path: root/fs/devpts
2010-05-21Simplify devpts_get_sb() failure exitsAl Viro
postpone simple_set_mnt() until we know we won't fail. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-11devpts_get_tty() should validate inodeSukadev Bhattiprolu
devpts_get_tty() assumes that the inode passed in is associated with a valid pty. But if the only reference to the pty is via a bind-mount, the inode passed to devpts_get_tty() while valid, would refer to a pty that no longer exists. With a lot of debug effort, Grzegorz Nosek developed a small program (see below) to reproduce a crash on recent kernels. This crash is a regression introduced by the commit: commit 527b3e4773628b30d03323a2cb5fb0d84441990f Author: Sukadev Bhattiprolu <sukadev@us.ibm.com> Date: Mon Oct 13 10:43:08 2008 +0100 To fix, ensure that the dentry associated with the inode has not yet been deleted/unhashed by devpts_pty_kill(). See also: https://lists.linux-foundation.org/pipermail/containers/2009-July/019273.html tty-bug.c: #define _GNU_SOURCE #include <fcntl.h> #include <sched.h> #include <stdlib.h> #include <sys/mount.h> #include <sys/signal.h> #include <unistd.h> #include <stdio.h> #include <linux/fs.h> void dummy(int sig) { } static int child(void *unused) { int fd; signal(SIGINT, dummy); signal(SIGHUP, dummy); pause(); /* cheesy synchronisation to wait for /dev/pts/0 to appear */ mount("/dev/pts/0", "/dev/console", NULL, MS_BIND, NULL); sleep(2); fd = open("/dev/console", O_RDWR); dup(0); dup(0); write(1, "Hello world!\n", sizeof("Hello world!\n")-1); return 0; } int main(void) { pid_t pid; char *stack; stack = malloc(16384); pid = clone(child, stack+16384, CLONE_NEWNS|SIGCHLD, NULL); open("/dev/ptmx", O_RDWR|O_NOCTTY|O_NONBLOCK); unlockpt(fd); grantpt(fd); sleep(2); kill(pid, SIGHUP); sleep(1); return 0; /* exit before child opens /dev/console */ } Reported-by: Grzegorz Nosek <root@localdomain.pl> Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Serge Hallyn <serue@us.ibm.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23Move magic numbers into magic.hNick Black
Move various magic-number definitions into magic.h. Signed-off-by: Nick Black <dank@qemfd.net> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "David S. Miller" <davem@davemloft.net> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24devpts: remove module-related codeH. Peter Anvin
These days, the devpts filesystem is closely integrated with the pty memory management, and cannot be built as a module, even less removed from the kernel. Accordingly, remove all module-related stuff from this filesystem. [ v2: only remove code that's actually dead ] Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11devpts: unregister the file system on errorAlan Cox
Closes-bug: http://bugzilla.kernel.org/show_bug.cgi?id=13429 Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-15devpts: correctly set default optionsSukadev Bhattiprolu
devpts_get_sb() calls memset(0) to clear mount options and calls parse_mount_options() if user specified any mount options. The memset(0) is bogus since the 'mode' and 'ptmxmode' options are non-zero by default. parse_mount_options() restores options to default anyway and can properly deal with NULL mount options. So in devpts_get_sb() remove memset(0) and call parse_mount_options() even for NULL mount options. Bug reported by Eric Paris: http://lkml.org/lkml/2009/5/7/448. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Tested-by: Marc Dionne <marc.c.dionne@gmail.com> Reported-by: Eric Paris <eparis@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Reviewed-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-09Convert obvious places to deactivate_locked_super()Al Viro
2009-03-27Merge code for single and multiple-instance mountsSukadev Bhattiprolu
new_pts_mount() (including the get_sb_nodev()), shares a lot of code with init_pts_mount(). The only difference between them is the 'test-super' function passed into sget(). Move all common code into devpts_get_sb() and remove the new_pts_mount() and init_pts_mount() functions, Changelog[v3]: [Serge Hallyn]: Remove unnecessary printk()s Changelog[v2]: (Christoph Hellwig): Merge code in 'do_pts_mount()' into devpts_get_sb() Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Tested-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27Remove get_init_pts_sb()Sukadev Bhattiprolu
With mknod_ptmx() moved to devpts_get_sb(), init_pts_mount() becomes a wrapper around get_init_pts_sb(). Remove get_init_pts_sb() and fold code into init_pts_mount(). Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27Move common mknod_ptmx() calls into callerSukadev Bhattiprolu
We create 'ptmx' node in both single-instance and multiple-instance mounts. So devpts_get_sb() can call mknod_ptmx() once rather than have both modes calling mknod_ptmx() separately. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27Parse mount options just once and copy them to super blockSukadev Bhattiprolu
Since all the mount option parsing is done in devpts, we could do it just once and pass it around in devpts functions and eventually store it in the super block. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27Unroll essentials of do_remount_sb() into devptsSukadev Bhattiprolu
On remount, devpts fs only needs to parse the mount options. Users cannot directly create/dirty files in /dev/pts so the MS_RDONLY flag and shrinking the dcache does not really apply to devpts. So effectively on remount, devpts only parses the mount options and updates these options in its super block. As such, we could replace do_remount_sb() call with a direct parse_mount_options(). Doing so enables subsequent patches to avoid parsing the mount options twice and simplify the code. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27vfs: simple_set_mnt() should return voidSukadev Bhattiprolu
simple_set_mnt() is defined as returning 'int' but always returns 0. Callers assume simple_set_mnt() never fails and don't properly cleanup if it were to _ever_ fail. For instance, get_sb_single() and get_sb_nodev() should: up_write(sb->s_unmount); deactivate_super(sb); if simple_set_mnt() fails. Since simple_set_mnt() never fails, would be cleaner if it did not return anything. [akpm@linux-foundation.org: fix build] Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27devpts: Must release s_umount on errorSukadev Bhattiprolu
We should drop the ->s_umount mutex if an error occurs after the sget()/grab_super() call. This was introduced when adding support for multiple instances of devpts and noticed during a code review/reorg. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-10devpts: remove graffitiAlexey Dobriyan
Very annoying when working with containters. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05zero i_uid/i_gid on inode allocationAl Viro
... and don't bother in callers. Don't bother with zeroing i_blocks, while we are at it - it's already been zeroed. i_mode is not worth the effort; it has no common default value. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-02CRED: Wrap task credential accesses in the devpts filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02devpts: fix unused function warningAndrew Morton
fs/devpts/inode.c:324: warning: 'compare_init_pts_sb' defined but not used Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02devpts: Coding style clean upAlan Cox
Just nail the oddments now while this code is being touched Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02Enable multiple instances of devptsSukadev Bhattiprolu
To support containers, allow multiple instances of devpts filesystem, such that indices of ptys allocated in one instance are independent of ptys allocated in other instances of devpts. But to preserve backward compatibility, enable this support for multiple instances only if: - CONFIG_DEVPTS_MULTIPLE_INSTANCES is set to Y, and - '-o newinstance' mount option is specified while mounting devpts To use multi-instance mount, a container startup script could: $ ns_exec -cm /bin/bash $ umount /dev/pts $ mount -t devpts -o newinstance lxcpts /dev/pts $ mount -o bind /dev/pts/ptmx /dev/ptmx $ /usr/sbin/sshd -p 1234 where 'ns_exec -cm /bin/bash' is calls clone() with CLONE_NEWNS flag and execs /bin/bash in the child process. A pty created by the sshd is not visible in the original mount of /dev/pts. USER-SPACE-IMPACT: - See Documentation/fs/devpts.txt (included in next patch) for user- space impact in multi-instance and mixed-mode operation. TODO: - Update mount(8), pts(4) man pages. Highlight impact of not redirecting /dev/ptmx to /dev/pts/ptmx after a multi-instance mount. Changelog[v6]: - [Dave Hansen] Use new get_init_pts_sb() interface - [Serge Hallyn] Don't bother displaying 'newinstance' in show_options - [Serge Hallyn] Use macros (PARSE_REMOUNT/PARSE_MOUNT) instead of 0/1. - [Serge Hallyn] Check error return from get_sb_single() (now get_init_pts_sb()) - devpts_pty_kill(): don't dput error dentries Changelog[v5]: - Move get_sb_ref() definition to earlier patch - Move usage info to Documentation/filesystems/devpts.txt (next patch) - Make ptmx node even in init_pts_ns, now that default mode is 0000 (defined in earlier patch, enabled here). - Cache ptmx dentry and use to update mode during remount (defined in earlier patch, enabled here). - Bugfix: explicitly ignore newinstance on remount (if newinstance was specified on remount of initial mount, it would be ignored but /proc/mounts would imply that the option was set) Changelog[v4]: - Update patch description to address H. Peter Anvin's comments - Consolidate multi-instance mode code under new config token, CONFIG_DEVPTS_MULTIPLE_INSTANCE. - Move usage-details from patch description to Documentation/fs/devpts.txt Changelog[v3]: - Rename new mount option to 'newinstance' - Create ptmx nodes only in 'newinstance' mounts - Bugfix: parse_mount_options() modifies @data but since we need to parse the @data twice (once in devpts_get_sb() and once during do_remount_sb()), parse a local copy of @data in devpts_get_sb(). (restructured code in devpts_get_sb() to fix this) Changelog[v2]: - Support both single-mount and multiple-mount semantics and provide '-onewmnt' option to select the semantics. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02Define get_init_pts_sb()Sukadev Bhattiprolu
See comments in the function header for details. The new interface will be used in a follow-on patch. Changelog [v2]: [Dave Hansen] Replace get_sb_ref() in fs/super.c with get_init_pts_sb() and make the new interface private to devpts Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02Define mknod_ptmx()Sukadev Bhattiprolu
/dev/ptmx is closely tied to the devpts filesystem. An open of /dev/ptmx, allocates the next pty index and the associated device shows up in the devpts fs as /dev/pts/n. Wih multiple instancs of devpts filesystem, during an open of /dev/ptmx we would be unable to determine which instance of the devpts is being accessed. So we move the 'ptmx' node into /dev/pts and use the inode of the 'ptmx' node to identify the superblock and hence the devpts instance. This patch adds ability for the kernel to internally create the [ptmx, c, 5:2] device when mounting devpts filesystem. Since the ptmx node in devpts is new and may surprise some userspace scripts, the default permissions for the new node is 0000. These permissions can be changed either using chmod or by remounting with the new '-o ptmxmode=0666' mount option. Changelog[v5]: - [Serge Hallyn bugfix]: Letting new_inode() assign inode number to ptmx can collide with hand-assigning inode numbers to ptys. So, hand-assign specific inode number to ptmx node also. - [Serge Hallyn]: Maybe safer to grab root dentry mutex while creating ptmx node - [Bugfix with Serge Hallyn] Replace lookup_one_len() in mknod_ptmx() wih d_alloc_name() (lookup during ->get_sb() locks up system). To simplify patchset, fold the ptmx_dentry patch into this. Changelog[v4]: - Change default permissions of pts/ptmx node to 0000. - Move code for ptmxmode under #ifdef CONFIG_DEVPTS_MULTIPLE_INSTANCES. Changelog[v3]: - Rename ptmx_mode to ptmxmode (for consistency with 'newinstance') Changelog[v2]: - [H. Peter Anvin] Remove mknod() system call support and create the ptmx node internally. Changelog[v1]: - Earlier version of this patch enabled creating /dev/pts/tty as well. As pointed out by Al Viro and H. Peter Anvin, that is not really necessary. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02Extract option parsing to new functionSukadev Bhattiprolu
Move code to parse mount options into a separate function so it can (later) be shared between mount and remount operations. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02Per-mount 'config' objectSukadev Bhattiprolu
With support for multiple mounts of devpts, the 'config' structure really represents per-mount options rather than config parameters. Rename 'config' structure to 'pts_mount_opts' and store it in the super-block. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02Per-mount allocated_ptysSukadev Bhattiprolu
To enable multiple mounts of devpts, 'allocated_ptys' must be a per-mount variable rather than a global variable. Move 'allocated_ptys' into the super_block's s_fs_info. Changelog[v2]: Define and use DEVPTS_SB() wrapper. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02Remove devpts_root globalSukadev Bhattiprolu
Remove the 'devpts_root' global variable and find the root dentry using the super_block. The super-block can be found from the device inode, using the new wrapper, pts_sb_from_inode(). Changelog: This patch is based on an earlier patchset from Serge Hallyn and Matt Helsley. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Wrap task credential accesses in the devpts filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-13vfs: Use const for kernel parser tableSteven Whitehouse
This is a much better version of a previous patch to make the parser tables constant. Rather than changing the typedef, we put the "const" in all the various places where its required, allowing the __initconst exception for nfsroot which was the cause of the previous trouble. This was posted for review some time ago and I believe its been in -mm since then. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Simplify devpts_pty_killSukadev Bhattiprolu
When creating a new pty, save the pty's inode in the tty->driver_data. Use this inode in pty_kill() to identify the devpts instance. Since we now have the inode for the pty, we can skip get_node() lookup and remove the unused get_node(). TODO: - check if the mutex_lock is needed in pty_kill(). Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Simplify devpts_pty_new()Sukadev Bhattiprolu
devpts_pty_new() is called when setting up a new pty and would not will not have an existing dentry or inode for the pty. So don't bother looking for an existing dentry - just create a new one. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Simplify devpts_get_tty()Sukadev Bhattiprolu
As pointed out by H. Peter Anvin, since the inode for the pty is known, we don't need to look it up. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Add an instance parameter devpts interfacesSukadev Bhattiprolu
Pass-in 'inode' or 'tty' parameter to devpts interfaces. With multiple devpts instances, these parameters will be used in subsequent patches to identify the instance of devpts mounted. The parameters also help simplify devpts implementation. Changelog[v3]: - minor changes due to merge with ttydev updates - rename parameters to emphasize they are ptmx or pts inodes - pass-in tty_struct * to devpts_pty_kill() (this will help cleanup the get_node() call in a subsequent patch) Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-01[PATCH] devpts: switch to IDAAlexey Dobriyan
Devpts code wants just numbers for tty indexes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-30devpts: factor out PTY index allocationSukadev Bhattiprolu
Factor out the code used to allocate/free a pts index into new interfaces, devpts_new_index() and devpts_kill_index(). This localizes the external data structures used in managing the pts indices. [akpm@linux-foundation.org: undo accidental mutex2sem conversion] Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08mount options: fix devptsMiklos Szeredi
Add a .show_options super operation to devpts. Small cleanup: when parsing the "mode" option, mask with S_IALLUGO instead of ~S_IFMT. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08devpts: add fsnotify create eventFlorin Malita
Currently, devpts doesn't generate an fsnotify event upon pts creation because the regular vfs paths aren't involved. Deallocation, on the other hand, correctly generates a nameremove event thanks to the d_delete() invocation in devpts_pty_kill(). This patch adds the missing fsnotify_create() trigger in devpts_pty_new(). Signed-off-by: Florin Malita <fmalita@gmail.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-27[PATCH] inode_diet: Replace inode.u.generic_ip with inode.i_privateTheodore Ts'o
The following patches reduce the size of the VFS inode structure by 28 bytes on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction in the inode size on a UP kernel that is configured in a production mode (i.e., with no spinlock or other debugging functions enabled; if you want to save memory taken up by in-core inodes, the first thing you should do is disable the debugging options; they are responsible for a huge amount of bloat in the VFS inode structure). This patch: The filesystem or device-specific pointer in the inode is inside a union, which is pretty pointless given that all 30+ users of this field have been using the void pointer. Get rid of the union and rename it to i_private, with a comment to explain who is allowed to use the void pointer. This is just a cleanup, but it allows us to reuse the union 'u' for something something where the union will actually be used. [judith@osdl.org: powerpc build fix] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Judith Lebzelter <judith@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] devpts: use lib/parser.c for parsing mount optionsDomen Puncer
Item from "2.6 should fix" list. Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-09-05[PATCH] Generic VFS fallback for security xattrsStephen Smalley
This patch modifies the VFS setxattr, getxattr, and listxattr code to fall back to the security module for security xattrs if the filesystem does not support xattrs natively. This allows security modules to export the incore inode security label information to userspace even if the filesystem does not provide xattr storage, and eliminates the need to individually patch various pseudo filesystem types to provide such access. The patch removes the existing xattr code from devpts and tmpfs as it is then no longer needed. The patch restructures the code flow slightly to reduce duplication between the normal path and the fallback path, but this should only have one user-visible side effect - a program may get -EACCES rather than -EOPNOTSUPP if policy denied access but the filesystem didn't support the operation anyway. Note that the post_setxattr hook call is not needed in the fallback case, as the inode_setsecurity hook call handles the incore inode security state update directly. In contrast, we do call fsnotify in both cases. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
