commit 4c17a6d56bb0cad3066a714e94f7185a24b40f49 upstream.
This might lead to local privilege escalation (code execution as
kernel) for systems where the following conditions are met:
- CONFIG_CIFS_SMB2 and CONFIG_CIFS_POSIX are enabled
- a cifs filesystem is mounted where:
- the mount option "vers" was used and set to a value >=2.0
- the attacker has write access to at least one file on the filesystem
To attack this, an attacker would have to guess the target_tcon
pointer (but guessing wrong doesn't cause a crash, it just returns an
error code) and win a narrow race.
Signed-off-by: Jann Horn <jann@thejh.net>
Signed-off-by: Steve French <smfrench@gmail.com>
It really needs to check that src is non-directory *and* use
{un,}lock_two_nodirectories(). As it is, it's trivial to cause
double-lock (ioctl(fd, CIFS_IOC_COPYCHUNK_FILE, fd)) and if the
last argument is an fd of directory, we are asking for trouble
by violating the locking order - all directories go before all
non-directories. If the last argument is an fd of parent
directory, it has 50% odds of locking child before parent,
which will cause AB-BA deadlock if we race with unlink().
Cc: stable@vger.kernel.org @ 3.13+
Signed-off-by: Libo Chen <clbchenlibo.chen@huawei.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
Change cifs.ko to using CIFS_IOCTL_COPYCHUNK instead
of BTRFS_IOC_CLONE to avoid confusion about whether
copy-on-write is required or optional for this operation.
SMB2/SMB3 copyoffload had used the BTRFS_IOC_CLONE ioctl since
they both speed up copy by offloading the copy rather than
passing many read and write requests back and forth and both have
identical syntax (passing file handles), but for SMB2/SMB3
CopyChunk the server is not required to use copy-on-write
to make a copy of the file (although some do), and Christoph
has commented that since CopyChunk does not require
copy-on-write we should not reuse BTRFS_IOC_CLONE.
This patch renames the ioctl to use a cifs specific IOCTL
CIFS_IOCTL_COPYCHUNK. This ioctl is particularly important
for SMB2/SMB3 since large file copy over the network otherwise
can be very slow, and with this is often more than 100 times
faster putting less load on server and client.
Note that if a copy syscall is ever introduced, depending on
its requirements/format it could end up using one of the other
three methods that CIFS/SMB2/SMB3 can do for copy offload,
but this method is particularly useful for file copy
and broadly supported (not just by Samba server).
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Reviewed-by: David Disseldorp <ddiss@samba.org>
This first patch adds the ability for us to do a server side copy
(ie fast copy offloaded to the server to perform, aka refcopy)
"cp --reflink"
of one file to another located on the same server. This
is much faster than traditional copy (which requires
reading and writing over the network and extra
memcpys).
This first version is not going to be copy
files larger than about 1MB (to Samba) until I add
support for multiple chunks and for autoconfiguring
the chunksize.
It includes:
1) processing of the ioctl
2) marshalling and sending the SMB2/SMB3 fsctl over the network
3) simple parsing of the response
It does not include yet (these will be in followon patches to come soon):
1) support for multiple chunks
2) support for autoconfiguring and remembering the chunksize
3) Support for the older style copychunk which Samba 4.1 server supports
(because this requires write permission on the target file, which
cp does not give you, apparently per-posix). This may require
a distinct tool (other than cp) and other ioctl to implement.
Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru>
Fix unused variable warning when CONFIG_CIFS_POSIX disabled.
fs/cifs/ioctl.c: In function 'cifs_ioctl':
>> fs/cifs/ioctl.c:40:8: warning: unused variable 'ExtAttrMask' [-Wunused-variable]
__u64 ExtAttrMask = 0;
Pointed out by 0-DAY kernel build testing backend
Allow cifs/smb2/smb3 to return whether or not a file is compressed
via lsattr, and allow SMB2/SMB3 to set the per-file compression
flag ("chattr +c filename" on an smb3 mount).
Windows users often set the compressed flag (it can be
done from the desktop and file manager). David Disseldorp
has patches to Samba server to support this (at least on btrfs)
which are complementary to this
It's not obvious from reading the macro names that these macros
are for debugging. Convert the names to a single more typical
kernel style cifs_dbg macro.
cERROR(1, ...) -> cifs_dbg(VFS, ...)
cFYI(1, ...) -> cifs_dbg(FYI, ...)
cFYI(DBG2, ...) -> cifs_dbg(NOISY, ...)
Move the terminating format newline from the macro to the call site.
Add CONFIG_CIFS_DEBUG function cifs_vfs_err to emit the
"CIFS VFS: " prefix for VFS messages.
Size is reduced ~ 1% when CONFIG_CIFS_DEBUG is set (default y)
$ size fs/cifs/cifs.ko*
265245 2525 132 267902 4167e fs/cifs/cifs.ko.new
268359 2525 132 271016 422a8 fs/cifs/cifs.ko.old
Other miscellaneous changes around these conversions:
o Miscellaneous typo fixes
o Add terminating \n's to almost all formats and remove them
from the macros to be more kernel style like. A few formats
previously had defective \n's
o Remove unnecessary OOM messages as kmalloc() calls dump_stack
o Coalesce formats to make grep easier,
added missing spaces when coalescing formats
o Use %s, __func__ instead of embedded function name
o Removed unnecessary "cifs: " prefixes
o Convert kzalloc with multiply to kcalloc
o Remove unused cifswarn macro
Signed-off-by: Jeff Layton <jlayton@redhat.com>
...as promised for 3.7.
This is help us to extend the code for future protocols that can use
another fid mechanism (as SMB2 that has it divided into two parts:
persistent and violatile).
Also rename variables and refactor the code around the changes.
Reviewed-by: Jeff Layton <jlayton@samba.org>
Signed-off-by: Pavel Shilovsky <pshilovsky@samba.org>
This was used by an ancient version of umount.cifs and in nowhere else
that I'm aware of. Let's add a warning now and dump it for 3.7.
secMode to sec_mode
and
cifsTconInfo to cifs_tcon
and
cifsSesInfo to cifs_ses
Signed-off-by: Steve French <sfrench@us.ibm.com>
Commit 13cfb7334e made cifs_ioctl use the tlink attached to the
cifsFileInfo for a filp. This ignores the case of an open directory
however, which in CIFS can have a NULL private_data until a readdir
is done on it.
This patch re-adds the NULL pointer checks that were removed in commit
50ae28f01 and moves the setting of tcon and "caps" variables lower.
Long term, a better fix would be to establish a f_op->open routine for
directories that populates that field at open time, but that requires
some other changes to how readdir calls are handled.
Reported-by: Kjell Rune Skaaraas <kjella79@yahoo.no>
Reviewed-and-Tested-by: Suresh Jayaraman <sjayaraman@suse.de>
Stanse found that pSMBFile in cifs_ioctl and file->f_path.dentry in
cifs_user_write are dereferenced prior their test to NULL.
The alternative is not to dereference them before the tests. The patch is
to point out the problem, you have to decide.
While at it we cache the inode in cifs_user_write to a local variable
and use all over the function.
Cc: Steve French <sfrench@samba.org>
Cc: linux-cifs@vger.kernel.org
Cc: Jeff Layton <jlayton@redhat.com>
cifsFileInfo needs a pointer to a tcon, but it doesn't currently hold a
reference to it. Change it to keep a pointer to a tcon_link instead and
hold a reference to it.
That will keep the tcon from being freed until the file is closed.
...where it's available and appropriate.
Neaten cERROR and cFYI macros, reduce text space
~2.5K
Convert '__FILE__ ": " fmt' to '"%s: " fmt', __FILE__' to save text space
Surround macros with do {} while
Add parentheses to macros
Make statement expression macro from macro with assign
Remove now unnecessary parentheses from cFYI and cERROR uses
defconfig with CIFS support old
$ size fs/cifs/built-in.o
156012 1760 148 157920 268e0 fs/cifs/built-in.o
153508 1760 148 155416 25f18 fs/cifs/built-in.o
allyesconfig old:
309138 3864 74824 387826 5eaf2 fs/cifs/built-in.o
allyesconfig new
305655 3864 74824 384343 5dd57 fs/cifs/built-in.o
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Cc: linux-cifs-client@lists.samba.org
Signed-off-by: James Morris <jmorris@namei.org>
cifs_ioctl doesn't seem to need the BKL for anything, so convert it over
to use unlocked_ioctl.
Signed-off-by: Andi Kleen <andi@firstfloor.org>
More than halfway there
Various coding style problems found by running fs/cifs
against the new checkpatch.pl script. Since there
were too many to fit in one patch. Updated the first
four files.
Move common FS-specific ioctls from linux/ext2_fs.h to linux/fs.h as FS_IOC_*
and FS_IOC32_* and have the users of them use those as a base.
Also move the GETFLAGS/SETFLAGS flags to linux/fs.h as FS_*_FL macros, and then
have the other users use them as a base.
Signed-Off-By: David Howells <dhowells@redhat.com>
And fix to not needlessly send new POSIX QFSInfo when server does not
explicitly claim support for the new protocol extensions.
Signed-off-by: Steve French (sfrench@us.ibm.com)
remove sparse warnings, unnecessary pad in QueryFileInfo and redundant
function define.
infrastructure for it.
Let it rip!
