path: root/fs/dlm/config.h
2011-07-12dlm: improve rsb searchesDavid Teigland
By pre-allocating rsb structs before searching the hash table, they can be inserted immediately. This avoids always having to repeat the search when adding the struct to hash list. This also adds space to the rsb struct for a max resource name, so an rsb allocation can be used by any request. The constant size also allows us to finally use a slab for the rsb structs. Signed-off-by: David Teigland <teigland@redhat.com>
2011-07-11dlm: keep lkbs in idrDavid Teigland
This is simpler and quicker than the hash table, and avoids needing to search the hash list for every new lkid to check if it's used. Signed-off-by: David Teigland <teigland@redhat.com>
2011-04-01dlm: delayed reply message warningDavid Teigland
Add an option (disabled by default) to print a warning message when a lock has been waiting a configurable amount of time for a reply message from another node. This is mainly for debugging. Signed-off-by: David Teigland <teigland@redhat.com>
2008-04-21dlm: recover nodes that are removed and re-addedDavid Teigland
If a node is removed from a lockspace, and then added back before the dlm is notified of the removal, the dlm will not detect the removal and won't clear the old state from the node. This is fixed by using a list of added nodes so the membership recovery can detect when a newly added node is already in the member list. Signed-off-by: David Teigland <teigland@redhat.com>
2007-07-09[DLM] add lock timeouts and warnings [2/6]David Teigland
New features: lock timeouts and time warnings. If the DLM_LKF_TIMEOUT flag is set, then the request/conversion will be canceled after waiting the specified number of centiseconds (specified per lock). This feature is only available for locks requested through libdlm (can be enabled for kernel dlm users if there's a use for it.) If the new DLM_LSFL_TIMEWARN flag is set when creating the lockspace, then a warning message will be sent to userspace (using genetlink) after a request/conversion has been waiting for a given number of centiseconds (configurable per node). The time warnings will be used in the future to do deadlock detection in userspace. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-05-01[DLM] Consolidate transport protocolsPatrick Caulfield
This patch consolidates the TCP & SCTP protocols for the DLM into a single file and makes it switchable at run-time (well, at least before the DLM actually starts up!) For RHEL5 this patch requires Neil Horman's patch that expands the in-kernel socket API but that has already been twice ACKed so it should be OK. The patch adds a new lowcomms.c file that replaces the existing lowcomms-sctp.c & lowcomms-tcp.c files. Signed-off-By: Patrick Caulfield <pcaulfie@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-02-05[DLM] add config entry to enable log_debugDavid Teigland
Add a new dlm_config_info field to enable log_debug output and change log_debug() to use it. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-02-05[DLM] rename dlm_config_info fieldsDavid Teigland
Add a "ci_" prefix to the fields in the dlm_config_info struct so that we can use macros to add configfs functions to access them (in a later patch). No functional changes in this patch, just naming changes. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-18[DLM] The core of the DLM for GFS2/CLVMDavid Teigland
This is the core of the distributed lock manager which is required to use GFS2 as a cluster filesystem. It is also used by CLVM and can be used as a standalone lock manager independantly of either of these two projects. It implements VAX-style locking modes. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steve Whitehouse <swhiteho@redhat.com>
