path: root/fs/coda
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25Coda: replace BKL with mutexYoshihisa Abe
Replace the BKL with a mutex to protect the venus_comm structure which binds the mountpoint with the character device and holds the upcall queues. Signed-off-by: Yoshihisa Abe <yoshiabe@cs.cmu.edu> Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25Coda: push BKL regions into coda_upcall()Yoshihisa Abe
Now that shared inode state is locked using the cii->c_lock, the BKL is only used to protect the upcall queues used to communicate with the userspace cache manager. The remaining state is all local and we can push the lock further down into coda_upcall(). Signed-off-by: Yoshihisa Abe <yoshiabe@cs.cmu.edu> Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25Coda: add spin lock to protect accesses to struct coda_inode_info.Yoshihisa Abe
We mostly need it to protect cached user permissions. The c_flags field is advisory, reading the wrong value is harmless and in the worst case we hit a slow path where we have to make an extra upcall to the userspace cache manager when revalidating a dentry or inode. Signed-off-by: Yoshihisa Abe <yoshiabe@cs.cmu.edu> Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-09-19Coda: mount hangs because of missed REQ_WRITE renameJan Harkes
Coda's REQ_* defines were renamed to avoid clashes with the block layer (commit 4aeefdc69f7b: "coda: fixup clash with block layer REQ_* defines"). However one was missed and response messages are no longer matched with requests and waiting threads are no longer woken up. This patch fixes this. Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu> [ Also fixed up whitespace while at it -Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10Merge branch 'for-2.6.36' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits) block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n xen-blkfront: fix missing out label blkdev: fix blkdev_issue_zeroout return value block: update request stacking methods to support discards block: fix missing export of blk_types.h writeback: fix bad _bh spinlock nesting drbd: revert "delay probes", feature is being re-implemented differently drbd: Initialize all members of sync_conf to their defaults [Bugz 315] drbd: Disable delay probes for the upcomming release writeback: cleanup bdi_register writeback: add new tracepoints writeback: remove unnecessary init_timer call writeback: optimize periodic bdi thread wakeups writeback: prevent unnecessary bdi threads wakeups writeback: move bdi threads exiting logic to the forker thread writeback: restructure bdi forker loop a little writeback: move last_active to bdi writeback: do not remove bdi from bdi_list writeback: simplify bdi code a little writeback: do not lose wake-ups in bdi threads ... Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and drivers/scsi/scsi_error.c as per Jens.
2010-08-09convert remaining ->clear_inode() to ->evict_inode()Al Viro
2010-08-07coda: fixup clash with block layer REQ_* definesJens Axboe
CODA should not be using defines in the global name space of that nature, prefix them with CODA_. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-24Merge branch 'bkl/ioctl' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing * 'bkl/ioctl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing: uml: Pushdown the bkl from harddog_kern ioctl sunrpc: Pushdown the bkl from sunrpc cache ioctl sunrpc: Pushdown the bkl from ioctl autofs4: Pushdown the bkl from ioctl uml: Convert to unlocked_ioctls to remove implicit BKL ncpfs: BKL ioctl pushdown coda: Clean-up whitespace problems in pioctl.c coda: BKL ioctl pushdown drivers: Push down BKL into various drivers isdn: Push down BKL into ioctl functions scsi: Push down BKL into ioctl functions dvb: Push down BKL into ioctl functions smbfs: Push down BKL into ioctl function coda/psdev: Remove BKL from ioctl function um/mmapper: Remove BKL usage sn_hwperf: Kill BKL usage hfsplus: Push down BKL into ioctl function
2010-05-21sanitize vfs_fsync calling conventionsChristoph Hellwig
Now that the last user passing a NULL file pointer is gone we can remove the redundant dentry argument and associated hacks inside vfs_fsynmc_range. The next step will be removig the dentry argument from ->fsync, but given the luck with the last round of method prototype changes I'd rather defer this until after the main merge window. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-17coda: Clean-up whitespace problems in pioctl.cJohn Kacur
Signed-off-by: John Kacur <jkacur@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2010-05-17coda: BKL ioctl pushdownJohn Kacur
Convert coda_pioctl to an unlocked_ioctl pushing down the BKL into it. Signed-off-by: John Kacur <jkacur@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2010-05-17coda/psdev: Remove BKL from ioctl functionArnd Bergmann
The ioctl function returns constant results, so it obviously does not need the BKL and can be converted to unlocked_ioctl. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2010-04-22coda: add bdi backing to mount sessionJens Axboe
This ensures that dirty data gets flushed properly. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-12sysctl fs: Remove dead binary sysctl supportEric W. Biederman
Now that sys_sysctl is a generic wrapper around /proc/sys .ctl_name and .strategy members of sysctl tables are dead code. Remove them. Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-10-04headers: remove sched.h from poll.hAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24sysctl: remove "struct file *" argument of ->proc_handlerAlexey Dobriyan
It's unused. It isn't needed -- read or write flag is already passed and sysctl shouldn't care about the rest. It _was_ used in two places at arch/frv for some reason. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-11splice: implement default splice_read methodMiklos Szeredi
If f_op->splice_read() is not implemented, fall back to a plain read. Use vfs_readv() to read into previously allocated pages. This will allow splice and functions using splice, such as the loop device, to work on all filesystems. This includes "direct_io" files in fuse which bypass the page cache. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-27constify dentry_operations: misc filesystemsAl Viro
2009-01-22fs/Kconfig: move coda outAlexey Dobriyan
2009-01-08coda: fix fs/coda/sysctl.c build warnings when !CONFIG_SYSCTLRichard A. Holden III
Fix fs/coda/sysctl.c:14: warning: 'fs_table_header' defined but not used fs/coda/sysctl.c:44: warning: 'fs_table' defined but not used these are only used when CONFIG_SYSCTL is defined. Signed-off-by: Richard A. Holden III <aciddeath@gmail.com> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05add a vfs_fsync helperChristoph Hellwig
Fsync currently has a fdatawrite/fdatawait pair around the method call, and a mutex_lock/unlock of the inode mutex. All callers of fsync have to duplicate this, but we have a few and most of them don't quite get it right. This patch adds a new vfs_fsync that takes care of this. It's a little more complicated as usual as ->fsync might get a NULL file pointer and just a dentry from nfsd, but otherwise gets afile and we want to take the mapping and file operations from it when it is there. Notes on the fsync callers: - ecryptfs wasn't calling filemap_fdatawrite / filemap_fdatawait on the lower file - coda wasn't calling filemap_fdatawrite / filemap_fdatawait on the host file, and returning 0 when ->fsync was missing - shm wasn't calling either filemap_fdatawrite / filemap_fdatawait nor taking i_mutex. Now given that shared memory doesn't have disk backing not doing anything in fsync seems fine and I left it out of the vfs_fsync conversion for now, but in that case we might just not pass it through to the lower file at all but just call the no-op simple_sync_file directly. [and now actually export vfs_fsync] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-11-20coda: fix creds referenceRandy Dunlap
Needs a header file for credentials struct: linux-next-20081023/fs/coda/file.c:177: error: dereferencing pointer to incomplete type Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Use creds in file structsDavid Howells
Attach creds to file structs and discard f_uid/f_gid. file_operations::open() methods (such as hppfs_open()) should use file->f_cred rather than current_cred(). At the moment file->f_cred will be current_cred() at this point. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the Coda filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Cc: codalist@coda.cs.cmu.edu Signed-off-by: James Morris <jmorris@namei.org>
2008-10-27Switch to a valid email address...Alan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23[PATCH] move executable checking into ->permission()Miklos Szeredi
For execute permission on a regular files we need to check if file has any execute bits at all, regardless of capabilites. This check is normally performed by generic_permission() but was also added to the case when the filesystem defines its own ->permission() method. In the latter case the filesystem should be responsible for performing this check. Move the check from inode_permission() inside filesystems which are not calling generic_permission(). Create a helper function execute_ok() that returns true if the inode is a directory or if any execute bits are present in i_mode. Also fix up the following code: - coda control file is never executable - sysctl files are never executable - hfs_permission seems broken on MAY_EXEC, remove - hfsplus_permission is eqivalent to generic_permission(), remove Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-10-16device create: misc: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-26[PATCH] sanitize __user_walk_fd() et.al.Al Viro
* do not pass nameidata; struct path is all the callers want. * switch to new helpers: user_path_at(dfd, pathname, flags, &path) user_path(pathname, &path) user_lpath(pathname, &path) user_path_dir(pathname, &path) (fail if not a directory) The last 3 are trivial macro wrappers for the first one. * remove nameidata in callers. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25coda: remove CODA_FS_OLD_APIAdrian Bunk
While fixing CONFIG_ leakages to the userspace kernel headers I ran into CODA_FS_OLD_API. After five years, are there still people using the old API left? Especially considering that you have to choose at compile time which API to support in the kernel (and distributions tend to offer the new API for some time). Jan: "The old API can definitely go. Around the time the new interface went in there were some non-Coda userspace file system implementations that took a while longer to convert to the new API, but by now they all switched to the new interface or in some cases to a FUSE-based solution." Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21device create: coda: convert device_create to device_create_drvdataGreg Kroah-Hartman
device_create() is race-prone, so use the race-free device_create_drvdata() instead as device_create() is going away. Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-29codafs: fix build warningAndrew Morton
powerpc: fs/coda/coda_linux.c: In function 'coda_iattr_to_vattr': fs/coda/coda_linux.c:137: warning: large integer implicitly truncated to unsigned type Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29coda: add static to functions in dir.cHarvey Harrison
coda_unlink, coda_rmdir, coda_readdir can all be static, the forward declarations already were. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Introduce path_put()Jan Blunck
* Add path_put() functions for releasing a reference to the dentry and vfsmount of a struct path in the right order * Switch from path_release(nd) to path_put(&nd->path) * Rename dput_path() to path_put_conditional() [akpm@linux-foundation.org: fix cifs] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: <linux-fsdevel@vger.kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Embed a struct path into struct nameidata instead of nd->{dentry,mnt}Jan Blunck
This is the central patch of a cleanup series. In most cases there is no good reason why someone would want to use a dentry for itself. This series reflects that fact and embeds a struct path into nameidata. Together with the other patches of this series - it enforced the correct order of getting/releasing the reference count on <dentry,vfsmount> pairs - it prepares the VFS for stacking support since it is essential to have a struct path in every place where the stack can be traversed - it reduces the overall code size: without patch series: text data bss dec hex filename 5321639 858418 715768 6895825 6938d1 vmlinux with patch series: text data bss dec hex filename 5320026 858418 715768 6894212 693284 vmlinux This patch: Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix cifs] [akpm@linux-foundation.org: fix smack] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-24coda: convert struct class_device to struct deviceKay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Tony Jones <tonyj@suse.de> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-19pid namespaces: round up the APIPavel Emelianov
The set of functions process_session, task_session, process_group and task_pgrp is confusing, as the names can be mixed with each other when looking at the code for a long time. The proposals are to * equip the functions that return the integer with _nr suffix to represent that fact, * and to make all functions work with task (not process) by making the common prefix of the same name. For monotony the routines signal_session() and set_signal_session() are replaced with task_session_nr() and set_task_session(), especially since they are only used with the explicit task->signal dereference. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21coda: remove CODA_STORE/CODA_RELEASE upcallsJan Harkes
This is an variation on the patch sent by Christoph Hellwig which kills file_count abuse by the Coda kernel module by moving the coda_flush functionality into coda_release. However part of reason we were using the coda_flush callback was to allow Coda to pass errors that occur during writeback from the userspace cache manager back to close(). As Al Viro explained on linux-fsdevel, it is impossible to guarantee that such errors can in fact be returned back to the caller. There are many cases where the last reference to a file is not released by the close system call and it is also impossible to pick some close as a 'last-close' and delay it until all other references have been destroyed. The CODA_STORE/CODA_RELEASE upcall combination is clearly a broken design, and it is better to remove it completely. Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ftp.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19coda breakageAl Viro
a) switch by loff_t == __cmpdi2 use. Replaced with a couple of obvious ifs; update of ->f_pos in the first one makes sure that we do the right thing in all cases. b) block_signals() and unblock_signals() are globals on UML. Renamed coda ones; in principle UML probably ought to do rename as well, but that's another story. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19coda: update module informationJan Harkes
Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
