path: root/fs/dlm/rcom.h
2007-10-10[DLM] block dlm_recv in recovery transitionDavid Teigland
Introduce a per-lockspace rwsem that's held in read mode by dlm_recv threads while working in the dlm. This allows dlm_recv activity to be suspended when the lockspace transitions to, from and between recovery cycles. The specific bug prompting this change is one where an in-progress recovery cycle is aborted by a new recovery cycle. While dlm_recv was processing a recovery message, the recovery cycle was aborted and dlm_recoverd began cleaning up. dlm_recv decremented recover_locks_count on an rsb after dlm_recoverd had reset it to zero. This is fixed by suspending dlm_recv (taking write lock on the rwsem) before aborting the current recovery. The transitions to/from normal and recovery modes are simplified by using this new ability to block dlm_recv. The switch from normal to recovery mode means dlm_recv goes from processing locking messages, to saving them for later, and vice versa. Races are avoided by blocking dlm_recv when setting the flag that switches between modes. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-18[DLM] The core of the DLM for GFS2/CLVMDavid Teigland
This is the core of the distributed lock manager which is required to use GFS2 as a cluster filesystem. It is also used by CLVM and can be used as a standalone lock manager independantly of either of these two projects. It implements VAX-style locking modes. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steve Whitehouse <swhiteho@redhat.com>
