path: root/fs/dcache.c
2010-05-21fix prune_dcache()/umount() raceAl Viro
... and get rid of the last __put_super_and_need_restart() caller Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21Leave superblocks on s_list until the endAl Viro
We used to remove from s_list and s_instances at the same time. So let's *not* do the former and skip superblocks that have empty s_instances in the loops over s_list. The next step, of course, will be to get rid of rescan logics in those loops. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21clean DCACHE_CANT_MOUNT in d_delete()Al Viro
We set the "it's dead, don't mount on it" flag _and_ do not remove it if we turn the damn thing negative and leave it around. And if it goes positive afterwards, well... Fortunately, there's only one place where that needs to be caught: only d_delete() can turn the sucker negative without immediately freeing it; all other places that can lead to ->d_iput() call are followed by unconditionally freeing struct dentry in question. So the fix is obvious: Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16014 Reported-by: Adam Tkac <vonsch@gmail.com> Tested-by: Adam Tkac <vonsch@gmail.com> Cc: <stable@kernel.org> [2.6.34.x] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-03fix race in d_splice_alias()Al Viro
rehashing the negative placeholder opens a race with d_lookup(); we unhash it almost immediately (by d_move()), but the race window is there. Since d_move() doesn't rely on target being hashed, we don't need that d_rehash() at all. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-03New helper: path_is_under(path1, path2)Al Viro
Analog of is_subdir for vfsmount,dentry pairs, moved from audit_tree.c Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-03fs/dcache.c: CodingStyle cleanupH Hartley Sweeten
Cleanup EXPORT* macros according to Documantation/CodingStyle. Move EXPORT* macros to the line immediately after the closing function brace. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16libfs: move EXPORT_SYMBOL for d_alloc_nameH Hartley Sweeten
The EXPORT_SYMBOL for d_alloc_name is in fs/libfs.c but the function is in fs/dcache.c. Move the EXPORT_SYMBOL to the line immediately after the closing function brace line in fs/dcache.c as mentioned in Documentation/CodingStyle. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-07-18sched: Pull up the might_sleep() check into cond_resched()Frederic Weisbecker
might_sleep() is called late-ish in cond_resched(), after the need_resched()/preempt enabled/system running tests are checked. It's better to check the sleeps while atomic earlier and not depend on some environment datas that reduce the chances to detect a problem. Also define cond_resched_*() helpers as macros, so that the FILE/LINE reported in the sleeping while atomic warning displays the real origin and not sched.h Changes in v2: - Call __might_sleep() directly instead of might_sleep() which may call cond_resched() - Turn cond_resched() into a macro so that the file:line couple reported refers to the caller of cond_resched() and not __cond_resched() itself. Changes in v3: - Also propagate this __might_sleep() pull up to cond_resched_lock() and cond_resched_softirq() Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1247725694-6082-6-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-11dcache: extrace and use d_unlinked()Alexey Dobriyan
d_unlinked() will be used in middle-term to ban checkpointing when opened but unlinked file is detected, and in long term, to detect such situation and special case on it. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09fs: dcache fix LRU orderingnpiggin@suse.de
Fix ordering of LRU when moving referenced dentries to the head of the list (they should go to the head of the list in the same order as they were found from the tail, rather than reverse order). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-20No need for crossing to mountpoint in audit_tag_tree()Al Viro
is_under() will DTRT anyway. And yes, is_subdir() behaviour is intentional. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-31Trim includes of fdtable.hAl Viro
2009-03-31Get rid of indirect include of fs_struct.hAl Viro
Don't pull it in sched.h; very few files actually need it and those can include directly. sched.h itself only needs forward declaration of struct fs_struct; Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27cleanup d_add_ciChristoph Hellwig
Make sure that comments describe what's going on and not how, and always use __d_instantiate instead of two separate branches, one with d_instantiate and one with __d_instantiate. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-02-27EXPORT_SYMBOL(d_obtain_alias) rather than EXPORT_SYMBOL_GPLBenny Halevy
Commit 4ea3ada2955e4519befa98ff55dd62d6dfbd1705 declares d_obtain_alias() as EXPORT_SYMBOL_GPL where it's supposed to replace d_alloc_anon which was previously declared as EXPORT_SYMBOL and thus available to any loadable module. This patch reverts that. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 20Heiko Carstens
2009-01-08generic swap(): dcache: use swap() instead of private do_switch()Wu Fengguang
Use the new generic implementation. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-31filp_cachep can be static in fs/file_table.cEric Dumazet
Instead of creating the "filp" kmem_cache in vfs_caches_init(), we can do it a litle be later in files_init(), so that filp_cachep is static to fs/file_table.c Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-31expand some comments (d_path / seq_path)Arjan van de Ven
Explain that you really need to use the return value of d_path rather than the buffer you passed into it. Also fix the comment for seq_path(), the function arguments changed recently but the comment hadn't been updated in sync. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-31correct wrong function name of d_put in kernel document and source commentZhaolei
no function named d_put(), it should be dput(). Impact: fix document and comment, no functionality changed Signed-off-by: Zhao Lei <zhaolei@cn.fuijtsu.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-31fix switch_names() breakage in short-to-short caseAl Viro
We want ->name.len to match the resulting name on *both* source and target Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-31shrink struct dentryNick Piggin
struct dentry is one of the most critical structures in the kernel. So it's sad to see it going neglected. With CONFIG_PROFILING turned on (which is probably the common case at least for distros and kernel developers), sizeof(struct dcache) == 208 here (64-bit). This gives 19 objects per slab. I packed d_mounted into a hole, and took another 4 bytes off the inline name length to take the padding out from the end of the structure. This shinks it to 200 bytes. I could have gone the other way and increased the length to 40, but I'm aiming for a magic number, read on... I then got rid of the d_cookie pointer. This shrinks it to 192 bytes. Rant: why was this ever a good idea? The cookie system should increase its hash size or use a tree or something if lookups are a problem. Also the "fast dcookie lookups" in oprofile should be moved into the dcookie code -- how can oprofile possibly care about the dcookie_mutex? It gets dropped after get_dcookie() returns so it can't be providing any sort of protection. At 192 bytes, 21 objects fit into a 4K page, saving about 3MB on my system with ~140 000 entries allocated. 192 is also a multiple of 64, so we get nice cacheline alignment on 64 and 32 byte line systems -- any given dentry will now require 3 cachelines to touch all fields wheras previously it would require 4. I know the inline name size was chosen quite carefully, however with the reduction in cacheline footprint, it should actually be just about as fast to do a name lookup for a 36 character name as it was before the patch (and faster for other sizes). The memory footprint savings for names which are <= 32 or > 36 bytes long should more than make up for the memory cost for 33-36 byte names. Performance is a feature... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23[PATCH] fs: add a sanity check in d_freeArjan van de Ven
Hi Al, remember that debug session we did at KS? You suggested this patch back then.... From 7751eaf30474b8cbfaea64795805a17eab05ac53 Mon Sep 17 00:00:00 2001 From: Arjan van de Ven <arjan@linux.intel.com> Date: Tue, 16 Sep 2008 16:51:17 -0700 Subject: [PATCH] fs: add a sanity check in d_free we're seeing some corruption in the dentry->d_alias list that appears like a free of an entry still on the list; this patch adds a WARN_ON() to catch this scenario, as suggested by Al Viro Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-10-23[PATCH] fs/dcache.c: update comment of d_validate()Qinghuang Feng
Parameters @hash and @len have been removed since 2.4.3, now just to delete them. Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com>
2008-10-23[PATCH vfs-2.6 4/6] vfs: remove unnecessary fsnotify_d_instantiate()OGAWA Hirofumi
This calls d_move(), so fsnotify_d_instantiate() is unnecessary like rename path. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2008-10-23[PATCH vfs-2.6 3/6] vfs: add __d_instantiate() helperOGAWA Hirofumi
This adds __d_instantiate() for users which is already taking dcache_lock, and replace with it. The part of d_add_ci() isn't equivalent. But it should be needed fsnotify_d_instantiate() actually, because the path is to add the inode to negative dentry. fsnotify_d_instantiate() should be called after change from negative to positive. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2008-10-23[PATCH vfs-2.6 2/6] vfs: add d_ancestor()OGAWA Hirofumi
This adds d_ancestor() instead of d_isparent(), then use it. If new_dentry == old_dentry, is_subdir() returns 1, looks strange. "new_dentry == old_dentry" is not subdir obviously. But I'm not checking callers for now, so this keeps current behavior. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2008-10-23[PATCH vfs-2.6 1/6] vfs: replace parent == dentry->d_parent by IS_ROOT()OGAWA Hirofumi
2008-10-23[PATCH] kill d_alloc_anonChristoph Hellwig
Remove d_alloc_anon now that no users are left. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23[PATCH] switch all filesystems over to d_obtain_aliasChristoph Hellwig
Switch all users of d_alloc_anon to d_obtain_alias. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23[PATCH] new helper: d_obtain_aliasChristoph Hellwig
The calling conventions of d_alloc_anon are rather unfortunate for all users, and it's name is not very descriptive either. Add d_obtain_alias as a new exported helper that drops the inode reference in the failure case, too and allows to pass-through NULL pointers and inodes to allow for tail-calls in the export operations. Incidentally this helper already existed as a private function in libfs.c as exportfs_d_alloc so kill that one and switch the callers to d_obtain_alias. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-09-29Fix NULL pointer dereference in proc_sys_compareLinus Torvalds
The VFS interface for the 'd_compare()' is a bit special (read: 'odd'), because it really just essentially replaces a memcmp(). The filesystem is supposed to just compare the two names with whatever case-independent or other function. And when I say 'is supposed to', I obviously mean that 'procfs does odd things, and actually looks at the dentry that we don't even pass down, rather than just the name'. Which results in problems, because we actually call d_compare before we have even verified that the dentry is still hashed at all. And that causes a problm since the inode that procfs looks at may have been free'd and the d_inode pointer is NULL. procfs just assumes that all dentries are positive, since procfs itself never generates a negative one. But memory pressure will still result in the dentry getting torn down, and as it is removed by RCU, it still remains visible on some lists - and to d_compare. If the filesystem just did a name comparison, we wouldn't care. And we could just fix procfs to know about negative dentries too. But rather than have the low-level filesystems know about internal VFS details, just move the check for a unhashed dentry up a bit, so that we will only call d_compare on dentries that are still active. The actual oops this caused didn't look like a NULL pointer dereference because procfs did a 'container_of(inode, struct proc_inode, vfs_inode)' to get at its internal proc_inode information from the inode pointer, and accessed a field below the inode. So the oops would look something like BUG: unable to handle kernel paging request at fffffffffffffff0 IP: [<ffffffff802bc6c6>] proc_sys_compare+0x36/0x50 and was seen on both x86-64 (Alexey Dobriyan and Hugh Dickins) and ppc64 (Hugh Dickins). Reported-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Hugh Dickins <hugh@veritas.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-of-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-25[PATCH] change d_add_ci argument orderingChristoph Hellwig
As pointed out during review d_add_ci argument order should match d_add, so switch the dentry and inode arguments. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-28dcache: Add case-insensitive support d_ci_add() routineBarry Naujok
This add a dcache entry to the dcache for lookup, but changing the name that is associated with the entry rather than the one passed in to the lookup routine. First, it sees if the case-exact match already exists in the dcache and uses it if one exists. Otherwise, it allocates a new node with the new name and splices it into the dcache. Original code from ntfs_lookup in fs/ntfs/namei.c by Anton Altaparmakov. Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Acked-by: Christoph Hellwig <hch@infradead.org>
2008-07-26vfs: add cond_resched_lock while scanning dentry LRU listsKentaro Makita
Add cond_resched_lock(&dcache_lock) while scanning LRU lists on superblocks in __shrink_dcache_sb() Signed-off-by: Kentaro Makita <k-makita@np.css.fujitsu.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24fix soft lock up at NFS mount via per-SB LRU-list of unused dentriesKentaro Makita
[Summary] Split LRU-list of unused dentries to one per superblock to avoid soft lock up during NFS mounts and remounting of any filesystem. Previously I posted here: http://lkml.org/lkml/2008/3/5/590 [Descriptions] - background dentry_unused is a list of dentries which are not referenced. dentry_unused grows up when references on directories or files are released. This list can be very long if there is huge free memory. - the problem When shrink_dcache_sb() is called, it scans all dentry_unused linearly under spin_lock(), and if dentry->d_sb is differnt from given superblock, scan next dentry. This scan costs very much if there are many entries, and very ineffective if there are many superblocks. IOW, When we need to shrink unused dentries on one dentry, but scans unused dentries on all superblocks in the system. For example, we scan 500 dentries to unmount a filesystem, but scans 1,000,000 or more unused dentries on other superblocks. In our case , At mounting NFS*, shrink_dcache_sb() is called to shrink unused dentries on NFS, but scans 100,000,000 unused dentries on superblocks in the system such as local ext3 filesystems. I hear NFS mounting took 1 min on some system in use. * : NFS uses virtual filesystem in rpc layer, so NFS is affected by this problem. 100,000,000 is possible number on large systems. Per-superblock LRU of unused dentried can reduce the cost in reasonable manner. - How to fix I found this problem is solved by David Chinner's "Per-superblock unused dentry LRU lists V3"(1), so I rebase it and add some fix to reclaim with fairness, which is in Andrew Morton's comments(2). 1) http://lkml.org/lkml/2006/5/25/318 2) http://lkml.org/lkml/2006/5/25/320 Split LRU-list of unused dentries to each superblocks. Then, NFS mounting will check dentries under a superblock instead of all. But this spliting will break LRU of dentry-unused. So, I've attempted to make reclaim unused dentrins with fairness by calculate number of dentries to scan on this sb based on following way number of dentries to scan on this sb = count * (number of dentries on this sb / number of dentries in the machine) - ToDo - I have to measuring performance number and do stress tests. - When unmount occurs during prune_dcache(), scanning on same superblock, It is unable to reach next superblock because it is gone away. We restart scannig superblock from first one, it causes unfairness of reclaim unused dentries on first superblock. But I think this happens very rarely. - Test Results Result on 6GB boxes with excessive unused dentries. Without patch: $ cat /proc/sys/fs/dentry-state 10181835 10180203 45 0 0 0 # mount -t nfs 10.124.60.70:/work/kernel-src nfs real 0m1.830s user 0m0.001s sys 0m1.653s With this patch: $ cat /proc/sys/fs/dentry-state 10236610 10234751 45 0 0 0 # mount -t nfs 10.124.60.70:/work/kernel-src nfs real 0m0.106s user 0m0.002s sys 0m0.032s [akpm@linux-foundation.org: fix comments] Signed-off-by: Kentaro Makita <k-makita@np.css.fujitsu.com> Cc: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: David Chinner <dgc@sgi.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-23[patch 2/3] vfs: dcache cleanupsMiklos Szeredi
Comment from Al Viro: add prepend_name() wrapper. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-06-23[patch 1/3] vfs: dcache sparse fixesMiklos Szeredi
Fix the following sparse warnings: fs/dcache.c:2183:19: warning: symbol 'filp_cachep' was not declared. Should it be static? fs/dcache.c:115:3: warning: context imbalance in 'dentry_iput' - unexpected unlock fs/dcache.c:188:2: warning: context imbalance in 'dput' - different lock contexts for basic block fs/dcache.c:400:2: warning: context imbalance in 'prune_one_dentry' - different lock contexts for basic block fs/dcache.c:431:22: warning: context imbalance in 'prune_dcache' - different lock contexts for basic block fs/dcache.c:563:2: warning: context imbalance in 'shrink_dcache_sb' - different lock contexts for basic block fs/dcache.c:1385:6: warning: context imbalance in 'd_delete' - wrong count at exit fs/dcache.c:1636:2: warning: context imbalance in '__d_unalias' - unexpected unlock fs/dcache.c:1735:2: warning: context imbalance in 'd_materialise_unique' - different lock contexts for basic block Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-06-23[patch 3/3] vfs: make d_path() consistent across mount operationsAndreas Gruenbacher
The path that __d_path() computes can become slightly inconsistent when it races with mount operations: it grabs the vfsmount_lock when traversing mount points but immediately drops it again, only to re-grab it when it reaches the next mount point. The result is that the filename computed is not always consisent, and the file may never have had that name. (This is unlikely, but still possible.) Fix this by grabbing the vfsmount_lock for the whole duration of __d_path(). Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: John Johansen <jjohansen@suse.de> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-06-23[patch 2/4] fs: make struct file arg to d_path constJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-23[patch 2/7] vfs: mountinfo: add seq_file_root()Miklos Szeredi
Add a new function: seq_file_root() This is similar to seq_path(), but calculates the path relative to the given root, instead of current->fs->root. If the path was unreachable from root, then modify the root parameter to reflect this. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-23[patch 1/7] vfs: mountinfo: add dentry_path()Ram Pai
[mszeredi@suse.cz] split big patch into managable chunks Add the following functions: dentry_path() seq_dentry() These are similar to d_path() and seq_path(). But instead of calculating the path within a mount namespace, they calculate the path from the root of the filesystem to a given dentry, ignoring mounts completely. Signed-off-by: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-14dentries: Extract common code to remove dentry from lruChristoph Lameter
Extract the common code to remove a dentry from the lru into a new function dentry_lru_remove(). Two call sites used list_del() instead of list_del_init(). AFAIK the performance of both is the same. dentry_lru_remove() does a list_del_init(). As a result dentry->d_lru is now always empty when a dentry is freed. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14d_path: Make d_path() use a struct pathJan Blunck
d_path() is used on a <dentry,vfsmount> pair. Lets use a struct path to reflect this. [akpm@linux-foundation.org: fix build in mm/memory.c] Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14d_path: kerneldoc cleanupJan Blunck
Move and update d_path() kernel API documentation. Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14One less parameter to __d_pathJan Blunck
All callers to __d_path pass the dentry and vfsmount of a struct path to __d_path. Pass the struct path directly, instead. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Use struct path in fs_structJan Blunck
* Use struct path in fs_struct. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06inotify: remove debug codeNick Piggin
The inotify debugging code is supposed to verify that the DCACHE_INOTIFY_PARENT_WATCHED scalability optimisation does not result in notifications getting lost nor extra needless locking generated. Unfortunately there are also some races in the debugging code. And it isn't very good at finding problems anyway. So remove it for now. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Robert Love <rlove@google.com> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Jan Kara <jack@ucw.cz> Cc: Yan Zheng <yanzheng@21cn.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fs: use hlist_unhashedAkinobu Mita
Use hlist_unhashed() instead of opencoded equivalent. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22dcache: don't expose uninitialized memory in /proc/<pid>/fd/<fd>J. Bruce Fields
Well, it's not especially important that target->d_iname get the contents of dentry->d_iname, but it's important that it get initialized with *something*, otherwise we're just exposing some random piece of memory to anyone who reads the link at /proc/<pid>/fd/<fd> for the deleted file, when it's still held open by someone. I've run a test program that copies a short (<36 character) name ontop of a long (>=36 character) name and see that the first time I run it, without this patch, I get unpredicatable results out of /proc/<pid>/fd/<fd>. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
