path: root/fs/coda
2017-11-24coda: fix 'kernel memory exposure attempt' in fsyncJan Harkes
commit d337b66a4c52c7b04eec661d86c2ef6e168965a2 upstream. When an application called fsync on a file in Coda a small request with just the file identifier was allocated, but the declared length was set to the size of union of all possible upcall requests. This bug has been around for a very long time and is now caught by the extra checking in usercopy that was introduced in Linux-4.8. The exposure happens when the Coda cache manager process reads the fsync upcall request at which point it is killed. As a result there is nobody servicing any further upcalls, trapping any processes that try to access the mounted Coda filesystem. Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: ">rename2() work from Miklos + current_time() from Deepa" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs: Replace current_fs_time() with current_time() fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps fs: Replace CURRENT_TIME with current_time() for inode timestamps fs: proc: Delete inode time initializations in proc_alloc_inode() vfs: Add current_time() api vfs: add note about i_op->rename changes to porting fs: rename "rename2" i_op to "rename" vfs: remove unused i_op->rename fs: make remaining filesystems use .rename2 libfs: support RENAME_NOREPLACE in simple_rename() fs: support RENAME_NOREPLACE for local filesystems ncpfs: fix unused variable warning
2016-10-10Merge remote-tracking branch 'ovl/rename2' into for-linusAl Viro
2016-10-05switch generic_file_splice_read() to use of ->read_iter()Al Viro
... and kill the ->splice_read() instances that can be switched to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-27fs: Replace CURRENT_TIME_SEC with current_time() for inode timestampsDeepa Dinamani
CURRENT_TIME_SEC is not y2038 safe. current_time() will be transitioned to use 64 bit time along with vfs in a separate patch. There is no plan to transistion CURRENT_TIME_SEC to use y2038 safe time interfaces. current_time() will also be extended to use superblock range checking parameters when range checking is introduced. This works because alloc_super() fills in the the s_time_gran in super block to NSEC_PER_SEC. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-27fs: rename "rename2" i_op to "rename"Miklos Szeredi
Generated patch: sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2` sed -i "s/\brename2\b/rename/g" `git grep -wl rename2` Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-09-27fs: make remaining filesystems use .rename2Miklos Szeredi
This is trivial to do: - add flags argument to foo_rename() - check if flags is zero - assign foo_rename() to .rename2 instead of .rename This doesn't mean it's impossible to support RENAME_NOREPLACE for these filesystems, but it is not trivial, like for local filesystems. RENAME_NOREPLACE must guarantee atomicity (i.e. it shouldn't be possible for a file to be created on one host while it is overwritten by rename on another host). Filesystems converted: 9p, afs, ceph, coda, ecryptfs, kernfs, lustre, ncpfs, nfs, ocfs2, orangefs. After this, we can get rid of the duplicate interfaces for rename. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: David Howells <dhowells@redhat.com> [AFS] Acked-by: Mike Marshall <hubcap@omnibond.com> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ilya Dryomov <idryomov@gmail.com> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Cc: Tyler Hicks <tyhicks@canonical.com> Cc: Oleg Drokin <oleg.drokin@intel.com> Cc: Trond Myklebust <trond.myklebust@primarydata.com> Cc: Mark Fasheh <mfasheh@suse.com>
2016-05-29drop redundant ->owner initializationsAl Viro
it's not needed for file_operations of inodes located on fs defined in the hosting module and for file_operations that go into procfs. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-02introduce a parallel variant of ->iterate()Al Viro
New method: ->iterate_shared(). Same arguments as in ->iterate(), called with the directory locked only shared. Once all filesystems switch, the old one will be gone. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull final vfs updates from Al Viro: - The ->i_mutex wrappers (with small prereq in lustre) - a fix for too early freeing of symlink bodies on shmem (they need to be RCU-delayed) (-stable fodder) - followup to dedupe stuff merged this cycle * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: vfs: abort dedupe loop if fatal signals are pending make sure that freeing shmem fast symlinks is RCU-delayed wrappers for ->i_mutex access lustre: remove unused declaration
2016-01-22tree wide: use kvfree() than conditional kfree()/vfree()Tetsuo Handa
There are many locations that do if (memory_was_allocated_by_vmalloc) vfree(ptr); else kfree(ptr); but kvfree() can handle both kmalloc()ed memory and vmalloc()ed memory using is_vmalloc_addr(). Unless callers have special reasons, we can replace this branch with kvfree(). Please check and reply if you found problems. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Jan Kara <jack@suse.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Andreas Dilger <andreas.dilger@intel.com> Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net> Acked-by: David Rientjes <rientjes@google.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Oleg Drokin <oleg.drokin@intel.com> Cc: Boris Petkov <bp@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-22wrappers for ->i_mutex accessAl Viro
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested}, inode_foo(inode) being mutex_foo(&inode->i_mutex). Please, use those for access to ->i_mutex; over the coming cycle ->i_mutex will become rwsem, with ->lookup() done with it held only shared. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-14kmemcg: account certain kmem allocations to memcgVladimir Davydov
Mark those kmem allocations that are known to be easily triggered from userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to memcg. For the list, see below: - threadinfo - task_struct - task_delay_info - pid - cred - mm_struct - vm_area_struct and vm_region (nommu) - anon_vma and anon_vma_chain - signal_struct - sighand_struct - fs_struct - files_struct - fdtable and fdtable->full_fds_bits - dentry and external_name - inode for all filesystems. This is the most tedious part, because most filesystems overwrite the alloc_inode method. The list is far from complete, so feel free to add more objects. Nevertheless, it should be close to "account everything" approach and keep most workloads within bounds. Malevolent users will be able to breach the limit, but this was possible even with the former "account everything" approach (simply because it did not account everything in fact). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Tejun Heo <tj@kernel.org> Cc: Greg Thelen <gthelen@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-12-30switch ->get_link() to delayed_call, kill ->put_link()Al Viro
2015-12-08replace ->follow_link() with new method that could stay in RCU modeAl Viro
new method: ->get_link(); replacement of ->follow_link(). The differences are: * inode and dentry are passed separately * might be called both in RCU and non-RCU mode; the former is indicated by passing it a NULL dentry. * when called that way it isn't allowed to block and should return ERR_PTR(-ECHILD) if it needs to be called in non-RCU mode. It's a flagday change - the old method is gone, all in-tree instances converted. Conversion isn't hard; said that, so far very few instances do not immediately bail out when called in RCU mode. That'll change in the next commits. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-08don't put symlink bodies in pagecache into highmemAl Viro
kmap() in page_follow_link_light() needed to go - allowing to hold an arbitrary number of kmaps for long is a great way to deadlocking the system. new helper (inode_nohighmem(inode)) needs to be used for pagecache symlinks inodes; done for all in-tree cases. page_follow_link_light() instrumented to yell about anything missed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-09-10fs/coda: fix readlink buffer overflowJan Harkes
Dan Carpenter discovered a buffer overflow in the Coda file system readlink code. A userspace file system daemon can return a 4096 byte result which then triggers a one byte write past the allocated readlink result buffer. This does not trigger with an unmodified Coda implementation because Coda has a 1024 byte limit for symbolic links, however other userspace file systems using the Coda kernel module could be affected. Although this is an obvious overflow, I don't think this has to be handled as too sensitive from a security perspective because the overflow is on the Coda userspace daemon side which already needs root to open Coda's kernel device and to mount the file system before we get to the point that links can be read. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-23fs: cleanup slight list_entry abuseRasmus Villemoes
list_entry is just a wrapper for container_of, but it is arguably wrong (and slightly confusing) to use it when the pointed-to struct member is not a struct list_head. Use container_of directly instead. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11make new_sync_{read,write}() staticAl Viro
All places outside of core VFS that checked ->read and ->write for being NULL or called the methods directly are gone now, so NULL {read,write} with non-NULL {read,write}_iter will do the right thing in all cases. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11coda: switch to ->read_iter/->write_iterAl Viro
... and request the same from the local cache - all filesystems with anything usable for that support those already. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-22VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry)David Howells
Convert the following where appropriate: (1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry). (2) S_ISREG(dentry->d_inode) to d_is_reg(dentry). (3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more complicated than it appears as some calls should be converted to d_can_lookup() instead. The difference is whether the directory in question is a real dir with a ->lookup op or whether it's a fake dir with a ->d_automount op. In some circumstances, we can subsume checks for dentry->d_inode not being NULL into this, provided we the code isn't in a filesystem that expects d_inode to be NULL if the dirent really *is* negative (ie. if we're going to use d_inode() rather than d_backing_inode() to get the inode pointer). Note that the dentry type field may be set to something other than DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS manages the fall-through from a negative dentry to a lower layer. In such a case, the dentry type of the negative union dentry is set to the same as the type of the lower dentry. However, if you know d_inode is not NULL at the call site, then you can use the d_is_xxx() functions even in a filesystem. There is one further complication: a 0,0 chardev dentry may be labelled DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was intended for special directory entry types that don't have attached inodes. The following perl+coccinelle script was used: use strict; my @callers; open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') || die "Can't grep for S_ISDIR and co. callers"; @callers = <$fd>; close($fd); unless (@callers) { print "No matches\n"; exit(0); } my @cocci = ( '@@', 'expression E;', '@@', '', '- S_ISLNK(E->d_inode->i_mode)', '+ d_is_symlink(E)', '', '@@', 'expression E;', '@@', '', '- S_ISDIR(E->d_inode->i_mode)', '+ d_is_dir(E)', '', '@@', 'expression E;', '@@', '', '- S_ISREG(E->d_inode->i_mode)', '+ d_is_reg(E)' ); my $coccifile = "tmp.sp.cocci"; open($fd, ">$coccifile") || die $coccifile; print($fd "$_\n") || die $coccifile foreach (@cocci); close($fd); foreach my $file (@callers) { chomp $file; print "Processing ", $file, "\n"; system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 || die "spatch failed"; } [AV: overlayfs parts skipped] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-17fs/coda/dir.c: forward declaration clean-upFabian Frederick
- Move operation structures to avoid forward declarations. - Fix some checkpatch warnings: WARNING: Missing a blank line after declarations + struct inode *host_inode = file_inode(host_file); + mutex_lock(&host_inode->i_mutex); ERROR: that open brace { should be on the previous line +const struct dentry_operations coda_dentry_operations = +{ ERROR: that open brace { should be on the previous line +const struct inode_operations coda_dir_inode_operations = +{ Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-20fs: introduce f_op->mmap_capabilities for nommu mmap supportChristoph Hellwig
Since "BDI: Provide backing device capability information [try #3]" the backing_dev_info structure also provides flags for the kind of mmap operation available in a nommu environment, which is entirely unrelated to it's original purpose. Introduce a new nommu-only file operation to provide this information to the nommu mmap code instead. Splitting this from the backing_dev_info structure allows to remove lots of backing_dev_info instance that aren't otherwise needed, and entirely gets rid of the concept of providing a backing_dev_info for a character device. It also removes the need for the mtd_inodefs filesystem. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Tejun Heo <tj@kernel.org> Acked-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-12-11coda_venus_readdir(): use file_inode()Al Viro
2014-11-03move d_rcu from overlapping d_child to overlapping d_aliasAl Viro
2014-10-31new helper: is_root_inode()Al Viro
replace open-coded instances Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-08-08fs/coda: use linux/uaccess.hFabian Frederick
Fix checkpatch warning WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h> Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06coda: convert use of typedef ctl_table to struct ctl_tableJoe Perches
This typedef is unnecessary and should just be removed. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/coda: use __func__Fabian Frederick
Replace all function names by __func__ in pr_foo() Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/coda: logging prefix uniformizationFabian Frederick
- Add pr_fmt based on module name. - Remove Coda: coda: from pr_foo() Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/coda: replace printk by pr_foo()Fabian Frederick
No level printk converted to pr_warn or pr_info Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-04Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 updates from Ted Ts'o: "Major changes for 3.14 include support for the newly added ZERO_RANGE and COLLAPSE_RANGE fallocate operations, and scalability improvements in the jbd2 layer and in xattr handling when the extended attributes spill over into an external block. Other than that, the usual clean ups and minor bug fixes" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (42 commits) ext4: fix premature freeing of partial clusters split across leaf blocks ext4: remove unneeded test of ret variable ext4: fix comment typo ext4: make ext4_block_zero_page_range static ext4: atomically set inode->i_flags in ext4_set_inode_flags() ext4: optimize Hurd tests when reading/writing inodes ext4: kill i_version support for Hurd-castrated file systems ext4: each filesystem creates and uses its own mb_cache fs/mbcache.c: doucple the locking of local from global data fs/mbcache.c: change block and index hash chain to hlist_bl_node ext4: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate ext4: refactor ext4_fallocate code ext4: Update inode i_size after the preallocation ext4: fix partial cluster handling for bigalloc file systems ext4: delete path dealloc code in ext4_ext_handle_uninitialized_extents ext4: only call sync_filesystm() when remounting read-only fs: push sync_filesystem() down to the file system's remount_fs() jbd2: improve error messages for inconsistent journal heads jbd2: minimize region locked by j_list_lock in jbd2_journal_forget() jbd2: minimize region locked by j_list_lock in journal_get_create_access() ...
2014-04-03fs/coda/inode.c: add __init to init_inodecache()Fabian Frederick
init_inodecache is only called by __init init_coda Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm + fs: store shadow entries in page cacheJohannes Weiner
Reclaim will be leaving shadow entries in the page cache radix tree upon evicting the real page. As those pages are found from the LRU, an iput() can lead to the inode being freed concurrently. At this point, reclaim must no longer install shadow pages because the inode freeing code needs to ensure the page tree is really empty. Add an address_space flag, AS_EXITING, that the inode freeing code sets under the tree lock before doing the final truncate. Reclaim will check for this flag before installing shadow pages. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-13fs: push sync_filesystem() down to the file system's remount_fs()Theodore Ts'o
Previously, the no-op "mount -o mount /dev/xxx" operation when the file system is already mounted read-write causes an implied, unconditional syncfs(). This seems pretty stupid, and it's certainly documented or guaraunteed to do this, nor is it particularly useful, except in the case where the file system was mounted rw and is getting remounted read-only. However, it's possible that there might be some file systems that are actually depending on this behavior. In most file systems, it's probably fine to only call sync_filesystem() when transitioning from read-write to read-only, and there are some file systems where this is not needed at all (for example, for a pseudo-filesystem or something like romfs). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-fsdevel@vger.kernel.org Cc: Christoph Hellwig <hch@infradead.org> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Jan Kara <jack@suse.cz> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Anders Larsen <al@alarsen.net> Cc: Phillip Lougher <phillip@squashfs.org.uk> Cc: Kees Cook <keescook@chromium.org> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: xfs@oss.sgi.com Cc: linux-btrfs@vger.kernel.org Cc: linux-cifs@vger.kernel.org Cc: samba-technical@lists.samba.org Cc: codalist@coda.cs.cmu.edu Cc: linux-ext4@vger.kernel.org Cc: linux-f2fs-devel@lists.sourceforge.net Cc: fuse-devel@lists.sourceforge.net Cc: cluster-devel@redhat.com Cc: linux-mtd@lists.infradead.org Cc: jfs-discussion@lists.sourceforge.net Cc: linux-nfs@vger.kernel.org Cc: linux-nilfs@vger.kernel.org Cc: linux-ntfs-dev@lists.sourceforge.net Cc: ocfs2-devel@oss.oracle.com Cc: reiserfs-devel@vger.kernel.org
2013-11-09coda_revalidate_inode(): switch to passing inode...Al Viro
2013-10-24file->f_op is never NULL...Al Viro
2013-07-05helper for reading ->d_countAl Viro
2013-06-29coda: don't bother with find_inode_number()Al Viro
the fallback it's using for dcache misses is actually the same value we would've used for inumber anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29[readdir] convert codaAl Viro
2013-06-29[readdir] introduce ->iterate(), ctx->pos, dir_emit()Al Viro
New method - ->iterate(file, ctx). That's the replacement for ->readdir(); it takes callback from ctx->actor, uses ctx->pos instead of file->f_pos and calls dir_emit(ctx, ...) instead of filldir(data, ...). It does *not* update file->f_pos (or look at it, for that matter); iterate_dir() does the update. Note that dir_emit() takes the offset from ctx->pos (and eventually filldir_t will lose that argument). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09lift sb_start_write() out of ->write()Al Viro
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-13coda: Cache permisions in struct coda_inode_info in a kuid_t.Eric W. Biederman
- Change c_uid in struct coda_indoe_info from a vuid_t to a kuid_t. - Initialize c_uid to GLOBAL_ROOT_UID instead of 0. - Use uid_eq to compare cached kuids. Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13coda: Restrict coda messages to the initial user namespaceEric W. Biederman
Remove the slight chance that uids and gids in coda messages will be interpreted in the wrong user namespace. - Only allow processes in the initial user namespace to open the coda character device to communicate with coda filesystems. - Explicitly convert the uids in the coda header into the initial user namespace. - In coda_vattr_to_attr make kuids and kgids from the initial user namespace uids and gids in struct coda_vattr that just came from userspace. - In coda_iattr_to_vattr convert kuids and kgids into uids and gids in the intial user namespace and store them in struct coda_vattr for sending to coda userspace programs. Nothing needs to be changed with mounts as coda does not support being mounted in anything other than the initial user namespace. Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13coda: Restrict coda messages to the initial pid namespaceEric W. Biederman
Remove the slight chance that pids in coda messages will be interpreted in the wrong pid namespace. - Explicitly send all pids in coda messages in the initial pid namespace. - Only allow mounts from processes in the initial pid namespace. - Only allow processes in the initial pid namespace to open the coda character device to communicate with coda. Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
