path: root/fs/ceph/locks.c
2011-06-07ceph: unwind canceled flock stateSage Weil
If we request a lock and then abort (e.g., ^C), we need to send a matching unlock request to the MDS to unwind our lock attempt to avoid indefinitely blocking other clients. Reported-by: Brian Chrisman <brchrisman@gmail.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-06-07ceph: use ihold when we already have an inode refSage Weil
We should use ihold whenever we already have a stable inode ref, even when we aren't holding i_lock. This avoids adding new and unnecessary locking dependencies. Signed-off-by: Sage Weil <sage@newdream.net>
2010-12-01ceph: Behave better when handling file lock replies.Herb Shiu
Fill in the local lock with response data if appropriate, and don't call posix_lock_file when reading locks. Signed-off-by: Herb Shiu <herb_shiu@tcloudcomputing.com> Acked-by: Greg Farnum <gregf@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2010-12-01ceph: pass lock information by struct file_lock instead of as individual params.Herb Shiu
2010-10-20ceph: preallocate flock state without locks heldGreg Farnum
When the lock_kernel() turns into lock_flocks() and a spinlock, we won't be able to do allocations with the lock held. Preallocate space without the lock, and retry if the lock state changes out from underneath us. Signed-off-by: Greg Farnum <gregf@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2010-10-20ceph: factor out libceph from Ceph file systemYehuda Sadeh
This factors out protocol and low-level storage parts of ceph into a separate libceph module living in net/ceph and include/linux/ceph. This is mostly a matter of moving files around. However, a few key pieces of the interface change as well: - ceph_client becomes ceph_fs_client and ceph_client, where the latter captures the mon and osd clients, and the fs_client gets the mds client and file system specific pieces. - Mount option parsing and debugfs setup is correspondingly broken into two pieces. - The mon client gets a generic handler callback for otherwise unknown messages (mds map, in this case). - The basic supported/required feature bits can be expanded (and are by ceph_fs_client). No functional change, aside from some subtle error handling cases that got cleaned up in the refactoring process. Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-25ceph: Fix warningsAlan Cox
Just scrubbing some warnings so I can see real problem ones in the build noise. For 32bit we need to coax gcc politely into believing we really honestly intend to the casts. Using (u64)(unsigned long) means we cast from a pointer to a type of the right size and then extend it. This stops the warning spew. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-02ceph: add flock/fcntl lock supportGreg Farnum
Implement flock inode operation to support advisory file locking. All lock/unlock operations are synchronous with the MDS. Lock state is sent when reconnecting to a recovering MDS to restore the shared lock state. Signed-off-by: Greg Farnum <gregf@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
