path: root/fs/ecryptfs/crypto.c
2008-02-06eCryptfs: set inode key only once per crypto operationTrevor Highland
There is no need to keep re-setting the same key for any given eCryptfs inode. This patch optimizes the use of the crypto API and helps performance a bit. Signed-off-by: Trevor Highland <trevor.highland@gmail.com> Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06eCryptfs: track header bytes rather than extentsMichael Halcrow
Remove internal references to header extents; just keep track of header bytes instead. Headers can easily span multiple pages with the recent persistent file changes. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fs/ecryptfs/: possible cleanupsAdrian Bunk
- make the following needlessly global code static: - crypto.c:ecryptfs_lower_offset_for_extent() - crypto.c:key_tfm_list - crypto.c:key_tfm_list_mutex - inode.c:ecryptfs_getxattr() - main.c:ecryptfs_init_persistent_file() - remove the no longer used mmap.c:ecryptfs_lower_page_cache - #if 0 the unused read_write.c:ecryptfs_read() Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-23ecryptfs: fix unlocking in error pathsEric Sandeen
Thanks to Josef Bacik for finding these. A couple of ecryptfs error paths don't properly unlock things they locked. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: Josef Bacik <jbacik@redhat.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-23ecryptfs: fix string overflow on long cipher namesEric Sandeen
Passing a cipher name > 32 chars on mount results in an overflow when the cipher name is printed, because the last character in the struct ecryptfs_key_tfm's cipher_name string was never zeroed. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-05eCryptfs: release mutex on hash error pathMichael Halcrow
Release the crypt_stat hash mutex on allocation error. Check for error conditions when doing crypto hash calls. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Reported-by: Kazuki Ohta <kazuki.ohta@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-05eCryptfs: increment extent_offset once per loop interationMichael Halcrow
The extent_offset is getting incremented twice per loop iteration through any given page. It should only be getting incremented once. This bug should only impact hosts with >4K page sizes. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-27[CRYPTO] users: Fix up scatterlist conversion errorsHerbert Xu
This patch fixes the errors made in the users of the crypto layer during the sg_init_table conversion. It also adds a few conversions that were missing altogether. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-24SG: Change sg_set_page() to take length and offset argumentJens Axboe
Most drivers need to set length and offset as well, so may as well fold those three lines into one. Add sg_assign_page() for those two locations that only needed to set the page, where the offset/length is set outside of the function context. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22Update fs/ to use sg helpersJens Axboe
2007-10-16ecryptfs: clean up page flag handlingMichael Halcrow
The functions that eventually call down to ecryptfs_read_lower(), ecryptfs_decrypt_page(), and ecryptfs_copy_up_encrypted_with_header() should have the responsibility of managing the page Uptodate status. This patch gets rid of some of the ugliness that resulted from trying to push some of the page flag setting too far down the stack. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: replace magic numbersMichael Halcrow
Replace some magic numbers with sizeof() equivalents. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: remove unused functions and kmem_cacheMichael Halcrow
The switch to read_write.c routines and the persistent file make a number of functions unnecessary. This patch removes them. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: fix data typesMichael Halcrow
Update data types and add casts in order to avoid potential overflow issues. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: make open, truncate, and setattr use persistent fileMichael Halcrow
Rather than open a new lower file for every eCryptfs file that is opened, truncated, or setattr'd, instead use the existing lower persistent file for the eCryptfs inode. Change truncate to use read_write.c functions. Change ecryptfs_getxattr() to use the common ecryptfs_getxattr_lower() function. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: update metadata read/write functionsMichael Halcrow
Update the metadata read/write functions and grow_file() to use the read_write.c routines. Do not open another lower file; use the persistent lower file instead. Provide a separate function for crypto.c::ecryptfs_read_xattr_region() to get to the lower xattr without having to go through the eCryptfs getxattr. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: replace encrypt, decrypt, and inode size writeMichael Halcrow
Replace page encryption and decryption routines and inode size write routine with versions that utilize the read_write.c functions. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: remove assignments in if-statementsMichael Halcrow
Remove assignments in if-statements. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: remove header_extent_sizeMichael Halcrow
There is no point to keeping a separate header_extent_size and an extent_size. The total size of the header can always be represented as some multiple of the regular data extent size. [randy.dunlap@oracle.com: ecryptfs: fix printk format warning] Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: make needlessly global symbols staticMichael Halcrow
Andrew Morton wrote: > Please check that all the newly-added global symbols do indeed need > to be global. Change symbols in keystore.c and crypto.o to static if they do not need to be global. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: kerneldoc fixes for crypto.c and keystore.cMichael Halcrow
Andrew Morton wrote: From: mhalcrow@us.ibm.com <mhalcrow@halcrow.austin.ibm.com> > > +/** > > + * decrypt_passphrase_encrypted_session_key - Decrypt the session key > > + * with the given auth_tok. > > * > > * Returns Zero on success; non-zero error otherwise. > > */ > > That comment purports to be a kerneldoc-style comment. But > > - kerneldoc doesn't support multiple lines on the introductory line > which identifies the name of the function (alas). So you'll need to > overflow 80 cols here. > > - the function args weren't documented > > But the return value is! People regularly forget to do that. And > they frequently forget to document the locking prerequisites and the > permissible calling contexts (process/might_sleep/hardirq, etc) > > (please check all ecryptfs kerneldoc for this stuff sometime) This patch cleans up some of the existing comments and makes a couple of line break tweaks. There is more work to do to bring eCryptfs into full kerneldoc-compliance. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: grammatical fix (destruct to destroy)Michael Halcrow
Andrew Morton wrote: > > +int ecryptfs_destruct_crypto(void) > > ecryptfs_destroy_crypto would be more grammatically correct ;) Grammatical fix for some function names. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: collapse flag set into one statementMichael Halcrow
Andrew Morton wrote: > > + crypt_stat->flags |= ECRYPTFS_ENCRYPTED; > > + crypt_stat->flags |= ECRYPTFS_KEY_VALID; > > Maybe the compiler can optimise those two statements, but we'd > normally provide it with some manual help. This patch provides the compiler with some manual help for optimizing the setting of some flags. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: remove unnecessary BUG_ONMichael Halcrow
Andrew Morton wrote: > > + mutex_lock(&mount_crypt_stat->global_auth_tok_list_mutex); > > + BUG_ON(mount_crypt_stat->num_global_auth_toks == 0); > > + mutex_unlock(&mount_crypt_stat->global_auth_tok_list_mutex); > > That's odd-looking. If it was a bug for num_global_auth_toks to be > zero, and if that mutex protects num_global_auth_toks then as soon > as the lock gets dropped, another thread can make > num_global_auth_toks zero, hence the bug is present. Perhaps? That was serving as an internal sanity check that should not have made it into the final patch set in the first place. This patch removes it. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: update comment and debug statementMichael Halcrow
Trivial updates to comment and debug statement. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: add key list structure; search keyringMichael Halcrow
Add support structures for handling multiple keys. The list in crypt_stat contains the key identifiers for all of the keys that should be used for encrypting each file's File Encryption Key (FEK). For now, each inode inherits this list from the mount-wide crypt_stat struct, via the ecryptfs_copy_mount_wide_sigs_to_inode_sigs() function. This patch also removes the global key tfm from the mount-wide crypt_stat struct, instead keeping a list of tfm's meant for dealing with the various inode FEK's. eCryptfs will now search the user's keyring for FEK's parsed from the existing file metadata, so the user can make keys available at any time before or after mounting. Now that multiple FEK packets can be written to the file metadata, we need to be more meticulous about size limits. The updates to the code for writing out packets to the file metadata makes sizes and limits more explicit, uniformly expressed, and (hopefully) easier to follow. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Cc: "Serge E. Hallyn" <serge@hallyn.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] eCryptfs: open-code flag checking and manipulationMichael Halcrow
Open-code flag checking and manipulation. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Trevor Highland <tshighla@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] eCryptfs: convert kmap() to kmap_atomic()Michael Halcrow
Replace kmap() with kmap_atomic(). Reduce the amount of time that mappings are held. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Trevor Highland <tshighla@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] eCryptfs: convert f_op->write() to vfs_write()Michael Halcrow
sys_write() takes a local copy of f_pos and writes that back into the struct file. It does this so that two concurrent write() callers don't make a mess of f_pos, and of the file contents. ecryptfs should be calling vfs_write(). That way we also get the fsnotify notifications, which ecryptfs presently appears to have subverted. Convert direct calls to f_op->write() into calls to vfs_write(). Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] eCryptfs: Encrypted passthroughMichael Halcrow
Provide an option to provide a view of the encrypted files such that the metadata is always in the header of the files, regardless of whether the metadata is actually in the header or in the extended attribute. This mode of operation is useful for applications like incremental backup utilities that do not preserve the extended attributes when directly accessing the lower files. With this option enabled, the files under the eCryptfs mount point will be read-only. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] eCryptfs: Generalize metadata read/writeMichael Halcrow
Generalize the metadata reading and writing mechanisms, with two targets for now: metadata in file header and metadata in the user.ecryptfs xattr of the lower file. [akpm@osdl.org: printk warning fix] [bunk@stusta.de: make some needlessly global code static] Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] eCryptfs: xattr flags and mount optionsMichael Halcrow
This patch set introduces the ability to store cryptographic metadata into an lower file extended attribute rather than the lower file header region. This patch set implements two new mount options: ecryptfs_xattr_metadata - When set, newly created files will have their cryptographic metadata stored in the extended attribute region of the file rather than the header. When storing the data in the file header, there is a minimum of 8KB reserved for the header information for each file, making each file at least 12KB in size. This can take up a lot of extra disk space if the user creates a lot of small files. By storing the data in the extended attribute, each file will only occupy at least of 4KB of space. As the eCryptfs metadata set becomes larger with new features such as multi-key associations, most popular filesystems will not be able to store all of the information in the xattr region in some cases due to space constraints. However, the majority of users will only ever associate one key per file, so most users will be okay with storing their data in the xattr region. This option should be used with caution. I want to emphasize that the xattr must be maintained under all circumstances, or the file will be rendered permanently unrecoverable. The last thing I want is for a user to forget to set an xattr flag in a backup utility, only to later discover that their backups are worthless. ecryptfs_encrypted_view - When set, this option causes eCryptfs to present applications a view of encrypted files as if the cryptographic metadata were stored in the file header, whether the metadata is actually stored in the header or in the extended attributes. No matter what eCryptfs winds up doing in the lower filesystem, I want to preserve a baseline format compatibility for the encrypted files. As of right now, the metadata may be in the file header or in an xattr. There is no reason why the metadata could not be put in a separate file in future versions. Without the compatibility mode, backup utilities would have to know to back up the metadata file along with the files. The semantics of eCryptfs have always been that the lower files are self-contained units of encrypted data, and the only additional information required to decrypt any given eCryptfs file is the key. That is what has always been emphasized about eCryptfs lower files, and that is what users expect. Providing the encrypted view option will provide a way to userspace applications wherein they can always get to the same old familiar eCryptfs encrypted files, regardless of what eCryptfs winds up doing with the metadata behind the scenes. This patch: Add extended attribute support to version bit vector, flags to indicate when xattr or encrypted view modes are enabled, and support for the new mount options. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Transform kmem_cache_alloc()+memset(0) -> kmem_cache_zalloc().Robert P. J. Day
Replace appropriate pairs of "kmem_cache_alloc()" + "memset(0)" with the corresponding "kmem_cache_zalloc()" call. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Roland McGrath <roland@redhat.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Acked-by: Joel Becker <Joel.Becker@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jan Kara <jack@ucw.cz> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07[CRYPTO] api: Remove deprecated interfaceHerbert Xu
This patch removes the old cipher interface and related code. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-12-07[PATCH] slab: remove SLAB_USERChristoph Lameter
SLAB_USER is an alias of GFP_USER Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-28[PATCH] ecryptfs: fix crypto_alloc_blkcipher() error checkAkinobu Mita
The return value of crypto_alloc_blkcipher() should be checked by IS_ERR(). Cc: Mike Halcrow <mhalcrow@us.ibm.com> Cc: Phillip Hellewell <phillip@hellewell.homeip.net> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] eCryptfs: Fix pointer derefMichael Halcrow
I missed a pointer dereference in this kmalloc result check. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] eCryptfs: Consolidate lower dentry_open'sMichael Halcrow
Opens on lower dentry objects happen in several places in eCryptfs, and they all involve the same steps (dget, mntget, dentry_open). This patch consolidates the lower open events into a single function call. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] eCryptfs: Cipher code to new crypto APIMichael Halcrow
Update cipher block encryption code to the new crypto API. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] eCryptfs: Hash code to new crypto APIMichael Halcrow
Update eCryptfs hash code to the new kernel crypto API. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] eCryptfs: Clean up crypto initializationMichael Halcrow
Clean up the crypto initialization code; let the crypto API take care of the key size checks. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] ecryptfs: fs/Makefile and fs/KconfigMichael Halcrow
eCryptfs is a stacked cryptographic filesystem for Linux. It is derived from Erez Zadok's Cryptfs, implemented through the FiST framework for generating stacked filesystems. eCryptfs extends Cryptfs to provide advanced key management and policy features. eCryptfs stores cryptographic metadata in the header of each file written, so that encrypted files can be copied between hosts; the file will be decryptable with the proper key, and there is no need to keep track of any additional information aside from what is already in the encrypted file itself. [akpm@osdl.org: updates for ongoing API changes] [bunk@stusta.de: cleanups] [akpm@osdl.org: alpha build fix] [akpm@osdl.org: cleanups] [tytso@mit.edu: inode-diet updates] [pbadari@us.ibm.com: generic_file_*_read/write() interface updates] [rdunlap@xenotime.net: printk format fixes] [akpm@osdl.org: make slab creation and teardown table-driven] Signed-off-by: Phillip Hellewell <phillip@hellewell.homeip.net> Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
