
invalidation.
The mess was started in v2.6.20 after commits 46d2277c796f ("Clean up
and make try_to_free_buffers() not race with dirty pages") and
3e67c0987d75 ("truncate: clear page dirtiness before running
try_to_free_buffers()") first was reverted right in v2.6.20 in commit
ecdfc9787fe5 ("Resurrect 'try_to_free_buffers()' VM hackery"), second in
v2.6.25 commit a2b345642f53 ("Fix dirty page accounting leak with ext3
data=journal").
Custom fixes were introduced between these points. NFS in v2.6.23, commit
1b3b4a1a2deb ("NFS: Fix a write request leak in nfs_invalidate_page()").
Kludge in __delete_from_page_cache() in v2.6.24, commit 3a6927906f1b ("Do
dirty page accounting when removing a page from the page cache"). Since
v2.6.25 all of them are redundant.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Tejun Heo <tj@kernel.org>
When quiet_error applies rate limiting to buffer_io_error calls, what the
they apply to is unclear because the name is so generic, particularly
if the messages are interleaved with others:
[ 1936.063572] quiet_error: 664293 callbacks suppressed
[ 1936.065297] Buffer I/O error on dev sdr, logical block 257429952, lost async page write
[ 1936.067814] Buffer I/O error on dev sdr, logical block 257429953, lost async page write
Also, the function uses printk_ratelimit(), although printk.h includes a
comment advising "Please don't use... Instead use printk_ratelimited()."
Change buffer_io_error to check the BH_Quiet bit itself, drop the
printk_ratelimit call, and print using printk_ratelimited.
This makes the messages look like:
[ 387.208839] buffer_io_error: 676394 callbacks suppressed
[ 387.210693] Buffer I/O error on dev sdr, logical block 211291776, lost async page write
[ 387.213432] Buffer I/O error on dev sdr, logical block 211291777, lost async page write
Signed-off-by: Robert Elliott <elliott@hp.com>
Reviewed-by: Webb Scales <webbnh@hp.com>
buffer.c uses two printk calls to print these messages:
[67353.422338] Buffer I/O error on device sdr, logical block 212868488
[67353.422338] lost page write due to I/O error on sdr
In a busy system, they may be interleaved with other prints,
losing the context for the second message. Merge them into
one line with one printk call so the prints are atomic.
Also, differentiate between async page writes, sync page writes, and
async page reads.
Also, shorten "device" to "dev" to match the block layer prints:
[67353.467906] blk_update_request: critical target error, dev sdr, sector
1707107328
Also, use %llu rather than %Lu.
Resulting prints look like:
[ 1356.437006] blk_update_request: critical target error, dev sdr, sector 1719693992
[ 1361.383522] quiet_error: 659876 callbacks suppressed
[ 1361.385816] Buffer I/O error on dev sdr, logical block 256902912, lost async page write
[ 1361.385819] Buffer I/O error on dev sdr, logical block 256903644, lost async page write
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"A large number of cleanups and bug fixes, with some (minor) journal
optimizations"
[ This got sent to me before -rc1, but was stuck in my spam folder. - Linus ]
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (67 commits)
ext4: check s_chksum_driver when looking for bg csum presence
ext4: move error report out of atomic context in ext4_init_block_bitmap()
ext4: Replace open coded mdata csum feature to helper function
ext4: delete useless comments about ext4_move_extents
ext4: fix reservation overflow in ext4_da_write_begin
ext4: add ext4_iget_normal() which is to be used for dir tree lookups
ext4: don't orphan or truncate the boot loader inode
ext4: grab missed write_count for EXT4_IOC_SWAP_BOOT
ext4: optimize block allocation on grow indepth
ext4: get rid of code duplication
ext4: fix over-defensive complaint after journal abort
ext4: fix return value of ext4_do_update_inode
ext4: fix mmap data corruption when blocksize < pagesize
vfs: fix data corruption when blocksize < pagesize for mmaped data
ext4: fold ext4_nojournal_sops into ext4_sops
ext4: support freezing ext2 (nojournal) file systems
ext4: fold ext4_sync_fs_nojournal() into ext4_sync_fs()
ext4: don't check quota format when there are no quota files
jbd2: simplify calling convention around __jbd2_journal_clean_checkpoint_list
jbd2: avoid pointless scanning of checkpoint lists
It's very common for the buffer heads in the lru to have different block
numbers. By comparing the blocknr before the bdev and size we can
reduce the cost of searching in the very common case where all the
entries have the same bdev and size.
In quick hot cache cycle counting tests on a single fs workstation this
cut the cost of a miss by about 20%.
A diff of the disassembly shows the reordering of the bdev and blocknr
comparisons. This is in such a tiny loop that skipping one comparison
is a meaningful portion of the total work being done:
1628: 83 c1 01 add $0x1,%ecx
162b: 83 f9 08 cmp $0x8,%ecx
162e: 74 60 je 1690 <__find_get_block+0xa0>
1630: 89 c8 mov %ecx,%eax
1632: 65 4c 8b 04 c5 00 00 mov %gs:0x0(,%rax,8),%r8
1639: 00 00
163b: 4d 85 c0 test %r8,%r8
163e: 4c 89 c3 mov %r8,%rbx
1641: 74 e5 je 1628 <__find_get_block+0x38>
- 1643: 4d 3b 68 30 cmp 0x30(%r8),%r13
+ 1643: 4d 3b 68 18 cmp 0x18(%r8),%r13
1647: 75 df jne 1628 <__find_get_block+0x38>
- 1649: 4d 3b 60 18 cmp 0x18(%r8),%r12
+ 1649: 4d 3b 60 30 cmp 0x30(%r8),%r12
164d: 75 d9 jne 1628 <__find_get_block+0x38>
164f: 49 39 50 20 cmp %rdx,0x20(%r8)
1653: 75 d3 jne 1628 <__find_get_block+0x38>
Signed-off-by: Zach Brown <zab@zabbo.net>
Pull vfs updates from Al Viro:
"The big thing in this pile is Eric's unmount-on-rmdir series; we
finally have everything we need for that. The final piece of prereqs
is delayed mntput() - now filesystem shutdown always happens on
shallow stack.
Other than that, we have several new primitives for iov_iter (Matt
Wilcox, culled from his XIP-related series) pushing the conversion to
->read_iter()/ ->write_iter() a bit more, a bunch of fs/dcache.c
cleanups and fixes (including the external name refcounting, which
gives consistent behaviour of d_move() wrt procfs symlinks for long
and short names alike) and assorted cleanups and fixes all over the
place.
This is just the first pile; there's a lot of stuff from various
people that ought to go in this window. Starting with
unionmount/overlayfs mess... ;-/"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (60 commits)
fs/file_table.c: Update alloc_file() comment
vfs: Deduplicate code shared by xattr system calls operating on paths
reiserfs: remove pointless forward declaration of struct nameidata
don't need that forward declaration of struct nameidata in dcache.h anymore
take dname_external() into fs/dcache.c
let path_init() failures treated the same way as subsequent link_path_walk()
fix misuses of f_count() in ppp and netlink
ncpfs: use list_for_each_entry() for d_subdirs walk
vfs: move getname() from callers to do_mount()
gfs2_atomic_open(): skip lookups on hashed dentry
[infiniband] remove pointless assignments
gadgetfs: saner API for gadgetfs_create_file()
f_fs: saner API for ffs_sb_create_file()
jfs: don't hash direct inode
[s390] remove pointless assignment of ->f_op in vmlogrdr ->open()
ecryptfs: ->f_op is never NULL
android: ->f_op is never NULL
nouveau: __iomem misannotations
missing annotation in fs/file.c
fs: namespace: suppress 'may be used uninitialized' warnings
Increase the buffer-head per-CPU LRU size to allow efficient filesystem
operations that access many blocks for each transaction. For example,
creating a file in a large ext4 directory with quota enabled will access
multiple buffer heads and will overflow the LRU at the default 8-block LRU
size:
* parent directory inode table block (ctime, nlinks for subdirs)
* new inode bitmap
* inode table block
* 2 quota blocks
* directory leaf block (not reused, but pollutes one cache entry)
* 2 levels htree blocks (only one is reused, other pollutes cache)
* 2 levels indirect/index blocks (only one is reused)
The buffer-head per-CPU LRU size is raised to 16, as it shows in metadata
performance benchmarks up to 10% gain for create, 4% for lookup and 7% for
destroy.
Signed-off-by: Liang Zhen <liang.zhen@intel.com>
Signed-off-by: Andreas Dilger <andreas.dilger@intel.com>
Signed-off-by: Sebastien Buisson <sebastien.buisson@bull.net>
Add guard_bio_eod() check for mpage code in order to allow us to do IO
even on the odd last sectors of a device, even if the block size is some
multiple of the physical sector size.
Using mpage_readpages() for block device requires this guard check.
Cc: Jeff Moyer <jmoyer@redhat.com>
This patchset implements readpages() operation for block device by using
mpage_readpages() which can create multipage BIOs instead of BIOs for each
page and reduce system CPU time consumption.
This patch (of 3):
guard_bh_eod() is used in submit_bh() to allow us to do IO even on the odd
last sectors of a device, even if the block size is some multiple of the
physical sector size. This makes guard_bh_eod() more generic and renames
it guard_bio_eod() so that we can use it without struct buffer_head
argument.
The reason for this change is that using mpage_readpages() for block
device requires to add this guard check in mpage code.
This patch makes it possible to kill a process looping in
cont_expand_zero. A process may spend a lot of time in this function, so
it is desirable to be able to kill it.
It happened to me that I wanted to copy a piece data from the disk to a
file. By mistake, I used the "seek" parameter to dd instead of "skip". Due
to the "seek" parameter, dd attempted to extend the file and became stuck
doing so - the only possibility was to reset the machine or wait many
hours until the filesystem runs out of space and cont_expand_zero fails.
We need this patch to be able to terminate the process.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: stable@vger.kernel.org
->page_mkwrite() is used by filesystems to allocate blocks under a page
which is becoming writeably mmapped in some process' address space. This
allows a filesystem to return a page fault if there is not enough space
available, user exceeds quota or similar problem happens, rather than
silently discarding data later when writepage is called.
However VFS fails to call ->page_mkwrite() in all the cases where
filesystems need it when blocksize < pagesize. For example when
blocksize = 1024, pagesize = 4096 the following is problematic:
ftruncate(fd, 0);
pwrite(fd, buf, 1024, 0);
map = mmap(NULL, 1024, PROT_WRITE, MAP_SHARED, fd, 0);
map[0] = 'a'; ----> page_mkwrite() for index 0 is called
ftruncate(fd, 10000); /* or even pwrite(fd, buf, 1, 10000) */
mremap(map, 1024, 10000, 0);
map[4095] = 'a'; ----> no page_mkwrite() called
At the moment ->page_mkwrite() is called, filesystem can allocate only
one block for the page because i_size == 1024. Otherwise it would create
blocks beyond i_size which is generally undesirable. But later at
->writepage() time, we also need to store data at offset 4095 but we
don't have block allocated for it.
This patch introduces a helper function filesystems can use to have
->page_mkwrite() called at all the necessary moments.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
On 32-bit architectures, the legacy buffer_head functions are not always
handling the sector number with the proper 64-bit types, and will thus
fail on 4TB+ disks.
Any code that uses __getblk() (and thus bread(), breadahead(),
sb_bread(), sb_breadahead(), sb_getblk()), and calls it using a 64-bit
block on a 32-bit arch (where "long" is 32-bit) causes an inifinite loop
in __getblk_slow() with an infinite stream of errors logged to dmesg
like this:
__find_get_block_slow() failed. block=6740375944, b_blocknr=2445408648
b_state=0x00000020, b_size=512
device sda1 blocksize: 512
Note how in hex block is 0x191C1F988 and b_blocknr is 0x91C1F988 i.e. the
top 32-bits are missing (in this case the 0x1 at the top).
This is because grow_dev_page() is broken and has a 32-bit overflow due
to shifting the page index value (a pgoff_t - which is just 32 bits on
32-bit architectures) left-shifted as the block number. But the top
bits to get lost as the pgoff_t is not type cast to sector_t / 64-bit
before the shift.
This patch fixes this issue by type casting "index" to sector_t before
doing the left shift.
Note this is not a theoretical bug but has been seen in the field on a
4TiB hard drive with logical sector size 512 bytes.
This patch has been verified to fix the infinite loop problem on 3.17-rc5
kernel using a 4TB disk image mounted using "-o loop". Without this patch
doing a "find /nt" where /nt is an NTFS volume causes the inifinite loop
100% reproducibly whilst with the patch it works fine as expected.
Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
A buffer cache is allocated from movable area because it is referred
for a while and released soon. But some filesystems are taking buffer
cache for a long time and it can disturb page migration.
New APIs are introduced to allocate buffer cache with user specific
flag. *_gfp APIs are for user want to set page allocation flag for
page cache allocation. And *_unmovable APIs are for the user wants to
allocate page cache from non-movable area.
Signed-off-by: Gioh Kim <gioh.kim@lge.com>
The current "wait_on_bit" interface requires an 'action'
function to be provided which does the actual waiting.
There are over 20 such functions, many of them identical.
Most cases can be satisfied by one of just two functions, one
which uses io_schedule() and one which just uses schedule().
So:
Rename wait_on_bit and wait_on_bit_lock to
wait_on_bit_action and wait_on_bit_lock_action
to make it explicit that they need an action function.
Introduce new wait_on_bit{,_lock} and wait_on_bit{,_lock}_io
which are *not* given an action function but implicitly use
a standard one.
The decision to error-out if a signal is pending is now made
based on the 'mode' argument rather than being encoded in the action
function.
All instances of the old wait_on_bit and wait_on_bit_lock which
can use the new version have been changed accordingly and their
action functions have been discarded.
wait_on_bit{_lock} does not return any specific error code in the
event of a signal so the caller must check for non-zero and
interpolate their own error code as appropriate.
The wait_on_bit() call in __fscache_wait_on_invalidate() was
ambiguous as it specified TASK_UNINTERRUPTIBLE but used
fscache_wait_bit_interruptible as an action function.
David Howells confirms this should be uniformly
"uninterruptible"
The main remaining user of wait_on_bit{,_lock}_action is NFS
which needs to use a freezer-aware schedule() call.
A comment in fs/gfs2/glock.c notes that having multiple 'action'
functions is useful as they display differently in the 'wchan'
field of 'ps'. (and /proc/$PID/wchan).
As the new bit_wait{,_io} functions are tagged "__sched", they
will not show up at all, but something higher in the stack. So
the distinction will still be visible, only with different
function names (gds2_glock_wait versus gfs2_glock_dq_wait in the
gfs2/glock.c case).
Since first version of this patch (against 3.15) two new action
functions appeared, on in NFS and one in CIFS. CIFS also now
uses an action function that makes the same freezer aware
schedule call as NFS.
Signed-off-by: NeilBrown <neilb@suse.de>
Acked-by: David Howells <dhowells@redhat.com> (fscache, keys)
Acked-by: Steven Whitehouse <swhiteho@redhat.com> (gfs2)
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Steve French <sfrench@samba.org>
Link: http://lkml.kernel.org/r/20140707051603.28027.72349.stgit@notabene.brown
possible
aops->write_begin may allocate a new page and make it visible only to have
mark_page_accessed called almost immediately after. Once the page is
visible the atomic operations are necessary which is noticable overhead
when writing to an in-memory filesystem like tmpfs but should also be
noticable with fast storage. The objective of the patch is to initialse
the accessed information with non-atomic operations before the page is
visible.
The bulk of filesystems directly or indirectly use
grab_cache_page_write_begin or find_or_create_page for the initial
allocation of a page cache page. This patch adds an init_page_accessed()
helper which behaves like the first call to mark_page_accessed() but may
called before the page is visible and can be done non-atomically.
The primary APIs of concern in this care are the following and are used
by most filesystems.
find_get_page
find_lock_page
find_or_create_page
grab_cache_page_nowait
All of them are very similar in detail to the patch creates a core helper
pagecache_get_page() which takes a flags parameter that affects its
behavior such as whether the page should be marked accessed or not. Then
old API is preserved but is basically a thin wrapper around this core
function.
Each of the filesystems are then updated to avoid calling
mark_page_accessed when it is known that the VM interfaces have already
done the job. There is a slight snag in that the timing of the
mark_page_accessed() has now changed so in rare cases it's possible a page
gets to the end of the LRU as PageReferenced where as previously it might
have been repromoted. This is expected to be rare but it's worth the
filesystem people thinking about it in case they see a problem with the
timing change. It is also the case that some filesystems may be marking
pages accessed that previously did not but it makes sense that filesystems
have consistent behaviour in this regard.
The test case used to evaulate this is a simple dd of a large file done
multiple times with the file deleted on each iterations. The size of the
file is 1/10th physical memory to avoid dirty page balancing. In the
async case it will be possible that the workload completes without even
hitting the disk and will have variable results but highlight the impact
of mark_page_accessed for async IO. The sync results are expected to be
more stable. The exception is tmpfs where the normal case is for the "IO"
to not hit the disk.
The test machine was single socket and UMA to avoid any scheduling or NUMA
artifacts. Throughput and wall times are presented for sync IO, only wall
times are shown for async as the granularity reported by dd and the
variability is unsuitable for comparison. As async results were variable
do to writback timings, I'm only reporting the maximum figures. The sync
results were stable enough to make the mean and stddev uninteresting.
The performance results are reported based on a run with no profiling.
Profile data is based on a separate run with oprofile running.
async dd
3.15.0-rc3 3.15.0-rc3
vanilla accessed-v2
ext3 Max elapsed 13.9900 ( 0.00%) 11.5900 ( 17.16%)
tmpfs Max elapsed 0.5100 ( 0.00%) 0.4900 ( 3.92%)
btrfs Max elapsed 12.8100 ( 0.00%) 12.7800 ( 0.23%)
ext4 Max elapsed 18.6000 ( 0.00%) 13.3400 ( 28.28%)
xfs Max elapsed 12.5600 ( 0.00%) 2.0900 ( 83.36%)
The XFS figure is a bit strange as it managed to avoid a worst case by
sheer luck but the average figures looked reasonable.
samples percentage
ext3 86107 0.9783 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext3 23833 0.2710 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext3 5036 0.0573 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
ext4 64566 0.8961 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext4 5322 0.0713 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext4 2869 0.0384 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 62126 1.7675 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
xfs 1904 0.0554 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 103 0.0030 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
btrfs 10655 0.1338 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
btrfs 2020 0.0273 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
btrfs 587 0.0079 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
tmpfs 59562 3.2628 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
tmpfs 1210 0.0696 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
tmpfs 94 0.0054 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
[akpm@linux-foundation.org: don't run init_page_accessed() against an uninitialised pointer]
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Tested-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
Discarding buffers uses a bunch of atomic operations when discarding
buffers because ...... I can't think of a reason. Use a cmpxchg loop to
clear all the necessary flags. In most (all?) cases this will be a single
atomic operations.
[akpm@linux-foundation.org: move BUFFER_FLAGS_DISCARD into the .c file]
The last in-tree caller of block_write_full_page_endio() was removed in
January 2013. It's time to remove the EXPORT_SYMBOL, which leaves
block_write_full_page() as the only caller of
block_write_full_page_endio(), so inline block_write_full_page_endio()
into block_write_full_page().
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Dheeraj Reddy <dheeraj.reddy@intel.com>
Mostly scripted conversion of the smp_mb__* barriers.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-55dhyhocezdw1dg7u19hmh1u@git.kernel.org
