path: root/fs/cifs/dir.c
2011-08-16cifs: demote cERROR in build_path_from_dentry to cFYIJeff Layton
Running the cthon tests on a recent kernel caused this message to pop occasionally: CIFS VFS: did not end path lookup where expected namelen is 0 Some added debugging showed that namelen and dfsplen were both 0 when this occurred. That means that the read_seqretry returned true. Assuming that the comment inside the if statement is true, this should be harmless and just means that we raced with a rename. If that is the case, then there's no need for alarm and we can demote this to cFYI. While we're at it, print the dfsplen too so that we can see what happened here if the message pops during debugging. Cc: stable@kernel.org Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: Cleanup: check return codes of crypto api calls CIFS: Fix oops while mounting with prefixpath [CIFS] Redundant null check after dereference cifs: use cifs_dirent in cifs_save_resume_key cifs: use cifs_dirent to replace cifs_get_name_from_search_buf cifs: introduce cifs_dirent cifs: cleanup cifs_filldir
2011-07-25CIFS: Fix oops while mounting with prefixpathPavel Shilovsky
commit fec11dd9a0109fe52fd631e5c510778d6cbff6cc caused a regression when we have already mounted //server/share/a and want to mount //server/share/a/b. The problem is that lookup_one_len calls __lookup_hash with nd pointer as NULL. Then __lookup_hash calls do_revalidate in the case when dentry exists and we end up with NULL pointer deference in cifs_d_revalidate: if (nd->flags & LOOKUP_RCU) return -ECHILD; Fix this by checking nd for NULL. Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Reviewed-by: Shirish Pargaonkar <shirishp@us.ibm.com> CC: Stable <stable@kernel.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-25[CIFS] Redundant null check after dereferenceSteve French
Reviewed-by: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
commit fec11dd9a0109fe52fd631e5c510778d6cbff6cc caused a regression when we have already mounted //server/share/a and want to mount //server/share/a/b. The problem is that lookup_one_len calls __lookup_hash with nd pointer as NULL. Then __lookup_hash calls do_revalidate in the case when dentry exists and we end up with NULL pointer deference in cifs_d_revalidate: if (nd->flags & LOOKUP_RCU) return -ECHILD; Fix this by checking nd for NULL. Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20cifs_lookup(): LOOKUP_OPEN is set only on the last componentAl Viro
2011-07-20LOOKUP_CREATE and LOOKUP_RENAME_TARGET can be set only on the last stepAl Viro
2011-07-20no need to check for LOOKUP_OPEN in ->create() instancesAl Viro
... it will be set in nd->flag for all cases with non-NULL nd (i.e. when called from do_last()). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-16cifs: build_path_from_dentry() race fixAl Viro
deal with d_move() races properly; rename_lock read-retry loop, rcu_read_lock() held while walking to root, d_lock held over subtraction from namelen and copying the component to stabilize ->d_name. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-27[CIFS] Rename three structures to avoid camel caseSteve French
secMode to sec_mode and cifsTconInfo to cifs_tcon and cifsSesInfo to cifs_ses Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-05-27[CIFS] Migrate from prefixpath logicSteve French
Now we point superblock to a server share root and set a root dentry appropriately. This let us share superblock between mounts like //server/sharename/foo/bar and //server/sharename/foo further. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-05-26CIFS: Use pid saved from cifsFileInfo in writepages and set_file_sizePavel Shilovsky
We need it to make them work with mandatory locking style because we can fail in a situation like when kernel need to flush dirty pages and there is a lock held by a process who opened file. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-15CIFS: Use d_automount() rather than abusing follow_link()David Howells
Make CIFS use the new d_automount() dentry operation rather than abusing follow_link() on directories. [NOTE: THIS IS UNTESTED!] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Steve French <sfrench@samba.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-12switch cifsAl Viro
2011-01-09cifs: switch cifs_open and cifs_create to use CIFSSMBUnixSetFileInfoJeff Layton
We call CIFSSMBUnixSetPathInfo in these functions, but we have a filehandle since an open was just done. Switch these functions to use CIFSSMBUnixSetFileInfo instead. In practice, these codepaths are only used if posix opens are broken. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-09[CIFS] Fix minor merge conflict in fs/cifs/dir.cSteve French
2011-01-09Merge branch 'master' of /pub/scm/linux/kernel/git/torvalds/linux-2.6Steve French
Conflicts: fs/cifs/dir.c
2011-01-07fs: rcu-walk aware d_revalidate methodNick Piggin
Require filesystems be aware of .d_revalidate being called in rcu-walk mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning -ECHILD from all implementations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_hash for rcu-walkNick Piggin
Change d_hash so it may be called from lock-free RCU lookups. See similar patch for d_compare for details. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_compare for rcu-walkNick Piggin
Change d_compare so it may be called from lock-free RCU lookups. This does put significant restrictions on what may be done from the callback, however there don't seem to have been any problems with in-tree fses. If some strange use case pops up that _really_ cannot cope with the rcu-walk rules, we can just add new rcu-unaware callbacks, which would cause name lookup to drop out of rcu-walk mode. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07cifs: dont overwrite dentry name in d_revalidateNick Piggin
Use vfat's method for dealing with negative dentries to preserve case, rather than overwrite dentry name in d_revalidate, which is a bit ugly and also gets in the way of doing lock-free path walking. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-06cifs: don't overwrite dentry name in d_revalidateNick Piggin
Instead, use fatfs's method for dealing with negative dentries to preserve case, rather than overwrite dentry name in d_revalidate, which is a bit ugly and also gets in the way of doing lock-free path walking. Signed-off-by: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-18cifs: move cifs_new_fileinfo to file.cJeff Layton
It's currently in dir.c which makes little sense... Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-18cifs: eliminate pfile pointer from cifsFileInfoJeff Layton
All the remaining users of cifsFileInfo->pfile just use it to get at the f_flags/f_mode. Now that we store that separately in the cifsFileInfo, there's no need to consult the pfile at all from a cifsFileInfo pointer. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-18cifs: clean up cifs_reopen_fileJeff Layton
Add a f_flags field that holds the f_flags field from the filp. We'll need this info in case the filp ever goes away before the cifsFileInfo does. Have cifs_reopen_file use that value instead of filp->f_flags too and have it take a cifsFileInfo arg instead of a filp. While we're at it, get rid of some bogus cargo-cult NULL pointer checks in that function and reduce the level of indentation. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-18cifs: eliminate the inode argument from cifs_new_fileinfoJeff Layton
It already takes a file pointer. The inode associated with that had damn well better be the same one we're passing in anyway. Thus, there's no need for a separate argument here. Also, get rid of the bogus check for a null pCifsInode pointer. The CIFS_I macro uses container_of(), and that will virtually never return a NULL pointer anyway. Finally, move the setting of the canCache* flags outside of the lock. Other places in the code don't hold that lock when setting it, so I assume it's not really needed here either. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-18cifs: eliminate oflags option from cifs_new_fileinfoJeff Layton
Eliminate the poor, misunderstood "oflags" option from cifs_new_fileinfo. The callers mostly pass in the filp->f_flags here. That's not correct however since we're checking that value for the presence of FMODE_READ. Luckily that only affects how the f_list is ordered. What it really wants here is the file->f_mode. Just use that field from the filp to determine it. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-18cifs: fix flags handling in cifs_posix_openJeff Layton
The way flags are passed and converted for cifs_posix_open is rather non-sensical. Some callers call cifs_posix_convert_flags on the flags before they pass them to cifs_posix_open, whereas some don't. Two flag conversion steps is just confusing though. Change the function instead to clearly expect input in f_flags format, and fix the callers to pass that in. Then, have cifs_posix_open call cifs_convert_posix_flags to do the conversion. Move cifs_posix_open to file.c as well so we can keep cifs_convert_posix_flags as a static function. Fix it also to not ignore O_CREAT, O_EXCL and O_TRUNC, and instead have cifs_reopen_file mask those bits off before calling cifs_posix_open. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-12cifs: don't use vfsmount to pin superblock for oplock breaksJeff Layton
Filesystems aren't really supposed to do anything with a vfsmount. It's considered a layering violation since vfsmounts are entirely managed at the VFS layer. CIFS currently keeps an active reference to a vfsmount in order to prevent the superblock vanishing before an oplock break has completed. What we really want to do instead is to keep sb->s_active high until the oplock break has completed. This patch borrows the scheme that NFS uses for handling sillyrenames. An atomic_t is added to the cifs_sb_info. When it transitions from 0 to 1, an extra reference to the superblock is taken (by bumping the s_active value). When it transitions from 1 to 0, that reference is dropped and a the superblock teardown may proceed if there are no more references to it. Also, the vfsmount pointer is removed from cifsFileInfo and from cifs_new_fileinfo, and some bogus forward declarations are removed from cifsfs.h. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-12cifs: keep dentry reference in cifsFileInfo instead of inode referenceJeff Layton
cifsFileInfo is a bit problematic. It contains a reference back to the struct file itself. This makes it difficult for a cifsFileInfo to exist without a corresponding struct file. It would be better instead of the cifsFileInfo just held info pertaining to the open file on the server instead without any back refrences to the struct file. This would allow it to exist after the filp to which it was originally attached was closed. Much of the use of the file pointer in this struct is to get at the dentry. Begin divorcing the cifsFileInfo from the struct file by keeping a reference to the dentry. Since the dentry will have a reference to the inode, we can eliminate the "pInode" field too and convert the igrab/iput to dget/dput. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-06cifs: have find_readable/writable_file filter by fsuidJeff Layton
When we implement multiuser mounts, we'll need to filter filehandles by fsuid. Add a flag for multiuser mounts and code to filter by fsuid when it's set. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-06cifs: have cifsFileInfo hold a reference to a tlink rather than tcon pointerJeff Layton
cifsFileInfo needs a pointer to a tcon, but it doesn't currently hold a reference to it. Change it to keep a pointer to a tcon_link instead and hold a reference to it. That will keep the tcon from being freed until the file is closed. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-06cifs: add refcounted and timestamped container for holding tconsJeff Layton
Eventually, we'll need to track the use of tcons on a per-sb basis, so that we know when it's ok to tear them down. Begin this conversion by adding a new "tcon_link" struct and accessors that get it. For now, the core data structures are untouched -- cifs_sb still just points to a single tcon and the pointers are just cast to deal with the accessor functions. A later patch will flesh this out. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs: have cifs_new_fileinfo take a tcon argJeff Layton
To minimize calls to cifs_sb_tcon and to allow for a clear error path if a tcon can't be acquired. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs: add cifs_sb_master_tcon and convert some callers to use itJeff Layton
At mount time, we'll always need to create a tcon that will serve as a template for others that are associated with the mount. This tcon is known as the "master" tcon. In some cases, we'll need to use that tcon regardless of who's accessing the mount. Add an accessor function for the master tcon and go ahead and switch the appropriate places to use it. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs: add function to get a tcon from cifs_sbJeff Layton
When we convert cifs to do multiple sessions per mount, we'll need more than one tcon per superblock. At that point "cifs_sb->tcon" will make no sense. Add a new accessor function that gets a tcon given a cifs_sb. For now, it just returns cifs_sb->tcon. Later it'll do more. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs: add tcon field to cifsFileInfo structJeff Layton
Eventually, we'll have more than one tcon per superblock. At that point, we'll need to know which one is associated with a particular fid. For now, this is just set from the cifs_sb->tcon pointer, but eventually the caller of cifs_new_fileinfo will pass a tcon pointer in. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs: fix broken oplock handlingSuresh Jayaraman
cifs_new_fileinfo() does not use the 'oplock' value from the callers. Instead, it sets it to REQ_OPLOCK which seems wrong. We should be using the oplock value obtained from the Server to set the inode's clientCanCacheAll or clientCanCacheRead flags. Fix this by passing oplock from the callers to cifs_new_fileinfo(). This change dates back to commit a6ce4932 (2.6.30-rc3). So, all the affected versions will need this fix. Please Cc stable once reviewed and accepted. Cc: Stable <stable@kernel.org> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-16cifs: consolidate error handling in several functionsJeff Layton
cifs has a lot of complicated functions that have to clean up things on error, but some of them don't have all of the cleanup code well-consolidated. Clean up and consolidate error handling in several functions. This is in preparation of later patches that will need to put references to the tcon link container. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-16cifs: clean up error handling in cifs_mknodJeff Layton
Get rid of some nesting and add a label we can goto on error. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-07Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (55 commits) workqueue: mark init_workqueues() as early_initcall() workqueue: explain for_each_*cwq_cpu() iterators fscache: fix build on !CONFIG_SYSCTL slow-work: kill it gfs2: use workqueue instead of slow-work drm: use workqueue instead of slow-work cifs: use workqueue instead of slow-work fscache: drop references to slow-work fscache: convert operation to use workqueue instead of slow-work fscache: convert object to use workqueue instead of slow-work workqueue: fix how cpu number is stored in work->data workqueue: fix mayday_mask handling on UP workqueue: fix build problem on !CONFIG_SMP workqueue: fix locking in retry path of maybe_create_worker() async: use workqueue for worker pool workqueue: remove WQ_SINGLE_CPU and use WQ_UNBOUND instead workqueue: implement unbound workqueue workqueue: prepare for WQ_UNBOUND implementation libata: take advantage of cmwq and remove concurrency limitations workqueue: fix worker management invocation without pending works ... Fixed up conflicts in fs/cifs/* as per Tejun. Other trivial conflicts in include/linux/workqueue.h, kernel/trace/Kconfig and kernel/workqueue.c
2010-08-02cifs: remove an potentially confusing, obsolete commentSuresh Jayaraman
The recent commit 6ca9f3bae8b1854794dfa63cdd3b88b7dfe24c13 modified the code so that filp is full instantiated whenever the file is created and passed back. The below comment is no longer true, remove it. Cc: Jeff Layton <jlayton@redhat.com> Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-07-22cifs: use workqueue instead of slow-workTejun Heo
Workqueue can now handle high concurrency. Use system_nrt_wq instead of slow-work. * Updated is_valid_oplock_break() to not call cifs_oplock_break_put() as advised by Steve French. It might cause deadlock. Instead, reference is increased after queueing succeeded and cifs_oplock_break() briefly grabs GlobalSMBSeslock before putting the cfile to make sure it doesn't put before the matching get is finished. * Anton Blanchard reported that cifs conversion was using now gone system_single_wq. Use system_nrt_wq which provides non-reentrance guarantee which is enough and much better. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Steve French <sfrench@samba.org> Cc: Anton Blanchard <anton@samba.org>
2010-06-16cifs: pass instantiated filp back after open callJeff Layton
The current scheme of sticking open files on a list and assuming that cifs_open will scoop them off of it is broken and leads to "Busy inodes after umount..." errors at unmount time. The problem is that there is no guarantee that cifs_open will always be called after a ->lookup or ->create operation. If there are permissions or other problems, then it's quite likely that it *won't* be called. Fix this by fully instantiating the filp whenever the file is created and pass that filp back to the VFS. If there is a problem, the VFS can clean up the references. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-and-Tested-by: Suresh Jayaraman <sjayaraman@suse.de>
2010-06-16cifs: move cifs_new_fileinfo call out of cifs_posix_openJeff Layton
Having cifs_posix_open call cifs_new_fileinfo is problematic and inconsistent with how "regular" opens work. It's also buggy as cifs_reopen_file calls this function on a reconnect, which creates a new struct cifsFileInfo that just gets leaked. Push it out into the callers. This also allows us to get rid of the "mnt" arg to cifs_posix_open. Finally, in the event that a cifsFileInfo isn't or can't be created, we always want to close the filehandle out on the server as the client won't have a record of the filehandle and can't actually use it. Make sure that CIFSSMBClose is called in those cases. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-and-Tested-by: Suresh Jayaraman <sjayaraman@suse.de>
2010-05-17cifs: fix noserverino handling when unix extensions are enabledJeff Layton
The uniqueid field sent by the server when unix extensions are enabled is currently used sometimes when it shouldn't be. The readdir codepath is correct, but most others are not. Fix it. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-05-11cifs: propagate cifs_new_fileinfo() error back to the callerSuresh Jayaraman
..otherwise memory allocation errors go undetected. Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-05-10cifs: add comments explaining cifs_new_fileinfo behaviorSuresh Jayaraman
The comments make it clear the otherwise subtle behavior of cifs_new_fileinfo(). Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de> Reviewed-by: Shirish Pargaonkar <shirishp@us.ibm.com> -- fs/cifs/dir.c | 18 ++++++++++++++++-- 1 files changed, 16 insertions(+), 2 deletions(-) Signed-off-by: Steve French <sfrench@us.ibm.com>
