path: root/fs/cifs
2011-12-21cifs: check for NULL last_entry before calling cifs_save_resume_keyJeff Layton
commit 7023676f9ee851d94f0942e879243fc1f9081c47 upstream. Prior to commit eaf35b1, cifs_save_resume_key had some NULL pointer checks at the top. It turns out that at least one of those NULL pointer checks is needed after all. When the LastNameOffset in a FIND reply appears to be beyond the end of the buffer, CIFSFindFirst and CIFSFindNext will set srch_inf.last_entry to NULL. Since eaf35b1, the code will now oops in this situation. Fix this by having the callers check for a NULL last entry pointer before calling cifs_save_resume_key. No change is needed for the call site in cifs_readdir as it's not reachable with a NULL current_entry pointer. This should fix: https://bugzilla.redhat.com/show_bug.cgi?id=750247 Cc: Christoph Hellwig <hch@infradead.org> Reported-by: Adam G. Metzler <adamgmetzler@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11CIFS: Fix DFS handling in cifs_get_file_infoPavel Shilovsky
commit 42274bb22afc3e877ae5abed787b0b09d7dede52 upstream. We should call cifs_all_info_to_fattr in rc == 0 case only. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11CIFS: Fix incorrect max RFC1002 write size valuePavel Shilovsky
commit 94443f43404239c2a6dc4252a7cb9e77f5b1eb6e upstream. ..the length field has only 17 bits. Acked-by: Jeff Layton <jlayton@samba.org> Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-07[CIFS] Fix first time message on mount, ntlmv2 upgrade delayed to 3.2Steve French
Microsoft has a bug with ntlmv2 that requires use of ntlmssp, but we didn't get the required information on when/how to use ntlmssp to old (but once very popular) legacy servers (various NT4 fixpacks for example) until too late to merge for 3.1. Will upgrade to NTLMv2 in NTLMSSP in 3.2 Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com>
2011-09-19cifs: Fix broken sec=ntlmv2/i sec option (try #2)Shirish Pargaonkar
Fix sec=ntlmv2/i authentication option during mount of Samba shares. cifs client was coding ntlmv2 response incorrectly. All that is needed in temp as specified in MS-NLMP seciton 3.3.2 "Define ComputeResponse(NegFlg, ResponseKeyNT, ResponseKeyLM, CHALLENGE_MESSAGE.ServerChallenge, ClientChallenge, Time, ServerName) as Set temp to ConcatenationOf(Responserversion, HiResponserversion, Z(6), Time, ClientChallenge, Z(4), ServerName, Z(4)" is MsvAvNbDomainName. For sec=ntlmsspi, build_av_pair is not used, a blob is plucked from type 2 response sent by the server to use in authentication. I tested sec=ntlmv2/i and sec=ntlmssp/i mount options against Samba (3.6) and Windows - XP, 2003 Server and 7. They all worked. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-09-19Fix the conflict between rwpidforward and rw mount optionsSteve French
Both these options are started with "rw" - that's why the first one isn't switched on even if it is specified. Fix this by adding a length check for "rw" option check. Cc: <stable@kernel.org> Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-09-19CIFS: Fix ERR_PTR dereference in cifs_get_rootPavel Shilovsky
move it to the beginning of the loop. Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-09-19cifs: fix possible memory corruption in CIFSFindNextJeff Layton
The name_len variable in CIFSFindNext is a signed int that gets set to the resume_name_len in the cifs_search_info. The resume_name_len however is unsigned and for some infolevels is populated directly from a 32 bit value sent by the server. If the server sends a very large value for this, then that value could look negative when converted to a signed int. That would make that value pass the PATH_MAX check later in CIFSFindNext. The name_len would then be used as a length value for a memcpy. It would then be treated as unsigned again, and the memcpy scribbles over a ton of memory. Fix this by making the name_len an unsigned value in CIFSFindNext. Cc: <stable@kernel.org> Reported-by: Darren Lavender <dcl@hppine99.gbr.hp.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-18update cifs version to 1.75Steve French
2011-08-18[CIFS] possible memory corruption on mountSteve French
CIFS cleanup_volume_info_contents() looks like having a memory corruption problem. When UNCip is set to "&vol->UNC[2]" in cifs_parse_mount_options(), it should not be kfree()-ed in cleanup_volume_info_contents(). Introduced in commit b946845a9dc523c759cae2b6a0f6827486c3221a Signed-off-by: J.R. Okajima <hooanon05@yahoo.co.jp> Reviewed-by: Jeff Layton <jlayton@redhat.com> CC: Stable <stable@kernel.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-16cifs: demote cERROR in build_path_from_dentry to cFYIJeff Layton
Running the cthon tests on a recent kernel caused this message to pop occasionally: CIFS VFS: did not end path lookup where expected namelen is 0 Some added debugging showed that namelen and dfsplen were both 0 when this occurred. That means that the read_seqretry returned true. Assuming that the comment inside the if statement is true, this should be harmless and just means that we raced with a rename. If that is the case, then there's no need for alarm and we can demote this to cFYI. While we're at it, print the dfsplen too so that we can see what happened here if the message pops during debugging. Cc: stable@kernel.org Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-11cifs: Do not set cifs/ntfs acl using a file handle (try #4)Shirish Pargaonkar
Set security descriptor using path name instead of a file handle. We can't be sure that the file handle has adequate permission to set a security descriptor (to modify DACL). Function set_cifs_acl_by_fid() has been removed since we can't be sure how a file was opened for writing, a valid request can fail if the file was not opened with two above mentioned permissions. We could have opted to add on WRITE_DAC and WRITE_OWNER permissions to file opens and then use that file handle but adding addtional permissions such as WRITE_DAC and WRITE_OWNER could cause an any open to fail. And it was incorrect to look for read file handle to set a security descriptor anyway. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-11[CIFS] Cleanup use of CONFIG_CIFS_STATS2 ifdef to make transport routines ↵Steve French
more readable Christoph had requested that the stats related code (in CONFIG_CIFS_STATS2) be moved into helpers to make code flow more readable. This patch should help. For example the following section from transport.c spin_unlock(&GlobalMid_Lock); atomic_inc(&ses->server->num_waiters); wait_event(ses->server->request_q, atomic_read(&ses->server->inFlight) < cifs_max_pending); atomic_dec(&ses->server->num_waiters); spin_lock(&GlobalMid_Lock); becomes simpler (with the patch below): spin_unlock(&GlobalMid_Lock); cifs_num_waiters_inc(server); wait_event(server->request_q, atomic_read(&server->inFlight) < cifs_max_pending); cifs_num_waiters_dec(server); spin_lock(&GlobalMid_Lock); Reviewed-by: Jeff Layton <jlayton@redhat.com> CC: Christoph Hellwig <hch@infradead.org> Signed-off-by: Steve French <sfrench@us.ibm.com> Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru>
2011-08-05cifs: cope with negative dentries in cifs_get_rootJeff Layton
The loop around lookup_one_len doesn't handle the case where it might return a negative dentry, which can cause an oops on the next pass through the loop. Check for that and break out of the loop with an error of -ENOENT if there is one. Fixes the panic reported here: https://bugzilla.redhat.com/show_bug.cgi?id=727927 Reported-by: TR Bentley <home@trarbentley.net> Reported-by: Iain Arnell <iarnell@gmail.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: stable@kernel.org Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-05cifs: convert prefixpath delimiters in cifs_build_path_to_rootJeff Layton
Regression from 2.6.39... The delimiters in the prefixpath are not being converted based on whether posix paths are in effect. Fixes: https://bugzilla.redhat.com/show_bug.cgi?id=727834 Reported-and-Tested-by: Iain Arnell <iarnell@gmail.com> Reported-by: Patrick Oltmann <patrick.oltmann@gmx.net> Cc: Pavel Shilovsky <piastryyy@gmail.com> Cc: stable@kernel.org Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-03CIFS: Fix missing a decrement of inFlight valuePavel Shilovsky
if we failed on getting mid entry in cifs_call_async. Cc: stable@kernel.org Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-03cifs: demote DFS referral lookup errors to cFYIJeff Layton
cifs: demote DFS referral lookup errors to cFYI Now that we call into this routine on every mount, anyone who doesn't have the upcall configured will get multiple printks about failed lookups. Reported-and-Tested-by: Martijn Uffing <mp3project@sarijopen.student.utwente.nl> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-03Revert "cifs: advertise the right receive buffer size to the server"Steve French
This reverts commit c4d3396b261473ded6f370edd1e79ba34e089d7e. Problems discovered with readdir to Samba due to not accounting for header size properly with this change
2011-08-01CIFS: Cleanup demupltiplex thread exiting codePavel Shilovsky
Reviewed-and-Tested-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-01CIFS: Move mid search to a separate functionPavel Shilovsky
2011-08-01CIFS: Move RFC1002 check to a separate functionPavel Shilovsky
2011-08-01CIFS: Simplify socket reading in demultiplex threadPavel Shilovsky
Move reading to separate function and remove csocket variable. Also change semantic in a little: goto incomplete_rcv only when we get -EAGAIN (or a familiar error) while reading rfc1002 header. In this case we don't check for echo timeout when we don't get whole header at once, as it was before. Reviewed-and-Tested-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-01CIFS: Move buffer allocation to a separate functionPavel Shilovsky
2011-07-31cifs: remove unneeded variable initialization in cifs_reconnect_tconJeff Layton
Reported-and-acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-31cifs: simplify refcounting for oplock breaksJeff Layton
Currently, we take a sb->s_active reference and a cifsFileInfo reference when an oplock break workqueue job is queued. This is unnecessary and more complicated than it needs to be. Also as Al points out, deactivate_super has non-trivial locking implications so it's best to avoid that if we can. Instead, just cancel any pending oplock breaks for this filehandle synchronously in cifsFileInfo_put after taking it off the lists. That should ensure that this job doesn't outlive the structures it depends on. Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-31cifs: fix compiler warning in CIFSSMBQAllEAsJeff Layton
The recent fix to the above function causes this compiler warning to pop on some gcc versions: CC [M] fs/cifs/cifssmb.o fs/cifs/cifssmb.c: In function ‘CIFSSMBQAllEAs’: fs/cifs/cifssmb.c:5708: warning: ‘ea_name_len’ may be used uninitialized in this function Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-31cifs: fix name parsing in CIFSSMBQAllEAsJeff Layton
The code that matches EA names in CIFSSMBQAllEAs is incorrect. It uses strncmp to do the comparison with the length limited to the name_len sent in the response. Problem: Suppose we're looking for an attribute named "foobar" and have an attribute before it in the EA list named "foo". The comparison will succeed since we're only looking at the first 3 characters. Fix this by also comparing the length of the provided ea_name with the name_len in the response. If they're not equal then it shouldn't match. Reported-by: Jian Li <jiali@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-31cifs: don't start signing too earlyJeff Layton
Sniffing traffic on the wire shows that windows clients send a zeroed out signature field in a NEGOTIATE request, and send "BSRSPYL" in the signature field during SESSION_SETUP. Make the cifs client behave the same way. It doesn't seem to make much difference in any server that I've tested against, but it's probably best to follow windows behavior as closely as possible here. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-31cifs: trivial: goto out here is unnecessaryJeff Layton
...and remove some obsolete comments. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-31cifs: advertise the right receive buffer size to the serverJeff Layton
Currently, we mirror the same size back to the server that it sends us. That makes little sense. Instead we should be sending the server the maximum buffer size that we can handle -- CIFSMaxBufSize minus the 4 byte RFC1001 header. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: Cleanup: check return codes of crypto api calls CIFS: Fix oops while mounting with prefixpath [CIFS] Redundant null check after dereference cifs: use cifs_dirent in cifs_save_resume_key cifs: use cifs_dirent to replace cifs_get_name_from_search_buf cifs: introduce cifs_dirent cifs: cleanup cifs_filldir
2011-07-25cifs: Cleanup: check return codes of crypto api callsShirish Pargaonkar
Check return codes of crypto api calls and either log an error or log an error and return from the calling function with error. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-25CIFS: Fix oops while mounting with prefixpathPavel Shilovsky
commit fec11dd9a0109fe52fd631e5c510778d6cbff6cc caused a regression when we have already mounted //server/share/a and want to mount //server/share/a/b. The problem is that lookup_one_len calls __lookup_hash with nd pointer as NULL. Then __lookup_hash calls do_revalidate in the case when dentry exists and we end up with NULL pointer deference in cifs_d_revalidate: if (nd->flags & LOOKUP_RCU) return -ECHILD; Fix this by checking nd for NULL. Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Reviewed-by: Shirish Pargaonkar <shirishp@us.ibm.com> CC: Stable <stable@kernel.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-25[CIFS] Redundant null check after dereferenceSteve French
Reviewed-by: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-25cifs: use cifs_dirent in cifs_save_resume_keyChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-25cifs: use cifs_dirent to replace cifs_get_name_from_search_bufChristoph Hellwig
This allows us to parse the on the wire structures only once in cifs_filldir. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-25cifs: introduce cifs_direntChristoph Hellwig
Introduce a generic directory entry structure, and factor the parsing of the various on the wire structures that can represent one into a common helper. Switch cifs_entry_is_dot over to use it as a start. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-25cifs: cleanup cifs_filldirChristoph Hellwig
Use sensible variable names and formatting and remove some superflous checks on entry. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
commit fec11dd9a0109fe52fd631e5c510778d6cbff6cc caused a regression when we have already mounted //server/share/a and want to mount //server/share/a/b. The problem is that lookup_one_len calls __lookup_hash with nd pointer as NULL. Then __lookup_hash calls do_revalidate in the case when dentry exists and we end up with NULL pointer deference in cifs_d_revalidate: if (nd->flags & LOOKUP_RCU) return -ECHILD; Fix this by checking nd for NULL. Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits) vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp isofs: Remove global fs lock jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory fix IN_DELETE_SELF on overwriting rename() on ramfs et.al. mm/truncate.c: fix build for CONFIG_BLOCK not enabled fs:update the NOTE of the file_operations structure Remove dead code in dget_parent() AFS: Fix silly characters in a comment switch d_add_ci() to d_splice_alias() in "found negative" case as well simplify gfs2_lookup() jfs_lookup(): don't bother with . or .. get rid of useless dget_parent() in btrfs rename() and link() get rid of useless dget_parent() in fs/btrfs/ioctl.c fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers drivers: fix up various ->llseek() implementations fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek Ext4: handle SEEK_HOLE/SEEK_DATA generically Btrfs: implement our own ->llseek fs: add SEEK_HOLE and SEEK_DATA flags reiserfs: make reiserfs default to barrier=flush ... Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new shrinker callout for the inode cache, that clashed with the xfs code to start the periodic workers later.
2011-07-21CIFS: Fix wrong length in cifs_iovec_readPavel Shilovsky
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseekJosef Bacik
This converts everybody to handle SEEK_HOLE/SEEK_DATA properly. In some cases we just return -EINVAL, in others we do the normal generic thing, and in others we're simply making sure that the properly due-dilligence is done. For example in NFS/CIFS we need to make sure the file size is update properly for the SEEK_HOLE and SEEK_DATA case, but since it calls the generic llseek stuff itself that is all we have to do. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20don't open-code parent_ino() in assorted ->readdir()Al Viro
2011-07-20cifs_lookup(): LOOKUP_OPEN is set only on the last componentAl Viro
2011-07-20LOOKUP_CREATE and LOOKUP_RENAME_TARGET can be set only on the last stepAl Viro
2011-07-20no need to check for LOOKUP_OPEN in ->create() instancesAl Viro
... it will be set in nd->flag for all cases with non-NULL nd (i.e. when called from do_last()). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20cifs: fix the type of cifs_demultiplex_thread()Al Viro
... and get rid of a bogus typecast, while we are at it; it's not just that we want a function returning int and not void, but cast to pointer to function taking void * and returning void would be (void (*)(void *)) and not (void *)(void *), TYVM... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to ->permission()Al Viro
not used by the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to generic_permission()Al Viro
redundant; all callers get it duplicated in mask & MAY_NOT_BLOCK and none of them removes that bit. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
