path: root/fs/compat_ioctl.c
2009-08-07compat_ioctl: hook up compat handler for FIEMAP ioctlEric Sandeen
The FIEMAP_IOC_FIEMAP mapping ioctl was missing a 32-bit compat handler, which means that 32-bit suerspace on 64-bit kernels cannot use this ioctl command. The structure is nicely aligned, padded, and sized, so it is just this simple. Tested w/ 32-bit ioctl tester (from Josef) on a 64-bit kernel on ext4. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: <linux-ext4@vger.kernel.org> Cc: Mark Lord <lkml@rtr.ca> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Josef Bacik <josef@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24fs: Add new pre-allocation ioctls to vfs for compatibility with legacy xfs ↵Ankit Jain
ioctls This patch adds ioctls to vfs for compatibility with legacy XFS pre-allocation ioctls (XFS_IOC_*RESVP*). The implementation effectively invokes sys_fallocate for the new ioctls. Also handles the compat_ioctl case. Note: These legacy ioctls are also implemented by OCFS2. [AV: folded fixes from hch] Signed-off-by: Ankit Jain <me@ankitjain.org> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-22Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (63 commits) mtd: OneNAND: Allow setting of boundary information when built as module jffs2: leaking jffs2_summary in function jffs2_scan_medium mtd: nand: Fix memory leak on txx9ndfmc probe failure. mtd: orion_nand: use burst reads with double word accesses mtd/nand: s3c6400 support for s3c2410 driver [MTD] [NAND] S3C2410: Use DIV_ROUND_UP [MTD] [NAND] S3C2410: Deal with unaligned lengths in S3C2440 buffer read/write [MTD] [NAND] S3C2410: Allow the machine code to get the BBT table from NAND [MTD] [NAND] S3C2410: Added a kerneldoc for s3c2410_nand_set mtd: physmap_of: Add multiple regions and concatenation support mtd: nand: max_retries off by one in mxc_nand mtd: nand: s3c2410_nand_setrate(): use correct macros for 2412/2440 mtd: onenand: add bbt_wait & unlock_all as replaceable for some platform mtd: Flex-OneNAND support mtd: nand: add OMAP2/OMAP3 NAND driver mtd: maps: Blackfin async: fix memory leaks in probe/remove funcs mtd: uclinux: mark local stuff static mtd: uclinux: do not allow to be built as a module mtd: uclinux: allow systems to override map addr/size mtd: blackfin NFC: fix hang when using NAND on BF527-EZKITs ...
2009-06-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: [SCSI] aic79xx: make driver respect nvram for IU and QAS settings [SCSI] don't attach ULD to Dell Universal Xport [SCSI] lpfc 8.3.3 : Update driver version to 8.3.3 [SCSI] lpfc 8.3.3 : Add support for Target Reset handler entrypoint [SCSI] lpfc 8.3.3 : Fix a couple of spin_lock and memory issues and a crash [SCSI] lpfc 8.3.3 : FC/FCOE discovery fixes [SCSI] lpfc 8.3.3 : Fix various SLI-3 vs SLI-4 differences [SCSI] qla2xxx: Resolve a performance issue in interrupt [SCSI] cnic, bnx2i: Fix build failure when CONFIG_PCI is not set. [SCSI] nsp_cs: time_out reaches -1 [SCSI] qla2xxx: fix printk format warnings [SCSI] ncr53c8xx: div reaches -1 [SCSI] compat: don't perform unneeded copy in sg_io code [SCSI] zfcp: Update FC pass-through support [SCSI] zfcp: Add FC pass-through support [SCSI] FC Pass Thru support
2009-06-15[SCSI] compat: don't perform unneeded copy in sg_io codeAlexey Zaytsev
The members from 'status' in struct sg_io_hdr to the last are used to transfer information from kernel to user space. The values that user space sets are just ignored. Signed-off-by: Alexey Zaytsev <alexey.zaytsev@gmail.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-12trivial: fix typo compatiable/compatiability has extra 'a'.Thadeu Lima de Souza Cascardo
2009-05-29mtd: Handle compat ioctls directly; remove all trace from compat_ioctl.cKevin Cernekee
Remove all references to MTD ioctls from fs/compat_ioctl.c and let them all be handled by mtd_compat_ioctl(). Signed-off-by: Kevin Cernekee <kpc.mtd@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-05-29mtd: add OOB ioctls for >4GiB devicesKevin Cernekee
2009-05-29mtd: compat_ioctl cleanupKevin Cernekee
1) Move the MEMREADOOB/MEMWRITEOOB compat_ioctl wrappers from fs/compat_ioctl.c into mtdchar.c . Original request was here: http://lkml.org/lkml/2009/4/1/295 2) Add missing COMPATIBLE_IOCTL lines, so that mtd-utils does not error out when running in 64/32 compatibility mode. LKML-Reference: <200904011650.22928.arnd@arndb.de> Signed-off-by: Kevin Cernekee <kpc.mtd@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-05-29mtd: add MEMERASE64 ioctl for >4GiB devicesKevin Cernekee
New MEMERASE/MEMREADOOB/MEMWRITEOOB ioctls are needed in order to support 64-bit offsets into large NAND flash devices. Signed-off-by: Kevin Cernekee <kpc.mtd@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-20fs/compat_ioctl: fix build when !BLOCKAlexander Beregalov
In file included from fs/compat_ioctl.c:61: include/linux/loop.h:59: error: field 'lo_bio_list' has incomplete type Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-03Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: (53 commits) md/raid5 revise rules for when to update metadata during reshape md/raid5: minor code cleanups in make_request. md: remove CONFIG_MD_RAID_RESHAPE config option. md/raid5: be more careful about write ordering when reshaping. md: don't display meaningless values in sysfs files resync_start and sync_speed md/raid5: allow layout and chunksize to be changed on active array. md/raid5: reshape using largest of old and new chunk size md/raid5: prepare for allowing reshape to change layout md/raid5: prepare for allowing reshape to change chunksize. md/raid5: clearly differentiate 'before' and 'after' stripes during reshape. Documentation/md.txt update md: allow number of drives in raid5 to be reduced md/raid5: change reshape-progress measurement to cope with reshaping backwards. md: add explicit method to signal the end of a reshape. md/raid5: enhance raid5_size to work correctly with negative delta_disks md/raid5: drop qd_idx from r6_state md/raid6: move raid6 data processing to raid6_pq.ko md: raid5 run(): Fix max_degraded for raid level 4. md: 'array_size' sysfs attribute md: centralize ->array_sectors modifications ...
2009-03-31md: move lots of #include lines out of .h files and into .cNeilBrown
This makes the includes more explicit, and is preparation for moving md_k.h to drivers/md/md.h Remove include/raid/md.h as its only remaining use was to #include other files. Signed-off-by: NeilBrown <neilb@suse.de>
2009-03-01Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-tx.c net/8021q/vlan_core.c net/core/dev.c
2009-02-27Fix FREEZE/THAW compat_ioctl regressionChristoph Hellwig
Commit 8e961870bb9804110d5c8211d5d9d500451c4518 removed the FREEZE/THAW handling in xfs_compat_ioctl but never added any compat handler back, so now any freeze/thaw request from a 32-bit binary ond 64-bit userspace will fail. As these ioctls are 32/64-bit compatible two simple COMPATIBLE_IOCTL entries in fs/compat_ioctl.c will do the job. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-24Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2009-02-18vt: Declare PIO_CMAP/GIO_CMAP as compatbile ioctls.Bill Nottingham
Otherwise, these don't work when called from 32-bit userspace on 64-bit kernels. Cc: Jiri Kosina <jkosina@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x, 2.6.27.x, 2.6.28.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-15net: pass new SIOCSHWTSTAMP through to device driversPatrick Ohly
Signed-off-by: Patrick Ohly <patrick.ohly@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-14Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/wireless/iwlwifi/iwl-agn.c drivers/net/wireless/iwlwifi/iwl3945-base.c
2009-02-05tun: Limit amount of queued packets per deviceHerbert Xu
Unlike a normal socket path, the tuntap device send path does not have any accounting. This means that the user-space sender may be able to pin down arbitrary amounts of kernel memory by continuing to send data to an end-point that is congested. Even when this isn't an issue because of limited queueing at most end points, this can also be a problem because its only response to congestion is packet loss. That is, when those local queues at the end-point fills up, the tuntap device will start wasting system time because it will continue to send data there which simply gets dropped straight away. Of course one could argue that everybody should do congestion control end-to-end, unfortunately there are people in this world still hooked on UDP, and they don't appear to be going away anywhere fast. In fact, we've always helped them by performing accounting in our UDP code, the sole purpose of which is to provide congestion feedback other than through packet loss. This patch attempts to apply the same bandaid to the tuntap device. It creates a pseudo-socket object which is used to account our packets just as a normal socket does for UDP. Of course things are a little complex because we're actually reinjecting traffic back into the stack rather than out of the stack. The stack complexities however should have been resolved by preceding patches. So this one can simply start using skb_set_owner_w. For now the accounting is essentially disabled by default for backwards compatibility. In particular, we set the cap to INT_MAX. This is so that existing applications don't get confused by the sudden arrival EAGAIN errors. In future we may wish (or be forced to) do this by default. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-05braino in sg_ioctl_trans()Al Viro
... and yes, gcc is insane enough to eat that without complaint. We probably want sparse to scream on those... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29tun: Add some missing TUN compat ioctl translations.David S. Miller
Based upon a report from Michael Tokarev <mjt@tls.msk.ru>: Just saw in dmesg: ioctl32(kvm:4408): Unknown cmd fd(9) cmd(800454cf){t:'T';sz:4} arg(ffc668e4) on /dev/net/tun Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25remove unused #include <linux/dirent.h>'sAdrian Bunk
Remove some unused #include <linux/dirent.h>'s. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24autofs4: remove unused ioctlsIan Kent
The ioctls AUTOFS_IOC_TOGGLEREGHOST and AUTOFS_IOC_ASKREGHOST were added several years ago but what they were intended for has never been implemented (as far as I'm aware noone uses them) so remove them. Signed-off-by: Ian Kent <raven@themaw.net> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-19Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-2.6
2008-07-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/powerpc/booting-without-of.txt drivers/atm/Makefile drivers/net/fs_enet/fs_enet-main.c drivers/pci/pci-acpi.c net/8021q/vlan.c net/iucv/iucv.c
2008-07-16Fix compile issues in fs/compat_ioctl.c when CONFIG_BLOCK is disabledRandy Dunlap
Fix fs/compat_ioctl.c to handle CONFIG_BLOCK=n, CONFIG_SCSI=n to avoid build errors: In file included from include/scsi/scsi.h:12, from fs/compat_ioctl.c:71: include/scsi/scsi_cmnd.h:27:25: warning: "BLK_MAX_CDB" is not defined include/scsi/scsi_cmnd.h:28:3: error: #error MAX_COMMAND_SIZE can not be bigger than BLK_MAX_CDB In file included from include/scsi/scsi.h:12, from fs/compat_ioctl.c:71: include/scsi/scsi_cmnd.h: In function 'scsi_bidi_cmnd': include/scsi/scsi_cmnd.h:182: error: implicit declaration of function 'blk_bidi_rq' include/scsi/scsi_cmnd.h:183: error: dereferencing pointer to incomplete type include/scsi/scsi_cmnd.h: In function 'scsi_in': include/scsi/scsi_cmnd.h:189: error: dereferencing pointer to incomplete type Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-14[Bluetooth] Export details about authentication requirementsMarcel Holtmann
With the Simple Pairing support, the authentication requirements are an explicit setting during the bonding process. Track and enforce the requirements and allow higher layers like L2CAP and RFCOMM to increase them if needed. This patch introduces a new IOCTL that allows to query the current authentication requirements. It is also possible to detect Simple Pairing support in the kernel this way. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-06-16wext: Remove compat handling from fs/compat_ioctl.cDavid S. Miller
No longer used. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16wext: Dispatch and handle compat ioctls entirely in net/wireless/wext.cDavid S. Miller
Next we can kill the hacks in fs/compat_ioctl.c and also dispatch compat ioctls down into the driver and 80211 protocol helper layers in order to handle iw_point objects embedded in stream replies which need to be translated. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-30tty: The big operations reworkAlan Cox
- Operations are now a shared const function block as with most other Linux objects - Introduce wrappers for some optional functions to get consistent behaviour - Wrap put_char which used to be patched by the tty layer - Document which functions are needed/optional - Make put_char report success/fail - Cache the driver->ops pointer in the tty as tty->ops - Remove various surplus lock calls we no longer need - Remove proc_write method as noted by Alexey Dobriyan - Introduce some missing sanity checks where certain driver/ldisc combinations would oops as they didn't check needed methods were present [akpm@linux-foundation.org: fix fs/compat_ioctl.c build] [akpm@linux-foundation.org: fix isicom] [akpm@linux-foundation.org: fix arch/ia64/hp/sim/simserial.c build] [akpm@linux-foundation.org: fix kgdb] Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty: BKL pushdownAlan Cox
- Push the BKL down into the line disciplines - Switch the tty layer to unlocked_ioctl - Introduce a new ctrl_lock spin lock for the control bits - Eliminate much of the lock_kernel use in n_tty - Prepare to (but don't yet) call the drivers with the lock dropped on the paths that historically held the lock BKL now primarily protects open/close/ldisc change in the tty layer [jirislaby@gmail.com: a couple of fixes] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14d_path: Make d_path() use a struct pathJan Blunck
d_path() is used on a <dentry,vfsmount> pair. Lets use a struct path to reflect this. [akpm@linux-foundation.org: fix build in mm/memory.c] Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08dm ioctl: move compat codeMilan Broz
Move compat_ioctl handling into dm-ioctl.c. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-02-07VFS: swap do_ioctl and vfs_ioctl namesErez Zadok
Rename old vfs_ioctl to do_ioctl, because the comment above it clearly indicates that it is an internal function not to be exported to modules; therefore it should have a more traditional do_XXX name. The new do_ioctl is exported in fs.h but not to modules. Rename the old do_ioctl to vfs_ioctl because the names vfs_XXX should preferably be reserved to callable VFS functions which modules may call, as many other vfs_XXX functions already do. Export the new vfs_ioctl to GPL modules so others can use it (including Unionfs and eCryptfs). Add DocBook for new vfs_ioctl. [akpm@linux-foundation.org: fix build] Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28remove __attribute_used__Adrian Bunk
Remove the deprecated __attribute_used__. [Introduce __section in a few places to silence checkpatch /sam] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-06fix: using joysticks in 32 bit applications on 64 bit systemsAkos Maroy
unfortunately 32 bit apps don't see the joysticks on a 64 bit system. this prevents one playing X-Plane (http://www.x-plane.com/) or other 32-bit games with joysticks. this is a known issue, and already raised several times: http://readlist.com/lists/vger.kernel.org/linux-kernel/28/144411.html http://www.brettcsmith.org/wiki/wiki.cgi?action=browse&diff=1&id=OzyComputer/Joystick unfortunately this is still not fixed in the mainline kernel. it would be nice to have this fixed, so that people can play these games without having to patch their kernel. the following patch solves the problem on 2.6.22. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29tty: add the new termios2 ioctls to the compatible list.Heiko Carstens
Make them depend on TCGETS2. If that one is implemented the rest should be there as well. Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-30[COMPAT]: Fix new dev_ifname32 returning -EFAULTBenjamin Herrenschmidt
A stray semicolon slipped in the patch that updated dev_ifname32 to not be inline, causing it to always return -EFAULT. This fixes it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-18sparse pointer use of zero as nullStephen Hemminger
Get rid of sparse related warnings from places that use integer as NULL pointer. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Andi Kleen <ak@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Ian Kent <raven@themaw.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Clean up duplicate includes in fs/Jesper Juhl
This patch cleans up duplicate includes in fs/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (867 commits) [SKY2]: status polling loop (post merge) [NET]: Fix NAPI completion handling in some drivers. [TCP]: Limit processing lost_retrans loop to work-to-do cases [TCP]: Fix lost_retrans loop vs fastpath problems [TCP]: No need to re-count fackets_out/sacked_out at RTO [TCP]: Extract tcp_match_queue_to_sack from sacktag code [TCP]: Kill almost unused variable pcount from sacktag [TCP]: Fix mark_head_lost to ignore R-bit when trying to mark L [TCP]: Add bytes_acked (ABC) clearing to FRTO too [IPv6]: Update setsockopt(IPV6_MULTICAST_IF) to support RFC 3493, try2 [NETFILTER]: x_tables: add missing ip6t_modulename aliases [NETFILTER]: nf_conntrack_tcp: fix connection reopening [QETH]: fix qeth_main.c [NETLINK]: fib_frontend build fixes [IPv6]: Export userland ND options through netlink (RDNSS support) [9P]: build fix with !CONFIG_SYSCTL [NET]: Fix dev_put() and dev_hold() comments [NET]: make netlink user -> kernel interface synchronious [NET]: unify netlink kernel socket recognition [NET]: cleanup 3rd argument in netlink_sendskb ... Fix up conflicts manually in Documentation/feature-removal-schedule.txt and my new least favourite crap, the "mod_devicetable" support in the files include/linux/mod_devicetable.h and scripts/mod/file2alias.c. (The latter files seem to be explicitly _designed_ to get conflicts when different subsystems work with them - that have an absolutely horrid lack of subsystem separation!) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[NET]: Don't implement dev_ifname32 inlineEric W. Biederman
The current implementation of dev_ifname makes maintenance difficult because updates to the implementation of the ioctl have to made in two places. So this patch updates dev_ifname32 to do a classic 32/64 structure conversion and call sys_ioctl like the rest of the compat calls do. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10compat_ioctl: move floppy handlers to block/compat_ioctl.cArnd Bergmann
The floppy ioctls are used by multiple drivers, so they should be handled in a shared location. Also, add minor cleanups. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: move cdrom handlers to block/compat_ioctl.cArnd Bergmann
These are shared by all cd-rom drivers and should have common handlers. Do slight cosmetic cleanups in the process. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: move BLKPG handling to block/compat_ioctl.cArnd Bergmann
BLKPG is common to all block devices, so it should be handled by common code. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: move hdio calls to block/compat_ioctl.cArnd Bergmann
These are common to multiple block drivers, so they should be handled by the block layer. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: handle blk_trace ioctlsArnd Bergmann
blk_trace_setup is broken on x86_64 compat systems, this makes the code work correctly on all 64 bit architectures in compat mode. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: add compat_blkdev_driver_ioctl()Arnd Bergmann
Handle those blockdev ioctl calls that are compatible directly from the compat_blkdev_ioctl() function, instead of having to go through the compat_ioctl hash lookup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
