path: root/fs/coda
2015-04-29move d_rcu from overlapping d_child to overlapping d_aliasAl Viro
commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream. move d_rcu from overlapping d_child to overlapping d_alias Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Ben Hutchings <ben@decadent.org.uk> [hujianyang: Backported to 3.14 refer to the work of Ben Hutchings in 3.2: - Apply name changes in all the different places we use d_alias and d_child - Move the WARN_ON() in __d_free() to d_free() as we don't have dentry_free()] Signed-off-by: hujianyang <hujianyang@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-09coda_revalidate_inode(): switch to passing inode...Al Viro
2013-10-24file->f_op is never NULL...Al Viro
2013-07-05helper for reading ->d_countAl Viro
2013-06-29coda: don't bother with find_inode_number()Al Viro
the fallback it's using for dcache misses is actually the same value we would've used for inumber anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29[readdir] convert codaAl Viro
2013-06-29[readdir] introduce ->iterate(), ctx->pos, dir_emit()Al Viro
New method - ->iterate(file, ctx). That's the replacement for ->readdir(); it takes callback from ctx->actor, uses ctx->pos instead of file->f_pos and calls dir_emit(ctx, ...) instead of filldir(data, ...). It does *not* update file->f_pos (or look at it, for that matter); iterate_dir() does the update. Note that dir_emit() takes the offset from ctx->pos (and eventually filldir_t will lose that argument). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09lift sb_start_write() out of ->write()Al Viro
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-13coda: Cache permisions in struct coda_inode_info in a kuid_t.Eric W. Biederman
- Change c_uid in struct coda_indoe_info from a vuid_t to a kuid_t. - Initialize c_uid to GLOBAL_ROOT_UID instead of 0. - Use uid_eq to compare cached kuids. Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13coda: Restrict coda messages to the initial user namespaceEric W. Biederman
Remove the slight chance that uids and gids in coda messages will be interpreted in the wrong user namespace. - Only allow processes in the initial user namespace to open the coda character device to communicate with coda filesystems. - Explicitly convert the uids in the coda header into the initial user namespace. - In coda_vattr_to_attr make kuids and kgids from the initial user namespace uids and gids in struct coda_vattr that just came from userspace. - In coda_iattr_to_vattr convert kuids and kgids into uids and gids in the intial user namespace and store them in struct coda_vattr for sending to coda userspace programs. Nothing needs to be changed with mounts as coda does not support being mounted in anything other than the initial user namespace. Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13coda: Restrict coda messages to the initial pid namespaceEric W. Biederman
Remove the slight chance that pids in coda messages will be interpreted in the wrong pid namespace. - Explicitly send all pids in coda messages in the initial pid namespace. - Only allow mounts from processes in the initial pid namespace. - Only allow processes in the initial pid namespace to open the coda character device to communicate with coda. Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-26switch simple cases of fget_light to fdgetAl Viro
2012-09-26switch coda get_device_index() to fget_light()Al Viro
2012-07-14don't pass nameidata to ->create()Al Viro
boolean "does it have to be exclusive?" flag is passed instead; Local filesystem should just ignore it - the object is guaranteed not to be there yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata * to ->d_revalidate()Al Viro
Just the lookup flags. Die, bastard, die... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14coda: use list_for_each_entryAl Viro
2012-05-06vfs: Rename end_writeback() to clear_inode()Jan Kara
After we moved inode_sync_wait() from end_writeback() it doesn't make sense to call the function end_writeback() anymore. Rename it to clear_inode() which well says what the function really does - set I_CLEAR flag. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-03-20coda: clean failure exits in coda_fill_super()Al Viro
same as for cifs, move iput() to the right place, make it unconditional Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-10coda: switch coda_cnode_make() to sane API as well, clean coda_lookup()Al Viro
2012-01-10coda: deal correctly with allocation failure from coda_cnode_makectl()Al Viro
lookup should fail with ENOMEM, not silently make dentry negative. Switched to saner calling conventions, while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch ->create() to umode_tAl Viro
vfs_create() ignores everything outside of 16bit subset of its mode argument; switching it to umode_t is obviously equivalent and it's the only caller of the method Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch vfs_mkdir() and ->mkdir() to umode_tAl Viro
vfs_mkdir() gets int, but immediately drops everything that might not fit into umode_t and that's the only caller of ->mkdir()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03vfs: fix the stupidity with i_dentry in inode destructorsAl Viro
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once(); the cost of taking it into inode_init_always() will be negligible for pipes and sockets and negative for everything else. Not to mention the removal of boilerplate code from ->destroy_inode() instances... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-11-02filesystems: add missing nlink wrappersMiklos Szeredi
Replace direct i_nlink updates with the respective updater function (inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-09-15fs: Convert vmalloc/memset to vzallocJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Alex Elder <aelder@sgi.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20don't open-code parent_ino() in assorted ->readdir()Al Viro
2011-07-20coda_venus_readdir(): use offsetof()Al Viro
2011-07-20->permission() sanitizing: don't pass flags to ->permission()Al Viro
not used by the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-20coda_ioctl_permission() is safe in RCU modeAl Viro
return (mask & MAY_EXEC) ? -EACCES : 0; is non-blocking... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-28coda: remove unnecessary dentry_unhash on rmdir, dir renameSage Weil
Coda has no problems with references to unlinked directories. CC: Jan Harkes <jaharkes@cs.cmu.edu> CC: coda@cs.cmu.edu CC: codalist@coda.cs.cmu.edu Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-25codafs: fix build break when CONFIG_PROC_SYSCTL=nRakib Mullick
Commit 0bc825d240ab ("codafs: fix compile warning when CONFIG_SYSCTL=n") introduces build breakage, when CONFIG_PROC_SYSCTL=n and CONFIG_CODA_FS=y: fs/built-in.o: In function `init_coda': psdev.c:(.init.text+0xc02): undefined reference to `coda_sysctl_init' psdev.c:(.init.text+0xc7c): undefined reference to `coda_sysctl_clean' fs/built-in.o: In function `exit_coda': psdev.c:(.exit.text+0xa9): undefined reference to `coda_sysctl_clean' make: *** [.tmp_vmlinux1] Error 1 Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Reported-by: Ingo Molnar <mingo@elte.hu> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22codafs: fix compile warning when CONFIG_SYSCTL=nRakib Mullick
When CONFIG_SYSCTL=n, we get the following warning: fs/coda/sysctl.c:18: warning: `coda_tabl' defined but not used Fix the warning by making sure coda_table and it's callee function are in the same context. Also clean up the code by removing extra #ifdef. [akpm@linux-foundation.org: remove unneeded stub macros] Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17fs: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. And change ntfs-objs to ntfs-y for cleaner conditional inclusion. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (41 commits) fs: add documentation on fallocate hole punching Gfs2: fail if we try to use hole punch Btrfs: fail if we try to use hole punch Ext4: fail if we try to use hole punch Ocfs2: handle hole punching via fallocate properly XFS: handle hole punching via fallocate properly fs: add hole punching to fallocate vfs: pass struct file to do_truncate on O_TRUNC opens (try #2) fix signedness mess in rw_verify_area() on 64bit architectures fs: fix kernel-doc for dcache::prepend_path fs: fix kernel-doc for dcache::d_validate sanitize ecryptfs ->mount() switch afs move internal-only parts of ncpfs headers to fs/ncpfs switch ncpfs switch 9p pass default dentry_operations to mount_pseudo() switch hostfs switch affs switch configfs ...
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-12take coda-private headers out of include/linuxAl Viro
2011-01-12switch codaAl Viro
Coda ->d_revalidate() actually checks for root, ->d_delete() is irrelevant. So we can use the same d_op for all coda dentries Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: rcu-walk aware d_revalidate methodNick Piggin
Require filesystems be aware of .d_revalidate being called in rcu-walk mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning -ECHILD from all implementations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
