path: root/fs/cifs/TODO
2010-11-02cifs: trivial doc fix: note setlease implementedJ. Bruce Fields
Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-20[CIFS] Enable DFS support for Unix query path infoSteve French
Final piece for handling DFS in unix_query_path_info, constructing a fake inode for the junction directory which the submount will cover. Acked-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-01-08[CIFS] fix checkpatch warnings in fs/cifs/inode.cSteve French
2007-11-16[CIFS] Have CIFS_SessSetup build correct SPNEGO SessionSetup requestSteve French
Have CIFS_SessSetup call cifs_get_spnego_key when Kerberos is negotiated. Use the info in the key payload to build a session setup request packet. Also clean up how the request buffer in the function is freed on error. With appropriate user space helper (in samba/source/client). Kerberos support (secure session establishment can be done now via Kerberos, previously users would have to use NTLMv2 instead for more secure session setup). Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-07-26[CIFS] Fix hang in find_writable_fileSteve French
Caused by unneeded reopen during reconnect while spinlock held. Fixes kernel bugzilla bug #7903 Thanks to Lin Feng Shen for testing this, and Amit Arora for some nice problem determination to narrow this down. Acked-by: Dave Kleikamp <shaggy@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-07-09[CIFS] Fix packet signatures for NTLMv2 caseSteve French
Signed-off-by: Yehuda Sadeh Weinraub <Yehuda.Sadeh@expand.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-06-24[CIFS] Add in some missing flags and cifs README and TODO correctionsSteve French
2007-04-30[CIFS] UID/GID override on CIFS mounts to SambaSteve French
When CIFS Unix Extensions are negotiated we get the Unix uid and gid owners of the file from the server (on the Unix Query Path Info levels), but if the server's uids don't match the client uid's users were having to disable the Unix Extensions (which turned off features they still wanted). The changeset patch allows users to override uid and/or gid for file/directory owner with a default uid and/or gid specified at mount (as is often done when mounting from Linux cifs client to Windows server). This changeset also displays the uid and gid used by default in /proc/mounts (if applicable). Also cleans up code by adding some of the missing spaces after "if" keywords per-kernel style guidelines (as suggested by Randy Dunlap when he reviewed the patch). Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-04-26[CIFS] Update cifs version to 1.49Steve French
2007-02-27[CIFS] cifs export operationsSteve French
For nfsd to work over cifs mounts (which presumably makes sense when trying to reexport mounts to windows, network appliances or Samba servers to nfs clients via nfs server). This is the first stage of that enablement, marked experimental and turned off by default. Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-02-14[CIFS] on reconnect to Samba - reset the unix capabilitiesSteve French
After temporary server or network failure and reconneciton, we were not resending the unix capabilities via SetFSInfo - which confused Samba posix byte range locking code. Discovered by jra Signed-off-by: Steve French <sfrench@us.ibm.com>
2005-11-29[CIFS] Fix missing permission check on setattr when noperm mount option isSteve French
disabled. Also set mode, uid, gid better on mkdir and create for the case when Unix Extensions is not enabled and setuids is enabled. This is necessary to fix the hole in which chown could be allowed for non-root users in some cases if root mounted, and also to display the mode and uid properly in some cases. Signed-off-by: Steve French <sfrench@us.ibm.com>
2005-10-10[CIFS] Fix byte range locking to Windows when Windows server returnsSteve French
illegal RFC1001 length (which had caused the lock to block forever until killed).
2005-09-06[CIFS] Update cifs TODO list with additional new features thatSteve French
have been requested. Signed-off-by: Steve French (sfrench@us.ibm.com)
2005-04-30[PATCH] cifs: Update cifs todo listSteve French
Signed-off-by: Steve French (sfrench@us.ibm.com) Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-28[PATCH] cifs: character mapping of special characters (part 3 of 3)Steve French
2005-04-28[PATCH] cifs: Add new mount parm mapcharsSteve French
For handling seven special characters that shells use for filenames. This first parts implements conversions from Unicode. Signed-off-by: Steve French Signed-off-by: Linus Torvalds <torvalds@osdl.org>
