Similar information can easily be obtained with strace -c.
Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu>
The sb_info structure only contains a single pointer to the character device,
there is no need for the added indirection.
Venus returns an ENOENT error on open, so we shouldn't try to grab the
filehandle for the returned fd.
We ignore signals for about 30 seconds to give userspace a chance to see the
upcall. As we did not block signals we ended up in a busy loop for the
remainder of the period when a signal is received.
Make the code that processes upcall responses more straightforward, uncovered
at least one bad assumption. We trusted that vc_inuse would be 0 when upcalls
are aborted, however the device may have been reopened.
- Make sure device index is not a negative number.
- Unlink queued requests when the device is closed to avoid passing them
to the next opener.
Set MS_NOATIME flag to avoid unnecessary calls when the coda inode is
accessed.
Also, set statfs.f_bsize to 4k. 1k is obviously too small for the suggested
IO size.
A directory without children may still be busy when it is the cwd for some
process. We can safely remove such a directory because the VFS prevents
further operations. Also we don't need to call d_delete as it is already
called in vfs_rmdir.
The Coda client sets the directory link count to 1 when it isn't sure how many
subdirectories we have. In this case we shouldn't change the link count in
the kernel when a subdirectory is created or removed.
Change the epoch value to forces a refresh instead of clearing the cached
rights mask and block all further accesses to the object.
When open fails the fd in the response is uninitialized and we ended up taking
a reference on the file struct and never released it.
Shows how many people are testing coda - the bug had been there for 5 years
and results of stepping on it are not subtle.
They can use generic_file_splice_read() instead. Since sys_sendfile() now
prefers that, there should be no change in behaviour.
First thing mm.h does is including sched.h solely for can_do_mlock() inline
function which has "current" dereference inside. By dealing with can_do_mlock()
mm.h can be detached from sched.h which is good. See below, why.
This patch
a) removes unconditional inclusion of sched.h from mm.h
b) makes can_do_mlock() normal function in mm/mlock.c
c) exports can_do_mlock() to not break compilation
d) adds sched.h inclusions back to files that were getting it indirectly.
e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were
getting them indirectly
Net result is:
a) mm.h users would get less code to open, read, preprocess, parse, ... if
they don't need sched.h
b) sched.h stops being dependency for significant number of files:
on x86_64 allmodconfig touching sched.h results in recompile of 4083 files,
after patch it's only 3744 (-8.3%).
Cross-compile tested on
all arm defconfigs, all mips defconfigs, all powerpc defconfigs,
alpha alpha-up
arm
i386 i386-up i386-defconfig i386-allnoconfig
ia64 ia64-up
m68k
mips
parisc parisc-up
powerpc powerpc-up
s390 s390-up
sparc sparc-up
sparc64 sparc64-up
um-x86_64
x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig
as well as my two usual configs.
SLAB_CTOR_CONSTRUCTOR is always specified. No point in checking it.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Steven French <sfrench@us.ibm.com>
Cc: Michael Halcrow <mhalcrow@us.ibm.com>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Dave Kleikamp <shaggy@austin.ibm.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Anton Altaparmakov <aia21@cantab.net>
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Cc: Jan Kara <jack@ucw.cz>
Cc: David Chinner <dgc@sgi.com>
I have never seen a use of SLAB_DEBUG_INITIAL. It is only supported by
SLAB.
I think its purpose was to have a callback after an object has been freed
to verify that the state is the constructor state again? The callback is
performed before each freeing of an object.
I would think that it is much easier to check the object state manually
before the free. That also places the check near the code object
manipulation of the object.
Also the SLAB_DEBUG_INITIAL callback is only performed if the kernel was
compiled with SLAB debugging on. If there would be code in a constructor
handling SLAB_DEBUG_INITIAL then it would have to be conditional on
SLAB_DEBUG otherwise it would just be dead code. But there is no such code
in the kernel. I think SLUB_DEBUG_INITIAL is too problematic to make real
use of, difficult to understand and there are easier ways to accomplish the
same effect (i.e. add debug code before kfree).
There is a related flag SLAB_CTOR_VERIFY that is frequently checked to be
clear in fs inode caches. Remove the pointless checks (they would even be
pointless without removeal of SLAB_DEBUG_INITIAL) from the fs constructors.
This is the last slab flag that SLUB did not support. Remove the check for
unimplemented flags from SLUB.
The semantic effect of insert_at_head is that it would allow new registered
sysctl entries to override existing sysctl entries of the same name. Which is
pain for caching and the proc interface never implemented.
I have done an audit and discovered that none of the current users of
register_sysctl care as (excpet for directories) they do not register
duplicate sysctl entries.
So this patch simply removes the support for overriding existing entries in
the sys_sysctl interface since no one uses it or cares and it makes future
enhancments harder.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andi Kleen <ak@muc.de>
Cc: Corey Minyard <minyard@acm.org>
Cc: Neil Brown <neilb@suse.de>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Patrick McHardy <kaber@trash.net>
Will converting the coda sysctl initializers I discovered that it is yet
another user of sysctl that was stomping CTL_KERN. So off with it's
sys_sysctl support since it wasn't done in a supportable way.
Cc: Jan Harkes <jaharkes@cs.cmu.edu>
This patch is inspired by Arjan's "Patch series to mark struct
file_operations and struct inode_operations const".
Compile tested with gcc & sparse.
Signed-off-by: Josef 'Jeff' Sipek <jsipek@cs.sunysb.edu>
Many struct inode_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Compile-tested.
Cc: <jaharkes@cs.cmu.edu>
Signed-off-by: Josef Sipek <jsipek@fsl.cs.sunysb.edu>
Replace all uses of kmem_cache_t with struct kmem_cache.
The patch was generated using the following script:
#!/bin/sh
# Replace one string by another in all the kernel sources.
set -e
for file in `find * -name "*.c" -o -name "*.h"|xargs grep -l $1`; do
quilt add $file
sed -e "1,\$s/$1/$2/g" $file >/tmp/$$
mv /tmp/$$ $file
quilt refresh
done
The script was run like this
sh replace kmem_cache_t "struct kmem_cache"
SLAB_KERNEL is an alias of GFP_KERNEL.
This is mostly included for parity with dec_nlink(), where we will have some
more hooks. This one should stay pretty darn straightforward for now.
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
Acked-by: Christoph Hellwig <hch@lst.de>
When a filesystem decrements i_nlink to zero, it means that a write must be
performed in order to drop the inode from the filesystem.
We're shortly going to have keep filesystems from being remounted r/o between
the time that this i_nlink decrement and that write occurs.
So, add a little helper function to do the decrements. We'll tie into it in a
bit to note when i_nlink hits zero.
This eliminates the i_blksize field from struct inode. Filesystems that want
to provide a per-inode st_blksize can do so by providing their own getattr
routine instead of using the generic_fillattr() function.
Note that some filesystems were providing pretty much random (and incorrect)
values for i_blksize.
[bunk@stusta.de: cleanup]
[akpm@osdl.org: generic_fillattr() fix]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
* Rougly half of callers already do it by not checking return value
* Code in drivers/acpi/osl.c does the following to be sure:
(void)kmem_cache_destroy(cache);
* Those who check it printk something, however, slab_error already printed
the name of failed cache.
* XFS BUGs on failed kmem_cache_destroy which is not the decision
low-level filesystem driver should make. Converted to ignore.
* Removing useless casts
* Removing useless wrapper
* Conversion from kmalloc+memset to kzalloc
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Acked-by: Dave Kleikamp <shaggy@austin.ibm.com>
coda_open()
Commit 398c53a757702e1e3a7a2c24860c7ad26acb53ed (in the historical GIT
tree) moved the lock_kernel() in coda_open after the allocation of a
coda_file_info struct, but left an unlock_kernel() in the allocation
failure error path; remove it.
Signed-off-by: Josh Triplett <josh@freedesktop.org>
Acked-by: Jan Harkes <jaharkes@cs.cmu.edu>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits)
[PATCH] devfs: Remove it from the feature_removal.txt file
[PATCH] devfs: Last little devfs cleanups throughout the kernel tree.
[PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV
[PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed
[PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed
[PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed
[PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed
[PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed
[PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree
[PATCH] devfs: Remove devfs_remove() function from the kernel tree
[PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree
[PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree
[PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree
[PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree
[PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree
[PATCH] devfs: Remove devfs support from the sound subsystem
[PATCH] devfs: Remove devfs support from the ide subsystem.
[PATCH] devfs: Remove devfs support from the serial subsystem
[PATCH] devfs: Remove devfs from the init code
[PATCH] devfs: Remove devfs from the partition code
Same as with already do with the file operations: keep them in .rodata and
prevents people from doing runtime patching.
Also fixes up all files that #include it.
Removes the devfs_remove() function and all callers of it.
Removes the devfs_mk_cdev() function and all callers of it.
Removes the devfs_mk_dir() function and all callers of it.
This patch converts list_add(A, B.prev) to list_add_tail(A, &B) for
readability.
Acked-by: Karsten Keil <kkeil@suse.de>
Acked-by: Jan Kara <jack@suse.cz>
AOLed-by: David Woodhouse <dwmw2@infradead.org>
Cc: Sridhar Samudrala <sri@us.ibm.com>
Signed-off-by: Akinobu Mita <mita@miraclelinux.com>
Pass the POSIX lock owner ID to the flush operation.
This is useful for filesystems which don't want to store any locking state
in inode->i_flock but want to handle locking/unlocking POSIX locks
internally. FUSE is one such filesystem but I think it possible that some
network filesystems would need this also.
Also add a flag to indicate that a POSIX locking request was generated by
close(), so filesystems using the above feature won't send an extra locking
request in this case.
Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
Give the statfs superblock operation a dentry pointer rather than a superblock
pointer.
This complements the get_sb() patch. That reduced the significance of
sb->s_root, allowing NFS to place a fake root there. However, NFS does
require a dentry to use as a target for the statfs operation. This permits
the root in the vfsmount to be used instead.
linux/mount.h has been added where necessary to make allyesconfig build
successfully.
Interest has also been expressed for use with the FUSE and XFS filesystems.
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Nathan Scott <nathans@sgi.com>
Extend the get_sb() filesystem operation to take an extra argument that
permits the VFS to pass in the target vfsmount that defines the mountpoint.
The filesystem is then required to manually set the superblock and root dentry
pointers. For most filesystems, this should be done with simple_set_mnt()
which will set the superblock pointer and then set the root dentry to the
superblock's s_root (as per the old default behaviour).
The get_sb() op now returns an integer as there's now no need to return the
superblock pointer.
This patch permits a superblock to be implicitly shared amongst several mount
points, such as can be done with NFS to avoid potential inode aliasing. In
such a case, simple_set_mnt() would not be called, and instead the mnt_root
and mnt_sb would be set directly.
The patch also makes the following changes:
(*) the get_sb_*() convenience functions in the core kernel now take a vfsmount
pointer argument and return an integer, so most filesystems have to change
very little.
(*) If one of the convenience function is not used, then get_sb() should
normally call simple_set_mnt() to instantiate the vfsmount. This will
always return 0, and so can be tail-called from get_sb().
(*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the
dcache upon superblock destruction rather than shrink_dcache_anon().
This is required because the superblock may now have multiple trees that
aren't actually bound to s_root, but that still need to be cleaned up. The
currently called functions assume that the whole tree is rooted at s_root,
and that anonymous dentries are not the roots of trees which results in
dentries being left unculled.
However, with the way NFS superblock sharing are currently set to be
implemented, these assumptions are violated: the root of the filesystem is
simply a dummy dentry and inode (the real inode for '/' may well be
inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries
with child trees.
[*] Anonymous until discovered from another tree.
(*) The documentation has been adjusted, including the additional bit of
changing ext2_* into foo_* in the documentation.
[akpm@osdl.org: convert ipath_fs, do other stuff]
Cc: Roland Dreier <rolandd@cisco.com>
This is a conversion to make the various file_operations structs in fs/
const. Basically a regexp job, with a few manual fixups
The goal is both to increase correctness (harder to accidentally write to
shared datastructures) and reducing the false sharing of cachelines with
things that get dirty in .data (while .rodata is nicely read only and thus
cache clean)
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
this changes if() BUG(); constructs to BUG_ON() which is
cleaner, contains unlikely() and can better optimized away.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD
memory spreading.
If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's
in a cpuset with the 'memory_spread_slab' option enabled goes to allocate
from such a slab cache, the allocations are spread evenly over all the
memory nodes (task->mems_allowed) allowed to that task, instead of favoring
allocation on the node local to the current cpu.
The following inode and similar caches are marked SLAB_MEM_SPREAD:
file cache
fs/adfs/super.c adfs_inode_cache
fs/affs/super.c affs_inode_cache
fs/befs/linuxvfs.c befs_inode_cache
fs/bfs/inode.c bfs_inode_cache
fs/block_dev.c bdev_cache
fs/cifs/cifsfs.c cifs_inode_cache
fs/coda/inode.c coda_inode_cache
fs/dquot.c dquot
fs/efs/super.c efs_inode_cache
fs/ext2/super.c ext2_inode_cache
fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr
fs/ext3/super.c ext3_inode_cache
fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr
fs/fat/cache.c fat_cache
fs/fat/inode.c fat_inode_cache
fs/freevxfs/vxfs_super.c vxfs_inode
fs/hpfs/super.c hpfs_inode_cache
fs/isofs/inode.c isofs_inode_cache
fs/jffs/inode-v23.c jffs_fm
fs/jffs2/super.c jffs2_i
fs/jfs/super.c jfs_ip
fs/minix/inode.c minix_inode_cache
fs/ncpfs/inode.c ncp_inode_cache
fs/nfs/direct.c nfs_direct_cache
fs/nfs/inode.c nfs_inode_cache
fs/ntfs/super.c ntfs_big_inode_cache_name
fs/ntfs/super.c ntfs_inode_cache
fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache
fs/ocfs2/super.c ocfs2_inode_cache
fs/proc/inode.c proc_inode_cache
fs/qnx4/inode.c qnx4_inode_cache
fs/reiserfs/super.c reiser_inode_cache
fs/romfs/inode.c romfs_inode_cache
fs/smbfs/inode.c smb_inode_cache
fs/sysv/inode.c sysv_inode_cache
fs/udf/super.c udf_inode_cache
fs/ufs/super.c ufs_inode_cache
net/socket.c sock_inode_cache
net/sunrpc/rpc_pipe.c rpc_inode_cache
The choice of which slab caches to so mark was quite simple. I marked
those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache,
inode_cache, and buffer_head, which were marked in a previous patch. Even
though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same
potentially large file system i/o related slab caches as we need for memory
spreading.
Given that the rule now becomes "wherever you would have used a
SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use
the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain.
Future file system writers will just copy one of the existing file system
slab cache setups and tend to get it right without thinking.
Signed-off-by: Paul Jackson <pj@sgi.com>
Introduce a file fs/coda/coda_int.h with proper prototypes for some code.
