path: root/fs/compat_ioctl.c
2020-01-12fix compat handling of FICLONERANGE, FIDEDUPERANGE and FS_IOC_FIEMAPAl Viro
commit 6b2daec19094a90435abe67d16fb43b1a5527254 upstream. Unlike FICLONE, all of those take a pointer argument; they do need compat_ptr() applied to arg. Fixes: d79bdd52d8be ("vfs: wire up compat ioctl for CLONE/CLONE_RANGE") Fixes: 54dbc1517237 ("vfs: hoist the btrfs deduplication ioctl to the vfs") Fixes: ceac204e1da9 ("fs: make fiemap work from compat_ioctl") Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-25media: dvb: fix compat ioctl translationArnd Bergmann
[ Upstream commit 1ccbeeb888ac33627d91f1ccf0b84ef3bcadef24 ] The VIDEO_GET_EVENT and VIDEO_STILLPICTURE was added back in 2005 but it never worked because the command number is wrong. Using the right command number means we have a better chance of them actually doing the right thing, though clearly nobody has ever tried it successfully. I noticed these while auditing the remaining users of compat_time_t for y2038 bugs. This one is fine in that regard, it just never did anything. Fixes: 6e87abd0b8cb ("[DVB]: Add compat ioctl handling.") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-08-11compat_ioctl: pppoe: fix PPPOEIOCSFWD handlingArnd Bergmann
[ Upstream commit 055d88242a6046a1ceac3167290f054c72571cd9 ] Support for handling the PPPOEIOCSFWD ioctl in compat mode was added in linux-2.5.69 along with hundreds of other commands, but was always broken sincen only the structure is compatible, but the command number is not, due to the size being sizeof(size_t), or at first sizeof(sizeof((struct sockaddr_pppox)), which is different on 64-bit architectures. Guillaume Nault adds: And the implementation was broken until 2016 (see 29e73269aa4d ("pppoe: fix reference counting in PPPoE proxy")), and nobody ever noticed. I should probably have removed this ioctl entirely instead of fixing it. Clearly, it has never been used. Fix it by adding a compat_ioctl handler for all pppoe variants that translates the command number and then calls the regular ioctl function. All other ioctl commands handled by pppoe are compatible between 32-bit and 64-bit, and require compat_ptr() conversion. This should apply to all stable kernels. Acked-by: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08fs: compat: Remove warning from COMPATIBLE_IOCTLMark Charlebois
commit 9280cdd6fe5b8287a726d24cc1d558b96c8491d7 upstream. cmd in COMPATIBLE_IOCTL is always a u32, so cast it so there isn't a warning about an overflow in XFORM. From: Mark Charlebois <charlebm@gmail.com> Signed-off-by: Mark Charlebois <charlebm@gmail.com> Signed-off-by: Behan Webster <behanw@converseincode.com> Signed-off-by: Matthias Kaehlcke <mka@chromium.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Chancellor <natechancellor@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24fs: compat_ioctl: add pretimeout functions for watchdogsWolfram Sang
Watchdog core now handles those ioctls centrally, so we want 64 bit support, too. Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: linux-fsdevel@vger.kernel.org Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Acked-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2016-06-28[media] cec: add compat32 ioctl supportHans Verkuil
The CEC ioctls didn't have compat32 support, so they returned -ENOTTY when used in a 32 bit application on a 64 bit kernel. Since all the CEC ioctls are 32-bit compatible adding support for this API is trivial. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-02-14Merge 4.5-rc4 into char-misc-nextGreg Kroah-Hartman
We want those fixes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-08fs/compat: remove useless compat ioctl for parport deviceBamvor Jian Zhang
Compat ioctl is already introduced in drivers/char/ppdev.c in order to fix y2038 issue for PP[GS]ETTIME. There is no need to define these here. Suggested-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com> Signed-off-by: Bamvor Jian Zhang <bamvor.zhangjian@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-01-27Bluetooth: Add missing COMPATIBLE_IOCTL for UART line disciplineMarcel Holtmann
The HCIUARTGETDEVICE, HCIUARTSETFLAGS and HCIUARTGETFLAGS ioctl are missing the COMPATIBLE_IOCTL declaration. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2016-01-12Merge branch 'work.misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc vfs updates from Al Viro: "All kinds of stuff. That probably should've been 5 or 6 separate branches, but by the time I'd realized how large and mixed that bag had become it had been too close to -final to play with rebasing. Some fs/namei.c cleanups there, memdup_user_nul() introduction and switching open-coded instances, burying long-dead code, whack-a-mole of various kinds, several new helpers for ->llseek(), assorted cleanups and fixes from various people, etc. One piece probably deserves special mention - Neil's lookup_one_len_unlocked(). Similar to lookup_one_len(), but gets called without ->i_mutex and tries to avoid ever taking it. That, of course, means that it's not useful for any directory modifications, but things like getting inode attributes in nfds readdirplus are fine with that. I really should've asked for moratorium on lookup-related changes this cycle, but since I hadn't done that early enough... I *am* asking for that for the coming cycle, though - I'm going to try and get conversion of i_mutex to rwsem with ->lookup() done under lock taken shared. There will be a patch closer to the end of the window, along the lines of the one Linus had posted last May - mechanical conversion of ->i_mutex accesses to inode_lock()/inode_unlock()/inode_trylock()/ inode_is_locked()/inode_lock_nested(). To quote Linus back then: ----- | This is an automated patch using | | sed 's/mutex_lock(&\(.*\)->i_mutex)/inode_lock(\1)/' | sed 's/mutex_unlock(&\(.*\)->i_mutex)/inode_unlock(\1)/' | sed 's/mutex_lock_nested(&\(.*\)->i_mutex,[ ]*I_MUTEX_\([A-Z0-9_]*\))/inode_lock_nested(\1, I_MUTEX_\2)/' | sed 's/mutex_is_locked(&\(.*\)->i_mutex)/inode_is_locked(\1)/' | sed 's/mutex_trylock(&\(.*\)->i_mutex)/inode_trylock(\1)/' | | with a very few manual fixups ----- I'm going to send that once the ->i_mutex-affecting stuff in -next gets mostly merged (or when Linus says he's about to stop taking merges)" * 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) nfsd: don't hold i_mutex over userspace upcalls fs:affs:Replace time_t with time64_t fs/9p: use fscache mutex rather than spinlock proc: add a reschedule point in proc_readfd_common() logfs: constify logfs_block_ops structures fcntl: allow to set O_DIRECT flag on pipe fs: __generic_file_splice_read retry lookup on AOP_TRUNCATED_PAGE fs: xattr: Use kvfree() [s390] page_to_phys() always returns a multiple of PAGE_SIZE nbd: use ->compat_ioctl() fs: use block_device name vsprintf helper lib/vsprintf: add %*pg format specifier fs: use gendisk->disk_name where possible poll: plug an unused argument to do_poll amdkfd: don't open-code memdup_user() cdrom: don't open-code memdup_user() rsxx: don't open-code memdup_user() mtip32xx: don't open-code memdup_user() [um] mconsole: don't open-code memdup_user_nul() [um] hostaudio: don't open-code memdup_user() ...
2016-01-12Merge branch 'work.copy_file_range' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs copy_file_range updates from Al Viro: "Several series around copy_file_range/CLONE" * 'work.copy_file_range' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: btrfs: use new dedupe data function pointer vfs: hoist the btrfs deduplication ioctl to the vfs vfs: wire up compat ioctl for CLONE/CLONE_RANGE cifs: avoid unused variable and label nfsd: implement the NFSv4.2 CLONE operation nfsd: Pass filehandle to nfs4_preprocess_stateid_op() vfs: pull btrfs clone API to vfs layer locks: new locks_mandatory_area calling convention vfs: Add vfs_copy_file_range() support for pagecache copies btrfs: add .copy_file_range file operation x86: add sys_copy_file_range to syscall tables vfs: add copy_file_range syscall and vfs helper
2016-01-08nbd: use ->compat_ioctl()Al Viro
2016-01-08compat_ioctl: don't call do_ioctl under set_fs(KERNEL_DS)Jann Horn
This replaces all code in fs/compat_ioctl.c that translated ioctl arguments into a in-kernel structure, then performed do_ioctl under set_fs(KERNEL_DS), with code that allocates data on the user stack and can call the VFS ioctl handler under USER_DS. This is done as a hardening measure because the caller does not know what kind of ioctl handler will be invoked, only that no corresponding compat_ioctl handler exists and what the ioctl command number is. The accidental invocation of an unlocked_ioctl handler that unexpectedly calls copy_to_user could be a severe security issue. Signed-off-by: Jann Horn <jann@thejh.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-08compat_ioctl: don't pass fd around when not neededAl Viro
2016-01-08compat_ioctl: don't look up the fd twiceJann Horn
In code in fs/compat_ioctl.c that translates ioctl arguments into a in-kernel structure, then performs sys_ioctl, possibly under set_fs(KERNEL_DS), this commit changes the sys_ioctl calls to do_ioctl calls. do_ioctl is a new function that does the same thing as sys_ioctl, but doesn't look up the fd again. This change is made to avoid (potential) security issues because of ioctl handlers that accept one of the ioctl commands I2C_FUNCS, VIDEO_GET_EVENT, MTIOCPOS, MTIOCGET, TIOCGSERIAL, TIOCSSERIAL, RTC_IRQP_READ, RTC_EPOCH_READ. This can happen for multiple reasons: - The ioctl command number could be reused. - The ioctl handler might not check the full ioctl command. This is e.g. true for drm_ioctl. - The ioctl handler is very special, e.g. cuse_file_ioctl The real issue is that set_fs(KERNEL_DS) is used here, but that's fixed in a separate commit "compat_ioctl: don't call do_ioctl under set_fs(KERNEL_DS)". This change mitigates potential security issues by preventing a race that permits invocation of unlocked_ioctl handlers under KERNEL_DS through compat code even if a corresponding compat_ioctl handler exists. So far, no way has been identified to use this to damage kernel memory without having CAP_SYS_ADMIN in the init ns (with the capability, doing reads/writes at arbitrary kernel addresses should be easy through CUSE's ioctl handler with FUSE_IOCTL_UNRESTRICTED set). [AV: two missed sys_ioctl() taken care of] Signed-off-by: Jann Horn <jann@thejh.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-01vfs: hoist the btrfs deduplication ioctl to the vfsDarrick J. Wong
Hoist the btrfs EXTENT_SAME ioctl up to the VFS and make the name more systematic (FIDEDUPERANGE). Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-01vfs: wire up compat ioctl for CLONE/CLONE_RANGEDarrick J. Wong
2015-10-23i2c-dev: Fix typo in ioctl name referenceJean Delvare
The ioctl is named I2C_RDWR for "I2C read/write". But references to it were misspelled "rdrw". Fix them. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2015-07-09ioctl_compat: handle FITRIMMikulas Patocka
The FITRIM ioctl has the same arguments on 32-bit and 64-bit architectures, so we can add it to the list of compatible ioctls and drop it from compat_ioctl method of various filesystems. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ted Ts'o <tytso@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-03Bluetooth: bnep: Add support for get bnep features via ioctlGrzegorz Kolodziejczyk
This is needed if user space wants to know supported bnep features by kernel, e.g. if kernel supports sending response to bnep setup control message. By now there is no possibility to know supported features by kernel in case of bnep. Ioctls allows only to add connection, delete connection, get connection list, get connection info. Adding connection if it's possible (establishing network device connection) is equivalent to starting bnep session. Bnep session handles data queue of transmit, receive messages over bnep channel. It means that if we add connection the received/transmitted data will be parsed immediately. In case of get bnep features we want to know before session start, if we should leave setup data on socket queue and let kernel to handle with it, or in case of no setup handling support, if we should pull this message and handle setup response within user space. Signed-off-by: Grzegorz Kolodziejczyk <grzegorz.kolodziejczyk@tieto.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-07-11Bluetooth: Move HCI socket definitions into its own header fileMarcel Holtmann
All the HCI sockets and ioctl based definitions have been in a global header file that also includes all the HCI protocol structures. To make this a bit cleaner, move them into its own file. This also adjusts fs/compat_ioctl.c to only include this new file and not all the protocol structures that are not needed. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2014-03-06fs/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter typesHeiko Carstens
Some fs compat system calls have unsigned long parameters instead of compat_ulong_t. In order to allow the COMPAT_SYSCALL_DEFINE macro generate code that performs proper zero and sign extension convert all 64 bit parameters their corresponding 32 bit counterparts. compat_sys_io_getevents() is a bit different: the non-compat version has signed parameters for the "min_nr" and "nr" parameters while the compat version has unsigned parameters. So change this as well. For all practical purposes this shouldn't make any difference (doesn't fix a real bug). Also introduce a generic compat_aio_context_t type which can be used everywhere. The access_ok() check within compat_sys_io_getevents() got also removed since the non-compat sys_io_getevents() should be able to handle everything anyway. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2014-01-21fs/compat_ioctl.c: fix an underflow issue (harmless)Dan Carpenter
We cap "nmsgs" at I2C_RDRW_IOCTL_MAX_MSGS (42) but the current code allows negative values. It's harmless but it makes my static checker upset so I've made nsmgs unsigned. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-24file->f_op is never NULL...Al Viro
2013-06-29compat.c: LOOP_CLR_FD is taken care of in loop.c itself...Al Viro
2013-05-04Removed unused typedef to avoid "unused local typedef" warnings.Han Shen
Fix warnings about unused local typedefs (reported by gcc 4.8). Signed-off-by: Han Shen (shenhan@google.com) Change-Id: I4bccc234f1390daa808d2b309ed112e20c0ac096 Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22new helper: file_inode(file)Al Viro
2012-10-29Merge 3.7-rc3 into tty-nextGreg Kroah-Hartman
This merges the tty changes in 3.7-rc3 into tty-next Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-25fs/compat_ioctl.c: VIDEO_SET_SPU_PALETTE missing error checkKees Cook
The compat ioctl for VIDEO_SET_SPU_PALETTE was missing an error check while converting ioctl arguments. This could lead to leaking kernel stack contents into userspace. Patch extracted from existing fix in grsecurity. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: David Miller <davem@davemloft.net> Cc: Brad Spengler <spender@grsecurity.net> Cc: PaX Team <pageexec@freemail.hu> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-25tty, ioctls -- Add new ioctl definitions for tty flags fetchingCyrill Gorcunov
This patch defines new ioctl codes TIOCGPKT, TIOCGPTLCK, TIOCGEXCL for fetching pty's packet mode and locking state, and exclusive mode of tty. [ No real handlers for the codes though, this will be addressed in another patch for easier review and bisectability ] Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> CC: Alan Cox <alan@lxorguk.ukuu.org.uk> CC: "H. Peter Anvin" <hpa@zytor.com> CC: Pavel Emelyanov <xemul@parallels.com> CC: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "A few drivers were updated with device tree bindings and others got a few small cleanups and fixes." Fix trivial conflict in drivers/input/keyboard/omap-keypad.c due to changes clashing with a whitespace cleanup. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (28 commits) Input: wacom - mark Intuos5 pad as in-prox when touching buttons Input: synaptics - adjust threshold for treating position values as negative Input: hgpk - use %*ph to dump small buffer Input: gpio_keys_polled - fix dt pdata->nbuttons Input: Add KD[GS]KBDIACRUC ioctls to the compatible list Input: omap-keypad - fixed formatting Input: tegra - move platform data header Input: wacom - add support for EMR on Cintiq 24HD touch Input: s3c2410_ts - make s3c_ts_pmops const Input: samsung-keypad - use of_get_child_count() helper Input: samsung-keypad - use of_match_ptr() Input: uinput - fix formatting Input: uinput - specify exact bit sizes on userspace APIs Input: uinput - mark failed submission requests as free Input: uinput - fix race that can block nonblocking read Input: uinput - return -EINVAL when read buffer size is too small Input: uinput - take event lock when fetching events from buffer Input: get rid of MATCH_BIT() macro Input: rotary-encoder - add DT bindings Input: rotary-encoder - constify platform data pointers ...
2012-09-26switch simple cases of fget_light to fdgetAl Viro
2012-09-25compat_ioctl: Avoid using undefined RS-485 IOCTLsJaeden Amero
Wrap the use of TIOCSRS485 and TIOCGRS485 in #ifdef so that we avoid adding undefined IOCTLs to the ioctl pointer list as compatible ioctls. This change was motivated by a build error on a MIPS build. tree: git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty.git tty-next head: ac57e7f38ea6fe7358cd0b7a2f2d21aef5ab70cd commit: 84c3b84860440a9e3a3666c14112f41311b8f623 [10/16] compat_ioctl: Add RS-485 IOCTLs to the list config: mips-fuloong2e_defconfig All related error/warning messages: fs/compat_ioctl.c:869:1: error: 'TIOCSRS485' undeclared here (not in a function) fs/compat_ioctl.c:870:1: error: 'TIOCGRS485' undeclared here (not in a function) vim +869 fs/compat_ioctl.c 863 COMPATIBLE_IOCTL(TIOCSPGRP) 864 COMPATIBLE_IOCTL(TIOCGPGRP) 865 COMPATIBLE_IOCTL(TIOCGPTN) 866 COMPATIBLE_IOCTL(TIOCSPTLCK) 867 COMPATIBLE_IOCTL(TIOCSERGETLSR) 868 COMPATIBLE_IOCTL(TIOCSIG) > 869 COMPATIBLE_IOCTL(TIOCSRS485) 870 COMPATIBLE_IOCTL(TIOCGRS485) 871 #ifdef TCGETS2 872 COMPATIBLE_IOCTL(TCGETS2) Reported-by: Fengguang Wu <fengguang.wu@intel.com> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jaeden Amero <jaeden.amero@ni.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-21compat_ioctl: Add RS-485 IOCTLs to the listJaeden Amero
The RS-485 TIOCSRS485 and TIOCGRS485 ioctls are 32-bit compatible, so in order to call them on 64-bit systems from 32-bit user mode, we add them to the ioctl pointer list as compatible ioctls. Signed-off-by: Jaeden Amero <jaeden.amero@ni.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-04Input: Add KD[GS]KBDIACRUC ioctls to the compatible listMichael Schutte
Allow handling of Unicode compose sequences by 32-bit apps on a 64-bit system. The issue has been reported in <http://bugs.debian.org/540534> and <http://lists.altlinux.org/pipermail/kbd/2009-December/000235.html>. A formal check of the two affected ioctls in drivers/char/vt_ioctl.c (introduced in 04c71976) and a test using x86 kbd 1.15.1 on a so patched x86_64 kernel both confirm that KD[GS]KBDIACRUC are ioctl32() compatible. Signed-off-by: Michael Schutte <michi@uiae.at> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2012-03-24Merge tag 'module-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker: "Fix up files in fs/ and lib/ dirs to only use module.h if they really need it. These are trivial in scope vs the work done previously. We now have things where any few remaining cleanups can be farmed out to arch or subsystem maintainers, and I have done so when possible. What is remaining here represents the bits that don't clearly lie within a single arch/subsystem boundary, like the fs dir and the lib dir. Some duplicate includes arising from overlapping fixes from independent subsystem maintainer submissions are also quashed." Fix up trivial conflicts due to clashes with other include file cleanups (including some due to the previous bug.h cleanup pull). * tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: lib: reduce the use of module.h wherever possible fs: reduce the use of module.h wherever possible includecheck: delete any duplicate instances of module.h
2012-03-04ppp: Replace uses of <linux/if_ppp.h> with <linux/ppp-ioctl.h>Paul Mackerras
Since all that include/linux/if_ppp.h does is #include <linux/ppp-ioctl.h>, this replaces the occurrences of #include <linux/if_ppp.h> with #include <linux/ppp-ioctl.h>. It also corrects an error in Documentation/networking/l2tp.txt, where it referenced include/linux/if_ppp.h as the source of some definitions that are actually now defined in include/linux/if_pppol2tp.h. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-28fs: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-01-15Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (655 commits) [media] revert patch: HDIC HD29L2 DMB-TH USB2.0 reference design driver mb86a20s: Add a few more register settings at the init seq mb86a20s: Group registers into the same line [media] [PATCH] don't reset the delivery system on DTV_CLEAR [media] [BUG] it913x-fe fix typo error making SNR levels unstable [media] cx23885: Query the CX25840 during enum_input for status [media] cx25840: Add support for g_input_status [media] rc-videomate-m1f.c Rename to match remote controler name [media] drivers: media: au0828: Fix dependency for VIDEO_AU0828 [media] convert drivers/media/* to use module_platform_driver() [media] drivers: video: cx231xx: Fix dependency for VIDEO_CX231XX_DVB [media] Exynos4 JPEG codec v4l2 driver [media] doc: v4l: selection: choose pixels as units for selection rectangles [media] v4l: s5p-tv: mixer: fix setup of VP scaling [media] v4l: s5p-tv: mixer: add support for selection API [media] v4l: emulate old crop API using extended crop/compose API [media] doc: v4l: add documentation for selection API [media] doc: v4l: add binary images for selection API [media] v4l: add support for selection api [media] hd29l2: fix review findings ...
2012-01-05vfs: fix up ENOIOCTLCMD error handlingLinus Torvalds
We're doing some odd things there, which already messes up various users (see the net/socket.c code that this removes), and it was going to add yet more crud to the block layer because of the incorrect error code translation. ENOIOCTLCMD is not an error return that should be returned to user mode from the "ioctl()" system call, but it should *not* be translated as EINVAL ("Invalid argument"). It should be translated as ENOTTY ("Inappropriate ioctl for device"). That EINVAL confusion has apparently so permeated some code that the block layer actually checks for it, which is sad. We continue to do so for now, but add a big comment about how wrong that is, and we should remove it entirely eventually. In the meantime, this tries to keep the changes localized to just the EINVAL -> ENOTTY fix, and removing code that makes it harder to do the right thing. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-31[media] fs/compat_ioctl: it needs to see the DVBv3 compat stuffMauro Carvalho Chehab
Only the ioctl core should see the DVBv3 compat stuff, as its contents are not available anymore to the drivers. As fs/compat_ioctl also handles DVBv3 ioctl's, it needs those definitions: fs/compat_ioctl.c:1345: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1345: error: array type has incomplete element type fs/compat_ioctl.c:1345: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1345: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1345: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1345: error: array type has incomplete element type fs/compat_ioctl.c:1345: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1345: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1345: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1345: error: array type has incomplete element type fs/compat_ioctl.c:1345: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1345: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1345: error: initializer element is not constant fs/compat_ioctl.c:1345: error: (near initialization for ‘ioctl_pointer[462]’) fs/compat_ioctl.c:1346: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1346: error: array type has incomplete element type fs/compat_ioctl.c:1346: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1346: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1346: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1346: error: array type has incomplete element type fs/compat_ioctl.c:1346: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1346: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1346: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1346: error: array type has incomplete element type fs/compat_ioctl.c:1346: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1346: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’ fs/compat_ioctl.c:1346: error: initializer element is not constant fs/compat_ioctl.c:1346: error: (near initialization for ‘ioctl_pointer[463]’) fs/compat_ioctl.c:1347: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_event’ fs/compat_ioctl.c:1347: error: array type has incomplete element type fs/compat_ioctl.c:1347: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_event’ fs/compat_ioctl.c:1347: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_event’ fs/compat_ioctl.c:1347: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_event’ fs/compat_ioctl.c:1347: error: array type has incomplete element type fs/compat_ioctl.c:1347: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_event’ fs/compat_ioctl.c:1347: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_event’ fs/compat_ioctl.c:1347: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_event’ fs/compat_ioctl.c:1347: error: array type has incomplete element type fs/compat_ioctl.c:1347: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_event’ fs/compat_ioctl.c:1347: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_event’ fs/compat_ioctl.c:1347: error: initializer element is not constant fs/compat_ioctl.c:1347: error: (near initialization for ‘ioctl_pointer[464]’) Reported-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-08-07compat_ioctl: add compat handler for PPPIOCGL2TPSTATSFlorian Westphal
fixes following error seen on x86_64 kernel: ioctl32(openl2tpd:7480): Unknown cmd fd(14) cmd(80487436){t:'t';sz:72} arg(ffa7e6c0) on socket:[105094] The argument (struct pppol2tp_ioc_stats) uses "aligned_u64" and thus doesn't need fixups. Cc: James Chapman <jchapman@katalix.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: linux-fsdevel@vger.kernel.org Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01compat_ioctl: fix warning caused by qemuJohannes Stezenbach
On Linux x86_64 host with 32bit userspace, running qemu or even just "qemu-img create -f qcow2 some.img 1G" causes a kernel warning: ioctl32(qemu-img:5296): Unknown cmd fd(3) cmd(00005326){t:'S';sz:0} arg(7fffffff) on some.img ioctl32(qemu-img:5296): Unknown cmd fd(3) cmd(801c0204){t:02;sz:28} arg(fff77350) on some.img ioctl 00005326 is CDROM_DRIVE_STATUS, ioctl 801c0204 is FDGETPRM. The warning appears because the Linux compat-ioctl handler for these ioctls only applies to block devices, while qemu also uses the ioctls on plain files. Signed-off-by: Johannes Stezenbach <js@sig21.net> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-07Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (36 commits) serial: apbuart: Fixup apbuart_console_init() TTY: Add tty ioctl to figure device node of the system console. tty: add 'active' sysfs attribute to tty0 and console device drivers: serial: apbuart: Handle OF failures gracefully Serial: Avoid unbalanced IRQ wake disable during resume tty: fix typos/errors in tty_driver.h comments pch_uart : fix warnings for 64bit compile 8250: fix uninitialized FIFOs ip2: fix compiler warning on ip2main_pci_tbl specialix: fix compiler warning on specialix_pci_tbl rocket: fix compiler warning on rocket_pci_ids 8250: add a UPIO_DWAPB32 for 32 bit accesses 8250: use container_of() instead of casting serial: omap-serial: Add support for kernel debugger serial: fix pch_uart kconfig & build drivers: char: hvc: add arm JTAG DCC console support RS485 documentation: add 16C950 UART description serial: ifx6x60: fix memory leak serial: ifx6x60: free IRQ on error Serial: EG20T: add PCH_UART driver ... Fixed up conflicts in drivers/serial/apbuart.c with evil merge that makes the code look fairly sane (unlike either side).
2010-12-29[media] V4L1 removal: Remove linux/videodev.hMauro Carvalho Chehab
There's no sense on keeping it on 2.6.38, as nobody is using it anymore, at the kernel tree, and installing it at the userspace API. As two deprecated drivers still need it, move it to their internal directories. Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-16TTY: Add tty ioctl to figure device node of the system console.Werner Fink
This has been in the SuSE kernels for a very long time. Signed-off-by: Werner Fink <werner@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-28Merge 'staging-next' to Linus's treeGreg Kroah-Hartman
This merges the staging-next tree to Linus's tree and resolves some conflicts that were present due to changes in other trees that were affected by files here. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-19fix rawctl compat ioctls breakage on amd64 and itanicAl Viro
RAW_SETBIND and RAW_GETBIND 32bit versions are fscked in interesting ways. 1) fs/compat_ioctl.c has COMPATIBLE_IOCTL(RAW_SETBIND) followed by HANDLE_IOCTL(RAW_SETBIND, raw_ioctl). The latter is ignored. 2) on amd64 (and itanic) the damn thing is broken - we have int + u64 + u64 and layouts on i386 and amd64 are _not_ the same. raw_ioctl() would work there, but it's never called due to (1). As it is, i386 /sbin/raw definitely doesn't work on amd64 boxen. 3) switching to raw_ioctl() as is would *not* work on e.g. sparc64 and ppc64, which would be rather sad, seeing that normal userland there is 32bit. The thing is, slapping __packed on the struct in question does not DTRT - it eliminates *all* padding. The real solution is to use compat_u64. 4) of course, all that stuff has no business being outside of raw.c in the first place - there should be ->compat_ioctl() for /dev/rawctl instead of messing with compat_ioctl.c. [akpm@linux-foundation.org: coding-style fixes] [arnd@arndb.de: port to 2.6.36] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
