path: root/fs/cachefiles
2013-11-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "All kinds of stuff this time around; some more notable parts: - RCU'd vfsmounts handling - new primitives for coredump handling - files_lock is gone - Bruce's delegations handling series - exportfs fixes plus misc stuff all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (101 commits) ecryptfs: ->f_op is never NULL locks: break delegations on any attribute modification locks: break delegations on link locks: break delegations on rename locks: helper functions for delegation breaking locks: break delegations on unlink namei: minor vfs_unlink cleanup locks: implement delegations locks: introduce new FL_DELEG lock flag vfs: take i_mutex on renamed file vfs: rename I_MUTEX_QUOTA now that it's not used for quotas vfs: don't use PARENT/CHILD lock classes for non-directories vfs: pull ext4's double-i_mutex-locking into common code exportfs: fix quadratic behavior in filehandle lookup exportfs: better variable name exportfs: move most of reconnect_path to helper function exportfs: eliminate unused "noprogress" counter exportfs: stop retrying once we race with rename/remove exportfs: clear DISCONNECTED on all parents sooner exportfs: more detailed comment for path_reconnect ...
2013-11-09locks: break delegations on any attribute modificationJ. Bruce Fields
NFSv4 uses leases to guarantee that clients can cache metadata as well as data. Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: David Howells <dhowells@redhat.com> Cc: Tyler Hicks <tyhicks@canonical.com> Cc: Dustin Kirkland <dustin.kirkland@gazzang.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-09locks: break delegations on renameJ. Bruce Fields
Cc: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-09locks: break delegations on unlinkJ. Bruce Fields
We need to break delegations on any operation that changes the set of links pointing to an inode. Start with unlink. Such operations also hold the i_mutex on a parent directory. Breaking a delegation may require waiting for a timeout (by default 90 seconds) in the case of a unresponsive NFS client. To avoid blocking all directory operations, we therefore drop locks before waiting for the delegation. The logic then looks like: acquire locks ... test for delegation; if found: take reference on inode release locks wait for delegation break drop reference on inode retry It is possible this could never terminate. (Even if we take precautions to prevent another delegation being acquired on the same inode, we could get a different inode on each retry.) But this seems very unlikely. The initial test for a delegation happens after the lock on the target inode is acquired, but the directory inode may have been acquired further up the call stack. We therefore add a "struct inode **" argument to any intervening functions, which we use to pass the inode back up to the caller in the case it needs a delegation synchronously broken. Cc: David Howells <dhowells@redhat.com> Cc: Tyler Hicks <tyhicks@canonical.com> Cc: Dustin Kirkland <dustin.kirkland@gazzang.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-27FS-Cache: Provide the ability to enable/disable cookiesDavid Howells
Provide the ability to enable and disable fscache cookies. A disabled cookie will reject or ignore further requests to: Acquire a child cookie Invalidate and update backing objects Check the consistency of a backing object Allocate storage for backing page Read backing pages Write to backing pages but still allows: Checks/waits on the completion of already in-progress objects Uncaching of pages Relinquishment of cookies Two new operations are provided: (1) Disable a cookie: void fscache_disable_cookie(struct fscache_cookie *cookie, bool invalidate); If the cookie is not already disabled, this locks the cookie against other dis/enablement ops, marks the cookie as being disabled, discards or invalidates any backing objects and waits for cessation of activity on any associated object. This is a wrapper around a chunk split out of fscache_relinquish_cookie(), but it reinitialises the cookie such that it can be reenabled. All possible failures are handled internally. The caller should consider calling fscache_uncache_all_inode_pages() afterwards to make sure all page markings are cleared up. (2) Enable a cookie: void fscache_enable_cookie(struct fscache_cookie *cookie, bool (*can_enable)(void *data), void *data) If the cookie is not already enabled, this locks the cookie against other dis/enablement ops, invokes can_enable() and, if the cookie is not an index cookie, will begin the procedure of acquiring backing objects. The optional can_enable() function is passed the data argument and returns a ruling as to whether or not enablement should actually be permitted to begin. All possible failures are handled internally. The cookie will only be marked as enabled if provisional backing objects are allocated. A later patch will introduce these to NFS. Cookie enablement during nfs_open() is then contingent on i_writecount <= 0. can_enable() checks for a race between open(O_RDONLY) and open(O_WRONLY/O_RDWR). This simplifies NFS's cookie handling and allows us to get rid of open(O_RDONLY) accidentally introducing caching to an inode that's open for writing already. One operation has its API modified: (3) Acquire a cookie. struct fscache_cookie *fscache_acquire_cookie( struct fscache_cookie *parent, const struct fscache_cookie_def *def, void *netfs_data, bool enable); This now has an additional argument that indicates whether the requested cookie should be enabled by default. It doesn't need the can_enable() function because the caller must prevent multiple calls for the same netfs object and it doesn't need to take the enablement lock because no one else can get at the cookie before this returns. Signed-off-by: David Howells <dhowells@redhat.com
2013-09-20CacheFiles: Don't try to dump the index key if the cookie has been clearedDavid Howells
Don't try to dump the index key that distinguishes an object if netfs data in the cookie the object refers to has been cleared (ie. the cookie has passed most of the way through __fscache_relinquish_cookie()). Since the netfs holds the index key, we can't get at it once the ->def and ->netfs_data pointers have been cleared - and a NULL pointer exception will ensue, usually just after a: CacheFiles: Error: Unexpected object collision error is reported. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-20CacheFiles: Fix memory leak in cachefiles_check_auxdata error pathsJosh Boyer
In cachefiles_check_auxdata(), we allocate auxbuf but fail to free it if we determine there's an error or that the data is stale. Further, assigning the output of vfs_getxattr() to auxbuf->len gives problems with checking for errors as auxbuf->len is a u16. We don't actually need to set auxbuf->len, so keep the length in a variable for now. We shouldn't need to check the upper limit of the buffer as an overflow there should be indicated by -ERANGE. While we're at it, fscache_check_aux() returns an enum value, not an int, so assign it to an appropriately typed variable rather than to ret. Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> Signed-off-by: David Howells <dhowells@redhat.com> cc: Hongyi Jia <jiayisuse@gmail.com> cc: Milosz Tanski <milosz@adfin.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-06CacheFiles: Implement interface to check cache consistencyDavid Howells
Implement the FS-Cache interface to check the consistency of a cache object in CacheFiles. Original-author: Hongyi Jia <jiayisuse@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: Hongyi Jia <jiayisuse@gmail.com> cc: Milosz Tanski <milosz@adfin.com>
2013-07-03mm: remove lru parameter from __pagevec_lru_add and remove parts of pagevec APIMel Gorman
Now that the LRU to add a page to is decided at LRU-add time, remove the misleading lru parameter from __pagevec_lru_add. A consequence of this is that the pagevec_lru_add_file, pagevec_lru_add_anon and similar helpers are misleading as the caller no longer has direct control over what LRU the page is added to. Unused helpers are removed by this patch and existing users of pagevec_lru_add_file() are converted to use lru_cache_add_file() directly and use the per-cpu pagevecs instead of creating their own pagevec. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Jan Kara <jack@suse.cz> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Alexey Lyahkov <alexey.lyashkov@gmail.com> Cc: Andrew Perepechko <anserper@ya.ru> Cc: Robin Dong <sanbai@taobao.com> Cc: Theodore Tso <tytso@mit.edu> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Bernd Schubert <bernd.schubert@fastmail.fm> Cc: David Howells <dhowells@redhat.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-19cachefiles: remove unused macro list_to_page()Haicheng Li
Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com> Signed-off-by: David Howells <dhowells@redhat.com> Tested-By: Milosz Tanski <milosz@adfin.com> Acked-by: Jeff Layton <jlayton@redhat.com>
2013-06-19FS-Cache: Simplify cookie retention for fscache_objects, fixing oopsDavid Howells
Simplify the way fscache cache objects retain their cookie. The way I implemented the cookie storage handling made synchronisation a pain (ie. the object state machine can't rely on the cookie actually still being there). Instead of the the object being detached from the cookie and the cookie being freed in __fscache_relinquish_cookie(), we defer both operations: (*) The detachment of the object from the list in the cookie now takes place in fscache_drop_object() and is thus governed by the object state machine (fscache_detach_from_cookie() has been removed). (*) The release of the cookie is now in fscache_object_destroy() - which is called by the cache backend just before it frees the object. This means that the fscache_cookie struct is now available to the cache all the way through from ->alloc_object() to ->drop_object() and ->put_object() - meaning that it's no longer necessary to take object->lock to guarantee access. However, __fscache_relinquish_cookie() doesn't wait for the object to go all the way through to destruction before letting the netfs proceed. That would massively slow down the netfs. Since __fscache_relinquish_cookie() leaves the cookie around, in must therefore break all attachments to the netfs - which includes ->def, ->netfs_data and any outstanding page read/writes. To handle this, struct fscache_cookie now has an n_active counter: (1) This starts off initialised to 1. (2) Any time the cache needs to get at the netfs data, it calls fscache_use_cookie() to increment it - if it is not zero. If it was zero, then access is not permitted. (3) When the cache has finished with the data, it calls fscache_unuse_cookie() to decrement it. This does a wake-up on it if it reaches 0. (4) __fscache_relinquish_cookie() decrements n_active and then waits for it to reach 0. The initialisation to 1 in step (1) ensures that we only get wake ups when we're trying to get rid of the cookie. This leaves __fscache_relinquish_cookie() a lot simpler. *** This fixes a problem in the current code whereby if fscache_invalidate() is followed sufficiently quickly by fscache_relinquish_cookie() then it is possible for __fscache_relinquish_cookie() to have detached the cookie from the object and cleared the pointer before a thread is dispatched to process the invalidation state in the object state machine. Since the pending write clearance was deferred to the invalidation state to make it asynchronous, we need to either wait in relinquishment for the stores tree to be cleared in the invalidation state or we need to handle the clearance in relinquishment. Further, if the relinquishment code does clear the tree, then the invalidation state need to make the clearance contingent on still having the cookie to hand (since that's where the tree is rooted) and we have to prevent the cookie from disappearing for the duration. This can lead to an oops like the following: BUG: unable to handle kernel NULL pointer dereference at 000000000000000c ... RIP: 0010:[<ffffffff8151023e>] _spin_lock+0xe/0x30 ... CR2: 000000000000000c ... ... Process kslowd002 (...) .... Call Trace: [<ffffffffa01c3278>] fscache_invalidate_writes+0x38/0xd0 [fscache] [<ffffffff810096f0>] ? __switch_to+0xd0/0x320 [<ffffffff8105e759>] ? find_busiest_queue+0x69/0x150 [<ffffffff8110ddd4>] ? slow_work_enqueue+0x104/0x180 [<ffffffffa01c1303>] fscache_object_slow_work_execute+0x5e3/0x9d0 [fscache] [<ffffffff81096b67>] ? bit_waitqueue+0x17/0xd0 [<ffffffff8110e233>] slow_work_execute+0x233/0x310 [<ffffffff8110e515>] slow_work_thread+0x205/0x360 [<ffffffff81096ca0>] ? autoremove_wake_function+0x0/0x40 [<ffffffff8110e310>] ? slow_work_thread+0x0/0x360 [<ffffffff81096936>] kthread+0x96/0xa0 [<ffffffff8100c0ca>] child_rip+0xa/0x20 [<ffffffff810968a0>] ? kthread+0x0/0xa0 [<ffffffff8100c0c0>] ? child_rip+0x0/0x20 The parameter to fscache_invalidate_writes() was object->cookie which is NULL. Signed-off-by: David Howells <dhowells@redhat.com> Tested-By: Milosz Tanski <milosz@adfin.com> Acked-by: Jeff Layton <jlayton@redhat.com>
2013-06-19FS-Cache: Fix object state machine to have separate work and wait statesDavid Howells
Fix object state machine to have separate work and wait states as that makes it easier to envision. There are now three kinds of state: (1) Work state. This is an execution state. No event processing is performed by a work state. The function attached to a work state returns a pointer indicating the next state to which the OSM should transition. Returning NO_TRANSIT repeats the current state, but goes back to the scheduler first. (2) Wait state. This is an event processing state. No execution is performed by a wait state. Wait states are just tables of "if event X occurs, clear it and transition to state Y". The dispatcher returns to the scheduler if none of the events in which the wait state has an interest are currently pending. (3) Out-of-band state. This is a special work state. Transitions to normal states can be overridden when an unexpected event occurs (eg. I/O error). Instead the dispatcher disables and clears the OOB event and transits to the specified work state. This then acts as an ordinary work state, though object->state points to the overridden destination. Returning NO_TRANSIT resumes the overridden transition. In addition, the states have names in their definitions, so there's no need for tables of state names. Further, the EV_REQUEUE event is no longer necessary as that is automatic for work states. Since the states are now separate structs rather than values in an enum, it's not possible to use comparisons other than (non-)equality between them, so use some object->flags to indicate what phase an object is in. The EV_RELEASE, EV_RETIRE and EV_WITHDRAW events have been squished into one (EV_KILL). An object flag now carries the information about retirement. Similarly, the RELEASING, RECYCLING and WITHDRAWING states have been merged into an KILL_OBJECT state and additional states have been added for handling waiting dependent objects (JUMPSTART_DEPS and KILL_DEPENDENTS). A state has also been added for synchronising with parent object initialisation (WAIT_FOR_PARENT) and another for initiating look up (PARENT_READY). Signed-off-by: David Howells <dhowells@redhat.com> Tested-By: Milosz Tanski <milosz@adfin.com> Acked-by: Jeff Layton <jlayton@redhat.com>
2013-06-19FS-Cache: Wrap checks on object stateDavid Howells
Wrap checks on object state (mostly outside of fs/fscache/object.c) with inline functions so that the mechanism can be replaced. Some of the state checks within object.c are left as-is as they will be replaced. Signed-off-by: David Howells <dhowells@redhat.com> Tested-By: Milosz Tanski <milosz@adfin.com> Acked-by: Jeff Layton <jlayton@redhat.com>
2013-06-19CacheFiles: name i_mutex lock class explicitlyJ. Bruce Fields
Just some cleanup. (And note the caller of this function may, for example, call vfs_unlink on a child, so the "1" (I_MUTEX_PARENT) really was what was intended here.) Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Tested-By: Milosz Tanski <milosz@adfin.com> Acked-by: Jeff Layton <jlayton@redhat.com>
2013-04-09lift sb_start_write() out of ->write()Al Viro
2012-12-20FS-Cache: Mark cancellation of in-progress operationDavid Howells
Mark as cancelled an operation that is in progress rather than pending at the time it is cancelled, and call fscache_complete_op() to cancel an operation so that blocked ops can be started. Signed-off-by: David Howells <dhowells@redhat.com>
2012-12-20FS-Cache: Don't mask off the object event mask when printing itDavid Howells
Don't mask off the object event mask when printing it. That way it can be seen if threre are bits set that shouldn't be. Signed-off-by: David Howells <dhowells@redhat.com>
2012-12-20CacheFiles: Add missing retrieval completionsDavid Howells
CacheFiles is missing some calls to fscache_retrieval_complete() in the error handling/collision paths of its reader functions. This can be seen by the following assertion tripping in fscache_put_operation() whereby the operation being destroyed is still in the in-progress state and has not been cancelled or completed: FS-Cache: Assertion failed 3 == 5 is false ------------[ cut here ]------------ kernel BUG at fs/fscache/operation.c:408! invalid opcode: 0000 [#1] SMP CPU 2 Modules linked in: xfs ioatdma dca loop joydev evdev psmouse dcdbas pcspkr serio_raw i5000_edac edac_core i5k_amb shpchp pci_hotplug sg sr_mod] Pid: 8062, comm: httpd Not tainted 3.1.0-rc8 #1 Dell Inc. PowerEdge 1950/0DT097 RIP: 0010:[<ffffffff81197b24>] [<ffffffff81197b24>] fscache_put_operation+0x304/0x330 RSP: 0018:ffff880062f739d8 EFLAGS: 00010296 RAX: 0000000000000025 RBX: ffff8800c5122e84 RCX: ffffffff81ddf040 RDX: 00000000ffffffff RSI: 0000000000000082 RDI: ffffffff81ddef30 RBP: ffff880062f739f8 R08: 0000000000000005 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000003 R12: ffff8800c5122e40 R13: ffff880037a2cd20 R14: ffff880087c7a058 R15: ffff880087c7a000 FS: 00007f63dcf636e0(0000) GS:ffff88022fc80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007f0c0a91f000 CR3: 0000000062ec2000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process httpd (pid: 8062, threadinfo ffff880062f72000, task ffff880087e58000) Stack: ffff880062f73bf8 0000000000000000 ffff880062f73bf8 ffff880037a2cd20 ffff880062f73a68 ffffffff8119aa7e ffff88006540e000 ffff880062f73ad4 ffff88008e9a4308 ffff880037a2cd20 ffff880062f73a48 ffff8800c5122e40 Call Trace: [<ffffffff8119aa7e>] __fscache_read_or_alloc_pages+0x1fe/0x530 [<ffffffff81250780>] __nfs_readpages_from_fscache+0x70/0x1c0 [<ffffffff8123142a>] nfs_readpages+0xca/0x1e0 [<ffffffff815f3c06>] ? rpc_do_put_task+0x36/0x50 [<ffffffff8122755b>] ? alloc_nfs_open_context+0x4b/0x110 [<ffffffff815ecd1a>] ? rpc_call_sync+0x5a/0x70 [<ffffffff810e7e9a>] __do_page_cache_readahead+0x1ca/0x270 [<ffffffff810e7f61>] ra_submit+0x21/0x30 [<ffffffff810e818d>] ondemand_readahead+0x11d/0x250 [<ffffffff810e83b6>] page_cache_sync_readahead+0x36/0x60 [<ffffffff810dffa4>] generic_file_aio_read+0x454/0x770 [<ffffffff81224ce1>] nfs_file_read+0xe1/0x130 [<ffffffff81121bd9>] do_sync_read+0xd9/0x120 [<ffffffff8114088f>] ? mntput+0x1f/0x40 [<ffffffff811238cb>] ? fput+0x1cb/0x260 [<ffffffff81122938>] vfs_read+0xc8/0x180 [<ffffffff81122af5>] sys_read+0x55/0x90 Reported-by: Mark Moseley <moseleymark@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com>
2012-12-20CacheFiles: Implement invalidationDavid Howells
Implement invalidation for CacheFiles. This is in two parts: (1) Provide an invalidation method (which just truncates the backing file). (2) Abort attempts to copy anything read from the backing file whilst invalidation is in progress. Question: CacheFiles uses truncation in a couple of places. It has been using notify_change() rather than sys_truncate() or something similar. This means it bypasses a bunch of checks and suchlike that it possibly should be making (security, file locking, lease breaking, vfsmount write). Should it be using vfs_truncate() as added by a preceding patch or should it use notify_write() and assume that anyone poking around in the cache files on disk gets everything they deserve? Signed-off-by: David Howells <dhowells@redhat.com>
2012-12-20FS-Cache: Fix operation state management and accountingDavid Howells
Fix the state management of internal fscache operations and the accounting of what operations are in what states. This is done by: (1) Give struct fscache_operation a enum variable that directly represents the state it's currently in, rather than spreading this knowledge over a bunch of flags, who's processing the operation at the moment and whether it is queued or not. This makes it easier to write assertions to check the state at various points and to prevent invalid state transitions. (2) Add an 'operation complete' state and supply a function to indicate the completion of an operation (fscache_op_complete()) and make things call it. The final call to fscache_put_operation() can then check that an op in the appropriate state (complete or cancelled). (3) Adjust the use of object->n_ops, ->n_in_progress, ->n_exclusive to better govern the state of an object: (a) The ->n_ops is now the number of extant operations on the object and is now decremented by fscache_put_operation() only. (b) The ->n_in_progress is simply the number of objects that have been taken off of the object's pending queue for the purposes of being run. This is decremented by fscache_op_complete() only. (c) The ->n_exclusive is the number of exclusive ops that have been submitted and queued or are in progress. It is decremented by fscache_op_complete() and by fscache_cancel_op(). fscache_put_operation() and fscache_operation_gc() now no longer try to clean up ->n_exclusive and ->n_in_progress. That was leading to double decrements against fscache_cancel_op(). fscache_cancel_op() now no longer decrements ->n_ops. That was leading to double decrements against fscache_put_operation(). fscache_submit_exclusive_op() now decides whether it has to queue an op based on ->n_in_progress being > 0 rather than ->n_ops > 0 as the latter will persist in being true even after all preceding operations have been cancelled or completed. Furthermore, if an object is active and there are runnable ops against it, there must be at least one op running. (4) Add a remaining-pages counter (n_pages) to struct fscache_retrieval and provide a function to record completion of the pages as they complete. When n_pages reaches 0, the operation is deemed to be complete and fscache_op_complete() is called. Add calls to fscache_retrieval_complete() anywhere we've finished with a page we've been given to read or allocate for. This includes places where we just return pages to the netfs for reading from the server and where accessing the cache fails and we discard the proposed netfs page. The bugs in the unfixed state management manifest themselves as oopses like the following where the operation completion gets out of sync with return of the cookie by the netfs. This is possible because the cache unlocks and returns all the netfs pages before recording its completion - which means that there's nothing to stop the netfs discarding them and returning the cookie. FS-Cache: Cookie 'NFS.fh' still has outstanding reads ------------[ cut here ]------------ kernel BUG at fs/fscache/cookie.c:519! invalid opcode: 0000 [#1] SMP CPU 1 Modules linked in: cachefiles nfs fscache auth_rpcgss nfs_acl lockd sunrpc Pid: 400, comm: kswapd0 Not tainted 3.1.0-rc7-fsdevel+ #1090 /DG965RY RIP: 0010:[<ffffffffa007050a>] [<ffffffffa007050a>] __fscache_relinquish_cookie+0x170/0x343 [fscache] RSP: 0018:ffff8800368cfb00 EFLAGS: 00010282 RAX: 000000000000003c RBX: ffff880023cc8790 RCX: 0000000000000000 RDX: 0000000000002f2e RSI: 0000000000000001 RDI: ffffffff813ab86c RBP: ffff8800368cfb50 R08: 0000000000000002 R09: 0000000000000000 R10: ffff88003a1b7890 R11: ffff88001df6e488 R12: ffff880023d8ed98 R13: ffff880023cc8798 R14: 0000000000000004 R15: ffff88003b8bf370 FS: 0000000000000000(0000) GS:ffff88003bd00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00000000008ba008 CR3: 0000000023d93000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process kswapd0 (pid: 400, threadinfo ffff8800368ce000, task ffff88003b8bf040) Stack: ffff88003b8bf040 ffff88001df6e528 ffff88001df6e528 ffffffffa00b46b0 ffff88003b8bf040 ffff88001df6e488 ffff88001df6e620 ffffffffa00b46b0 ffff88001ebd04c8 0000000000000004 ffff8800368cfb70 ffffffffa00b2c91 Call Trace: [<ffffffffa00b2c91>] nfs_fscache_release_inode_cookie+0x3b/0x47 [nfs] [<ffffffffa008f25f>] nfs_clear_inode+0x3c/0x41 [nfs] [<ffffffffa0090df1>] nfs4_evict_inode+0x2f/0x33 [nfs] [<ffffffff810d8d47>] evict+0xa1/0x15c [<ffffffff810d8e2e>] dispose_list+0x2c/0x38 [<ffffffff810d9ebd>] prune_icache_sb+0x28c/0x29b [<ffffffff810c56b7>] prune_super+0xd5/0x140 [<ffffffff8109b615>] shrink_slab+0x102/0x1ab [<ffffffff8109d690>] balance_pgdat+0x2f2/0x595 [<ffffffff8103e009>] ? process_timeout+0xb/0xb [<ffffffff8109dba3>] kswapd+0x270/0x289 [<ffffffff8104c5ea>] ? __init_waitqueue_head+0x46/0x46 [<ffffffff8109d933>] ? balance_pgdat+0x595/0x595 [<ffffffff8104bf7a>] kthread+0x7f/0x87 [<ffffffff813ad6b4>] kernel_thread_helper+0x4/0x10 [<ffffffff81026b98>] ? finish_task_switch+0x45/0xc0 [<ffffffff813abcdd>] ? retint_restore_args+0xe/0xe [<ffffffff8104befb>] ? __init_kthread_worker+0x53/0x53 [<ffffffff813ad6b0>] ? gs_change+0xb/0xb Signed-off-by: David Howells <dhowells@redhat.com>
2012-12-20CacheFiles: Make some debugging statements conditionalDavid Howells
Downgrade some debugging statements to not unconditionally print stuff, but rather be conditional on the appropriate module parameter setting. Signed-off-by: David Howells <dhowells@redhat.com>
2012-12-20CacheFiles: Downgrade the requirements passed to the allocatorDavid Howells
Downgrade the requirements passed to the allocator in the gfp flags parameter. FS-Cache/CacheFiles can handle OOM conditions simply by aborting the attempt to store an object or a page in the cache. Signed-off-by: David Howells <dhowells@redhat.com>
2012-12-20CacheFiles: Fix the marking of cached pagesDavid Howells
Under some circumstances CacheFiles defers the marking of pages with PG_fscache so that it can take advantage of pagevecs to reduce the number of calls to fscache_mark_pages_cached() and the netfs's hook to keep track of this. There are, however, two problems with this: (1) It can lead to the PG_fscache mark being applied _after_ the page is set PG_uptodate and unlocked (by the call to fscache_end_io()). (2) CacheFiles's ref on the page is dropped immediately following fscache_end_io() - and so may not still be held when the mark is applied. This can lead to the page being passed back to the allocator before the mark is applied. Fix this by, where appropriate, marking the page before calling fscache_end_io() and releasing the page. This means that we can't take advantage of pagevecs and have to make a separate call for each page to the marking routines. The symptoms of this are Bad Page state errors cropping up under memory pressure, for example: BUG: Bad page state in process tar pfn:002da page:ffffea0000009fb0 count:0 mapcount:0 mapping: (null) index:0x1447 page flags: 0x1000(private_2) Pid: 4574, comm: tar Tainted: G W 3.1.0-rc4-fsdevel+ #1064 Call Trace: [<ffffffff8109583c>] ? dump_page+0xb9/0xbe [<ffffffff81095916>] bad_page+0xd5/0xea [<ffffffff81095d82>] get_page_from_freelist+0x35b/0x46a [<ffffffff810961f3>] __alloc_pages_nodemask+0x362/0x662 [<ffffffff810989da>] __do_page_cache_readahead+0x13a/0x267 [<ffffffff81098942>] ? __do_page_cache_readahead+0xa2/0x267 [<ffffffff81098d7b>] ra_submit+0x1c/0x20 [<ffffffff8109900a>] ondemand_readahead+0x28b/0x29a [<ffffffff81098ee2>] ? ondemand_readahead+0x163/0x29a [<ffffffff810990ce>] page_cache_sync_readahead+0x38/0x3a [<ffffffff81091d8a>] generic_file_aio_read+0x2ab/0x67e [<ffffffffa008cfbe>] nfs_file_read+0xa4/0xc9 [nfs] [<ffffffff810c22c4>] do_sync_read+0xba/0xfa [<ffffffff81177a47>] ? security_file_permission+0x7b/0x84 [<ffffffff810c25dd>] ? rw_verify_area+0xab/0xc8 [<ffffffff810c29a4>] vfs_read+0xaa/0x13a [<ffffffff810c2a79>] sys_read+0x45/0x6c [<ffffffff813ac37b>] system_call_fastpath+0x16/0x1b As can be seen, PG_private_2 (== PG_fscache) is set in the page flags. Instrumenting fscache_mark_pages_cached() to verify whether page->mapping was set appropriately showed that sometimes it wasn't. This led to the discovery that sometimes the page has apparently been reclaimed by the time the marker got to see it. Reported-by: M. Stevens <m@tippett.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Jeff Layton <jlayton@redhat.com>
2012-07-30fs: cachefiles: add support for large files in filesystem cachingJustin Lecher
Support the caching of large files. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=31182 Signed-off-by: Justin Lecher <jlec@gentoo.org> Signed-off-by: Suresh Jayaraman <sjayaraman@suse.com> Tested-by: Suresh Jayaraman <sjayaraman@suse.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-23switch dentry_open() to struct path, make it grab references itselfAl Viro
2012-07-14don't pass nameidata * to vfs_create()Al Viro
all we want is a boolean flag, same as the method gets now Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20switch touch_atime to struct pathAl Viro
2012-01-03fs: move code out of buffer.cAl Viro
Move invalidate_bdev, block_sync_page into fs/block_dev.c. Export kill_bdev as well, so brd doesn't have to open code it. Reduce buffer_head.h requirement accordingly. Removed a rather large comment from invalidate_bdev, as it looked a bit obsolete to bother moving. The small comment replacing it says enough. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20kill useless checks for sb->s_op == NULLAl Viro
never is... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20get rid of pointless checks for dentry->sb == NULLAl Viro
it never is... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-24CacheFiles: Add calls to path-based security hooksDavid Howells
Add calls to path-based security hooks into CacheFiles as, unlike inode-based security, these aren't implicit in the vfs_mkdir() and similar calls. Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-12Add a dummy printk function for the maintenance of unused printksDavid Howells
Add a dummy printk function for the maintenance of unused printks through gcc format checking, and also so that side-effect checking is maintained too. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11vfs: add helpers to get root and pwdMiklos Szeredi
Add three helpers that retrieve a refcounted copy of the root and cwd from the supplied fs_struct. get_fs_root() get_fs_pwd() get_fs_root_and_pwd() Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-11cachefiles: use path_get instead of lone dgetMiklos Szeredi
Dentry references should not be acquired without a corresponding vfsmount ref. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09pass a struct path to vfs_statfsChristoph Hellwig
We'll need the path to implement the flags field for statvfs support. We do have it available in all callers except: - ecryptfs_statfs. This one doesn't actually need vfs_statfs but just needs to do a caller to the lower filesystem statfs method. - sys_ustat. Add a non-exported statfs_by_dentry helper for it which doesn't won't be able to fill out the flags field later on. In addition rename the helpers for statfs vs fstatfs to do_*statfs instead of the misleading vfs prefix. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-07-22fscache: convert operation to use workqueue instead of slow-workTejun Heo
Make fscache operation to use only workqueue instead of combination of workqueue and slow-work. FSCACHE_OP_SLOW is dropped and FSCACHE_OP_FAST is renamed to FSCACHE_OP_ASYNC and uses newly added fscache_op_wq workqueue to execute op->processor(). fscache_operation_init_slow() is dropped and fscache_operation_init() now takes @processor argument directly. * Unbound workqueue is used. * fscache_retrieval_work() is no longer necessary as OP_ASYNC now does the equivalent thing. * sysctl fscache.operation_max_active added to control concurrency. The default value is nr_cpus clamped between 2 and WQ_UNBOUND_MAX_ACTIVE. * debugfs support is dropped for now. Tracing API based debug facility is planned to be added. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David Howells <dhowells@redhat.com>
2010-07-22fscache: convert object to use workqueue instead of slow-workTejun Heo
Make fscache object state transition callbacks use workqueue instead of slow-work. New dedicated unbound CPU workqueue fscache_object_wq is created. get/put callbacks are renamed and modified to take @object and called directly from the enqueue wrapper and the work function. While at it, make all open coded instances of get/put to use fscache_get/put_object(). * Unbound workqueue is used. * work_busy() output is printed instead of slow-work flags in object debugging outputs. They mean basically the same thing bit-for-bit. * sysctl fscache.object_max_active added to control concurrency. The default value is nr_cpus clamped between 4 and WQ_UNBOUND_MAX_ACTIVE. * slow_work_sleep_till_thread_needed() is replaced with fscache private implementation fscache_object_sleep_till_congested() which waits on fscache_object_wq congestion. * debugfs support is dropped for now. Tracing API based debug facility is planned to be added. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David Howells <dhowells@redhat.com>
2010-05-12CacheFiles: Fix error handling in cachefiles_determine_cache_security()David Howells
cachefiles_determine_cache_security() is expected to return with a security override in place. However, if set_create_files_as() fails, we fail to do this. In this case, we should just reinstate the security override that was set by the caller. Furthermore, if set_create_files_as() fails, we should dispose of the new credentials we were in the process of creating. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-11CacheFiles: Fix occasional EIO on call to vfs_unlink()David Howells
Fix an occasional EIO returned by a call to vfs_unlink(): [ 4868.465413] CacheFiles: I/O Error: Unlink failed [ 4868.465444] FS-Cache: Cache cachefiles stopped due to I/O error [ 4947.320011] CacheFiles: File cache on md3 unregistering [ 4947.320041] FS-Cache: Withdrawing cache "mycache" [ 5127.348683] FS-Cache: Cache "mycache" added (type cachefiles) [ 5127.348716] CacheFiles: File cache on md3 registered [ 7076.871081] CacheFiles: I/O Error: Unlink failed [ 7076.871130] FS-Cache: Cache cachefiles stopped due to I/O error [ 7116.780891] CacheFiles: File cache on md3 unregistering [ 7116.780937] FS-Cache: Withdrawing cache "mycache" [ 7296.813394] FS-Cache: Cache "mycache" added (type cachefiles) [ 7296.813432] CacheFiles: File cache on md3 registered What happens is this: (1) A cached NFS file is seen to have become out of date, so NFS retires the object and immediately acquires a new object with the same key. (2) Retirement of the old object is done asynchronously - so the lookup/create to generate the new object may be done first. This can be a problem as the old object and the new object must exist at the same point in the backing filesystem (i.e. they must have the same pathname). (3) The lookup for the new object sees that a backing file already exists, checks to see whether it is valid and sees that it isn't. It then deletes that file and creates a new one on disk. (4) The retirement phase for the old file is then performed. It tries to delete the dentry it has, but ext4_unlink() returns -EIO because the inode attached to that dentry no longer matches the inode number associated with the filename in the parent directory. The trace below shows this quite well. [md5sum] ==> __fscache_relinquish_cookie(ffff88002d12fb58{NFS.fh,ffff88002ce62100},1) [md5sum] ==> __fscache_acquire_cookie({NFS.server},{NFS.fh},ffff88002ce62100) NFS has retired the old cookie and asked for a new one. [kslowd] ==> fscache_object_state_machine({OBJ52,OBJECT_ACTIVE,24}) [kslowd] <== fscache_object_state_machine() [->OBJECT_DYING] [kslowd] ==> fscache_object_state_machine({OBJ53,OBJECT_INIT,0}) [kslowd] <== fscache_object_state_machine() [->OBJECT_LOOKING_UP] [kslowd] ==> fscache_object_state_machine({OBJ52,OBJECT_DYING,24}) [kslowd] <== fscache_object_state_machine() [->OBJECT_RECYCLING] The old object (OBJ52) is going through the terminal states to get rid of it, whilst the new object - (OBJ53) - is coming into being. [kslowd] ==> fscache_object_state_machine({OBJ53,OBJECT_LOOKING_UP,0}) [kslowd] ==> cachefiles_walk_to_object({ffff88003029d8b8},OBJ53,@68,) [kslowd] lookup '@68' [kslowd] next -> ffff88002ce41bd0 positive [kslowd] advance [kslowd] lookup 'Es0g00og0_Nd_XCYe3BOzvXrsBLMlN6aw16M1htaA' [kslowd] next -> ffff8800369faac8 positive The new object has looked up the subdir in which the file would be in (getting dentry ffff88002ce41bd0) and then looked up the file itself (getting dentry ffff8800369faac8). [kslowd] validate 'Es0g00og0_Nd_XCYe3BOzvXrsBLMlN6aw16M1htaA' [kslowd] ==> cachefiles_bury_object(,'@68','Es0g00og0_Nd_XCYe3BOzvXrsBLMlN6aw16M1htaA') [kslowd] remove ffff8800369faac8 from ffff88002ce41bd0 [kslowd] unlink stale object [kslowd] <== cachefiles_bury_object() = 0 It then checks the file's xattrs to see if it's valid. NFS says that the auxiliary data indicate the file is out of date (obvious to us - that's why NFS ditched the old version and got a new one). CacheFiles then deletes the old file (dentry ffff8800369faac8). [kslowd] redo lookup [kslowd] lookup 'Es0g00og0_Nd_XCYe3BOzvXrsBLMlN6aw16M1htaA' [kslowd] next -> ffff88002cd94288 negative [kslowd] create -> ffff88002cd94288{ffff88002cdaf238{ino=148247}} CacheFiles then redoes the lookup and gets a negative result in a new dentry (ffff88002cd94288) which it then creates a file for. [kslowd] ==> cachefiles_mark_object_active(,OBJ53) [kslowd] <== cachefiles_mark_object_active() = 0 [kslowd] === OBTAINED_OBJECT === [kslowd] <== cachefiles_walk_to_object() = 0 [148247] [kslowd] <== fscache_object_state_machine() [->OBJECT_AVAILABLE] The new object is then marked active and the state machine moves to the available state - at which point NFS can start filling the object. [kslowd] ==> fscache_object_state_machine({OBJ52,OBJECT_RECYCLING,20}) [kslowd] ==> fscache_release_object() [kslowd] ==> cachefiles_drop_object({OBJ52,2}) [kslowd] ==> cachefiles_delete_object(,OBJ52{ffff8800369faac8}) The old object, meanwhile, goes on with being retired. If allocation occurs first, cachefiles_delete_object() has to wait for dir->d_inode->i_mutex to become available before it can continue. [kslowd] ==> cachefiles_bury_object(,'@68','Es0g00og0_Nd_XCYe3BOzvXrsBLMlN6aw16M1htaA') [kslowd] remove ffff8800369faac8 from ffff88002ce41bd0 [kslowd] unlink stale object EXT4-fs warning (device sda6): ext4_unlink: Inode number mismatch in unlink (148247!=148193) CacheFiles: I/O Error: Unlink failed FS-Cache: Cache cachefiles stopped due to I/O error CacheFiles then tries to delete the file for the old object, but the dentry it has (ffff8800369faac8) no longer points to a valid inode for that directory entry, and so ext4_unlink() returns -EIO when de->inode does not match i_ino. [kslowd] <== cachefiles_bury_object() = -5 [kslowd] <== cachefiles_delete_object() = -5 [kslowd] <== fscache_object_state_machine() [->OBJECT_DEAD] [kslowd] ==> fscache_object_state_machine({OBJ53,OBJECT_AVAILABLE,0}) [kslowd] <== fscache_object_state_machine() [->OBJECT_ACTIVE] (Note that the above trace includes extra information beyond that produced by the upstream code). The fix is to note when an object that is being retired has had its object deleted preemptively by a replacement object that is being created, and to skip the second removal attempt in such a case. Reported-by: Greg M <gregm@servu.net.au> Reported-by: Mark Moseley <moseleymark@gmail.com> Reported-by: Romain DEGEZ <romain.degez@smartjog.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-20CacheFiles: Fix a race in cachefiles_delete_object() vs renameDavid Howells
cachefiles_delete_object() can race with rename. It gets the parent directory of the object it's asked to delete, then locks it - but rename may have changed the object's parent between the get and the completion of the lock. However, if such a circumstance is detected, we abandon our attempt to delete the object - since it's no longer in the index key path, it won't be seen again by lookups of that key. The assumption is that cachefilesd may have culled it by renaming it to the graveyard for later destruction. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16Untangling ima mess, part 2: deal with countersAl Viro
* do ima_get_count() in __dentry_open() * stop doing that in followups * move ima_path_check() to right after nameidata_to_filp() * don't bump counters on it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16switch cachefiles to kern_path()Al Viro
2009-12-15tree-wide: convert open calls to remove spaces to skip_spaces() lib functionAndré Goddard Rosa
Makes use of skip_spaces() defined in lib/string.c for removing leading spaces from strings all over the tree. It decreases lib.a code size by 47 bytes and reuses the function tree-wide: text data bss dec hex filename 64688 584 592 65864 10148 (TOTALS-BEFORE) 64641 584 592 65817 10119 (TOTALS-AFTER) Also, while at it, if we see (*str && isspace(*str)), we can be sure to remove the first condition (*str) as the second one (isspace(*str)) also evaluates to 0 whenever *str == 0, making it redundant. In other words, "a char equals zero is never a space". Julia Lawall tried the semantic patch (http://coccinelle.lip6.fr) below, and found occurrences of this pattern on 3 more files: drivers/leds/led-class.c drivers/leds/ledtrig-timer.c drivers/video/output.c @@ expression str; @@ ( // ignore skip_spaces cases while (*str && isspace(*str)) { \(str++;\|++str;\) } | - *str && isspace(*str) ) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Julia Lawall <julia@diku.dk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Neil Brown <neilb@suse.de> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: David Howells <dhowells@redhat.com> Cc: <linux-ext4@vger.kernel.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-01CacheFiles: Update IMA counters when using dentry_openMarc Dionne
When IMA is active, using dentry_open without updating the IMA counters will result in free/open imbalance errors when fput is eventually called. Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-19CacheFiles: Don't log lookup/create failing with ENOBUFSDavid Howells
Don't log the CacheFiles lookup/create object routined failing with ENOBUFS as under high memory load or high cache load they can do this quite a lot. This error simply means that the requested object cannot be created on disk due to lack of space, or due to failure of the backing filesystem to find sufficient resources. Signed-off-by: David Howells <dhowells@redhat.com>
2009-11-19CacheFiles: Catch an overly long wait for an old active objectDavid Howells
Catch an overly long wait for an old, dying active object when we want to replace it with a new one. The probability is that all the slow-work threads are hogged, and the delete can't get a look in. What we do instead is: (1) if there's nothing in the slow work queue, we sleep until either the dying object has finished dying or there is something in the slow work queue behind which we can queue our object. (2) if there is something in the slow work queue, we return ETIMEDOUT to fscache_lookup_object(), which then puts us back on the slow work queue, presumably behind the deletion that we're blocked by. We are then deferred for a while until we work our way back through the queue - without blocking a slow-work thread unnecessarily. A backtrace similar to the following may appear in the log without this patch: INFO: task kslowd004:5711 blocked for more than 120 seconds. "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. kslowd004 D 0000000000000000 0 5711 2 0x00000080 ffff88000340bb80 0000000000000046 ffff88002550d000 0000000000000000 ffff88002550d000 0000000000000007 ffff88000340bfd8 ffff88002550d2a8 000000000000ddf0 00000000000118c0 00000000000118c0 ffff88002550d2a8 Call Trace: [<ffffffff81058e21>] ? trace_hardirqs_on+0xd/0xf [<ffffffffa011c4d8>] ? cachefiles_wait_bit+0x0/0xd [cachefiles] [<ffffffffa011c4e1>] cachefiles_wait_bit+0x9/0xd [cachefiles] [<ffffffff81353153>] __wait_on_bit+0x43/0x76 [<ffffffff8111ae39>] ? ext3_xattr_get+0x1ec/0x270 [<ffffffff813531ef>] out_of_line_wait_on_bit+0x69/0x74 [<ffffffffa011c4d8>] ? cachefiles_wait_bit+0x0/0xd [cachefiles] [<ffffffff8104c125>] ? wake_bit_function+0x0/0x2e [<ffffffffa011bc79>] cachefiles_mark_object_active+0x203/0x23b [cachefiles] [<ffffffffa011c209>] cachefiles_walk_to_object+0x558/0x827 [cachefiles] [<ffffffffa011a429>] cachefiles_lookup_object+0xac/0x12a [cachefiles] [<ffffffffa00aa1e9>] fscache_lookup_object+0x1c7/0x214 [fscache] [<ffffffffa00aafc5>] fscache_object_state_machine+0xa5/0x52d [fscache] [<ffffffffa00ab4ac>] fscache_object_slow_work_execute+0x5f/0xa0 [fscache] [<ffffffff81082093>] slow_work_execute+0x18f/0x2d1 [<ffffffff8108239a>] slow_work_thread+0x1c5/0x308 [<ffffffff8104c0f1>] ? autoremove_wake_function+0x0/0x34 [<ffffffff810821d5>] ? slow_work_thread+0x0/0x308 [<ffffffff8104be91>] kthread+0x7a/0x82 [<ffffffff8100beda>] child_rip+0xa/0x20 [<ffffffff8100b87c>] ? restore_args+0x0/0x30 [<ffffffff8104be17>] ? kthread+0x0/0x82 [<ffffffff8100bed0>] ? child_rip+0x0/0x20 1 lock held by kslowd004/5711: #0: (&sb->s_type->i_mutex_key#7/1){+.+.+.}, at: [<ffffffffa011be64>] cachefiles_walk_to_object+0x1b3/0x827 [cachefiles] Signed-off-by: David Howells <dhowells@redhat.com>
