path: root/fs/cifs/link.c
2010-04-21[CIFS] Neaten cERROR and cFYI macros, reduce text spaceJoe Perches
Neaten cERROR and cFYI macros, reduce text space ~2.5K Convert '__FILE__ ": " fmt' to '"%s: " fmt', __FILE__' to save text space Surround macros with do {} while Add parentheses to macros Make statement expression macro from macro with assign Remove now unnecessary parentheses from cFYI and cERROR uses defconfig with CIFS support old $ size fs/cifs/built-in.o text data bss dec hex filename 156012 1760 148 157920 268e0 fs/cifs/built-in.o defconfig with CIFS support old $ size fs/cifs/built-in.o text data bss dec hex filename 153508 1760 148 155416 25f18 fs/cifs/built-in.o allyesconfig old: $ size fs/cifs/built-in.o text data bss dec hex filename 309138 3864 74824 387826 5eaf2 fs/cifs/built-in.o allyesconfig new $ size fs/cifs/built-in.o text data bss dec hex filename 305655 3864 74824 384343 5dd57 fs/cifs/built-in.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-25cifs: Fix incorrect return code being printed in cFYI messagesSuresh Jayaraman
FreeXid() along with freeing Xid does add a cifsFYI debug message that prints rc (return code) as well. In some code paths where we set/return error code after calling FreeXid(), incorrect error code is being printed when cifsFYI is enabled. This could be misleading in few cases. For eg. In cifs_open() if cifs_fill_filedata() returns a valid pointer to cifsFileInfo, FreeXid() prints rc=-13 whereas 0 is actually being returned. Fix this by setting rc before calling FreeXid(). Basically convert FreeXid(xid); rc = -ERR; return -ERR; => FreeXid(xid); return rc; [Note that Christoph would like to replace the GetXid/FreeXid calls, which are primarily used for debugging. This seems like a good longer term goal, but although there is an alternative tracing facility, there are no examples yet available that I know of that we can use (yet) to convert this cifs function entry/exit logging, and for creating an identifier that we can use to correlate all dmesg log entries for a particular vfs operation (ie identify all log entries for a particular vfs request to cifs: e.g. a particular close or read or write or byte range lock call ... and just using the thread id is harder). Eventually when a replacement for this is available (e.g. when NFS switches over and various samples to look at in other file systems) we can remove the GetXid/FreeXid macro but in the meantime multiple people use this run time configurable logging all the time for debugging, and Suresh's patch fixes a problem which made it harder to notice some low memory problems in the log so it is worthwhile to fix this problem until a better logging approach is able to be used] Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-05-19cifs: fix pointer initialization and checks in cifs_follow_symlink (try #4)Jeff Layton
This is the third respin of the patch posted yesterday to fix the error handling in cifs_follow_symlink. It also includes a fix for a bogus NULL pointer check in CIFSSMBQueryUnixSymLink that Jeff Moyer spotted. It's possible for CIFSSMBQueryUnixSymLink to return without setting target_path to a valid pointer. If that happens then the current value to which we're initializing this pointer could cause an oops when it's kfree'd. This patch is a little more comprehensive than the last patches. It reorganizes cifs_follow_link a bit for (hopefully) better readability. It should also eliminate the uneeded allocation of full_path on servers without unix extensions (assuming they can get to this point anyway, of which I'm not convinced). On a side note, I'm not sure I agree with the logic of enabling this query even when unix extensions are disabled on the client. It seems like that should disable this as well. But, changing that is outside the scope of this fix, so I've left it alone for now. Reported-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Reviewed-by: Christoph Hellwig <hch@inraded.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-05-01[CIFS] Remove sparse endian warningsSteve French
Removes two sparse CHECK_ENDIAN warnings from Jeffs earlier patch, and removes the dead readlink code (after noting where in findfirst we will need to add something like that in the future to handle the newly discovered unexpected error on FindFirst of NTFS symlinks. Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-04-30[CIFS] Remove unneeded QuerySymlink call and fix mapping for unmapped statusSteve French
2009-04-30cifs: change CIFSSMBUnixQuerySymLink to use new helpersJeff Layton
Change CIFSSMBUnixQuerySymLink to use the new unicode helper functions. Also change the calling conventions so that the allocation of the target name buffer is done in CIFSSMBUnixQuerySymLink rather than by the caller. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-15[CIFS] Finishup DFS codeSteve French
Fixup GetDFSRefer to prepare for cleanup of SMB response processing Fix build warning in link.c Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-15[CIFS] Fix paths when share is in DFS to include proper prefixSteve French
Some versions of Samba (3.2-pre e.g.) are stricter about checking to make sure that paths in DFS name spaces are sent in the form \\server\share\dir\subdir ... instead of \dir\subdir Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-04-29[CIFS] convert usage of implicit booleans to boolSteve French
2008-03-14[CIFS] file create with acl support enabled is slowSteve French
Shirish Pargaonkar noted: With cifsacl mount option, when a file is created on the Windows server, exclusive oplock is broken right away because the get cifs acl code again opens the file to obtain security descriptor. The client does not have the newly created file handle or inode in any of its lists yet so it does not respond to oplock break and server waits for its duration and then responds to the second open. This slows down file creation signficantly. The fix is to pass the file descriptor to the get cifsacl code wherever available so that get cifs acl code does not send second open (NT Create ANDX) and oplock is not broken. CC: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-01-25[CIFS] DFS build fixesSteve French
Also includes a few minor changes suggested by Christoph Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-08-31[CIFS] Fix warnings shown by newer version of sparseSteve French
2007-07-18[CIFS] Allow disabling CIFS Unix Extensions as mount optionSteve French
Previously the only way to do this was to umount all mounts to that server, turn off a proc setting (/proc/fs/cifs/LinuxExtensionsEnabled). Fixes Samba bugzilla bug number: 4582 (and also 2008) Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-07-17[CIFS] More whitespace/formatting fixes (noticed by checkpatch)Steve French
2007-07-13[CIFS] whitespace/formatting fixesSteve French
This should be the last big batch of whitespace/formatting fixes. checkpatch warnings for the cifs directory are down about 90% and many of the remaining ones are harder to remove or make the code harder to read. Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-07-10[CIFS] whitespace cleanupSteve French
More than halfway there Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-02-17[CIFS] mtime bounces from local to remote when cifs nocmtime i_flags overwrittenSteve French
atime flag was also overwritten. Noticed by Shirish when he was debugging an atime problem. Should help performance a bit too. cifs should be getting time stamps from the server (that was the original intent too) Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-11-16[CIFS] Incorrect hardlink count when original file is cached (oplocked)Steve French
Fixes Samba bug 2823 In this case hardlink count is stale for one of the two inodes (ie the original file) until it is closed - since revalidate does not go to server while file is cached locally. Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-09-28[CIFS] Legacy time handling for Win9x and OS/2 part 1Steve French
2006-05-31[CIFS] Cleanup extra whitespace in dmesg logging. Update cifs change logSteve French
2006-04-21[CIFS] [CIFS] Do not take rename sem on most path based calls (duringSteve French
building of full path) to avoid hang rename/readdir hang Reported by Alan Tyson Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-03-31Merge with /pub/scm/linux/kernel/git/torvalds/linux-2.6.gitSteve French
2006-03-23[PATCH] sem2mutex: vfs_rename_mutexArjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-03[CIFS] Workaround various server bugs found in testing at connectathonSteve French
- slow down negprot 1ms during mount when RFC1001 over port 139 to give buggy servers time to clear sess_init - remap some plausible but incorrect SMB return codes to the right ones in truncate and hardlink paths Signed-off-by: Steve French <sfrench@us.ibm.com>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-30[CIFS] Remove cifs_sb argument from *build_path_from_dentrySteve French
This argument was added in a recent patch, but is unnecessary, since the superblock is easily obtained from the dentry. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2005-08-22[CIFS] Finish up of case-insensitive dentry handling for cifs. ThisSteve French
will eventually (or should eventually) be common code for jfs, smbfs, etc. but in the meantime is small enough and necessary when mounting case insensitive to Windows (nocase). Signed-off-by: Shaggy (shaggy@austin.ibm.com) Signed-off-by: Steve French (sfrench@us.ibm.com)
2005-08-20Merge with /pub/scm/linux/kernel/git/torvalds/linux-2.6.gitSteve French
2005-08-19Fix nasty ncpfs symlink handling bug.Linus Torvalds
This bug could cause oopses and page state corruption, because ncpfs used the generic page-cache symlink handlign functions. But those functions only work if the page cache is guaranteed to be "stable", ie a page that was installed when the symlink walk was started has to still be installed in the page cache at the end of the walk. We could have fixed ncpfs to not use the generic helper routines, but it is in many ways much cleaner to instead improve on the symlink walking helper routines so that they don't require that absolute stability. We do this by allowing "follow_link()" to return a error-pointer as a cookie, which is fed back to the cleanup "put_link()" routine. This also simplifies NFS symlink handling. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22[CIFS] POSIX extensions, SetFSInfo addedJeremy Allison
Signed-off-by: Steve French@sfrench@us.ibm.com Signed-off-by: Jeremy Allison (jra@samba.org)
2005-04-28[PATCH] cifs: character mapping of special characters (part 3 of 3)Steve French
Signed-off-by: Steve French (sfrench@us.ibm.com) Signed-off-by: Linus Torvalds <torvalds@osdl.org>
