commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream.
move d_rcu from overlapping d_child to overlapping d_alias
Cc: Ben Hutchings <ben@decadent.org.uk>
[hujianyang: Backported to 3.14 refer to the work of Ben Hutchings in 3.2:
- Apply name changes in all the different places we use d_alias and d_child
- Move the WARN_ON() in __d_free() to d_free() as we don't have dentry_free()]
Signed-off-by: hujianyang <hujianyang@huawei.com>
commit e1e9bda22d7ddf88515e8fe401887e313922823e upstream.
Under intermittent network outages, find_writable_file() is susceptible
to the following race condition, which results in a user-after-free in
the cifs_writepages code-path:
Thread 1 Thread 2
inv_file = NULL
refind = 0
spin_lock(&cifs_file_list_lock)
// invalidHandle found on openFileList
inv_file = open_file
// inv_file->count currently 1
cifsFileInfo_get(inv_file)
// inv_file->count = 2
spin_unlock(&cifs_file_list_lock);
cifs_reopen_file() cifs_close()
// fails (rc != 0) ->cifsFileInfo_put()
// inv_file->count = 1
spin_lock(&cifs_file_list_lock);
list_move_tail(&inv_file->flist,
&cifs_inode->openFileList);
cifsFileInfo_put(inv_file);
->spin_lock(&cifs_file_list_lock)
// inv_file->count = 0
list_del(&cifs_file->flist);
// cleanup!!
kfree(cifs_file);
++refind;
// refind = 1
goto refind_writable;
At this point we loop back through with an invalid inv_file pointer
and a refind value of 1. On second pass, inv_file is not overwritten on
openFileList traversal, and is subsequently dereferenced.
Signed-off-by: David Disseldorp <ddiss@suse.de>
Reviewed-by: Jeff Layton <jlayton@samba.org>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 2477bc58d49edb1c0baf59df7dc093dce682af2b upstream.
While attempting to clone a file on a samba server, we receive a
STATUS_INVALID_DEVICE_REQUEST. This is mapped to -EOPNOTSUPP which
isn't handled in smb2_clone_range(). We end up looping in the while loop
making same call to the samba server over and over again.
The proposed fix is to exit and return the error value when encountered
with an unhandled error.
Signed-off-by: Sachin Prabhu <sprabhu@redhat.com>
Signed-off-by: Steve French <steve.french@primarydata.com>
commit ca7df8e0bb2a5ec79691de8a1a4c0e611fe04e60 upstream.
Commit
c11f1df5003d534fd067f0168bfad7befffb3b5c
requires writers to wait for any pending oplock break handler to
complete before proceeding to write. This is done by waiting on bit
CIFS_INODE_PENDING_OPLOCK_BREAK in cifsFileInfo->flags. This bit is
cleared by the oplock break handler job queued on the workqueue once it
has completed handling the oplock break allowing writers to proceed with
writing to the file.
While testing, it was noticed that the filehandle could be closed while
there is a pending oplock break which results in the oplock break
handler on the cifsiod workqueue being cancelled before it has had a
chance to execute and clear the CIFS_INODE_PENDING_OPLOCK_BREAK bit.
Any subsequent attempt to write to this file hangs waiting for the
CIFS_INODE_PENDING_OPLOCK_BREAK bit to be cleared.
We fix this by ensuring that we also clear the bit
CIFS_INODE_PENDING_OPLOCK_BREAK when we remove the oplock break handler
from the workqueue.
The bug was found by Red Hat QA while testing using ltp's fsstress
command.
Acked-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Signed-off-by: Jeff Layton <jlayton@samba.org>
commit 378ff1a53b5724f3ac97b0aba3c9ecac072f6fcd upstream.
It really needs to check that src is non-directory *and* use
{un,}lock_two_nodirectories(). As it is, it's trivial to cause
double-lock (ioctl(fd, CIFS_IOC_COPYCHUNK_FILE, fd)) and if the
last argument is an fd of directory, we are asking for trouble
by violating the locking order - all directories go before all
non-directories. If the last argument is an fd of parent
directory, it has 50% odds of locking child before parent,
which will cause AB-BA deadlock if we race with unlink().
commit 52755808d4525f4d5b86d112d36ffc7a46f3fb48 upstream.
SMB2 servers indicates the end of a directory search with
STATUS_NO_MORE_FILE error code that is not processed now.
This causes generic/257 xfstest to fail. Fix this by triggering
the end of search by this error code in SMB2_query_directory.
Also when negotiating CIFS protocol we tell the server to close
the search automatically at the end and there is no need to do
it itself. In the case of SMB2 protocol, we need to close it
explicitly - separate close directory checks for different
protocols.
Signed-off-by: Pavel Shilovsky <pshilovsky@samba.org>
commit 19e81573fca7b87ced7701e01ba164b968d929bd upstream.
Changeset eb85d94bd introduced a problem where if a cifs open
fails during query info of a file we
will still try to close the file (happens with certain types
of reparse points) even though the file handle is not valid.
In addition for SMB2/SMB3 we were not mapping the return code returned
by Windows when trying to open a file (like a Windows NFS symlink)
which is a reparse point.
Reviewed-by: Pavel Shilovsky <pshilovsky@samba.org>
commit da80659d4aa758dc6935b10ec64513f0b67bc969 upstream.
We were not checking for symlink support properly for SMB2/SMB3
mounts so could oops when mounted with mfsymlinks when try
to create symlink when mfsymlinks on smb2/smb3 mounts
CC: Sachin Prabhu <sprabhu@redhat.com>
commit f736906a7669a77cf8cabdcbcf1dc8cb694e12ef upstream.
The existing code calls server->ops->close() that is not
right. This causes XFS test generic/310 to fail. Fix this
by using server->ops->closedir() function.
commit 1bbe4997b13de903c421c1cc78440e544b5f9064 upstream.
The existing code uses the old MAX_NAME constant. This causes
XFS test generic/013 to fail. Fix it by replacing MAX_NAME with
PATH_MAX that SMB1 uses. Also remove an unused MAX_NAME constant
definition.
commit a07d322059db66b84c9eb4f98959df468e88b34b upstream.
CIFS servers process nlink counts differently for files and directories.
In cifs_rename() if we the request fails on the existing target, we
try to remove it through cifs_unlink() but this is not what we want
to do for directories. As the result the following sequence of commands
mkdir {1,2}; mv -T 1 2; rmdir {1,2}; mkdir {1,2}; echo foo > 2/bar
and XFS test generic/023 fail with -ENOENT error. That's why the second
mkdir reuses the existing inode (target inode of the mv -T command) with
S_DEAD flag.
Fix this by checking whether the target is directory or not and
calling cifs_rmdir() rather than cifs_unlink() for directories.
commit b46799a8f28c43c5264ac8d8ffa28b311b557e03 upstream.
When we requests rename we also need to update attributes
of both source and target parent directories. Not doing it
causes generic/309 xfstest to fail on SMB2 mounts. Fix this
by marking these directories for force revalidating.
commit 18f39e7be0121317550d03e267e3ebd4dbfbb3ce upstream.
As Raphael Geissert pointed out, tcon_error_exit can dereference tcon
and there is one path in which tcon can be null.
Reported-by: Raphael Geissert <geissert@debian.org>
commit 038bc961c31b070269ecd07349a7ee2e839d4fec upstream.
If we get into read_into_pages() from cifs_readv_receive() and then
loose a network, we issue cifs_reconnect that moves all mids to
a private list and issue their callbacks. The callback of the async
read request sets a mid to retry, frees it and wakes up a process
that waits on the rdata completion.
After the connection is established we return from read_into_pages()
with a short read, use the mid that was freed before and try to read
the remaining data from the a newly created socket. Both actions are
not what we want to do. In reconnect cases (-EAGAIN) we should not
mask off the error with a short read but should return the error
code instead.
Acked-by: Jeff Layton <jlayton@samba.org>
commit 21496687a79424572f46a84c690d331055f4866f upstream.
The existing mapping causes unlink() call to return error after delete
operation. Changing the mapping to -EACCES makes the client process
the call like CIFS protocol does - reset dos attributes with ATTR_READONLY
flag masked off and retry the operation.
option
commit ce36d9ab3bab06b7b5522f5c8b68fac231b76ffb upstream.
When we SMB3 mounted with mapchars (to allow reserved characters : \ / > < * ?
via the Unicode Windows to POSIX remap range) empty paths
(eg when we open "" to query the root of the SMB3 directory on mount) were not
null terminated so we sent garbarge as a path name on empty paths which caused
SMB2/SMB2.1/SMB3 mounts to fail when mapchars was specified. mapchars is
particularly important since Unix Extensions for SMB3 are not supported (yet)
Reviewed-by: David Disseldorp <ddiss@suse.de>
commit a1d0b84c308d7fdfb67eb76498116a6c2fdda507 upstream.
commit d81b8a40e2ece0a9ab57b1fe1798e291e75bf8fc
("CIFS: Cleanup cifs open codepath")
changed disposition to FILE_OPEN.
Signed-off-by: Björn Baumbach <bb@sernet.de>
Signed-off-by: Stefan Metzmacher <metze@samba.org>
Reviewed-by: Stefan Metzmacher <metze@samba.org>
Cc: Pavel Shilovsky <piastry@etersoft.ru>
Cc: Steve French <sfrench@samba.org>
commit 663a962151593c69374776e8651238d0da072459 upstream.
Reviewed-by: Shirish Pargaonkar <spargaonkar@suse.com>
commit c11f1df5003d534fd067f0168bfad7befffb3b5c upstream.
Problem reported in Red Hat bz 1040329 for strict writes where we cache
only when we hold oplock and write direct to the server when we don't.
When we receive an oplock break, we first change the oplock value for
the inode in cifsInodeInfo->oplock to indicate that we no longer hold
the oplock before we enqueue a task to flush changes to the backing
device. Once we have completed flushing the changes, we return the
oplock to the server.
There are 2 ways here where we can have data corruption
1) While we flush changes to the backing device as part of the oplock
break, we can have processes write to the file. These writes check for
the oplock, find none and attempt to write directly to the server.
These direct writes made while we are flushing from cache could be
overwritten by data being flushed from the cache causing data
corruption.
2) While a thread runs in cifs_strict_writev, the machine could receive
and process an oplock break after the thread has checked the oplock and
found that it allows us to cache and before we have made changes to the
cache. In that case, we end up with a dirty page in cache when we
shouldn't have any. This will be flushed later and will overwrite all
subsequent writes to the part of the file represented by this page.
Before making any writes to the server, we need to confirm that we are
not in the process of flushing data to the server and if we are, we
should wait until the process is complete before we attempt the write.
We should also wait for existing writes to complete before we process
an oplock break request which changes oplock values.
We add a version specific downgrade_oplock() operation to allow for
differences in the oplock values set for the different smb versions.
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru>
The rfc1002 length actually includes a type byte, which we aren't
masking off. In most cases, it's not a problem since the
RFC1002_SESSION_MESSAGE type is 0, but when doing a RFC1002 session
establishment, the type is non-zero and that throws off the returned
length.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Tested-by: Sachin Prabhu <sprabhu@redhat.com>
We had a bug discovered recently where an upper layer function
(cifs_iovec_write) could pass down a smb_rqst with an invalid amount of
data in it. The length of the SMB frame would be correct, but the rqst
struct would cause smb_send_rqst to send nearly 4GB of data.
This should never be the case. Add some sanity checking to the beginning
of smb_send_rqst that ensures that the amount of data we're going to
send agrees with the length in the RFC1002 header. If it doesn't, WARN()
and return -EIO to the upper layers.
Acked-by: Sachin Prabhu <sprabhu@redhat.com>
and use generic_file_aio_write rather than __generic_file_aio_write
in cifs_writev.
Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru>
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Pull CIFS fixes from Steve French:
"Three cifs fixes, the most important fixing the problem with passing
bogus pointers with writev (CVE-2014-0069).
Two additional cifs fixes are still in review (including the fix for
an append problem which Al also discovered)"
* 'for-linus' of git://git.samba.org/sfrench/cifs-2.6:
CIFS: Fix too big maxBuf size for SMB3 mounts
cifs: ensure that uncached writes handle unmapped areas correctly
[CIFS] Fix cifsacl mounts over smb2 to not call cifs
SMB3 servers can respond with MaxTransactSize of more than 4M
that can cause a memory allocation error returned from kmalloc
in a lock codepath. Also the client doesn't support multicredit
requests now and allows buffer sizes of 65536 bytes only. Set
MaxTransactSize to this maximum supported value.
Cc: stable@vger.kernel.org # 3.7+
Acked-by: Jeff Layton <jlayton@redhat.com>
It's possible for userland to pass down an iovec via writev() that has a
bogus user pointer in it. If that happens and we're doing an uncached
write, then we can end up getting less bytes than we expect from the
call to iov_iter_copy_from_user. This is CVE-2014-0069
cifs_iovec_write isn't set up to handle that situation however. It'll
blindly keep chugging through the page array and not filling those pages
with anything useful. Worse yet, we'll later end up with a negative
number in wdata->tailsz, which will confuse the sending routines and
cause an oops at the very least.
Fix this by having the copy phase of cifs_iovec_write stop copying data
in this situation and send the last write as a short one. At the same
time, we want to avoid sending a zero-length write to the server, so
break out of the loop and set rc to -EFAULT if that happens. This also
allows us to handle the case where no address in the iovec is valid.
[Note: Marking this for stable on v3.4+ kernels, but kernels as old as
v2.6.38 may have a similar problem and may need similar fix]
Cc: <stable@vger.kernel.org> # v3.4+
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
When mounting with smb2/smb3 (e.g. vers=2.1) and cifsacl mount option,
it was trying to get the mode by querying the acl over the cifs
rather than smb2 protocol. This patch makes that protocol
independent and makes cifsacl smb2 mounts return a more intuitive
operation not supported error (until we add a worker function
for smb2_get_acl).
Note that a previous patch fixed getxattr/setxattr for the CIFSACL xattr
which would unconditionally call cifs_get_acl and cifs_set_acl (even when
mounted smb2). I made those protocol independent last week (new protocol
version operations "get_acl" and "set_acl" but did not add an
smb2_get_acl and smb2_set_acl yet so those now simply return EOPNOTSUPP
which at least is better than sending cifs requests on smb2 mount)
The previous patches did not fix the one remaining case though ie
mounting with "cifsacl" when getting mode from acl would unconditionally
end up calling "cifs_get_acl_from_fid" even for smb2 - so made that protocol
independent but to make that protocol independent had to make sure that the callers
were passing the protocol independent handle structure (cifs_fid) instead
of cifs specific _u16 network file handle (ie cifs_fid instead of cifs_fid->fid)
Now mount with smb2 and cifsacl mount options will return EOPNOTSUP (instead
of timing out) and a future patch will add smb2 operations (e.g. get_smb2_acl)
to enable this.
"Small fix from Jeff for writepages leak, and some fixes for ACLs and
xattrs when SMB2 enabled.
Am expecting another fix from Jeff and at least one more fix (for
mounting SMB2 with cifsacl) in the next week"
* 'for-next' of git://git.samba.org/sfrench/cifs-2.6:
[CIFS] clean up page array when uncached write send fails
cifs: use a flexarray in cifs_writedata
retrieving CIFS ACLs when mounted with SMB2 fails dropping session
Add protocol specific operation for CIFS xattrs
It actually goes back to 2004 ([PATCH] Concurrent O_SYNC write support)
when sync_page_range() had been introduced; generic_file_write{,v}() correctly
synced
pos_after_write - written .. pos_after_write - 1
but generic_file_aio_write() synced
pos_before_write .. pos_before_write + written - 1
instead. Which is not the same thing with O_APPEND, obviously.
A couple of years later correct variant had been killed off when
everything switched to use of generic_file_aio_write().
All users of generic_file_aio_write() are affected, and the same bug
has been copied into other instances of ->aio_write().
The fix is trivial; the only subtle point is that generic_write_sync()
ought to be inlined to avoid calculations useless for the majority of
calls.
In the event that a send fails in an uncached write, or we end up
needing to reissue it (-EAGAIN case), we'll kfree the wdata but
the pages currently leak.
Fix this by adding a new kref release routine for uncached writedata
that releases the pages, and have the uncached codepaths use that.
[original patch by Jeff modified to fix minor formatting problems]
The cifs_writedata code uses a single element trailing array, which
just adds unneeded complexity. Use a flexarray instead.
The get/set ACL xattr support for CIFS ACLs attempts to send old
cifs dialect protocol requests even when mounted with SMB2 or later
dialects. Sending cifs requests on an smb2 session causes problems -
the server drops the session due to the illegal request.
This patch makes CIFS ACL operations protocol specific to fix that.
Attempting to query/set CIFS ACLs for SMB2 will now return
EOPNOTSUPP (until we add worker routines for sending query
ACL requests via SMB2) instead of sending invalid (cifs)
requests.
A separate followon patch will be needed to fix cifs_acl_to_fattr
(which takes a cifs specific u16 fid so can't be abstracted
to work with SMB2 until that is changed) and will be needed
to fix mount problems when "cifsacl" is specified on mount
with e.g. vers=2.1
CC: Stable <stable@kernel.org>
Changeset 666753c3ef8fc88b0ddd5be4865d0aa66428ac35 added protocol
operations for get/setxattr to avoid calling cifs operations
on smb2/smb3 mounts for xattr operations and this changeset
adds the calls to cifs specific protocol operations for xattrs
(in order to reenable cifs support for xattrs which was
temporarily disabled by the previous changeset. We do not
have SMB2/SMB3 worker function for setting xattrs yet so
this only enables it for cifs.
CCing stable since without these two small changsets (its
small coreq 666753c3ef8fc88b0ddd5be4865d0aa66428ac35 is
also needed) calling getfattr/setfattr on smb2/smb3 mounts
causes problems.
MF Symlinks are regular files containing content in a specified format.
The function couldbe_mf_symlink() checks the mode for a set S_IFREG bit
as a test to confirm that it is a regular file. This bit is also set for
other filetypes and simply checking for this bit being set may return
false positives.
We ensure that we are actually checking for a regular file by using the
S_ISREG macro to test instead.
Reported-by: Neil Brown <neilb@suse.de>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
When mounting with smb2 (or smb2.1 or smb3) we need to check to make
sure that attempts to query or set extended attributes do not
attempt to send the request with the older cifs protocol instead
(eventually we also need to add the support in SMB2
to query/set extended attributes but this patch prevents us from
using the wrong protocol for extended attribute operations).
Rename CIFSSMBOpen to CIFS_open and make it take
cifs_open_parms structure as a parm.
Rename camel case variable and fix comment style.
Remove indentation, fix comment style, rename camel case
variables in preparation to make it work with cifs_open_parms
When using posix extensions, dfs shares in the dfs root show up as
symlinks resulting in userland tools such as 'ls' calling readlink() on
these shares. Since these are dfs shares, we end up returning -EREMOTE.
$ ls -l /mnt
ls: cannot read symbolic link /mnt/test: Object is remote
total 0
lrwxrwxrwx. 1 root root 19 Nov 6 09:47 test
With added follow_link() support for dfs shares, when using unix
extensions, we call GET_DFS_REFERRAL to obtain the DFS referral and
return the first node returned.
The dfs share in the dfs root is now displayed in the following manner.
$ ls -l /mnt
total 0
lrwxrwxrwx. 1 root root 19 Nov 6 09:47 test -> \vm140-31\test
Unix extensions rigth now are only applicable to smb1 operations.
Move the check and subsequent unix extension call to the smb1
specific call to query_symlink() ie. cifs_query_symlink().
This patch makes cosmetic changes. We group similar functions together
and separate out the protocol specific functions.
Add a new protocol ops function create_mf_symlink and have
create_mf_symlink() use it.
This patchset moves the MFSymlink operations completely to the
ops structure so that we only use the right protocol versions when
querying or creating MFSymlinks.
We have an existing protocol specific call query_mf_symlink() created
for check_mf_symlink which can also be used for query_mf_symlink().
Clean up camel case in functionnames.
Rename open_query_close_cifs_symlink to cifs_query_mf_symlink() to make
the name more consistent with other protocol version specific functions.
We also pass tcon as an argument to the function. This is already
available in the calling functions and we can avoid having to make an
unnecessary lookup.
Fix a potential memory leak in the cifs_hardlink() error handling path.
Detected by Coverity: CID 728510, CID 728511.
Signed-off-by: Christian Engelmayer <cengelma@gmx.at>
Set FILE_CREATED on O_CREAT|O_EXCL.
cifs code didn't change during commit 116cc0225381415b96551f725455d067f63a76a0
Kernel bugzilla 66251
Signed-off-by: Shirish Pargaonkar <spargaonkar@suse.com>
When we obtain tcon from cifs_sb, we use cifs_sb_tlink() to first obtain
tlink which also grabs a reference to it. We do not drop this reference
to tlink once we are done with the call.
The patch fixes this issue by instead passing tcon as a parameter and
avoids having to obtain a reference to the tlink. A lookup for the tcon
is already made in the calling functions and this way we avoid having to
re-run the lookup. This is also consistent with the argument list for
other similar calls for M-F symlinks.
We should also return an ENOSYS when we do not find a protocol specific
function to lookup the MF Symlink data.
Signed-off-by: Gregor Beck <gbeck@sernet.de>
Change cifs.ko to using CIFS_IOCTL_COPYCHUNK instead
of BTRFS_IOC_CLONE to avoid confusion about whether
copy-on-write is required or optional for this operation.
SMB2/SMB3 copyoffload had used the BTRFS_IOC_CLONE ioctl since
they both speed up copy by offloading the copy rather than
passing many read and write requests back and forth and both have
identical syntax (passing file handles), but for SMB2/SMB3
CopyChunk the server is not required to use copy-on-write
to make a copy of the file (although some do), and Christoph
has commented that since CopyChunk does not require
copy-on-write we should not reuse BTRFS_IOC_CLONE.
This patch renames the ioctl to use a cifs specific IOCTL
CIFS_IOCTL_COPYCHUNK. This ioctl is particularly important
for SMB2/SMB3 since large file copy over the network otherwise
can be very slow, and with this is often more than 100 times
faster putting less load on server and client.
Note that if a copy syscall is ever introduced, depending on
its requirements/format it could end up using one of the other
three methods that CIFS/SMB2/SMB3 can do for copy offload,
but this method is particularly useful for file copy
and broadly supported (not just by Samba server).
Reviewed-by: David Disseldorp <ddiss@samba.org>
