path: root/fs/devpts/inode.c
2016-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: ">rename2() work from Miklos + current_time() from Deepa" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs: Replace current_fs_time() with current_time() fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps fs: Replace CURRENT_TIME with current_time() for inode timestamps fs: proc: Delete inode time initializations in proc_alloc_inode() vfs: Add current_time() api vfs: add note about i_op->rename changes to porting fs: rename "rename2" i_op to "rename" vfs: remove unused i_op->rename fs: make remaining filesystems use .rename2 libfs: support RENAME_NOREPLACE in simple_rename() fs: support RENAME_NOREPLACE for local filesystems ncpfs: fix unused variable warning
2016-09-27fs: Replace CURRENT_TIME with current_time() for inode timestampsDeepa Dinamani
CURRENT_TIME macro is not appropriate for filesystems as it doesn't use the right granularity for filesystem timestamps. Use current_time() instead. CURRENT_TIME is also not y2038 safe. This is also in preparation for the patch that transitions vfs timestamps to use 64 bit time and hence make them y2038 safe. As part of the effort current_time() will be extended to do range checks. Hence, it is necessary for all file system timestamps to use current_time(). Also, current_time() will be transitioned along with vfs to be y2038 safe. Note that whenever a single call to current_time() is used to change timestamps in different inodes, it is because they share the same time granularity. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Felipe Balbi <balbi@kernel.org> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: David Sterba <dsterba@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-23devpts: Change the owner of /dev/pts/ptmx to the mounter of /dev/ptsEric W. Biederman
In 99.99% of the cases only root in a user namespace can mount /dev/pts and in those cases the owner of /dev/pts/ptmx will remain root.root In the oddball case where someone else has CAP_SYS_ADMIN this code modifies the /dev/pts mount code to use current_fsuid and current_fsgid as the values to use when creating the /dev/ptmx inode. As is done when any other file is created. This is a code simplification, and it allows running without a root user entirely. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-23devpts: Remove sync_filesystemsEric W. Biederman
devpts does not and never will have anything to sync so don't bother calling sync_filesystems on remount. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-23devpts: Make devpts_kill_sb safe if fsi is NULLEric W. Biederman
2016-09-23devpts: Simplify devpts_mount by using mount_nodevEric W. Biederman
Now that all of the work of setting up a superblock has been moved to devpts_fill_super simplify devpts_mount by calling mount_nodev instead of rolling mount_nodev by hand. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-23devpts: Move the creation of /dev/pts/ptmx into fill_superEric W. Biederman
The code makes more sense here and things are just clearer. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-23devpts: Move parse_mount_options into fill_superEric W. Biederman
2016-09-03devpts: return NULL pts 'priv' entry for non-devpts nodesLinus Torvalds
In commit 8ead9dd54716 ("devpts: more pty driver interface cleanups") I made devpts_get_priv() just return the dentry->fs_data directly. And because I thought it wouldn't happen, I added a warning if you ever saw a pts node that wasn't on devpts. And no, that warning never triggered under any actual real use, but you can trigger it by creating nonsensical pts nodes by hand. So just revert the warning, and make devpts_get_priv() return NULL for that case like it used to. Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: stable@vger.kernel.org # 4.6+ Cc: Eric W Biederman" <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-23userns: Remove the now unnecessary FS_USERNS_DEV_MOUNT flagEric W. Biederman
Now that SB_I_NODEV controls the nodev behavior devpts can just clear this flag during mount. Simplifying the code and making it easier to audit how the code works. While still preserving the invariant that s_iflags is only modified during mount. Acked-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2016-06-05devpts: Make each mount of devpts an independent filesystem.Eric W. Biederman
The /dev/ptmx device node is changed to lookup the directory entry "pts" in the same directory as the /dev/ptmx device node was opened in. If there is a "pts" entry and that entry is a devpts filesystem /dev/ptmx uses that filesystem. Otherwise the open of /dev/ptmx fails. The DEVPTS_MULTIPLE_INSTANCES configuration option is removed, so that userspace can now safely depend on each mount of devpts creating a new instance of the filesystem. Each mount of devpts is now a separate and equal filesystem. Reserved ttys are now available to all instances of devpts where the mounter is in the initial mount namespace. A new vfs helper path_pts is introduced that finds a directory entry named "pts" in the directory of the passed in path, and changes the passed in path to point to it. The helper path_pts uses a function path_parent_directory that was factored out of follow_dotdot. In the implementation of devpts: - devpts_mnt is killed as it is no longer meaningful if all mounts of devpts are equal. - pts_sb_from_inode is replaced by just inode->i_sb as all cached inodes in the tty layer are now from the devpts filesystem. - devpts_add_ref is rolled into the new function devpts_ptmx. And the unnecessary inode hold is removed. - devpts_del_ref is renamed devpts_release and reduced to just a deacrivate_super. - The newinstance mount option continues to be accepted but is now ignored. In devpts_fs.h definitions for when !CONFIG_UNIX98_PTYS are removed as they are never used. Documentation/filesystems/devices.txt is updated to describe the current situation. This has been verified to work properly on openwrt-15.05, centos5, centos6, centos7, debian-6.0.2, debian-7.9, debian-8.2, ubuntu-14.04.3, ubuntu-15.10, fedora23, magia-5, mint-17.3, opensuse-42.1, slackware-14.1, gentoo-20151225 (13.0?), archlinux-2015-12-01. With the caveat that on centos6 and on slackware-14.1 that there wind up being two instances of the devpts filesystem mounted on /dev/pts, the lower copy does not end up getting used. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Greg KH <greg@kroah.com> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Peter Anvin <hpa@zytor.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Serge Hallyn <serge.hallyn@ubuntu.com> Cc: Willy Tarreau <w@1wt.eu> Cc: Aurelien Jarno <aurelien@aurel32.net> Cc: One Thousand Gnomes <gnomes@lxorguk.ukuu.org.uk> Cc: Jann Horn <jann@thejh.net> Cc: Jiri Slaby <jslaby@suse.com> Cc: Florian Weimer <fw@deneb.enyo.de> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-04-26devpts: more pty driver interface cleanupsLinus Torvalds
This is more prep-work for the upcoming pty changes. Still just code cleanup with no actual semantic changes. This removes a bunch pointless complexity by just having the slave pty side remember the dentry associated with the devpts slave rather than the inode. That allows us to remove all the "look up the dentry" code for when we want to remove it again. Together with moving the tty pointer from "inode->i_private" to "dentry->d_fsdata" and getting rid of pointless inode locking, this removes about 30 lines of code. Not only is the end result smaller, it's simpler and easier to understand. The old code, for example, depended on the d_find_alias() to not just find the dentry, but also to check that it is still hashed, which in turn validated the tty pointer in the inode. That is a _very_ roundabout way to say "invalidate the cached tty pointer when the dentry is removed". The new code just does dentry->d_fsdata = NULL; in devpts_pty_kill() instead, invalidating the tty pointer rather more directly and obviously. Don't do something complex and subtle when the obvious straightforward approach will do. The rest of the patch (ie apart from code deletion and the above tty pointer clearing) is just switching the calling convention to pass the dentry or file pointer around instead of the inode. Cc: Eric Biederman <ebiederm@xmission.com> Cc: Peter Anvin <hpa@zytor.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Serge Hallyn <serge.hallyn@ubuntu.com> Cc: Willy Tarreau <w@1wt.eu> Cc: Aurelien Jarno <aurelien@aurel32.net> Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk> Cc: Jann Horn <jann@thejh.net> Cc: Greg KH <greg@kroah.com> Cc: Jiri Slaby <jslaby@suse.com> Cc: Florian Weimer <fw@deneb.enyo.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-04-18devpts: clean up interface to pty driversLinus Torvalds
This gets rid of the horrible notion of having that struct inode *ptmx_inode be the linchpin of the interface between the pty code and devpts. By de-emphasizing the ptmx inode, a lot of things actually get cleaner, and we will have a much saner way forward. In particular, this will allow us to associate with any particular devpts instance at open-time, and not be artificially tied to one particular ptmx inode. The patch itself is actually fairly straightforward, and apart from some locking and return path cleanups it's pretty mechanical: - the interfaces that devpts exposes all take "struct pts_fs_info *" instead of "struct inode *ptmx_inode" now. NOTE! The "struct pts_fs_info" thing is a completely opaque structure as far as the pty driver is concerned: it's still declared entirely internally to devpts. So the pty code can't actually access it in any way, just pass it as a "cookie" to the devpts code. - the "look up the pts fs info" is now a single clear operation, that also does the reference count increment on the pts superblock. So "devpts_add/del_ref()" is gone, and replaced by a "lookup and get ref" operation (devpts_get_ref(inode)), along with a "put ref" op (devpts_put_ref()). - the pty master "tty->driver_data" field now contains the pts_fs_info, not the ptmx inode. - because we don't care about the ptmx inode any more as some kind of base index, the ref counting can now drop the inode games - it just gets the ref on the superblock. - the pts_fs_info now has a back-pointer to the super_block. That's so that we can easily look up the information we actually need. Although quite often, the pts fs info was actually all we wanted, and not having to look it up based on some magical inode makes things more straightforward. In particular, now that "devpts_get_ref(inode)" operation should really be the *only* place we need to look up what devpts instance we're associated with, and we do it exactly once, at ptmx_open() time. The other side of this is that one ptmx node could now be associated with multiple different devpts instances - you could have a single /dev/ptmx node, and then have multiple mount namespaces with their own instances of devpts mounted on /dev/pts/. And that's all perfectly sane in a model where we just look up the pts instance at open time. This will eventually allow us to get rid of our odd single-vs-multiple pts instance model, but this patch in itself changes no semantics, only an internal binding model. Cc: Eric Biederman <ebiederm@xmission.com> Cc: Peter Anvin <hpa@zytor.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Serge Hallyn <serge.hallyn@ubuntu.com> Cc: Willy Tarreau <w@1wt.eu> Cc: Aurelien Jarno <aurelien@aurel32.net> Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk> Cc: Jann Horn <jann@thejh.net> Cc: Greg KH <greg@kroah.com> Cc: Jiri Slaby <jslaby@suse.com> Cc: Florian Weimer <fw@deneb.enyo.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-02-06pty: make sure super_block is still valid in final /dev/tty closeHerton R. Krzesinski
Considering current pty code and multiple devpts instances, it's possible to umount a devpts file system while a program still has /dev/tty opened pointing to a previosuly closed pty pair in that instance. In the case all ptmx and pts/N files are closed, umount can be done. If the program closes /dev/tty after umount is done, devpts_kill_index will use now an invalid super_block, which was already destroyed in the umount operation after running ->kill_sb. This is another "use after free" type of issue, but now related to the allocated super_block instance. To avoid the problem (warning at ida_remove and potential crashes) for this specific case, I added two functions in devpts which grabs additional references to the super_block, which pty code now uses so it makes sure the super block structure is still valid until pty shutdown is done. I also moved the additional inode references to the same functions, which also covered similar case with inode being freed before /dev/tty final close/shutdown. Signed-off-by: Herton R. Krzesinski <herton@redhat.com> Cc: stable@vger.kernel.org # 2.6.29+ Reviewed-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-01-22wrappers for ->i_mutex accessAl Viro
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested}, inode_foo(inode) being mutex_foo(&inode->i_mutex). Please, use those for access to ->i_mutex; over the coming cycle ->i_mutex will become rwsem, with ->lookup() done with it held only shared. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-06-30devpts: if initialization failed, don't crash when opening /dev/ptmxJosh Triplett
If devpts failed to initialize, it would store an ERR_PTR in the global devpts_mnt. A subsequent open of /dev/ptmx would call devpts_new_index, which would dereference devpts_mnt and crash. Avoid storing invalid values in devpts_mnt; leave it NULL instead. Make both devpts_new_index and devpts_pty_new fail gracefully with ENODEV in that case, which then becomes the return value to the userspace open call on /dev/ptmx. [akpm@linux-foundation.org: remove unneeded static] Signed-off-by: Josh Triplett <josh@joshtriplett.org> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Reviewed-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-06-06fs/devpts/inode.c: convert printk to pr_foo()Fabian Frederick
Also convert spaces to tabs (checkpatch warnings) if (!dentry) KERN_NOTICE converted to pr_err (like if (!inode) error process) [akpm@linux-foundation.org: use KBUILD_MODNAME, per Joe] Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Joe Perches <joe@perches.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-13fs: push sync_filesystem() down to the file system's remount_fs()Theodore Ts'o
Previously, the no-op "mount -o mount /dev/xxx" operation when the file system is already mounted read-write causes an implied, unconditional syncfs(). This seems pretty stupid, and it's certainly documented or guaraunteed to do this, nor is it particularly useful, except in the case where the file system was mounted rw and is getting remounted read-only. However, it's possible that there might be some file systems that are actually depending on this behavior. In most file systems, it's probably fine to only call sync_filesystem() when transitioning from read-write to read-only, and there are some file systems where this is not needed at all (for example, for a pseudo-filesystem or something like romfs). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-fsdevel@vger.kernel.org Cc: Christoph Hellwig <hch@infradead.org> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Jan Kara <jack@suse.cz> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Anders Larsen <al@alarsen.net> Cc: Phillip Lougher <phillip@squashfs.org.uk> Cc: Kees Cook <keescook@chromium.org> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: xfs@oss.sgi.com Cc: linux-btrfs@vger.kernel.org Cc: linux-cifs@vger.kernel.org Cc: samba-technical@lists.samba.org Cc: codalist@coda.cs.cmu.edu Cc: linux-ext4@vger.kernel.org Cc: linux-f2fs-devel@lists.sourceforge.net Cc: fuse-devel@lists.sourceforge.net Cc: cluster-devel@redhat.com Cc: linux-mtd@lists.infradead.org Cc: jfs-discussion@lists.sourceforge.net Cc: linux-nfs@vger.kernel.org Cc: linux-nilfs@vger.kernel.org Cc: linux-ntfs-dev@lists.sourceforge.net Cc: ocfs2-devel@oss.oracle.com Cc: reiserfs-devel@vger.kernel.org
2013-11-13devpts: plug the memory leak in kill_sbIlija Hadzic
When devpts is unmounted, there may be a no-longer-used IDR tree hanging off the superblock we are about to kill. This needs to be cleaned up before destroying the SB. The leak is usually not a big deal because unmounting devpts is typically done when shutting down the whole machine. However, shutting down an LXC container instead of a physical machine exposes the problem (the garbage is detectable with kmemleak). Signed-off-by: Ilija Hadzic <ihadzic@research.bell-labs.com> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-26userns: Allow the userns root to mount of devptsEric W. Biederman
- The context in which devpts is mounted has no effect on the creation of ptys as the /dev/ptmx interface has been used by unprivileged users for many years. - Only support unprivileged mounts in combination with the newinstance option to ensure that mounting of /dev/pts in a user namespace will not allow the options of an existing mount of devpts to be modified. - Create /dev/pts/ptmx as the root user in the user namespace that mounts devpts so that it's permissions to be changed. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-10-22TTY: devpts, document devpts inode operationsJiri Slaby
Add kernel-doc texts for some devpts functions, i.e. document them. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: devpts, do not set driver_dataJiri Slaby
The goal is to stop setting and using tty->driver_data in devpts code. It should be used solely by the driver's code, pty in this case. Now driver_data are managed only in the pty driver. devpts_pty_new is switched to accept what we used to dig out of tty_struct, i.e. device node number and index. This also removes a note about driver_data being set outside of the driver. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: devpts, return created inode from devpts_pty_newJiri Slaby
The goal is to stop setting and using tty->driver_data in devpts code. It should be used solely by the driver's code, pty in this case. For the cleanup of layering, we will need the inode created in devpts_pty_new to be stored into slave's driver_data. So we convert devpts_pty_new to return the inode or an ERR_PTR-encoded error in case of failure. The move of 'inode = new_inode(sb);' from declarators to the code is only cosmetical, but it makes the code easier to read. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: devpts, don't care about TTY in devpts_get_ttyJiri Slaby
The goal is to stop setting and using tty->driver_data in devpts code. It should be used solely by the driver's code, pty in this case. First, here we remove TTY from devpts_get_tty and rename it to devpts_get_priv. Note we do not remove type safety, we just shift the [implicit] (void *) cast one layer up. index was unused in devpts_get_tty, so remove that from the prototype too. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-14VFS: Pass mount flags to sget()David Howells
Pass mount flags to sget() so that it can use them in initialising a new superblock before the set function is called. They could also be passed to the compare function. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-15userns: Convert devpts to use kuid/kgid where appropriateEric W. Biederman
Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "This is _not_ all; in particular, Miklos' and Jan's stuff is not there yet." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits) ext4: initialization of ext4_li_mtx needs to be done earlier debugfs-related mode_t whack-a-mole hfsplus: add an ioctl to bless files hfsplus: change finder_info to u32 hfsplus: initialise userflags qnx4: new helper - try_extent() qnx4: get rid of qnx4_bread/qnx4_getblk take removal of PF_FORKNOEXEC to flush_old_exec() trim includes in inode.c um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it um: embed ->stub_pages[] into mmu_context gadgetfs: list_for_each_safe() misuse ocfs2: fix leaks on failure exits in module_init ecryptfs: make register_filesystem() the last potential failure exit ntfs: forgets to unregister sysctls on register_filesystem() failure logfs: missing cleanup on register_filesystem() failure jfs: mising cleanup on register_filesystem() failure make configfs_pin_fs() return root dentry on success configfs: configfs_create_dir() has parent dentry in dentry->d_parent configfs: sanitize configfs_create() ...
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-01-24tty: rework pty count limitingKonstantin Khlebnikov
After adding devpts multiple-insrances sysctl kernel.pty.max limit pty count for each devpts instance independently, while kernel.pty.nr shows total pty count. This patch restores sysctl kernel.pty.max as global limit (4096 by default), adds pty reseve for main devpts (mounted without "newinstance" argument), and new sysctl to tune it: kernel.pty.reserve (1024 by default) Also it adds devpts mount option "max=%d" to limit pty count for each devpts instance independently. (by default NR_UNIX98_PTY_MAX == 2^20) Thus devpts instances in containers cannot eat up all available pty even if we didn't set any limits, while with "max" argument we can adjust limits more precisely. Plus, now open("/dev/ptmx") return -ENOSPC in case lack of pty indexes, this is more informative than -EIO. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24tty: move pty count limiting into devptsKonstantin Khlebnikov
Let's move this stuff to the better place, where we can account pty right in tty-indexes managing code. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-08devpts: fix double-free on mount failureAl Viro
devpts_kill_sb() is called even if devpts_fill_super() fails; we should not do that kfree() in the latter, especially not with ->s_fs_info left pointing to freed object. Double kfree() is a Bad Thing(tm)... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-06vfs: switch ->show_options() to struct dentry *Al Viro
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-11-02filesystems: add missing nlink wrappersMiklos Szeredi
Replace direct i_nlink updates with the respective updater function (inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-03-22fs/devpts/inode.c: correctly check d_alloc_name() return code in ↵Andrey Vagin
devpts_pty_new() d_alloc_name return NULL in case error, but we expect errno in devpts_pty_new. Addresses http://bugzilla.openvz.org/show_bug.cgi?id=1758 Signed-off-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-21fs: devpts_pty_new() return -ENOMEM if dentry allocation failedAndrey Vagin
In this case nobody can open a slave point, so will be better return from devpts_pty_new() Now we should not check error code from d_find_alias() in devpts_pty_kill(), because the dentry exists all times. Signed-off-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-29convert get_sb_single() usersAl Viro
2010-05-21Simplify devpts_get_sb() failure exitsAl Viro
postpone simple_set_mnt() until we know we won't fail. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-11devpts_get_tty() should validate inodeSukadev Bhattiprolu
devpts_get_tty() assumes that the inode passed in is associated with a valid pty. But if the only reference to the pty is via a bind-mount, the inode passed to devpts_get_tty() while valid, would refer to a pty that no longer exists. With a lot of debug effort, Grzegorz Nosek developed a small program (see below) to reproduce a crash on recent kernels. This crash is a regression introduced by the commit: commit 527b3e4773628b30d03323a2cb5fb0d84441990f Author: Sukadev Bhattiprolu <sukadev@us.ibm.com> Date: Mon Oct 13 10:43:08 2008 +0100 To fix, ensure that the dentry associated with the inode has not yet been deleted/unhashed by devpts_pty_kill(). See also: https://lists.linux-foundation.org/pipermail/containers/2009-July/019273.html tty-bug.c: #define _GNU_SOURCE #include <fcntl.h> #include <sched.h> #include <stdlib.h> #include <sys/mount.h> #include <sys/signal.h> #include <unistd.h> #include <stdio.h> #include <linux/fs.h> void dummy(int sig) { } static int child(void *unused) { int fd; signal(SIGINT, dummy); signal(SIGHUP, dummy); pause(); /* cheesy synchronisation to wait for /dev/pts/0 to appear */ mount("/dev/pts/0", "/dev/console", NULL, MS_BIND, NULL); sleep(2); fd = open("/dev/console", O_RDWR); dup(0); dup(0); write(1, "Hello world!\n", sizeof("Hello world!\n")-1); return 0; } int main(void) { pid_t pid; char *stack; stack = malloc(16384); pid = clone(child, stack+16384, CLONE_NEWNS|SIGCHLD, NULL); open("/dev/ptmx", O_RDWR|O_NOCTTY|O_NONBLOCK); unlockpt(fd); grantpt(fd); sleep(2); kill(pid, SIGHUP); sleep(1); return 0; /* exit before child opens /dev/console */ } Reported-by: Grzegorz Nosek <root@localdomain.pl> Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Serge Hallyn <serue@us.ibm.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23Move magic numbers into magic.hNick Black
Move various magic-number definitions into magic.h. Signed-off-by: Nick Black <dank@qemfd.net> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "David S. Miller" <davem@davemloft.net> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24devpts: remove module-related codeH. Peter Anvin
These days, the devpts filesystem is closely integrated with the pty memory management, and cannot be built as a module, even less removed from the kernel. Accordingly, remove all module-related stuff from this filesystem. [ v2: only remove code that's actually dead ] Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11devpts: unregister the file system on errorAlan Cox
Closes-bug: http://bugzilla.kernel.org/show_bug.cgi?id=13429 Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-15devpts: correctly set default optionsSukadev Bhattiprolu
devpts_get_sb() calls memset(0) to clear mount options and calls parse_mount_options() if user specified any mount options. The memset(0) is bogus since the 'mode' and 'ptmxmode' options are non-zero by default. parse_mount_options() restores options to default anyway and can properly deal with NULL mount options. So in devpts_get_sb() remove memset(0) and call parse_mount_options() even for NULL mount options. Bug reported by Eric Paris: http://lkml.org/lkml/2009/5/7/448. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Tested-by: Marc Dionne <marc.c.dionne@gmail.com> Reported-by: Eric Paris <eparis@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Reviewed-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-09Convert obvious places to deactivate_locked_super()Al Viro
2009-03-27Merge code for single and multiple-instance mountsSukadev Bhattiprolu
new_pts_mount() (including the get_sb_nodev()), shares a lot of code with init_pts_mount(). The only difference between them is the 'test-super' function passed into sget(). Move all common code into devpts_get_sb() and remove the new_pts_mount() and init_pts_mount() functions, Changelog[v3]: [Serge Hallyn]: Remove unnecessary printk()s Changelog[v2]: (Christoph Hellwig): Merge code in 'do_pts_mount()' into devpts_get_sb() Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Tested-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27Remove get_init_pts_sb()Sukadev Bhattiprolu
With mknod_ptmx() moved to devpts_get_sb(), init_pts_mount() becomes a wrapper around get_init_pts_sb(). Remove get_init_pts_sb() and fold code into init_pts_mount(). Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27Move common mknod_ptmx() calls into callerSukadev Bhattiprolu
We create 'ptmx' node in both single-instance and multiple-instance mounts. So devpts_get_sb() can call mknod_ptmx() once rather than have both modes calling mknod_ptmx() separately. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27Parse mount options just once and copy them to super blockSukadev Bhattiprolu
Since all the mount option parsing is done in devpts, we could do it just once and pass it around in devpts functions and eventually store it in the super block. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
