path: root/fs/dlm/memory.c
2011-07-12dlm: improve rsb searchesDavid Teigland
By pre-allocating rsb structs before searching the hash table, they can be inserted immediately. This avoids always having to repeat the search when adding the struct to hash list. This also adds space to the rsb struct for a max resource name, so an rsb allocation can be used by any request. The constant size also allows us to finally use a slab for the rsb structs. Signed-off-by: David Teigland <teigland@redhat.com>
2009-11-30dlm: always use GFP_NOFSDavid Teigland
Replace all GFP_KERNEL and ls_allocation with GFP_NOFS. ls_allocation would be GFP_KERNEL for userland lockspaces and GFP_NOFS for file system lockspaces. It was discovered that any lockspaces on the system can affect all others by triggering memory reclaim in the file system which could in turn call back into the dlm to acquire locks, deadlocking dlm threads that were shared by all lockspaces, like dlm_recv. Signed-off-by: David Teigland <teigland@redhat.com>
2008-12-23dlm: fix up memory allocation flagsSteven Whitehouse
Use ls_allocation for memory allocations, which a cluster fs sets to GFP_NOFS. Use GFP_NOFS for allocations when no lockspace struct is available. Taking dlm locks needs to avoid calling back into the cluster fs because write-out can require taking dlm locks. Cc: Christine Caulfield <ccaulfie@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2008-02-06dlm: add __init and __exit marks to init and exit functionsDenis Cheng
it moves 365 bytes from .text to .init.text, and 30 bytes from .text to .exit.text, saves memory. Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: David Teigland <teigland@redhat.com>
2008-02-06dlm: eliminate astparam type castingDavid Teigland
Put lkb_astparam in a union with a dlm_user_args pointer to eliminate a lot of type casting. Signed-off-by: David Teigland <teigland@redhat.com>
2008-01-29dlm: use dlm prefix on alloc and free functionsDavid Teigland
The dlm functions in memory.c should use the dlm_ prefix. Also, use kzalloc/kfree directly for dlm_direntry's, removing the wrapper functions. Signed-off-by: David Teigland <teigland@redhat.com>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Transform kmem_cache_alloc()+memset(0) -> kmem_cache_zalloc().Robert P. J. Day
Replace appropriate pairs of "kmem_cache_alloc()" + "memset(0)" with the corresponding "kmem_cache_zalloc()" call. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Roland McGrath <roland@redhat.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Acked-by: Joel Becker <Joel.Becker@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jan Kara <jack@ucw.cz> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-08-09[DLM] print bad length in assertionDavid Teigland
Print the violating name length in the assertion. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-07-13[DLM] dlm: user locksDavid Teigland
This changes the way the dlm handles user locks. The core dlm is now aware of user locks so they can be dealt with more efficiently. There is no more dlm_device module which previously managed its own duplicate copy of every user lock. Signed-off-by: Patrick Caulfield <pcaulfie@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-02-23[DLM] Remove range locks from the DLMDavid Teigland
This patch removes support for range locking from the DLM Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-18[DLM] The core of the DLM for GFS2/CLVMDavid Teigland
This is the core of the distributed lock manager which is required to use GFS2 as a cluster filesystem. It is also used by CLVM and can be used as a standalone lock manager independantly of either of these two projects. It implements VAX-style locking modes. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steve Whitehouse <swhiteho@redhat.com>
