path: root/fs/cifs/cifspdu.h
2013-11-11cifs: Use data structures to compute NTLMv2 response offsetsTim Gardner
A bit of cleanup plus some gratuitous variable renaming. I think using structures instead of numeric offsets makes this code much more understandable. Also added a comment about current time range expected by the server. Acked-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Shirish Pargaonkar <spargaonkar@suse.com> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-11-02Allow setting per-file compression via CIFS protocolSteve French
An earlier patch allowed setting the per-file compression flag "chattr +c filename" on an smb2 or smb3 mount, and also allowed lsattr to return whether a file on a cifs, or smb2/smb3 mount was compressed. This patch extends the ability to set the per-file compression flag to the cifs protocol, which uses a somewhat different IOCTL mechanism than SMB2, although the payload (the flags stored in the compression_state) are the same. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-11-02cifs: Make big endian multiplex ID sequences monotonic on the wireTim Gardner
The multiplex identifier (MID) in the SMB header is only ever used by the client, in conjunction with PID, to match responses from the server. As such, the endianess of the MID is not important. However, When tracing packet sequences on the wire, protocol analyzers such as wireshark display MID as little endian. It is much more informative for the on-the-wire MID sequences to match debug information emitted by the CIFS driver. Therefore, one should write and read MID in the SMB header assuming it is always little endian. Observed from wireshark during the protocol negotiation and session setup: Multiplex ID: 256 Multiplex ID: 256 Multiplex ID: 512 Multiplex ID: 512 Multiplex ID: 768 Multiplex ID: 768 After this patch on-the-wire MID values begin at 1 and increase monotonically. Introduce get_next_mid64() for the internal consumers that use the full 64 bit multiplex identifier. Introduce the helpers get_mid() and compare_mid() to make the endian translation clear. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Tim Gardner <timg@tpi.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-10-28Query file system attributes from server on SMB2, not just cifs, mountsSteve French
Currently SMB2 and SMB3 mounts do not query the file system attributes from the server at mount time as is done for cifs. These can be useful for debugging. Signed-off-by: Steve French <smfrench@gmail.com>
2013-10-05do not treat non-symlink reparse points as valid symlinksSteve French
Windows 8 and later can create NFS symlinks (within reparse points) which we were assuming were normal NTFS symlinks and thus reporting corrupt paths for. Add check for reparse points to make sure that they really are normal symlinks before we try to parse the pathname. We also should not be parsing other types of reparse points (DFS junctions etc) as if they were a symlink so return EOPNOTSUPP on those. Also fix endian errors (we were not parsing symlink lengths as little endian). This fixes commit d244bf2dfbebfded05f494ffd53659fa7b1e32c1 which implemented follow link for non-Unix CIFS mounts CC: Stable <stable@kernel.org> Reviewed-by: Andrew Bartlett <abartlet@samba.org> Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-25[CIFS] Remove ext2 flags that have been moved to fs.hSteve French
These flags were unused by cifs and since the EXT flags have been moved to common code in uapi/linux/fs.h we won't need to have a cifs specific copy. Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-08CIFS: Implement follow_link for nounix CIFS mountsPavel Shilovsky
by using a query reparse ioctl request. Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <pshilovsky@samba.org> Signed-off-by: Steve French <smfrench@gmail.com>
2013-06-26[CIFS] SMB3 Signing enablementSteve French
SMB3 uses a much faster method of signing (which is also better in other ways), AES-CMAC. With the kernel now supporting AES-CMAC since last release, we are overdue to allow SMB3 signing (today only CIFS and SMB2 and SMB2.1, but not SMB3 and SMB3.1 can sign) - and we need this also for checking secure negotation and also per-share encryption (two other new SMB3 features which we need to implement). This patch needs some work in a few areas - for example we need to move signing for SMB2/SMB3 from per-socket to per-user (we may be able to use the "nosharesock" mount option in the interim for the multiuser case), and Shirish found a bug in the earlier authentication overhaul (setting signing flags properly) - but those can be done in followon patches. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-06-24Update headers to update various SMB3 ioctl definitionsSteve French
MS-SMB2 Section 2.2.31 lists fsctls. Update our list of valid cifs/smb2/smb3 fsctls and some related structs based on more recent version of docs. Additional detail on less common ones can be found in MS-FSCC section 2.3. CopyChunk (server side copy, ie refcopy) will depend on a few of these Signed-off-by: Steve French <smfrench@gmail.com>
2013-06-24cifs: break out decoding of security blob into separate functionJeff Layton
...cleanup. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <sfrench@us.ibm.com>
2013-02-13cifs: Use kuids and kgids SID to uid/gid mappingEric W. Biederman
Update id_mode_to_cifs_acl to take a kuid_t and a kgid_t. Replace NO_CHANGE_32 with INVALID_UID and INVALID_GID, and tests for NO_CHANGE_32 with uid_valid and gid_valid. Carefully unpack the value returned from request_key. memcpy the value into the expected type. The convert the uid/gid into a kuid/kgid. And then only if the result is a valid kuid or kgid update fuid/fgid. Cc: Steve French <smfrench@gmail.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-09-24CIFS: Fix endian conversion of IndexNumberPavel Shilovsky
by making it __le64 rather than __u64 in FILE_AL_INFO structure. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <smfrench@gmail.com>
2011-10-27Add definition for share encryptionSteve French
Samba supports a setfs info level to negotiate encrypted shares. This patch adds the defines so we recognize this info level. Later patches will add the enablement for it. Acked-by: Jeremy Allison <jra@samba.org> Signed-off-by: Steve French <smfrench@gmail.com>
2011-10-19cifs: fix protocol definition for READ_RSPJeff Layton
There is no pad, and it simplifies the code to remove the "Data" field. None of the existing code relies on these fields, or on the READ_RSP being a particular length. Reviewed-and-Tested-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Jeff Layton <jlayton@redhat.com>
2011-05-19cifs: turn BCC into a static inlined functionJeff Layton
It's a bad idea to have macro functions that reference variables more than once, as the arguments could have side effects. Turn BCC() into a static inlined function instead. While we're at it, make it return a void * to discourage anyone from dereferencing it as-is. Reported-and-acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-05-19cifs: keep BCC in little-endian formatJeff Layton
This is the same patch as originally posted, just with some merge conflicts fixed up... Currently, the ByteCount is usually converted to host-endian on receive. This is confusing however, as we need to keep two sets of routines for accessing it, and keep track of when to use each routine. Munging received packets like this also limits when the signature can be calulated. Simplify the code by keeping the received ByteCount in little-endian format. This allows us to eliminate a set of routines for accessing it and we can now drop the *_le suffixes from the accessor functions since that's now implied. While we're at it, switch all of the places that read the ByteCount directly to use the get_bcc inline which should also clean up some unaligned accesses. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-05-19consistently use smb_buf_length as be32 for cifs (try 3)Steve French
There is one big endian field in the cifs protocol, the RFC1001 length, which cifs code (unlike in the smb2 code) had been handling as u32 until the last possible moment, when it was converted to be32 (its native form) before sending on the wire. To remove the last sparse endian warning, and to make this consistent with the smb2 implementation (which always treats the fields in their native size and endianness), convert all uses of smb_buf_length to be32. This version incorporates Christoph's comment about using be32_add_cpu, and fixes a typo in the second version of the patch. Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20cifs: use get/put_unaligned functions to access ByteCountJeff Layton
It's possible that when we access the ByteCount that the alignment will be off. Most CPUs deal with that transparently, but there's usually some performance impact. Some CPUs raise an exception on unaligned accesses. Fix this by accessing the byte count using the get_unaligned and put_unaligned inlined functions. While we're at it, fix the types of some of the variables that end up getting returns from these functions. Acked-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20cifs: add ability to send an echo requestJeff Layton
Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-26NTLM auth and sign - Define crypto hash functions and create and send keys ↵Shirish Pargaonkar
needed for key exchange Mark dependency on crypto modules in Kconfig. Defining per structures sdesc and cifs_secmech which are used to store crypto hash functions and contexts. They are stored per smb connection and used for all auth mechs to genereate hash values and signatures. Allocate crypto hashing functions, security descriptiors, and respective contexts when a smb/tcp connection is established. Release them when a tcp/smb connection is taken down. md5 and hmac-md5 are two crypto hashing functions that are used throught the life of an smb/tcp connection by various functions that calcualte signagure and ntlmv2 hash, HMAC etc. structure ntlmssp_auth is defined as per smb connection. ntlmssp_auth holds ciphertext which is genereated by rc4/arc4 encryption of secondary key, a nonce using ntlmv2 session key and sent in the session key field of the type 3 message sent by the client during ntlmssp negotiation/exchange A key is exchanged with the server if client indicates so in flags in type 1 messsage and server agrees in flag in type 2 message of ntlmssp negotiation. If both client and agree, a key sent by client in type 3 message of ntlmssp negotiation in the session key field. The key is a ciphertext generated off of secondary key, a nonce, using ntlmv2 hash via rc4/arc4. Signing works for ntlmssp in this patch. The sequence number within the server structure needs to be zero until session is established i.e. till type 3 packet of ntlmssp exchange of a to be very first smb session on that smb connection is sent. Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-26NTLM auth and sign - Allocate session key/client response dynamicallyShirish Pargaonkar
Start calculating auth response within a session. Move/Add pertinet data structures like session key, server challenge and ntlmv2_hash in a session structure. We should do the calculations within a session before copying session key and response over to server data structures because a session setup can fail. Only after a very first smb session succeeds, it copy/make its session key, session key of smb connection. This key stays with the smb connection throughout its life. sequence_number within server is set to 0x2. The authentication Message Authentication Key (mak) which consists of session key followed by client response within structure session_key is now dynamic. Every authentication type allocates the key + response sized memory within its session structure and later either assigns or frees it once the client response is sent and if session's session key becomes connetion's session key. ntlm/ntlmi authentication functions are rearranged. A function named setup_ntlm_resp(), similar to setup_ntlmv2_resp(), replaces function cifs_calculate_session_key(). size of CIFS_SESS_KEY_SIZE is changed to 16, to reflect the byte size of the key it holds. Reviewed-by: Jeff Layton <jlayton@samba.org> Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs NTLMv2/NTLMSSP ntlmv2 within ntlmssp autentication codeShirish Pargaonkar
Attribue Value (AV) pairs or Target Info (TI) pairs are part of ntlmv2 authentication. Structure ntlmv2_resp had only definition for two av pairs. So removed it, and now allocation of av pairs is dynamic. For servers like Windows 7/2008, av pairs sent by server in challege packet (type 2 in the ntlmssp exchange/negotiation) can vary. Server sends them during ntlmssp negotiation. So when ntlmssp is used as an authentication mechanism, type 2 challenge packet from server has this information. Pluck it and use the entire blob for authenticaiton purpose. If user has not specified, extract (netbios) domain name from the av pairs which is used to calculate ntlmv2 hash. Servers like Windows 7 are particular about the AV pair blob. Servers like Windows 2003, are not very strict about the contents of av pair blob used during ntlmv2 authentication. So when security mechanism such as ntlmv2 is used (not ntlmv2 in ntlmssp), there is no negotiation and so genereate a minimal blob that gets used in ntlmv2 authentication as well as gets sent. Fields tilen and tilbob are session specific. AV pair values are defined. To calculate ntlmv2 response we need ti/av pair blob. For sec mech like ntlmssp, the blob is plucked from type 2 response from the server. From this blob, netbios name of the domain is retrieved, if user has not already provided, to be included in the Target String as part of ntlmv2 hash calculations. For sec mech like ntlmv2, create a minimal, two av pair blob. The allocated blob is freed in case of error. In case there is no error, this blob is used in calculating ntlmv2 response (in CalcNTLMv2_response) and is also copied on the response to the server, and then freed. The type 3 ntlmssp response is prepared on a buffer, 5 * sizeof of struct _AUTHENTICATE_MESSAGE, an empirical value large enough to hold _AUTHENTICATE_MESSAGE plus a blob with max possible 10 values as part of ntlmv2 response and lmv2 keys and domain, user, workstation names etc. Also, kerberos gets selected as a default mechanism if server supports it, over the other security mechanisms. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-08Revert "[CIFS] Fix ntlmv2 auth with ntlmssp"Steve French
This reverts commit 9fbc590860e75785bdaf8b83e48fabfe4d4f7d58. The change to kernel crypto and fixes to ntlvm2 and ntlmssp series, introduced a regression. Deferring this patch series to 2.6.37 after Shirish fixes it. Signed-off-by: Steve French <sfrench@us.ibm.com> Acked-by: Jeff Layton <jlayton@redhat.com> CC: Shirish Pargaonkar <shirishp@us.ibm.com>
2010-08-20[CIFS] Fix ntlmv2 auth with ntlmsspSteve French
Make ntlmv2 as an authentication mechanism within ntlmssp instead of ntlmv1. Parse type 2 response in ntlmssp negotiation to pluck AV pairs and use them to calculate ntlmv2 response token. Also, assign domain name from the sever response in type 2 packet of ntlmssp and use that (netbios) domain name in calculation of response. Enable cifs/smb signing using rc4 and md5. Changed name of the structure mac_key to session_key to reflect the type of key it holds. Use kernel crypto_shash_* APIs instead of the equivalent cifs functions. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-02-23cifs: add parens around smb_var in BCC macrosJeff Layton
...to remove ambiguity about how these values are interpreted when passing in more complex values as arguments. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-12-04tree-wide: fix misspelling of "definition" in commentsAdam Buchbinder
"Definition" is misspelled "defintion" in several comments; this patch fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-07-01cifs: add new cifs_iget function and convert unix codepath to use itJeff Layton
cifs: add new cifs_iget function and convert unix codepath to use it In order to unify some codepaths, introduce a common cifs_fattr struct for storing inode attributes. The different codepaths (unix, legacy, normal, etc...) can fill out this struct with inode info. It can then be passed as an arg to a common set of routines to get and update inodes. Add a new cifs_iget function that uses iget5_locked to identify inodes. This will compare inodes based on the uniqueid value in a cifs_fattr struct. Rather than filling out an already-created inode, have cifs_get_inode_info_unix instead fill out cifs_fattr and hand that off to cifs_iget. cifs_iget can then properly look for hardlinked inodes. On the readdir side, add a new cifs_readdir_lookup function that spawns populated dentries. Redefine FILE_UNIX_INFO so that it's basically a FILE_UNIX_BASIC_INFO that has a few fields wrapped around it. This allows us to more easily use the same function for filling out the fattr as the non-readdir codepath. With this, we should then have proper hardlink detection and can eventually get rid of some nasty CIFS-specific hacks for handing them. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-04-17[CIFS] Endian convert UniqueId when reporting inode numbers from server filesSteve French
Jeff made a good point that we should endian convert the UniqueId when we use it to set i_ino Even though this value is opaque to the client, when comparing the inode numbers of the same server file from two different clients (one big endian, one little endian) or when we compare a big endian client's view of i_ino with what the server thinks - we should get the same value Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-03-12[CIFS] Add definitions for remoteably fsctl callsSteve French
There are about 60 fsctl calls which Windows claims would be able to be sent remotely and handled by the server. This adds the #defines for them. A few of them look immediately useful, but need to also add the structure definitions for them so they can be sent as SMBs. Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-03-12[CIFS] DFS no longer experimentalSteve French
Also updates some DFS flag definitions Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-03-12[CIFS] Send SMB flush in cifs_fsyncSteve French
In contrast to the now-obsolete smbfs, cifs does not send SMB_COM_FLUSH in response to an explicit fsync(2) to guarantee that all volatile data is written to stable storage on the server side, provided the server honors the request (which, to my knowledge, is true for Windows and Samba with 'strict sync' enabled). This patch modifies the cifs_fsync implementation to restore the fsync-behavior of smbfs by triggering SMB_COM_FLUSH after sending outstanding data on the client side to the server. Signed-off-by: Horst Reiterer <horst.reiterer@gmail.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-12-26[CIFS] various minor cleanups pointed out by checkpatch scriptSteve French
2008-08-06bundle up Unix SET_PATH_INFO args into a struct and change nameJeff Layton
We'd like to be able to use the unix SET_PATH_INFO_BASIC args to set file times as well, but that makes the argument list rather long. Bundle up the args for unix SET_PATH_INFO call into a struct. For now, we don't actually use the times fields anywhere. That will be done in a follow-on patch. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-07-24[CIFS] Fix warnings from checkpatchShirish Pargaonkar
2008-05-23[CIFS] Correct incorrect obscure open flagSteve French
Also add defines for pipe subcommand codes Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-16[CIFS] Add missing defines for DFSSteve French
Also has minor cleanup of previous patch CC: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-16CIFSGetDFSRefer cleanup + dfs_referral_level_3 fixed to conform REFERRAL_V3 ↵Igor Mammedov
the MS-DFSC spec. Signed-off-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-11[CIFS] when not using unix extensions, check for and set ATTR_READONLY on ↵Jeff Layton
create and mkdir When creating a directory on a CIFS share without POSIX extensions, and the given mode has no write bits set, set the ATTR_READONLY bit. When creating a file, set ATTR_READONLY if the create mode has no write bits set and we're not using unix extensions. There are some comments about this being problematic due to the VFS splitting creates into 2 parts. I'm not sure what that's actually talking about, but I'm assuming that it has something to do with how mknod is implemented. In the simple case where we have no unix extensions and we're just creating a regular file, there's no reason we can't set ATTR_READONLY. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-04-25[CIFS] Fix spelling mistakeSteve French
Noticed by Joe Perches Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-04-24[CIFS] Fix typo in previous commitSteve French
2008-04-24[CIFS] Fix define for new proxy cap to match documentationSteve French
The transport encryption capability and new SetFSInfo level were missing, and the new proxy capability (which Samba server is implementing) and proxy setfsinfo needed to be moved down to not collide with Samba's transport encryption capability. CC: Jeremy Allison <jra@samba.org> CC: Sam Liddicott <sam@lidicott.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-04-18[CIFS] Reserve new proxy cap for WAFSSteve French
New WAFS filer uses ioctls which are shown to be available on a share by querying this info level Acked-by: Sam Liddicott <sam@liddicott.com> Signed-off-by: Stevef French <sfrench@us.ibm.com>
2008-04-17[CIFS] Add various missing flags and defintionsSteve French
2007-12-31[CIFS] Allow setting mode via cifs aclSteve French
Requires cifsacl mount flag to be on and CIFS_EXPERIMENTAL enabled CC: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-11-01[CIFS] If no Access Control Entries, set mode perm bits to zeroSteve French
Also clean up ACL code Acked-by: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-10-31[CIFS] Don't request too much permission when reading an ACLSteve French
We were requesting GENERIC_READ but that fails when we do not have read permission on the file (even if we could read the ACL). Also move the dump access control entry code into debug ifdef. Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-10-17[CIFS] acl support part 4Steve French
2007-09-29[CIFS] named pipe support (part 2)Steve French
Also fixes typo which could cause build break Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-08-30[CIFS] formatting cleanup found by checkpatchSteve French
2007-07-15[CIFS] Add support for new POSIX unlinkSteve French
In the cleanup phase of the dbench test, we were noticing sharing violation followed by failed directory removals when dbench did not close the test files before the cleanup phase started. Using the new POSIX unlink, which Samba has supported for a few months, avoids this. Signed-off-by: Steve French <sfrench@us.ibm.com>
