commit 5858bdad4d0d0fc18bf29f34c3ac836e0b59441f upstream.
The directory may have been removed when entering
fscrypt_ioctl_set_policy(). If so, the empty_dir() check will return
error for ext4 file system.
ext4_rmdir() sets i_size = 0, then ext4_empty_dir() reports an error
because 'inode->i_size < EXT4_DIR_REC_LEN(1) + EXT4_DIR_REC_LEN(2)'. If
the fs is mounted with errors=panic, it will trigger a panic issue.
Add the check IS_DEADDIR() to fix this problem.
Fixes: 9bd8212f981e ("ext4 crypto: add encryption policy and password salt support")
Cc: <stable@vger.kernel.org> # v4.1+
Signed-off-by: Hongjie Fang <hongjiefang@asrmicro.com>
[ Upstream commit 36dd26e0c8d42699eeba87431246c07c28075bae ]
Improve fscrypt read performance by switching the decryption workqueue
from bound to unbound. With the bound workqueue, when multiple bios
completed on the same CPU, they were decrypted on that same CPU. But
with the unbound queue, they are now decrypted in parallel on any CPU.
Although fscrypt read performance can be tough to measure due to the
many sources of variation, this change is most beneficial when
decryption is slow, e.g. on CPUs without AES instructions. For example,
I timed tarring up encrypted directories on f2fs. On x86 with AES-NI
instructions disabled, the unbound workqueue improved performance by
about 25-35%, using 1 to NUM_CPUs jobs with 4 or 8 CPUs available. But
with AES-NI enabled, performance was unchanged to within ~2%.
I also did the same test on a quad-core ARM CPU using xts-speck128-neon
encryption. There performance was usually about 10% better with the
unbound workqueue, bringing it closer to the unencrypted speed.
The unbound workqueue may be worse in some cases due to worse locality,
but I think it's still the better default. dm-crypt uses an unbound
workqueue by default too, so this change makes fscrypt match.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
[ Upstream commit dffd0cfa06d4ed83bb3ae8eb067989ceec5d18e1 ]
As part of an effort to clean up fscrypt-related error codes, make
FS_IOC_SET_ENCRYPTION_POLICY fail with ENOTDIR when the file descriptor
does not refer to a directory. This is more descriptive than EINVAL,
which was ambiguous with some of the other error cases.
I am not aware of any users who might be relying on the previous error
code of EINVAL, which was never documented anywhere, and in some buggy
kernels did not exist at all as the S_ISDIR() check was missing.
This failure case will be exercised by an xfstest.
[ Upstream commit 54475f531bb8d7078f63c159e5e0615d486c498c ]
attempting to create a file in an encrypted directory that hasn't been
"unlocked" fail with ENOKEY. Previously, several error codes were used
for this case, including ENOENT, EACCES, and EPERM, and they were not
consistent between and within filesystems. ENOKEY is a better choice
because it expresses that the failure is due to lacking the encryption
key. It also matches the error code returned when trying to open an
encrypted regular file without the key.
inconsistent error codes, which were never documented anywhere.
commit a0b3bc855374c50b5ea85273553485af48caf2f7 upstream.
fscrypt_initialize(), which allocates the global bounce page pool when
an encrypted file is first accessed, uses "double-checked locking" to
try to avoid locking fscrypt_init_mutex. However, it doesn't use any
memory barriers, so it's theoretically possible for a thread to observe
a bounce page pool which has not been fully initialized. This is a
classic bug with "double-checked locking".
While "only a theoretical issue" in the latest kernel, in pre-4.8
kernels the pointer that was checked was not even the last to be
initialized, so it was easily possible for a crash (NULL pointer
dereference) to happen. This was changed only incidentally by the large
refactor to use fs/crypto/.
Solve both problems in a trivial way that can easily be backported: just
always take the mutex. It's theoretically less efficient, but it
shouldn't be noticeable in practice as the mutex is only acquired very
briefly once per encrypted file.
Later I'd like to make this use a helper macro like DO_ONCE(). However,
DO_ONCE() runs in atomic context, so we'd need to add a new macro that
allows blocking.
commit d60b5b7854c3d135b869f74fb93eaf63cbb1991a upstream.
When an fscrypt-encrypted file is opened, we request the file's master
key from the keyrings service as a logon key, then access its payload.
However, a revoked key has a NULL payload, and we failed to check for
this. request_key() *does* skip revoked keys, but there is still a
window where the key can be revoked before we acquire its semaphore.
Fix it by checking for a NULL payload, treating it like a key which was
already revoked at the time it was requested.
Fixes: 88bd6ccdcdd6 ("ext4 crypto: add encryption key management facilities")
Reviewed-by: James Morris <james.l.morris@oracle.com>
commit 6b06cdee81d68a8a829ad8e8d0f31d6836744af9 upstream.
When accessing an encrypted directory without the key, userspace must
operate on filenames derived from the ciphertext names, which contain
arbitrary bytes. Since we must support filenames as long as NAME_MAX,
we can't always just base64-encode the ciphertext, since that may make
it too long. Currently, this is solved by presenting long names in an
abbreviated form containing any needed filesystem-specific hashes (e.g.
to identify a directory block), then the last 16 bytes of ciphertext.
This needs to be sufficient to identify the actual name on lookup.
However, there is a bug. It seems to have been assumed that due to the
use of a CBC (ciphertext block chaining)-based encryption mode, the last
16 bytes (i.e. the AES block size) of ciphertext would depend on the
full plaintext, preventing collisions. However, we actually use CBC
with ciphertext stealing (CTS), which handles the last two blocks
specially, causing them to appear "flipped". Thus, it's actually the
second-to-last block which depends on the full plaintext.
This caused long filenames that differ only near the end of their
plaintexts to, when observed without the key, point to the wrong inode
and be undeletable. For example, with ext4:
# echo pass | e4crypt add_key -p 16 edir/
# seq -f "edir/abcdefghijklmnopqrstuvwxyz012345%.0f" 100000 | xargs touch
# find edir/ -type f | xargs stat -c %i | sort | uniq | wc -l
100000
# sync
# echo 3 > /proc/sys/vm/drop_caches
# keyctl new_session
2004
# rm -rf edir/
rm: cannot remove 'edir/_A7nNFi3rhkEQlJ6P,hdzluhODKOeWx5V': Structure needs cleaning
To fix this, when presenting long encrypted filenames, encode the
second-to-last block of ciphertext rather than the last 16 bytes.
Although it would be nice to solve this without depending on a specific
encryption mode, that would mean doing a cryptographic hash like SHA-256
which would be much less efficient. This way is sufficient for now, and
it's still compatible with encryption modes like HEH which are strong
pseudorandom permutations. Also, changing the presented names is still
allowed at any time because they are only provided to allow applications
to do things like delete encrypted directories. They're not designed to
be used to persistently identify files --- which would be hard to do
anyway, given that they're encrypted after all.
For ease of backports, this patch only makes the minimal fix to both
ext4 and f2fs. It leaves ubifs as-is, since ubifs doesn't compare the
ciphertext block yet. Follow-on patches will clean things up properly
and make the filesystems use a shared helper function.
Fixes: 5de0b4d0cd15 ("ext4 crypto: simplify and speed up filename encryption")
Reported-by: Gwendal Grignou <gwendal@chromium.org>
commit 272f98f6846277378e1758a49a49d7bf39343c02 upstream.
To mitigate some types of offline attacks, filesystem encryption is
designed to enforce that all files in an encrypted directory tree use
the same encryption policy (i.e. the same encryption context excluding
the nonce). However, the fscrypt_has_permitted_context() function which
enforces this relies on comparing struct fscrypt_info's, which are only
available when we have the encryption keys. This can cause two
incorrect behaviors:
1. If we have the parent directory's key but not the child's key, or
vice versa, then fscrypt_has_permitted_context() returned false,
causing applications to see EPERM or ENOKEY. This is incorrect if
the encryption contexts are in fact consistent. Although we'd
normally have either both keys or neither key in that case since the
master_key_descriptors would be the same, this is not guaranteed
because keys can be added or removed from keyrings at any time.
2. If we have neither the parent's key nor the child's key, then
fscrypt_has_permitted_context() returned true, causing applications
to see no error (or else an error for some other reason). This is
incorrect if the encryption contexts are in fact inconsistent, since
in that case we should deny access.
To fix this, retrieve and compare the fscrypt_contexts if we are unable
to set up both fscrypt_infos.
While this slightly hurts performance when accessing an encrypted
directory tree without the key, this isn't a case we really need to be
optimizing for; access *with* the key is much more important.
Furthermore, the performance hit is barely noticeable given that we are
already retrieving the fscrypt_context and doing two keyring searches in
fscrypt_get_encryption_info(). If we ever actually wanted to optimize
this case we might start by caching the fscrypt_contexts.
commit 1b53cf9815bb4744958d41f3795d5d5a1d365e2d upstream.
Filesystem encryption ostensibly supported revoking a keyring key that
had been used to "unlock" encrypted files, causing those files to become
"locked" again. This was, however, buggy for several reasons, the most
severe of which was that when key revocation happened to be detected for
an inode, its fscrypt_info was immediately freed, even while other
threads could be using it for encryption or decryption concurrently.
This could be exploited to crash the kernel or worse.
This patch fixes the use-after-free by removing the code which detects
the keyring key having been revoked, invalidated, or expired. Instead,
an encrypted inode that is "unlocked" now simply remains unlocked until
it is evicted from memory. Note that this is no worse than the case for
block device-level encryption, e.g. dm-crypt, and it still remains
possible for a privileged user to evict unused pages, inodes, and
dentries by running 'sync; echo 3 > /proc/sys/vm/drop_caches', or by
simply unmounting the filesystem. In fact, one of those actions was
already needed anyway for key revocation to work even somewhat sanely.
This change is not expected to break any applications.
In the future I'd like to implement a real API for fscrypt key
revocation that interacts sanely with ongoing filesystem operations ---
waiting for existing operations to complete and blocking new operations,
and invalidating and sanitizing key material and plaintext from the VFS
caches. But this is a hard problem, and for now this bug must be fixed.
This bug affected almost all versions of ext4, f2fs, and ubifs
encryption, and it was potentially reachable in any kernel configured
with encryption support (CONFIG_EXT4_ENCRYPTION=y,
CONFIG_EXT4_FS_ENCRYPTION=y, CONFIG_F2FS_FS_ENCRYPTION=y, or
CONFIG_UBIFS_FS_ENCRYPTION=y). Note that older kernels did not use the
shared fs/crypto/ code, but due to the potential security implications
of this bug, it may still be worthwhile to backport this fix to them.
Fixes: b7236e21d55f ("ext4 crypto: reorganize how we store keys in the inode")
Acked-by: Michael Halcrow <mhalcrow@google.com>
commit 42d97eb0ade31e1bc537d086842f5d6e766d9d51 upstream.
Attempting to link a device node, named pipe, or socket file into an
encrypted directory through rename(2) or link(2) always failed with
EPERM. This happened because fscrypt_has_permitted_context() saw that
the file was unencrypted and forbid creating the link. This behavior
was unexpected because such files are never encrypted; only regular
files, directories, and symlinks can be encrypted.
To fix this, make fscrypt_has_permitted_context() always return true on
special files.
This will be covered by a test in my encryption xfstests patchset.
Reviewed-by: Richard Weinberger <richard@nod.at>
With the new (in 4.9) option to use a virtually-mapped stack
(CONFIG_VMAP_STACK), stack buffers cannot be used as input/output for
the scatterlist crypto API because they may not be directly mappable to
struct page. get_crypt_info() was using a stack buffer to hold the
output from the encryption operation used to derive the per-file key.
Fix it by using a heap buffer.
This bug could most easily be observed in a CONFIG_DEBUG_SG kernel
because this allowed the BUG in sg_set_buf() to be triggered.
Cc: stable@vger.kernel.org
struct page. For short filenames, fname_encrypt() was encrypting a
stack buffer holding the padded filename. Fix it by encrypting the
filename in-place in the output buffer, thereby making the temporary
buffer unnecessary.
i_rwsem needs to be acquired while setting an encryption policy so that
concurrent calls to FS_IOC_SET_ENCRYPTION_POLICY are correctly
serialized (especially the ->get_context() + ->set_context() pair), and
so that new files cannot be created in the directory during or after the
->empty_dir() check.
The XTS tweak (or IV) was initialized differently on little endian and
big endian systems. Because the ciphertext depends on the XTS tweak, it
was not possible to use an encrypted filesystem created by a little
endian system on a big endian system and vice versa, even if they shared
the same PAGE_SIZE. Fix this by always using little endian.
This will break hypothetical big endian users of ext4 or f2fs
encryption. However, all users we are aware of are little endian, and
it's believed that "real" big endian users are unlikely to exist yet.
So this might as well be fixed now before it's too late.
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"Lots of bug fixes and cleanups"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (40 commits)
ext4: remove unused variable
ext4: use journal inode to determine journal overhead
ext4: create function to read journal inode
ext4: unmap metadata when zeroing blocks
ext4: remove plugging from ext4_file_write_iter()
ext4: allow unlocked direct IO when pages are cached
ext4: require encryption feature for EXT4_IOC_SET_ENCRYPTION_POLICY
fscrypto: use standard macros to compute length of fname ciphertext
ext4: do not unnecessarily null-terminate encrypted symlink data
ext4: release bh in make_indexed_dir
ext4: Allow parallel DIO reads
ext4: allow DAX writeback for hole punch
jbd2: fix lockdep annotation in add_transaction_credits()
blockgroup_lock.h: simplify definition of NR_BG_LOCKS
blockgroup_lock.h: remove debris from bgl_lock_ptr() conversion
fscrypto: make filename crypto functions return 0 on success
fscrypto: rename completion callbacks to reflect usage
fscrypto: remove unnecessary includes
fscrypto: improved validation when loading inode encryption metadata
ext4: fix memory leak when symlink decryption fails
Several filename crypto functions: fname_decrypt(),
fscrypt_fname_disk_to_usr(), and fscrypt_fname_usr_to_disk(), returned
the output length on success or -errno on failure. However, the output
length was redundant with the value written to 'oname->len'. It is also
potentially error-prone to make callers have to check for '< 0' instead
of '!= 0'.
Therefore, make these functions return 0 instead of a length, and make
the callers who cared about the return value being a length use
'oname->len' instead. For consistency also make other callers check for
a nonzero result rather than a negative result.
This change also fixes the inconsistency of fname_encrypt() actually
already returning 0 on success, not a length like the other filename
crypto functions and as documented in its function comment.
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
Acked-by: Jaegeuk Kim <jaegeuk@kernel.org>
fscrypt_complete() was used only for data pages, not for all
encryption/decryption. Rename it to page_crypt_complete().
dir_crypt_complete() was used for filename encryption/decryption for
both directory entries and symbolic links. Rename it to
fname_crypt_complete().
This patch removes some #includes that are clearly not needed, such as a
reference to ecryptfs, which is unrelated to the new filesystem
encryption code.
- Validate fscrypt_context.format and fscrypt_context.flags. If
unrecognized values are set, then the kernel may not know how to
interpret the encrypted file, so it should fail the operation.
- Validate that AES_256_XTS is used for contents and that AES_256_CTS is
used for filenames. It was previously possible for the kernel to
accept these reversed, though it would have taken manual editing of
the block device. This was not intended.
- Fail cleanly rather than BUG()-ing if a file has an unexpected type.
Since setting an encryption policy requires writing metadata to the
filesystem, it should be guarded by mnt_want_write/mnt_drop_write.
Otherwise, a user could cause a write to a frozen or readonly
filesystem. This was handled correctly by f2fs but not by ext4. Make
fscrypt_process_policy() handle it rather than relying on the filesystem
to get it right.
Cc: stable@vger.kernel.org # 4.1+; check fs/{ext4,f2fs}
The FS_IOC_SET_ENCRYPTION_POLICY ioctl allowed setting an encryption
policy on nondirectory files. This was unintentional, and in the case
of nonempty regular files did not behave as expected because existing
data was not actually encrypted by the ioctl.
In the case of ext4, the user could also trigger filesystem errors in
->empty_dir(), e.g. due to mismatched "directory" checksums when the
kernel incorrectly tried to interpret a regular file as a directory.
This bug affected ext4 with kernels v4.8-rc1 or later and f2fs with
kernels v4.6 and later. It appears that older kernels only permitted
directories and that the check was accidentally lost during the
refactoring to share the file encryption code between ext4 and f2fs.
This patch restores the !S_ISDIR() check that was present in older
kernels.
On an ext4 or f2fs filesystem with file encryption supported, a user
could set an encryption policy on any empty directory(*) to which they
had readonly access. This is obviously problematic, since such a
directory might be owned by another user and the new encryption policy
would prevent that other user from creating files in their own directory
(for example).
Fix this by requiring inode_owner_or_capable() permission to set an
encryption policy. This means that either the caller must own the file,
or the caller must have the capability CAP_FOWNER.
(*) Or also on any regular file, for f2fs v4.6 and later and ext4
v4.8-rc1 and later; a separate bug fix is coming for that.
This patch converts the simple bi_rw use cases in the block,
drivers, mm and fs code to set/get the bio operation using
bio_set_op_attrs/bio_op
These should be simple one or two liner cases, so I just did them
in one patch. The next patches handle the more complicated
cases in a module per patch.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
This has callers of submit_bio/submit_bio_wait set the bio->bi_rw
instead of passing it in. This makes that use the same as
generic_make_request and how we set the other bio fields.
Fixed up fs/ext4/crypto.c
This patch allows fscrypto to handle a second key prefix given by filesystem.
The main reason is to provide backward compatibility, since previously f2fs
used "f2fs:" as a crypto prefix instead of "fscrypt:".
Later, ext4 should also provide key_prefix() to give "ext4:".
One concern decribed by Ted would be kinda double check overhead of prefixes.
In x86, for example, validate_user_key consumes 8 ms after boot-up, which turns
out derive_key_aes() consumed most of the time to load specific crypto module.
After such the cold miss, it shows almost zero latencies, which treats as a
negligible overhead.
Note that request_key() detects wrong prefix in prior to derive_key_aes() even.
Cc: Ted Tso <tytso@mit.edu>
Cc: stable@vger.kernel.org # v4.6
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
As Al pointed, d_revalidate should return RCU lookup before using d_inode.
This was originally introduced by:
commit 34286d666230 ("fs: rcu-walk aware d_revalidate method").
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: stable <stable@vger.kernel.org>
This patch fixes the issue introduced by the ext4 crypto fix in a same manner.
For F2FS, however, we flush the pending IOs and wait for a while to acquire free
memory.
Fixes: c9af28fdd4492 ("ext4 crypto: don't let data integrity writebacks fail with ENOMEM")
This patch updates fscrypto along with the below ext4 crypto change.
Fixes: 3d43bcfef5f0 ("ext4 crypto: use dget_parent() in ext4_d_revalidate()")
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Commit 0b81d07790726 ("fs crypto: move per-file encryption from f2fs
tree to fs/crypto") moved the f2fs crypto files to fs/crypto/ and
renamed the symbol prefixes from "f2fs_" to "fscrypt_" (and from "F2FS_"
to just "FS" for preprocessor symbols).
Because of the symbol renaming, it's a bit hard to see it as a file
move: use
git show -M30 0b81d07790726
to lower the rename detection to just 30% similarity and make git show
the files as renamed (the header file won't be shown as a rename even
then - since all it contains is symbol definitions, it looks almost
completely different).
Even with the renames showing as renames, the diffs are not all that
easy to read, since so much is just the renames. But Eric Biggers
noticed that it's not just all renames: the initialization of the
xts_tweak had been broken too, using the inode number rather than the
page offset.
That's not right - it makes the xfs_tweak the same for all pages of each
inode. It _might_ make sense to make the xfs_tweak contain both the
offset _and_ the inode number, but not just the inode number.
Reported-by: Eric Biggers <ebiggers3@gmail.com>
Cc: Jaegeuk Kim <jaegeuk@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs
Pull f2fs updates from Jaegeuk Kim:
"New Features:
- uplift filesystem encryption into fs/crypto/
- give sysfs entries to control memroy consumption
Enhancements:
- aio performance by preallocating blocks in ->write_iter
- use writepages lock for only WB_SYNC_ALL
- avoid redundant inline_data conversion
- enhance forground GC
- use wait_for_stable_page as possible
- speed up SEEK_DATA and fiiemap
Bug Fixes:
- corner case in terms of -ENOSPC for inline_data
- hung task caused by long latency in shrinker
- corruption between atomic write and f2fs_trace_pid
- avoid garbage lengths in dentries
- revoke atomicly written pages if an error occurs
In addition, there are various minor bug fixes and clean-ups"
* tag 'for-f2fs-4.6' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (81 commits)
f2fs: submit node page write bios when really required
f2fs: add missing argument to f2fs_setxattr stub
f2fs: fix to avoid unneeded unlock_new_inode
f2fs: clean up opened code with f2fs_update_dentry
f2fs: declare static functions
f2fs: use cryptoapi crc32 functions
f2fs: modify the readahead method in ra_node_page()
f2fs crypto: sync ext4_lookup and ext4_file_open
fs crypto: move per-file encryption from f2fs tree to fs/crypto
f2fs: mutex can't be used by down_write_nest_lock()
f2fs: recovery missing dot dentries in root directory
f2fs: fix to avoid deadlock when merging inline data
f2fs: introduce f2fs_flush_merged_bios for cleanup
f2fs: introduce f2fs_update_data_blkaddr for cleanup
f2fs crypto: fix incorrect positioning for GCing encrypted data page
f2fs: fix incorrect upper bound when iterating inode mapping tree
f2fs: avoid hungtask problem caused by losing wake_up
f2fs: trace old block address for CoWed page
f2fs: try to flush inode after merging inline data
f2fs: show more info about superblock recovery
This patch adds the renamed functions moved from the f2fs crypto files.
1. definitions for per-file encryption used by ext4 and f2fs.
2. crypto.c for encrypt/decrypt functions
a. IO preparation:
- fscrypt_get_ctx / fscrypt_release_ctx
b. before IOs:
- fscrypt_encrypt_page
- fscrypt_decrypt_page
- fscrypt_zeroout_range
c. after IOs:
- fscrypt_decrypt_bio_pages
- fscrypt_pullback_bio_page
- fscrypt_restore_control_page
3. policy.c supporting context management.
a. For ioctls:
- fscrypt_process_policy
- fscrypt_get_policy
b. For context permission
- fscrypt_has_permitted_context
- fscrypt_inherit_context
4. keyinfo.c to handle permissions
- fscrypt_get_encryption_info
- fscrypt_free_encryption_info
5. fname.c to support filename encryption
a. general wrapper functions
- fscrypt_fname_disk_to_usr
- fscrypt_fname_usr_to_disk
- fscrypt_setup_filename
- fscrypt_free_filename
b. specific filename handling functions
- fscrypt_fname_alloc_buffer
- fscrypt_fname_free_buffer
6. Makefile and Kconfig
Cc: Al Viro <viro@ftp.linux.org.uk>
Signed-off-by: Michael Halcrow <mhalcrow@google.com>
Signed-off-by: Ildar Muslukhov <ildarm@google.com>
Signed-off-by: Uday Savagaonkar <savagaon@google.com>
