path: root/fs/ceph
2010-05-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: clean up on forwarded aborted mds request ceph: fix leak of osd authorizer ceph: close out mds, osd connections before stopping auth ceph: make lease code DN specific fs/ceph: Use ERR_CAST ceph: renew auth tickets before they expire ceph: do not resend mon requests on auth ticket renewal ceph: removed duplicated #includes ceph: avoid possible null dereference ceph: make mds requests killable, not interruptible sched: add wait_for_completion_killable_timeout
2010-05-29ceph: clean up on forwarded aborted mds requestSage Weil
If an mds request is aborted (timeout, SIGKILL), it is left registered to keep our state in sync with the mds. If we get a forward notification, though, we know the request didn't succeed and we can unregister it safely. We were trying to resend it, but then bailing out (and not unregistering) in __do_request. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-29ceph: fix leak of osd authorizerSage Weil
Release the ceph_authorizer when releasing osd state. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-29ceph: close out mds, osd connections before stopping authSage Weil
The auth module (part of the mon_client) is needed to free any ceph_authorizer(s) used by the mds and osd connections. Flush the msgr workqueue before stopping monc to ensure that the destroy_authorizer auth op is available when those connections are closed out. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-29ceph: make lease code DN specificSage Weil
The lease code includes a mask in the CEPH_LOCK_* namespace, but that namespace is changing, and only one mask (formerly _DN == 1) is used, so hard code for that value for now. If we ever extend this code to handle leases over different data types we can extend it accordingly. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-29fs/ceph: Use ERR_CASTJulia Lawall
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)). The former makes more clear what is the purpose of the operation, which otherwise looks like a no-op. In the case of fs/ceph/inode.c, ERR_CAST is not needed, because the type of the returned value is the same as the type of the enclosing function. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ type T; T x; identifier f; @@ T f (...) { <+... - ERR_PTR(PTR_ERR(x)) + x ...+> } @@ expression x; @@ - ERR_PTR(PTR_ERR(x)) + ERR_CAST(x) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-29ceph: renew auth tickets before they expireSage Weil
We were only requesting renewal after our tickets expire; do so before that. Most of the low-level logic for this was already there; just use it. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-29ceph: do not resend mon requests on auth ticket renewalSage Weil
We only want to send pending mon requests when we successfully authenticate. If we are already authenticated, like when we renew our ticket, there is no need to resend pending requests. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-29ceph: removed duplicated #includesAndrea Gelmini
fs/ceph/auth.c: linux/slab.h is included more than once. fs/ceph/super.h: linux/slab.h is included more than once. Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-29ceph: avoid possible null dereferenceSage Weil
ac->ops may be null; use protocol id in error message instead. Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-29ceph: make mds requests killable, not interruptibleSage Weil
The underlying problem is that many mds requests can't be restarted. For example, a restarted create() would return -EEXIST if the original request succeeds. However, we do not want a hung MDS to hang the client too. So, use the _killable wait_for_completion variants to abort on SIGKILL but nothing else. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (59 commits) ceph: reuse mon subscribe message instead of allocated anew ceph: avoid resending queued message to monitor ceph: Storage class should be before const qualifier ceph: all allocation functions should get gfp_mask ceph: specify max_bytes on readdir replies ceph: cleanup pool op strings ceph: Use kzalloc ceph: use common helper for aborted dir request invalidation ceph: cope with out of order (unsafe after safe) mds reply ceph: save peer feature bits in connection structure ceph: resync headers with userland ceph: use ceph. prefix for virtual xattrs ceph: throw out dirty caps metadata, data on session teardown ceph: attempt mds reconnect if mds closes our session ceph: clean up send_mds_reconnect interface ceph: wait for mds OPEN reply to indicate reconnect success ceph: only send cap releases when mds is OPEN|HUNG ceph: dicard cap releases on mds restart ceph: make mon client statfs handling more generic ceph: drop src address(es) from message header [new protocol feature] ...
2010-05-21ceph: reuse mon subscribe message instead of allocated anewSage Weil
Use the same message, allocated during startup. No need to reallocate a new one each time around (and potentially ENOMEM). Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-21sanitize vfs_fsync calling conventionsChristoph Hellwig
Now that the last user passing a NULL file pointer is gone we can remove the redundant dentry argument and associated hacks inside vfs_fsynmc_range. The next step will be removig the dentry argument from ->fsync, but given the luck with the last round of method prototype changes I'd rather defer this until after the main merge window. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21ceph: should use deactivate_locked_super() on failure exitsAl Viro
2010-05-21ceph: avoid resending queued message to monitorSage Weil
The auth_reply handler will (re)send any pending requests. For the initial mon authenticate phase, that's correct, but when a auth ticket renewal races with an in-flight request, we may resend a request message that is already in flight. Avoid this by revoking the message before sending it. We should also avoid resending requests at all during ticket renewal; that will come soon. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-21ceph: Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: all allocation functions should get gfp_maskYehuda Sadeh
This is essential, as for the rados block device we'll need to run in different contexts that would need flags that are other than GFP_NOFS. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: specify max_bytes on readdir repliesSage Weil
Specify max bytes in request to bound size of reply. Add associated mount option with default value of 512 KB. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: cleanup pool op stringsSage Weil
2010-05-17ceph: Use kzallocJulia Lawall
Use kzalloc rather than the combination of kmalloc and memset. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x,size,flags; statement S; @@ -x = kmalloc(size,flags); +x = kzalloc(size,flags); if (x == NULL) S -memset(x, 0, size); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: use common helper for aborted dir request invalidationSage Weil
We invalidate I_COMPLETE and dentry leases in two places: on aborted mds request and on request replay. Use common helper to avoid duplicate code. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: cope with out of order (unsafe after safe) mds replySage Weil
2010-05-17ceph: save peer feature bits in connection structureSage Weil
These are used for adjusting behavior, such as conditionally encoding a newer message format. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: resync headers with userlandSage Weil
Notable changes include pool op defines and types, FLOCK feature bit, and new CMPXATTR osd ops. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: use ceph. prefix for virtual xattrsSage Weil
Drop the 'user.' prefix and use just 'ceph.' for fs virtual xattrs. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: throw out dirty caps metadata, data on session teardownSage Weil
The remove_session_caps() helper is called when an MDS closes out our session (either normally, or as a result of a failed reconnect), and when we tear down state for umount. If we remove the last cap, and there are no cap migrations in progress, then there is little hope of us flushing out that data to the mds (without heroic efforts to reconnect and flush). So, to avoid leaving inodes pinned (due to dirty state) and crashing after umount, throw out dirty caps state and unpin the inodes. Print a warning to the console so we know something was lost. NOTE: Although we drop wrbuffer refs, we don't actually mark pages clean; maybe a truncate should be queued? Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: attempt mds reconnect if mds closes our sessionSage Weil
Currently, if our session is closed (due to a timeout, or explicit close, or whatever), we just sit there doing nothing unless/until the MDS restarts, at which point we try to reconnect. Change client to attempt an immediate reconnect if our session is closed. Note that currently the MDS doesn't support this, and our attempt will fail. We'll get a session CLOSE, our caps and dirty cap state will be dropped, and the client will be free to attempt to reconnect. That's clearly not as nice as a successful reconnect, but it at least allows us to try to carry on, and in the future the MDS will support a reconnect and we will fare better. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: clean up send_mds_reconnect interfaceSage Weil
Pass a ceph_mds_session, since the caller has it. Remove the dead code for sending empty reconnects. It used to be used when the MDS contacted _us_ to solicit a reconnect, and we could reply saying "go away, I have no session." Now we only send reconnects based on the mds map, and only when we do in fact have an open session. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: wait for mds OPEN reply to indicate reconnect successSage Weil
We used to infer reconnect success by watching the MDS state, essentially assuming that hearing nothing meant things were ok. That wasn't particularly reliable. Instead, the MDS replies with an explicit OPEN message to indicate success. Strictly speaking, this is a protocol change, but it is a backwards compatible one that does not break new clients + old servers or old clients + new servers. At least not yet. Drop unused @all argument from kick_requests while we're at it. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: only send cap releases when mds is OPEN|HUNGSage Weil
On OPENING we shouldn't have any caps (or releases). On CLOSING, we should wait until we succeed (and throw it all out), or don't (and are OPEN again). On RECONNECTING we can wait until we are OPEN. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: dicard cap releases on mds restartSage Weil
If the MDS restarts, the expire caps state is no longer shared, and can be thrown out. Caps state will be rebuilt on the MDS during the reconnect process that follows. Zero out any release messages and adjust the release counter accordingly. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: make mon client statfs handling more genericYehuda Sadeh
This is being done so that we could reuse the statfs infrastructure with other requests that return values. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: drop src address(es) from message header [new protocol feature]Sage Weil
The CEPH_FEATURE_NOSRCADDR protocol feature avoids putting the full source address in each message header (twice). This patch switches the client to the new scheme, and _requires_ this feature on the server. The server will support both the old and new schemes. That means an old client will work with a new server, but a new client will not work with an old server. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: cleanup: remove unused assignementDan Carpenter
We don't ever use "dirty" so we can remove it. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: clean up cap release loop vs spinlockSage Weil
2010-05-17ceph: name bdi ceph-%d instead of major:minorSage Weil
The bdi_setup_and_register() helper doesn't help us since we bdi_init() in create_client() and bdi_register() only when sget() succeeds. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: skip mds sync on forced unmountSage Weil
2010-05-17ceph: adjust masked struct_v variable namesSage Weil
Reported-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: clean up mount options, ->show_options()Sage Weil
Ensure all options are included in /proc/mounts. Some cleanup. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: set dn offset when splicedSage Weil
We want to assign an offset when the dentry goes from null to linked, which is always done by splice_dentry(). Notably, we should NOT assign an offset when a dentry is first created and is still null. BUG if we try to splice a non-null dentry (we shouldn't). Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: don't clobber i_max_offset on already complete dirSage Weil
This can screw up offsets assigned to new dentries and break dcache readdir results. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: skip set_dentry_offset work if directory not I_COMPLETESage Weil
2010-05-17ceph: set next_offset on readdir finishSage Weil
Set next_offset to 2 (always 2!), not 0, on readdir finish. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: listxattr should compare version by >=Henry C Chang
If the version hasn't changed, don't rebuild the index. Signed-off-by: Henry C Chang <henry_c_chang@tcloudcomputing.com> Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: fix xattr dangling pointer / double freeSage Weil
If we use the xattr_blob, clear the pointer so we don't release the memory at the bottom of the fuction. Reported-by: Henry C Chang <henry_c_chang@tcloudcomputing.com> Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: close messenger raceSage Weil
Simplify messenger locking, and close race between ceph_con_close() setting the CLOSED bit and con_work() checking the bit, then taking the mutex. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: name msgpools; useful error messagesSage Weil
2010-05-17ceph: fix memory leak due to possible dentry init raceSage Weil
Free dentry_info in error path. Signed-off-by: Sage Weil <sage@newdream.net>
