path: root/fs/dcache.c
2011-08-06vfs: renumber DCACHE_xyz flags, remove some stale onesLinus Torvalds
Gcc tends to generate better code with small integers, including the DCACHE_xyz flag tests - so move the common ones to be first in the list. Also just remove the unused DCACHE_INOTIFY_PARENT_WATCHED and DCACHE_AUTOFS_PENDING values, their users no longer exists in the source tree. And add a "unlikely()" to the DCACHE_OP_COMPARE test, since we want the common case to be a nice straight-line fall-through. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03fs/dcache.c: fix new kernel-doc warningRandy Dunlap
Fix new kernel-doc warning in fs/dcache.c: Warning(fs/dcache.c:797): No description found for parameter 'sb' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-01VFS: Reorganise shrink_dcache_for_umount_subtree() after demise of dcache_lockDavid Howells
Reorganise shrink_dcache_for_umount_subtree() in light of the demise of dcache_lock. Without that dcache_lock, there is no need for the batching of removal of dentries from the system under it (we wanted to make intensive use of the locked data whilst we held it, but didn't want to hold it for long at a time). This works, provided the preceding patch is correct in its removal of locking on dentry->d_lock on the basis that no one should be locking these dentries any more as the whole superblock is defunct. With this patch, the calls to dentry_lru_del() and __d_shrink() are placed at the point where each dentry is detached handled. It is possible that, as an alternative, the batching should still be done - but only for dentry_lru_del() of all a dentry's children in one go. In such a case, the batching would be done under dcache_lru_lock. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-08-01VFS: Remove dentry->d_lock locking from shrink_dcache_for_umount_subtree()David Howells
Locks of the dcache_lock were replaced by locks of dentry->d_lock in commits such as: 2304450783dfde7b0b94ae234edd0dbffa865073 2fd6b7f50797f2e993eea59e0a0b8c6399c811dc as part of the RCU-based pathwalk changes, despite the fact that the caller (shrink_dcache_for_umount()) notes in the banner comment the reasons that d_lock is not necessary in these functions: /* * destroy the dentries attached to a superblock on unmounting * - we don't need to use dentry->d_lock because: * - the superblock is detached from all mountings and open files, so the * dentry trees will not be rearranged by the VFS * - s_umount is write-locked, so the memory pressure shrinker will ignore * any dentries belonging to this superblock that it comes across * - the filesystem itself is no longer permitted to rearrange the dentries * in this superblock */ So remove these locks. If the locks are actually necessary, then this banner comment should be altered instead. The hash table chains are protected by 1-bit locks in the hash table heads, so those shouldn't be a problem. Note that to make this work, __d_drop() has to be split so that the RCUwalk barrier can be avoided. This causes problems otherwise as it has an assertion that dentry->d_lock is locked - but there is no need for that as no one else can be trying to access this dentry, except to step over it (and that should be handled by d_free(), I think). Signed-off-by: David Howells <dhowells@redhat.com> Cc: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-08-01VFS: Remove detached-dentry counter from shrink_dcache_for_umount_subtree()David Howells
Remove the detached-dentry counter from shrink_dcache_for_umount_subtree() as the value it computes is no longer used as of commit 312d3ca856d369bb04d0443846b85b4cdde6fa8a which made the nr_dentry counters summed per-CPU rather than global atomic. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-26vfs: document locking requirements for d_move, __d_move and d_materialise_uniqueJeff Layton
Adding a comment to d_materialise_unique per Al's request... d_move and __d_move have some pretty substantial locking requirements, but they are not clearly documented. Add some comments spelling them out. Also, document the requirement for the i_mutex of the parent in d_materialise_unique. Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits) vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp isofs: Remove global fs lock jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory fix IN_DELETE_SELF on overwriting rename() on ramfs et.al. mm/truncate.c: fix build for CONFIG_BLOCK not enabled fs:update the NOTE of the file_operations structure Remove dead code in dget_parent() AFS: Fix silly characters in a comment switch d_add_ci() to d_splice_alias() in "found negative" case as well simplify gfs2_lookup() jfs_lookup(): don't bother with . or .. get rid of useless dget_parent() in btrfs rename() and link() get rid of useless dget_parent() in fs/btrfs/ioctl.c fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers drivers: fix up various ->llseek() implementations fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek Ext4: handle SEEK_HOLE/SEEK_DATA generically Btrfs: implement our own ->llseek fs: add SEEK_HOLE and SEEK_DATA flags reiserfs: make reiserfs default to barrier=flush ... Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new shrinker callout for the inode cache, that clashed with the xfs code to start the periodic workers later.
2011-07-21vfs: drop conditional inode prefetch in __do_lookup_rcuLinus Torvalds
It seems to hurt performance in real life. Yes, the inode will be used later, but the conditional doesn't seem to predict all that well (negative dentries are not uncommon) and it looks like the cost of prefetching is simply higher than depending on the cache doing the right thing. As usual. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-20Remove dead code in dget_parent()Al Viro
->d_parent is never NULL... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20switch d_add_ci() to d_splice_alias() in "found negative" case as wellAl Viro
2011-07-20superblock: introduce per-sb cache shrinker infrastructureDave Chinner
With context based shrinkers, we can implement a per-superblock shrinker that shrinks the caches attached to the superblock. We currently have global shrinkers for the inode and dentry caches that split up into per-superblock operations via a coarse proportioning method that does not batch very well. The global shrinkers also have a dependency - dentries pin inodes - so we have to be very careful about how we register the global shrinkers so that the implicit call order is always correct. With a per-sb shrinker callout, we can encode this dependency directly into the per-sb shrinker, hence avoiding the need for strictly ordering shrinker registrations. We also have no need for any proportioning code for the shrinker subsystem already provides this functionality across all shrinkers. Allowing the shrinker to operate on a single superblock at a time means that we do less superblock list traversals and locking and reclaim should batch more effectively. This should result in less CPU overhead for reclaim and potentially faster reclaim of items from each filesystem. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20make d_splice_alias(ERR_PTR(err), dentry) = ERR_PTR(err)Al Viro
... and simplify the living hell out of callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20Make ->d_sb assign-once and always non-NULLAl Viro
New helper (non-exported, fs/internal.h-only): __d_alloc(sb, name). Allocates dentry, sets its ->d_sb to given superblock and sets ->d_op accordingly. Old d_alloc(NULL, name) callers are converted to that (all of them know what superblock they want). d_alloc() itself is left only for parent != NULl case; uses __d_alloc(), inserts result into the list of parent's children. Note that now ->d_sb is assign-once and never NULL *and* ->d_parent is never NULL either. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: add a DCACHE_NEED_LOOKUP flag for d_flagsJosef Bacik
Btrfs (and I'd venture most other fs's) stores its indexes in nice disk order for readdir, but unfortunately in the case of anything that stats the files in order that readdir spits back (like oh say ls) that means we still have to do the normal lookup of the file, which means looking up our other index and then looking up the inode. What I want is a way to create dummy dentries when we find them in readdir so that when ls or anything else subsequently does a stat(), we already have the location information in the dentry and can go straight to the inode itself. The lookup stuff just assumes that if it finds a dentry it is done, it doesn't perform a lookup. So add a DCACHE_NEED_LOOKUP flag so that the lookup code knows it still needs to run i_op->lookup() on the parent to get the inode for the dentry. I have tested this with btrfs and I went from something that looks like this http://people.redhat.com/jwhiter/ls-noreada.png To this http://people.redhat.com/jwhiter/ls-good.png Thats a savings of 1300 seconds, or 22 minutes. That is a significant savings. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-14fix loop checks in d_materialise_unique()Al Viro
Both __d_unalias() and __d_materialise_dentry() need loop prevention. Grab rename_lock in caller, check for loops there... As a side benefit, we have dentry_lock_for_move() called only under rename_lock, which seriously reduces deadlock potential of the execrable "locking order" used for ->d_lock. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-25vmscan: change shrinker API by passing shrink_control structYing Han
Change each shrinker's API by consolidating the existing parameters into shrink_control struct. This will simplify any further features added w/o touching each file of shrinker. [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: fix warning] [kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API] [akpm@linux-foundation.org: fix xfs warning] [akpm@linux-foundation.org: update gfs2] Signed-off-by: Ying Han <yinghan@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-20sanitize <linux/prefetch.h> usageLinus Torvalds
Commit e66eed651fd1 ("list: remove prefetching from regular list iterators") removed the include of prefetch.h from list.h, which uncovered several cases that had apparently relied on that rather obscure header file dependency. So this fixes things up a bit, using grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]') grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]') to guide us in finding files that either need <linux/prefetch.h> inclusion, or have it despite not needing it. There are more of them around (mostly network drivers), but this gets many core ones. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-25add hlist_bl_lock/unlock helpersChristoph Hellwig
Now that the whole dcache_hash_bucket crap is gone, go all the way and also remove the weird locking layering violations for locking the hash buckets. Add hlist_bl_lock/unlock helpers to move the locking into the list abstraction instead of requiring each caller to open code it. After all allowing for the bit locks is the whole point of these helpers over the plain hlist variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-24vfs: get rid of insane dentry hashing rulesLinus Torvalds
The dentry hashing rules have been really quite complicated for a long while, in odd ways. That made functions like __d_drop() very fragile and non-obvious. In particular, whether a dentry was hashed or not was indicated with an explicit DCACHE_UNHASHED bit. That's despite the fact that the hash abstraction that the dentries use actually have a 'is this entry hashed or not' model (which is a simple test of the 'pprev' pointer). The reason that was done is because we used the normal 'is this entry unhashed' model to mark whether the dentry had _ever_ been hashed in the dentry hash tables, and that logic goes back many years (commit b3423415fbc2: "dcache: avoid RCU for never-hashed dentries"). That, in turn, meant that __d_drop had totally different unhashing logic for the dentry hash table case and for the anonymous dcache case, because in order to use the "is this dentry hashed" logic as a flag for whether it had ever been on the RCU hash table, we had to unhash such a dentry differently so that we'd never think that it wasn't 'unhashed' and wouldn't be free'd correctly. That's just insane. It made the logic really hard to follow, when there were two different kinds of "unhashed" states, and one of them (the one that used "list_bl_unhashed()") really had nothing at all to do with being unhashed per se, but with a very subtle lifetime rule instead. So turn all of it around, and make it logical. Instead of having a DENTRY_UNHASHED bit in d_flags to indicate whether the dentry is on the hash chains or not, use the hash chain unhashed logic for that. Suddenly "d_unhashed()" just uses "list_bl_unhashed()", and everything makes sense. And for the lifetime rule, just use an explicit DENTRY_RCUACCEES bit. If we ever insert the dentry into the dentry hash table so that it is visible to RCU lookup, we mark it DENTRY_RCUACCESS to show that it now needs the RCU lifetime rules. Now suddently that test at dentry free time makes sense too. And because unhashing now is sane and doesn't depend on where the dentry got unhashed from (because the dentry hash chain details doesn't have some subtle side effects), we can re-unify the __d_drop() logic and use common code for the unhashing. Also fix one more open-coded hash chain bit_spin_lock() that I missed in the previous chain locking cleanup commit. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-23vfs: get rid of 'struct dcache_hash_bucket' abstractionLinus Torvalds
It's a useless abstraction for 'hlist_bl_head', and it doesn't actually help anything - quite the reverse. All the users end up having to know about the hlist_bl_head details anyway, using 'struct hlist_bl_node *' etc. So it just makes the code look confusing. And the cost of it is extra '&b->head' syntactic noise, but more importantly it spuriously makes the hash table dentry list look different from the per-superblock DCACHE_DISCONNECTED dentry list. As a result, the code ended up using ad-hoc locking for one case and special helper functions for what is really another totally identical case in the very same function. Make it all look and work the same. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-15vfs: fix incorrect dentry_update_name_case() BUG_ON() testLinus Torvalds
The case we should be verifying when updating the dentry name is that the _parent_ inode (the directory) semaphore is held, not the semaphore for the dentry itself. It's the directory locking that rename and readdir() etc all care about. The comment just above even says so - but then the BUG_ON() still checked the dentry inode itself. Very few people noticed, because this helper function really isn't used for very much, so you had to be using ncpfs to ever hit it. I think I should just remove the BUG_ON (the function really has just one user), but let's run with it fixed for a while before getting rid of it entirely. Reported-and-tested-by: Bongani Hlope <bonganih@bankservafrica.com> Reported-and-tested-by: Bernd Feige <bernd.feige@uniklinik-freiburg.de> Cc: Petr Vandrovec <petr@vandrovec.name>, Cc: Arnd Bergmann <arnd@arndb.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fs: call security_d_instantiate in d_obtain_alias V2 lose 'mounting_here' argument in ->d_manage() don't pass 'mounting_here' flag to follow_down() change the locking order for namespace_sem fix deadlock in pivot_root() vfs: split off vfsmount-related parts of vfs_kern_mount() Some fixes for pstore kill simple_set_mnt()
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-18fs: call security_d_instantiate in d_obtain_alias V2Josef Bacik
While trying to track down some NFS problems with BTRFS, I kept noticing I was getting -EACCESS for no apparent reason. Eric Paris and printk() helped me figure out that it was SELinux that was giving me grief, with the following denial type=AVC msg=audit(1290013638.413:95): avc: denied { 0x800000 } for pid=1772 comm="nfsd" name="" dev=sda1 ino=256 scontext=system_u:system_r:kernel_t:s0 tcontext=system_u:object_r:unlabeled_t:s0 tclass=file Turns out this is because in d_obtain_alias if we can't find an alias we create one and do all the normal instantiation stuff, but we don't do the security_d_instantiate. Usually we are protected from getting a hashed dentry that hasn't yet run security_d_instantiate() by the parent's i_mutex, but obviously this isn't an option there, so in order to deal with the case that a second thread comes in and finds our new dentry before we get to run security_d_instantiate(), we go ahead and call it if we find a dentry already. Eric assures me that this is ok as the code checks to see if the dentry has been initialized already so calling security_d_instantiate() against the same dentry multiple times is ok. With this patch I'm no longer getting errant -EACCESS values. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-15VFS: Fix the nfs sillyrename regression in kernel 2.6.38Trond Myklebust
The new vfs locking scheme introduced in 2.6.38 breaks NFS sillyrename because the latter relies on being able to determine the parent directory of the dentry in the ->iput() callback in order to send the appropriate unlink rpc call. Looking at the code that cares about races with dput(), there doesn't seem to be anything that specifically uses d_parent as a test for whether or not there is a race: - __d_lookup_rcu(), __d_lookup() all test for d_hashed() after d_parent - shrink_dcache_for_umount() is safe since nothing else can rearrange the dentries in that super block. - have_submount(), select_parent() and d_genocide() can test for a deletion if we set the DCACHE_DISCONNECTED flag when the dentry is removed from the parent's d_subdirs list. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org (2.6.38, needs commit c826cb7dfce8 "dcache.c: create helper function for duplicated functionality" ) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-15dcache.c: create helper function for duplicated functionalityLinus Torvalds
This creates a helper function for he "try to ascend into the parent directory" case, which was written out in triplicate before. With all the locking and subtle sequence number stuff, we really don't want to duplicate that kind of code. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-10fs/dcache: allow d_obtain_alias() to return unhashed dentriesJ. Bruce Fields
Without this patch, inodes are not promptly freed on last close of an unlinked file by an nfs client: client$ mount -tnfs4 server:/export/ /mnt/ client$ tail -f /mnt/FOO ... server$ df -i /export server$ rm /export/FOO (^C the tail -f) server$ df -i /export server$ echo 2 >/proc/sys/vm/drop_caches server$ df -i /export the df's will show that the inode is not freed on the filesystem until the last step, when it could have been freed after killing the client's tail -f. On-disk data won't be deallocated either, leading to possible spurious ENOSPC. This occurs because when the client does the close, it arrives in a compound with a putfh and a close, processed like: - putfh: look up the filehandle.  The only alias found for the inode will be DCACHE_UNHASHED alias referenced by the filp this, so it creates a new DCACHE_DISCONECTED dentry and returns that instead. - close: closes the existing filp, which is destroyed immediately by dput() since it's DCACHE_UNHASHED. - end of the compound: release the reference to the current filehandle, and dput() the new DCACHE_DISCONECTED dentry, which gets put on the unused list instead of being destroyed immediately. Nick Piggin suggested fixing this by allowing d_obtain_alias to return the unhashed dentry that is referenced by the filp, instead of making it create a new dentry. Leave __d_find_alias() alone to avoid changing behavior of other callers. Also nfsd doesn't need all the checks of __d_find_alias(); any dentry, hashed or unhashed, disconnected or not, should work. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-02-17fs: update comments to point correct documentNamhyung Kim
dcache-locking.txt is not exist any more, and the path was not correct anyway. Fix it. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-22fs: fix new dcache.c kernel-doc warningsRandy Dunlap
Fix new fs/dcache.c kernel-doc warnings: Warning(fs/dcache.c:184): No description found for parameter 'dentry' Warning(fs/dcache.c:296): No description found for parameter 'parent' Warning(fs/dcache.c:1985): No description found for parameter 'dparent' Warning(fs/dcache.c:1985): Excess function parameter 'parent' description in 'd_validate' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (23 commits) sanitize vfsmount refcounting changes fix old umount_tree() breakage autofs4: Merge the remaining dentry ops tables Unexport do_add_mount() and add in follow_automount(), not ->d_automount() Allow d_manage() to be used in RCU-walk mode Remove a further kludge from __do_follow_link() autofs4: Bump version autofs4: Add v4 pseudo direct mount support autofs4: Fix wait validation autofs4: Clean up autofs4_free_ino() autofs4: Clean up dentry operations autofs4: Clean up inode operations autofs4: Remove unused code autofs4: Add d_manage() dentry operation autofs4: Add d_automount() dentry operation Remove the automount through follow_link() kludge code from pathwalk CIFS: Use d_automount() rather than abusing follow_link() NFS: Use d_automount() rather than abusing follow_link() AFS: Use d_automount() rather than abusing follow_link() Add an AT_NO_AUTOMOUNT flag to suppress terminal automount ...
2011-01-15Add a dentry op to handle automounting rather than abusing follow_link()David Howells
Add a dentry op (d_automount) to handle automounting directories rather than abusing the follow_link() inode operation. The operation is keyed off a new dentry flag (DCACHE_NEED_AUTOMOUNT). This also makes it easier to add an AT_ flag to suppress terminal segment automount during pathwalk and removes the need for the kludge code in the pathwalk algorithm to handle directories with follow_link() semantics. The ->d_automount() dentry operation: struct vfsmount *(*d_automount)(struct path *mountpoint); takes a pointer to the directory to be mounted upon, which is expected to provide sufficient data to determine what should be mounted. If successful, it should return the vfsmount struct it creates (which it should also have added to the namespace using do_add_mount() or similar). If there's a collision with another automount attempt, NULL should be returned. If the directory specified by the parameter should be used directly rather than being mounted upon, -EISDIR should be returned. In any other case, an error code should be returned. The ->d_automount() operation is called with no locks held and may sleep. At this point the pathwalk algorithm will be in ref-walk mode. Within fs/namei.c itself, a new pathwalk subroutine (follow_automount()) is added to handle mountpoints. It will return -EREMOTE if the automount flag was set, but no d_automount() op was supplied, -ELOOP if we've encountered too many symlinks or mountpoints, -EISDIR if the walk point should be used without mounting and 0 if successful. The path will be updated to point to the mounted filesystem if a successful automount took place. __follow_mount() is replaced by follow_managed() which is more generic (especially with the patch that adds ->d_manage()). This handles transits from directories during pathwalk, including automounting and skipping over mountpoints (and holding processes with the next patch). __follow_mount_rcu() will jump out of RCU-walk mode if it encounters an automount point with nothing mounted on it. follow_dotdot*() does not handle automounts as you don't want to trigger them whilst following "..". I've also extracted the mount/don't-mount logic from autofs4 and included it here. It makes the mount go ahead anyway if someone calls open() or creat(), tries to traverse the directory, tries to chdir/chroot/etc. into the directory, or sticks a '/' on the end of the pathname. If they do a stat(), however, they'll only trigger the automount if they didn't also say O_NOFOLLOW. I've also added an inode flag (S_AUTOMOUNT) so that filesystems can mark their inodes as automount points. This flag is automatically propagated to the dentry as DCACHE_NEED_AUTOMOUNT by __d_instantiate(). This saves NFS and could save AFS a private flag bit apiece, but is not strictly necessary. It would be preferable to do the propagation in d_set_d_op(), but that doesn't normally have access to the inode. [AV: fixed breakage in case if __follow_mount_rcu() fails and nameidata_drop_rcu() succeeds in RCU case of do_lookup(); we need to fall through to non-RCU case after that, rather than just returning with ungrabbed *path] Signed-off-by: David Howells <dhowells@redhat.com> Was-Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-14Turn d_set_d_op() BUG_ON() into WARN_ON_ONCE()Linus Torvalds
It's indicative of a real problem, and it actually triggers with autofs4, but the BUG_ON() is excessive. The autofs4 case is being fixed (to only set d_op in the ->lookup method) but not merged yet. In the meantime this gets the code limping along. Reported-by: Alex Elder <aelder@sgi.com> Cc: Ian Kent <raven@themaw.net> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-12fs: fix kernel-doc for dcache::prepend_pathRandy Dunlap
Fix function kernel-doc warning for prepend_path(): Warning(fs/dcache.c:1924): missing initial short description on line: Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-12fs: fix kernel-doc for dcache::d_validateRandy Dunlap
Fix function parameter kernel-doc for d_validate(): Warning(fs/dcache.c:1495): No description found for parameter 'parent' Warning(fs/dcache.c:1495): Excess function parameter 'dparent' description in 'd_validate' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-12per-superblock default ->d_opAl Viro
2011-01-07fs: implement faster dentry memcmpNick Piggin
The standard memcmp function on a Westmere system shows up hot in profiles in the `git diff` workload (both parallel and single threaded), and it is likely due to the costs associated with trapping into microcode, and little opportunity to improve memory access (dentry name is not likely to take up more than a cacheline). So replace it with an open-coded byte comparison. This increases code size by 8 bytes in the critical __d_lookup_rcu function, but the speedup is huge, averaging 10 runs of each: git diff st user sys elapsed CPU before 1.15 2.57 3.82 97.1 after 1.14 2.35 3.61 96.8 git diff mt user sys elapsed CPU before 1.27 3.85 1.46 349 after 1.26 3.54 1.43 333 Elapsed time for single threaded git diff at 95.0% confidence: -0.21 +/- 0.01 -5.45% +/- 0.24% It's -0.66% +/- 0.06% elapsed time on my Opteron, so rep cmp costs on the fam10h seem to be relatively smaller, but there is still a win. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: prefetch inode data in dcache lookupNick Piggin
This makes single threaded git diff -1.25% +/- 0.05% elapsed time on my 2s12c24t Westmere system, and -0.86% +/- 0.05% on my 2s8c Barcelona, by prefetching the important first cacheline of the inode in while we do the actual name compare and other operations on the dentry. There was no measurable slowdown in the single file stat case, or the creat case (where negative dentries would be common). Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: improve scalability of pseudo filesystemsNick Piggin
Regardless of how much we possibly try to scale dcache, there is likely always going to be some fundamental contention when adding or removing children under the same parent. Pseudo filesystems do not seem need to have connected dentries because by definition they are disconnected. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache per-inode inode alias lockingNick Piggin
dcache_inode_lock can be replaced with per-inode locking. Use existing inode->i_lock for this. This is slightly non-trivial because we sometimes need to find the inode from the dentry, which requires d_inode to be stabilised (either with refcount or d_lock). Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache per-bucket dcache hash lockingNick Piggin
We can turn the dcache hash locking from a global dcache_hash_lock into per-bucket locking. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: cache optimise dentry and inode for rcu-walkNick Piggin
Put dentry and inode fields into top of data structure. This allows RCU path traversal to perform an RCU dentry lookup in a path walk by touching only the first 56 bytes of the dentry. We also fit in 8 bytes of inline name in the first 64 bytes, so for short names, only 64 bytes needs to be touched to perform the lookup. We should get rid of the hash->prev pointer from the first 64 bytes, and fit 16 bytes of name in there, which will take care of 81% rather than 32% of the kernel tree. inode is also rearranged so that RCU lookup will only touch a single cacheline in the inode, plus one in the i_ops structure. This is important for directory component lookups in RCU path walking. In the kernel source, directory names average is around 6 chars, so this works. When we reach the last element of the lookup, we need to lock it and take its refcount which requires another cacheline access. Align dentry and inode operations structs, so members will be at predictable offsets and we can group common operations into head of structure. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache remove d_mountedNick Piggin
Rather than keep a d_mounted count in the dentry, set a dentry flag instead. The flag can be cleared by checking the hash table to see if there are any mounts left, which is not time critical because it is performed at detach time. The mounted state of a dentry is only used to speculatively take a look in the mount hash table if it is set -- before following the mount, vfsmount lock is taken and mount re-checked without races. This saves 4 bytes on 32-bit, nothing on 64-bit but it does provide a hole I might use later (and some configs have larger than 32-bit spinlocks which might make use of the hole). Autofs4 conversion and changelog by Ian Kent <raven@themaw.net>: In autofs4, when expring direct (or offset) mounts we need to ensure that we block user path walks into the autofs mount, which is covered by another mount. To do this we clear the mounted status so that follows stop before walking into the mount and are essentially blocked until the expire is completed. The automount daemon still finds the correct dentry for the umount due to the follow mount logic in fs/autofs4/root.c:autofs4_follow_link(), which is set as an inode operation for direct and offset mounts only and is called following the lookup that stopped at the covered mount. At the end of the expire the covering mount probably has gone away so the mounted status need not be restored. But we need to check this and only restore the mounted status if the expire failed. XXX: autofs may not work right if we have other mounts go over the top of it? Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: rcu-walk for path lookupNick Piggin
Perform common cases of path lookups without any stores or locking in the ancestor dentry elements. This is called rcu-walk, as opposed to the current algorithm which is a refcount based walk, or ref-walk. This results in far fewer atomic operations on every path element, significantly improving path lookup performance. It also avoids cacheline bouncing on common dentries, significantly improving scalability. The overall design is like this: * LOOKUP_RCU is set in nd->flags, which distinguishes rcu-walk from ref-walk. * Take the RCU lock for the entire path walk, starting with the acquiring of the starting path (eg. root/cwd/fd-path). So now dentry refcounts are not required for dentry persistence. * synchronize_rcu is called when unregistering a filesystem, so we can access d_ops and i_ops during rcu-walk. * Similarly take the vfsmount lock for the entire path walk. So now mnt refcounts are not required for persistence. Also we are free to perform mount lookups, and to assume dentry mount points and mount roots are stable up and down the path. * Have a per-dentry seqlock to protect the dentry name, parent, and inode, so we can load this tuple atomically, and also check whether any of its members have changed. * Dentry lookups (based on parent, candidate string tuple) recheck the parent sequence after the child is found in case anything changed in the parent during the path walk. * inode is also RCU protected so we can load d_inode and use the inode for limited things. * i_mode, i_uid, i_gid can be tested for exec permissions during path walk. * i_op can be loaded. When we reach the destination dentry, we lock it, recheck lookup sequence, and increment its refcount and mountpoint refcount. RCU and vfsmount locks are dropped. This is termed "dropping rcu-walk". If the dentry refcount does not match, we can not drop rcu-walk gracefully at the current point in the lokup, so instead return -ECHILD (for want of a better errno). This signals the path walking code to re-do the entire lookup with a ref-walk. Aside from the final dentry, there are other situations that may be encounted where we cannot continue rcu-walk. In that case, we drop rcu-walk (ie. take a reference on the last good dentry) and continue with a ref-walk. Again, if we can drop rcu-walk gracefully, we return -ECHILD and do the whole lookup using ref-walk. But it is very important that we can continue with ref-walk for most cases, particularly to avoid the overhead of double lookups, and to gain the scalability advantages on common path elements (like cwd and root). The cases where rcu-walk cannot continue are: * NULL dentry (ie. any uncached path element) * parent with d_inode->i_op->permission or ACLs * dentries with d_revalidate * Following links In future patches, permission checks and d_revalidate become rcu-walk aware. It may be possible eventually to make following links rcu-walk aware. Uncached path elements will always require dropping to ref-walk mode, at the very least because i_mutex needs to be grabbed, and objects allocated. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: consolidate dentry kill sequenceNick Piggin
The tricky locking for disposing of a dentry is duplicated 3 times in the dcache (dput, pruning a dentry from the LRU, and pruning its ancestors). Consolidate them all into a single function dentry_kill. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: use RCU in shrink_dentry_list to reduce lock nestingNick Piggin
2011-01-07fs: reduce dcache_inode_lock width in lru scanningNick Piggin
2011-01-07fs: dcache reduce prune_one_dentry lockingNick Piggin
prune_one_dentry can avoid quite a bit of locking in the common case where ancestors have an elevated refcount. Alternatively, we could have gone the other way and made fewer trylocks in the case where d_count goes to zero, but is probably less common. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce d_parent lockingNick Piggin
Use RCU to simplify locking in dget_parent. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache rationalise dget variantsNick Piggin
dget_locked was a shortcut to avoid the lazy lru manipulation when we already held dcache_lock (lru manipulation was relatively cheap at that point). However, how that the lru lock is an innermost one, we never hold it at any caller, so the lock cost can now be avoided. We already have well working lazy dcache LRU, so it should be fine to defer LRU manipulations to scan time. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
