path: root/fs/cifs/link.c
2011-11-02filesystems: add missing nlink wrappersMiklos Szeredi
Replace direct i_nlink updates with the respective updater function (inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-10-12cifs: Add mount options for backup intent (try #6)Shirish Pargaonkar
Add mount options backupuid and backugid. It allows an authenticated user to access files with the intent to back them up including their ACLs, who may not have access permission but has "Backup files and directories user right" on them (by virtue of being part of the built-in group Backup Operators. When mount options backupuid is specified, cifs client restricts the use of backup intents to the user whose effective user id is specified along with the mount option. When mount options backupgid is specified, cifs client restricts the use of backup intents to the users whose effective user id belongs to the group id specified along with the mount option. If an authenticated user is not part of the built-in group Backup Operators at the server, access to such files is denied, even if allowed by the client. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2011-07-25cifs: Cleanup: check return codes of crypto api callsShirish Pargaonkar
Check return codes of crypto api calls and either log an error or log an error and return from the calling function with error. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-05-27[CIFS] Rename three structures to avoid camel caseSteve French
secMode to sec_mode and cifsTconInfo to cifs_tcon and cifsSesInfo to cifs_ses Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-05-27CIFS: Add rwpidforward mount optionPavel Shilovsky
Add rwpidforward mount option that switches on a mode when we forward pid of a process who opened a file to any read and write operation. This can prevent applications like WINE from failing on read or write operation on a previously locked file region from the same netfd from another process if we use mandatory brlock style. It is actual for WINE because during a run of WINE program two processes work on the same netfd - share the same file struct between several VFS fds: 1) WINE-server does open and lock; 2) WINE-application does read and write. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-05-26CIFS: Use pid saved from cifsFileInfo in writepages and set_file_sizePavel Shilovsky
We need it to make them work with mandatory locking style because we can fail in a situation like when kernel need to flush dirty pages and there is a lock held by a process who opened file. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-12various endian fixes to cifsSteve French
make modules C=2 M=fs/cifs CF=-D__CHECK_ENDIAN__ Found for example: CHECK fs/cifs/cifssmb.c fs/cifs/cifssmb.c:728:22: warning: incorrect type in assignment (different base types) fs/cifs/cifssmb.c:728:22: expected unsigned short [unsigned] [usertype] Tid fs/cifs/cifssmb.c:728:22: got restricted __le16 [usertype] <noident> fs/cifs/cifssmb.c:1883:45: warning: incorrect type in assignment (different base types) fs/cifs/cifssmb.c:1883:45: expected long long [signed] [usertype] fl_start fs/cifs/cifssmb.c:1883:45: got restricted __le64 [usertype] start fs/cifs/cifssmb.c:1884:54: warning: restricted __le64 degrades to integer fs/cifs/cifssmb.c:1885:58: warning: restricted __le64 degrades to integer fs/cifs/cifssmb.c:1886:43: warning: incorrect type in assignment (different base types) fs/cifs/cifssmb.c:1886:43: expected unsigned int [unsigned] fl_pid fs/cifs/cifssmb.c:1886:43: got restricted __le32 [usertype] pid In checking new smb2 code for missing endian conversions, I noticed some endian errors had crept in over the last few releases into the cifs code (symlink, ntlmssp, posix lock, and also a less problematic warning in fscache). A followon patch will address a few smb2 endian problems. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-31cifs: fix two compiler warning about uninitialized varsJeff Layton
fs/cifs/link.c: In function ‘symlink_hash’: fs/cifs/link.c:58:3: warning: ‘rc’ may be used uninitialized in this function [-Wuninitialized] fs/cifs/smbencrypt.c: In function ‘mdfour’: fs/cifs/smbencrypt.c:61:3: warning: ‘rc’ may be used uninitialized in this function [-Wuninitialized] Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-27cifs: More crypto cleanup (try #2)Shirish Pargaonkar
Replaced md4 hashing function local to cifs module with kernel crypto APIs. As a result, md4 hashing function and its supporting functions in file md4.c are not needed anymore. Cleaned up function declarations, removed forward function declarations, and removed a header file that is being deleted from being included. Verified that sec=ntlm/i, sec=ntlmv2/i, and sec=ntlmssp/i work correctly. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-25[CIFS] Replace cifs md5 hashing functions with kernel crypto APIsSteve French
Replace remaining use of md5 hash functions local to cifs module with kernel crypto APIs. Remove header and source file containing those local functions. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-12switch cifsAl Viro
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-06cifs: have cifsFileInfo hold a reference to a tlink rather than tcon pointerJeff Layton
cifsFileInfo needs a pointer to a tcon, but it doesn't currently hold a reference to it. Change it to keep a pointer to a tcon_link instead and hold a reference to it. That will keep the tcon from being freed until the file is closed. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-06cifs: add refcounted and timestamped container for holding tconsJeff Layton
Eventually, we'll need to track the use of tcons on a per-sb basis, so that we know when it's ok to tear them down. Begin this conversion by adding a new "tcon_link" struct and accessors that get it. For now, the core data structures are untouched -- cifs_sb still just points to a single tcon and the pointers are just cast to deal with the accessor functions. A later patch will flesh this out. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs: add function to get a tcon from cifs_sbJeff Layton
When we convert cifs to do multiple sessions per mount, we'll need more than one tcon per superblock. At that point "cifs_sb->tcon" will make no sense. Add a new accessor function that gets a tcon given a cifs_sb. For now, it just returns cifs_sb->tcon. Later it'll do more. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs: use Minshall+French symlink functionsStefan Metzmacher
If configured, Minshall+French Symlinks are used against all servers. If the server supports UNIX Extensions, we still create Minshall+French Symlinks on write, but on read we fallback to UNIX Extension symlinks. Signed-off-by: Stefan Metzmacher <metze@samba.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs: implement CIFSCreateMFSymLink()Stefan Metzmacher
2010-09-29cifs: implement CIFSFormatMFSymlink()Stefan Metzmacher
2010-09-29cifs: implement CIFSQueryMFSymLink()Stefan Metzmacher
2010-09-29cifs: implement CIFSCouldBeMFSymlink() and CIFSCheckMFSymlink()Stefan Metzmacher
2010-09-29cifs: implement CIFSParseMFSymlink()Stefan Metzmacher
2010-04-21[CIFS] Neaten cERROR and cFYI macros, reduce text spaceJoe Perches
Neaten cERROR and cFYI macros, reduce text space ~2.5K Convert '__FILE__ ": " fmt' to '"%s: " fmt', __FILE__' to save text space Surround macros with do {} while Add parentheses to macros Make statement expression macro from macro with assign Remove now unnecessary parentheses from cFYI and cERROR uses defconfig with CIFS support old $ size fs/cifs/built-in.o text data bss dec hex filename 156012 1760 148 157920 268e0 fs/cifs/built-in.o defconfig with CIFS support old $ size fs/cifs/built-in.o text data bss dec hex filename 153508 1760 148 155416 25f18 fs/cifs/built-in.o allyesconfig old: $ size fs/cifs/built-in.o text data bss dec hex filename 309138 3864 74824 387826 5eaf2 fs/cifs/built-in.o allyesconfig new $ size fs/cifs/built-in.o text data bss dec hex filename 305655 3864 74824 384343 5dd57 fs/cifs/built-in.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-25cifs: Fix incorrect return code being printed in cFYI messagesSuresh Jayaraman
FreeXid() along with freeing Xid does add a cifsFYI debug message that prints rc (return code) as well. In some code paths where we set/return error code after calling FreeXid(), incorrect error code is being printed when cifsFYI is enabled. This could be misleading in few cases. For eg. In cifs_open() if cifs_fill_filedata() returns a valid pointer to cifsFileInfo, FreeXid() prints rc=-13 whereas 0 is actually being returned. Fix this by setting rc before calling FreeXid(). Basically convert FreeXid(xid); rc = -ERR; return -ERR; => FreeXid(xid); return rc; [Note that Christoph would like to replace the GetXid/FreeXid calls, which are primarily used for debugging. This seems like a good longer term goal, but although there is an alternative tracing facility, there are no examples yet available that I know of that we can use (yet) to convert this cifs function entry/exit logging, and for creating an identifier that we can use to correlate all dmesg log entries for a particular vfs operation (ie identify all log entries for a particular vfs request to cifs: e.g. a particular close or read or write or byte range lock call ... and just using the thread id is harder). Eventually when a replacement for this is available (e.g. when NFS switches over and various samples to look at in other file systems) we can remove the GetXid/FreeXid macro but in the meantime multiple people use this run time configurable logging all the time for debugging, and Suresh's patch fixes a problem which made it harder to notice some low memory problems in the log so it is worthwhile to fix this problem until a better logging approach is able to be used] Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-05-19cifs: fix pointer initialization and checks in cifs_follow_symlink (try #4)Jeff Layton
This is the third respin of the patch posted yesterday to fix the error handling in cifs_follow_symlink. It also includes a fix for a bogus NULL pointer check in CIFSSMBQueryUnixSymLink that Jeff Moyer spotted. It's possible for CIFSSMBQueryUnixSymLink to return without setting target_path to a valid pointer. If that happens then the current value to which we're initializing this pointer could cause an oops when it's kfree'd. This patch is a little more comprehensive than the last patches. It reorganizes cifs_follow_link a bit for (hopefully) better readability. It should also eliminate the uneeded allocation of full_path on servers without unix extensions (assuming they can get to this point anyway, of which I'm not convinced). On a side note, I'm not sure I agree with the logic of enabling this query even when unix extensions are disabled on the client. It seems like that should disable this as well. But, changing that is outside the scope of this fix, so I've left it alone for now. Reported-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Reviewed-by: Christoph Hellwig <hch@inraded.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-05-01[CIFS] Remove sparse endian warningsSteve French
Removes two sparse CHECK_ENDIAN warnings from Jeffs earlier patch, and removes the dead readlink code (after noting where in findfirst we will need to add something like that in the future to handle the newly discovered unexpected error on FindFirst of NTFS symlinks. Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-04-30[CIFS] Remove unneeded QuerySymlink call and fix mapping for unmapped statusSteve French
2009-04-30cifs: change CIFSSMBUnixQuerySymLink to use new helpersJeff Layton
Change CIFSSMBUnixQuerySymLink to use the new unicode helper functions. Also change the calling conventions so that the allocation of the target name buffer is done in CIFSSMBUnixQuerySymLink rather than by the caller. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-15[CIFS] Finishup DFS codeSteve French
Fixup GetDFSRefer to prepare for cleanup of SMB response processing Fix build warning in link.c Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-15[CIFS] Fix paths when share is in DFS to include proper prefixSteve French
Some versions of Samba (3.2-pre e.g.) are stricter about checking to make sure that paths in DFS name spaces are sent in the form \\server\share\dir\subdir ... instead of \dir\subdir Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-04-29[CIFS] convert usage of implicit booleans to boolSteve French
2008-03-14[CIFS] file create with acl support enabled is slowSteve French
Shirish Pargaonkar noted: With cifsacl mount option, when a file is created on the Windows server, exclusive oplock is broken right away because the get cifs acl code again opens the file to obtain security descriptor. The client does not have the newly created file handle or inode in any of its lists yet so it does not respond to oplock break and server waits for its duration and then responds to the second open. This slows down file creation signficantly. The fix is to pass the file descriptor to the get cifsacl code wherever available so that get cifs acl code does not send second open (NT Create ANDX) and oplock is not broken. CC: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-01-25[CIFS] DFS build fixesSteve French
Also includes a few minor changes suggested by Christoph Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-08-31[CIFS] Fix warnings shown by newer version of sparseSteve French
2007-07-18[CIFS] Allow disabling CIFS Unix Extensions as mount optionSteve French
Previously the only way to do this was to umount all mounts to that server, turn off a proc setting (/proc/fs/cifs/LinuxExtensionsEnabled). Fixes Samba bugzilla bug number: 4582 (and also 2008) Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-07-17[CIFS] More whitespace/formatting fixes (noticed by checkpatch)Steve French
2007-07-13[CIFS] whitespace/formatting fixesSteve French
This should be the last big batch of whitespace/formatting fixes. checkpatch warnings for the cifs directory are down about 90% and many of the remaining ones are harder to remove or make the code harder to read. Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-07-10[CIFS] whitespace cleanupSteve French
More than halfway there Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-02-17[CIFS] mtime bounces from local to remote when cifs nocmtime i_flags overwrittenSteve French
atime flag was also overwritten. Noticed by Shirish when he was debugging an atime problem. Should help performance a bit too. cifs should be getting time stamps from the server (that was the original intent too) Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-11-16[CIFS] Incorrect hardlink count when original file is cached (oplocked)Steve French
Fixes Samba bug 2823 In this case hardlink count is stale for one of the two inodes (ie the original file) until it is closed - since revalidate does not go to server while file is cached locally. Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-09-28[CIFS] Legacy time handling for Win9x and OS/2 part 1Steve French
2006-05-31[CIFS] Cleanup extra whitespace in dmesg logging. Update cifs change logSteve French
2006-04-21[CIFS] [CIFS] Do not take rename sem on most path based calls (duringSteve French
building of full path) to avoid hang rename/readdir hang Reported by Alan Tyson Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-03-31Merge with /pub/scm/linux/kernel/git/torvalds/linux-2.6.gitSteve French
2006-03-23[PATCH] sem2mutex: vfs_rename_mutexArjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-03[CIFS] Workaround various server bugs found in testing at connectathonSteve French
- slow down negprot 1ms during mount when RFC1001 over port 139 to give buggy servers time to clear sess_init - remap some plausible but incorrect SMB return codes to the right ones in truncate and hardlink paths Signed-off-by: Steve French <sfrench@us.ibm.com>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-30[CIFS] Remove cifs_sb argument from *build_path_from_dentrySteve French
This argument was added in a recent patch, but is unnecessary, since the superblock is easily obtained from the dentry. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2005-08-22[CIFS] Finish up of case-insensitive dentry handling for cifs. ThisSteve French
will eventually (or should eventually) be common code for jfs, smbfs, etc. but in the meantime is small enough and necessary when mounting case insensitive to Windows (nocase). Signed-off-by: Shaggy (shaggy@austin.ibm.com) Signed-off-by: Steve French (sfrench@us.ibm.com)
2005-08-20Merge with /pub/scm/linux/kernel/git/torvalds/linux-2.6.gitSteve French
