path: root/fs/cifs/cifs_dfs_ref.c
2009-07-28cifs: fix error handling in mount-time DFS referral chasing codeJeff Layton
If the referral is malformed or the hostname can't be resolved, then the current code generates an oops. Fix it to handle these errors gracefully. Reported-by: Sandro Mathys <sm@sandro-mathys.ch> Acked-by: Igor Mammedov <niallain@gmail.com> CC: Stable <stable@kernel.org> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-06-11switch follow_down()Al Viro
2009-05-01[CIFS] Fix build warningSteve French
2009-04-30Enable dfs submounts to handle remote referrals.Igor Mammedov
Having remote dfs root support in cifs_mount, we can afford to pass into it UNC that is remote. Signed-off-by: Igor Mammedov <niallain@gmail.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-03-18[CIFS] Rename compose_mount_options to cifs_compose_mount_options.Steve French
Make it available to others for reuse. Signed-off-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-12-26[CIFS] make sure that DFS pathnames are properly formedSteve French
The paths in a DFS request are supposed to only have a single preceding backslash, but we are sending them with a double backslash. This is exposing a bug in Windows where it also sends a path in the response that has a double backslash. The existing code that builds the mount option string however expects a double backslash prefix in a couple of places when it tries to use the path returned by build_path_from_dentry. Fix compose_mount_options to expect properly formed DFS paths (single backslash at front). Also clean up error handling in that function. There was a possible NULL pointer dereference and situations where a partially built option string would be returned. Tested against Samba 3.0.28-ish server and Samba 3.3 and Win2k8. CC: Stable <stable@kernel.org> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-11-18Fixed parsing of mount options when doing DFS submountIgor Mammedov
Since these hit the same routines, and are relatively small, it is easier to review them as one patch. Fixed incorrect handling of the last option in some cases Fixed prefixpath handling convert path_consumed into host depended string length (in bytes) Use non default separator if it is provided in the original mount options Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-08-01[PATCH] pass struct path * to do_add_mount()Al Viro
2008-05-16Fixed DFS code to work with new 'build_path_from_dentry', that returns full ↵Igor Mammedov
path if share in the dfs, now. Signed-off-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-04-28[CIFS] fixed compatibility issue with samba refferal requestIgor Mammedov
treeName part is canonicalized to '/' path separator Signed-off-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-04-25cifs: timeout dfs automounts +little fix.Igor Mammedov
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-16[CIFS] make cifs_dfs_automount_list_staticSteve French
This patch makes the needlessly global cifs_dfs_automount_list static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-03-27[PATCH] do shrink_submounts() for all fs typesAl Viro
... and take it out of ->umount_begin() instances. Call with all locks already taken (by do_umount()) and leave calling release_mounts() to caller (it will do release_mounts() anyway, so we can just put into the same list). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-03-10[CIFS] cifs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-02-15Merge branch 'master' of /pub/scm/linux/kernel/git/torvalds/linux-2.6Steve French
2008-02-15[CIFS] Fix mixed case name in structure dfs_info3_paramIgor Mammedov
2008-02-14Introduce path_put()Jan Blunck
* Add path_put() functions for releasing a reference to the dentry and vfsmount of a struct path in the right order * Switch from path_release(nd) to path_put(&nd->path) * Rename dput_path() to path_put_conditional() [akpm@linux-foundation.org: fix cifs] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: <linux-fsdevel@vger.kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Embed a struct path into struct nameidata instead of nd->{dentry,mnt}Jan Blunck
This is the central patch of a cleanup series. In most cases there is no good reason why someone would want to use a dentry for itself. This series reflects that fact and embeds a struct path into nameidata. Together with the other patches of this series - it enforced the correct order of getting/releasing the reference count on <dentry,vfsmount> pairs - it prepares the VFS for stacking support since it is essential to have a struct path in every place where the stack can be traversed - it reduces the overall code size: without patch series: text data bss dec hex filename 5321639 858418 715768 6895825 6938d1 vmlinux with patch series: text data bss dec hex filename 5320026 858418 715768 6894212 693284 vmlinux This patch: Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix cifs] [akpm@linux-foundation.org: fix smack] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25[CIFS] DFS build fixesSteve French
Also includes a few minor changes suggested by Christoph Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-01-25[CIFS] DFS support: provide shrinkable mountsIgor Mammedov
