commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream.
move d_rcu from overlapping d_child to overlapping d_alias
Cc: Ben Hutchings <ben@decadent.org.uk>
[hujianyang: Backported to 3.14 refer to the work of Ben Hutchings in 3.2:
- Apply name changes in all the different places we use d_alias and d_child
- Move the WARN_ON() in __d_free() to d_free() as we don't have dentry_free()]
Signed-off-by: hujianyang <hujianyang@huawei.com>
commit 00bd8edb861eb41d274938cfc0338999d9c593a3 upstream.
send_mds_reconnect() may call discard_cap_releases() after all
release messages have been dropped by cleanup_cap_releases()
Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
Reviewed-by: Sage Weil <sage@inktank.com>
Cc: Markus Blank-Burian <burian@muenster.de>
commit 021b77bee210843bed1ea91b5cad58235ff9c8e5 upstream.
Probably this code was syncing a lot more often then intended because
the do_sync variable wasn't set to zero.
Fixes: c62988ec0910 ('ceph: avoid meaningless calling ceph_caps_revoking if sync_mode == WB_SYNC_ALL.')
Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
commit 0a8a70f96fe1bd3e07c15bb86fd247e76102398a upstream.
When creating a file, ceph_set_dentry_offset() puts the new dentry
at the end of directory's d_subdirs, then set the dentry's offset
based on directory's max offset. The offset does not reflect the
real postion of the dentry in directory. Later readdir reply from
MDS may change the dentry's position/offset. This inconsistency
can cause missing/duplicate entries in readdir result if readdir
is partly satisfied by dcache_readdir().
The fix is clear directory's completeness after creating/renaming
file. It prevents later readdir from using dcache_readdir().
Fixes: http://tracker.ceph.com/issues/8025
If directory is fragmented, readdir() read its dirfrags one by one.
After reading all dirfrags, the corresponding dentries are sorted in
(frag_t, off) order in the dcache. If dentries of a directory are all
cached, __dcache_readdir() can use the cached dentries to satisfy
readdir syscall. But when checking if a given dentry is after the
position of readdir, __dcache_readdir() compares numerical value of
frag_t directly. This is wrong, it should use ceph_frag_compare().
Make the 'acl' option dependent on having ACL support compiled in. Make
the 'noacl' option work even without it so that one can always ask it to
be off and not error out on mount when it is not supported.
Signed-off-by: Guangliang Zhao <lucienchao@gmail.com>
Signed-off-by: Sage Weil <sage@inktank.com>
Reviewed-by: Alex Elder <elder@linaro.org>
If acl is equivalent to file mode permission bits, ceph_set_acl()
needs to remove any existing acl xattr. Use __ceph_setxattr() to
handle both setting and removing acl xattr cases, it doesn't return
-ENODATA when there is no acl xattr.
For the setxattr request, introduce a new flag CEPH_XATTR_REMOVE
to distinguish null value case from the zero-length value case.
return -EEXIST if XATTR_CREATE is set and xattr alread exists.
return -ENODATA if XATTR_REPLACE is set but xattr does not exist.
Add matching dput() for d_find_alias(). Move d_find_alias() down a bit
at Julia's suggestion.
[ Introduced by commit 72466d0b92e0: "ceph: fix posix ACL hooks" ]
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Reported-by: Julia Lawall <julia.lawall@lip6.fr>
Reviewed-by: Ilya Dryomov <ilya.dryomov@inktank.com>
- ->get_acl only gets called after we checked for a cached ACL, so no
need to call get_cached_acl again.
- no need to check IS_POSIXACL in ->get_acl, without that it should
never get set as all the callers that set it already have the check.
- you should be able to use the full posix_acl_create in CEPH
Signed-off-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Peter Rosin <peda@lysator.liu.se>
The merge of commit 7221fe4c2ed7 ("ceph: add acl for cephfs") raced with
upstream changes in the generic POSIX ACL code (eg commit 2aeccbe957d0
"fs: add generic xattr_acl handlers" and others).
Some of the fallout was fixed in commit 4db658ea0ca ("ceph: Fix up after
semantic merge conflict"), but it was incomplete: the set_acl
inode_operation wasn't getting set, and the prototype needed to be
adjusted a bit (it doesn't take a dentry anymore).
Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
The previous ceph-client merge resulted in ceph not even building,
because there was a merge conflict that wasn't visible as an actual data
conflict: commit 7221fe4c2ed7 ("ceph: add acl for cephfs") added support
for POSIX ACL's into Ceph, but unluckily we also had the VFS tree change
a lot of the POSIX ACL helper functions to be much more helpful to
filesystems (see for example commits 2aeccbe957d0 "fs: add generic
xattr_acl handlers", 5bf3258fd2ac "fs: make posix_acl_chmod more useful"
and 37bc15392a23 "fs: make posix_acl_create more useful")
The reason this conflict wasn't obvious was many-fold: because it was a
semantic conflict rather than a data conflict, it wasn't visible in the
git merge as a conflict. And because the VFS tree hadn't been in
linux-next, people hadn't become aware of it that way. And because I
was at jury duty this morning, I was using my laptop and as a result not
doing constant "allmodconfig" builds.
Anyway, this fixes the build and generally removes a fair chunk of the
Ceph POSIX ACL support code, since the improved helpers seem to match
really well for Ceph too. But I don't actually have any way to *test*
the end result, and I was really hoping for some ACK's for this. Oh,
well.
Not compiling certainly doesn't make things easier to test, so I'm
committing this without the acks after having waited for four hours...
Plus it's what I would have done for the merge had I noticed the
semantic conflict..
Reported-by: Dave Jones <davej@redhat.com>
Cc: Sage Weil <sage@inktank.com>
Cc: Guangliang Zhao <lucienchao@gmail.com>
Cc: Li Wang <li.wang@ubuntykylin.com>
Use min_t(size_t, ...) instead of plain min(), which does strict type
checking, to avoid compile warning on i386.
Cc: Jianpeng Ma <majianpeng@gmail.com>
PAGE_CACHE_SIZE is unsigned long on all architectures, however size_t
is either unsigned int or unsigned long. Rather than change format
strings, cast PAGE_CACHE_SIZE to size_t to be in line with dout()s in
ceph_page_mkwrite().
Cc: Yan, Zheng <zheng.z.yan@intel.com>
Switch ceph_calc_ceph_pg() to new oloc and oid abstractions and rename
it to ceph_oloc_oid_to_pg() to make its purpose more clear.
Version 3 cap export message includes information about the imported
caps. It allows us to add the imported caps if the corresponding cap
import message still hasn't been received.
This allow us to handle situation that the importer MDS crashes and
the cap import message is missing.
Version 3 cap import message includes the ID of the exported
caps. It allow us to remove the exported caps if we still haven't
received the corresponding cap export message.
We remove the exported caps because they are stale, keeping them
can compromise consistence.
Some inodes in readdir reply may have no caps. Getattr mds request
for these inodes can return -ESTALE. The fix is consider dentry that
links to inode with no caps as invalid. Invalid dentry causes a
lookup request to send to the mds, the MDS will send caps back.
Send requests that operate on path to directory's auth MDS if
mode == USE_AUTH_MDS. Always retry using the auth MDS if got
-ESTALE reply from non-auth MDS. Also clean up the code that
handles auth MDS change.
- don't trim auth cap if there are flusing caps
- don't trim auth cap if any 'write' cap is wanted
- allow trimming non-auth cap even if the inode is dirty
handle following sequence of events:
- non-auth MDS revokes Fc cap. queue invalidate work
- auth MDS issues Fc cap through request reply. i_rdcache_gen gets
increased.
- invalidate work runs. it finds i_rdcache_revoking != i_rdcache_gen,
so it does nothing.
auth cap may change after releasing the i_ceph_lock
"disconnected" is too easily confused with "DCACHE_DISCONNECTED". I
think "unhashed" is the more precise term here.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
In preparation for ceph_features.h update, change all features fields
from unsigned int/u32 to u64. (ceph.git has ~40 feature bits at this
point.)
Currently, if one new page allocated into fscache in readpage(), however,
with no data read into due to error encountered during reading from OSDs,
the slot in fscache is not uncached. This patch fixes this.
Signed-off-by: Li Wang <liwang@ubuntukylin.com>
Reviewed-by: Milosz Tanski <milosz@adfin.com>
Reviewed-by: Li Wang <li.wang@ubuntykylin.com>
Reviewed-by: Zheng Yan <zheng.z.yan@intel.com>
Adds cap check to the page fault handler. The check prevents page
fault handler from adding new page to the page cache while Fcb caps
are being revoked. This solves Fc revoking hang in multiple clients
mmap IO workload.
Signed-off-by: Libo Chen <clbchenlibo.chen@huawei.com>
Clean up if error occurred rather than going through normal process
Signed-off-by: Yunchuan Wen <yunchuanwen@ubuntukylin.com>
For readv/preadv sync-operatoin, ceph only do the first iov.
Now implement this.
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
Reviewed-by: Yan, Zheng <zheng.z.yan@intel.com>
For writev/pwritev sync-operatoin, ceph only do the first iov.
I divided the write-sync-operation into two functions. One for
direct-write, other for none-direct-sync-write. This is because for
none-direct-sync-write we can merge iovs to one. But for direct-write,
we can't merge iovs.
Positve dentry and corresponding inode are always accompanied in MDS reply.
So no need to keep inode in the cache after dropping all its aliases.
If the length of data to be read in readpage() is exactly
PAGE_CACHE_SIZE, the original code does not flush d-cache
for data consistency after finishing reading. This patches fixes
this.
commit b18825a7c8 (Put a small type field into struct dentry::d_flags)
put a type field into struct dentry::d_flags. __d_instantiate() set the
field by checking inode->i_mode. So we should initialize inode before
instantiating dentry when handling mds reply.
Fixes: http://tracker.ceph.com/issues/6930
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull ceph bug-fixes from Sage Weil:
"These include a couple fixes to the new fscache code that went in
during the last cycle (which will need to go stable@ shortly as well),
a couple client-side directory fragmentation fixes, a fix for a race
in the cap release queuing path, and a couple race fixes in the
request abort and resend code.
Obviously some of this could have gone into 3.12 final, but I
preferred to overtest rather than send things in for a late -rc, and
then my travel schedule intervened"
* 'for-linus-bugs' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: allocate non-zero page to fscache in readpage()
ceph: wake up 'safe' waiters when unregistering request
ceph: cleanup aborted requests when re-sending requests.
ceph: handle race between cap reconnect and cap release
ceph: set caps count after composing cap reconnect message
ceph: queue cap release in __ceph_remove_cap()
ceph: handle frag mismatch between readdir request and reply
ceph: remove outdated frag information
ceph: hung on ceph fscache invalidate in some cases
ceph_osdc_readpages() returns number of bytes read, currently,
the code only allocate full-zero page into fscache, this patch
fixes this.
We also need to wake up 'safe' waiters if error occurs or request
aborted. Otherwise sync(2)/fsync(2) may hang forever.
Aborted requests usually get cleared when the reply is received.
If MDS crashes, no reply will be received. So we need to cleanup
Reviewed-by: Greg Farnum <greg@inktank.com>
When a cap get released while composing the cap reconnect message.
We should skip queuing the release message if the cap hasn't been
added to the cap reconnect message.
It's possible that some caps get released while composing the cap
reconnect message.
call __queue_cap_release() in __ceph_remove_cap(), this avoids
acquiring s_cap_lock twice.
