path: root/fs/cifs/cifs_unicode.c
2010-04-21[CIFS] Neaten cERROR and cFYI macros, reduce text spaceJoe Perches
Neaten cERROR and cFYI macros, reduce text space ~2.5K Convert '__FILE__ ": " fmt' to '"%s: " fmt', __FILE__' to save text space Surround macros with do {} while Add parentheses to macros Make statement expression macro from macro with assign Remove now unnecessary parentheses from cFYI and cERROR uses defconfig with CIFS support old $ size fs/cifs/built-in.o text data bss dec hex filename 156012 1760 148 157920 268e0 fs/cifs/built-in.o defconfig with CIFS support old $ size fs/cifs/built-in.o text data bss dec hex filename 153508 1760 148 155416 25f18 fs/cifs/built-in.o allyesconfig old: $ size fs/cifs/built-in.o text data bss dec hex filename 309138 3864 74824 387826 5eaf2 fs/cifs/built-in.o allyesconfig new $ size fs/cifs/built-in.o text data bss dec hex filename 305655 3864 74824 384343 5dd57 fs/cifs/built-in.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-08-03cifs: Read buffer overflowRoel Kluin
Check whether index is within bounds before testing the element. Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-05-02[CIFS] remove cifs_strfromUCS_leJeff Layton
Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-04-30[CIFS] rename cifs_strndup to cifs_strndup_from_ucsSteve French
In most cases, cifs_strndup is converting from Unicode (UCS2 / UTF-32) to the configured local code page for the Linux mount (usually UTF8), so Jeff suggested that to make it more clear that cifs_strndup is doing a conversion not just memory allocation and copy, rename the function to including "from_ucs" (ie Unicode) Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-04-30cifs: rename cifs_strlcpy_to_host and make it use new functionsJeff Layton
Rename cifs_strlcpy_to_host to cifs_strndup since that better describes what this function really does. Then, convert it to use the new string conversion and measurement functions that work in units of bytes rather than wide chars. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-04-30cifs: add new function to get unicode string length in bytesJeff Layton
Working in units of words means we do a lot of unnecessary conversion back and forth. Standardize on bytes instead since that's more useful for allocating buffers and such. Also, remove hostlen_fromUCS since the new function has a similar purpose. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-04-30cifs: add replacement for cifs_strtoUCS_le called cifs_from_ucs2Jeff Layton
Add a replacement function for cifs_strtoUCS_le. cifs_from_ucs2 takes args for the source and destination length so that we can ensure that the function is confined within the intended buffers. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-02-07[CIFS] reduce checkpatch warningsSteve French
2007-07-13[CIFS] whitespace/formatting fixesSteve French
This should be the last big batch of whitespace/formatting fixes. checkpatch warnings for the cifs directory are down about 90% and many of the remaining ones are harder to remove or make the code harder to read. Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-06-05[CIFS] whitespace cleanup part 2Steve French
Various coding style problems found by running the new checkpatch.pl script against fs/cifs. 3 more files fixed up. Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-04-04[CIFS] Remove unnecessary parm to cifs_reopen_fileSteve French
Also expand debug entry to show which character on a failed Unicode mapping. Acked-by: Shaggy <shaggy@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-05-31[CIFS] Support for setting up SMB sessions to legacy lanman serversSteve French
2005-11-11[CIFS] Cleanup sparse warnings for unicode little endian castsSteve French
Following Shaggy's suggestion, do a better job on the unicode string handling routines in cifs in specifying that the wchar_t are really little endian widechars (__le16). Signed-off-by: Steve French <sfrench@us.ibm.com>
2005-11-10[CIFS] Reduce sparse endian warningsSteve French
2005-04-28[PATCH] cifs: finish up of special character mapping capable unicode ↵Steve French
conversion routine part 2 of 3 Signed-off-by: Steve French (sfrench@us.ibm.com) Signed-off-by: Linus Torvalds <torvalds@osdl.org>
