path: root/fs/ecryptfs/mmap.c
2012-11-07eCryptfs: Avoid unnecessary disk read and data decryption during writingLi Wang
ecryptfs_write_begin grabs a page from page cache for writing. If the page contains invalid data, or data older than the counterpart on the disk, eCryptfs will read out the corresponing data from the disk into the page, decrypt them, then perform writing. However, for this page, if the length of the data to be written into is equal to page size, that means the whole page of data will be overwritten, in which case, it does not matter whatever the data were before, it is beneficial to perform writing directly rather than bothering to read and decrypt first. With this optimization, according to our test on a machine with Intel Core 2 Duo processor, iozone 'write' operation on an existing file with write size being multiple of page size will enjoy a steady 3x speedup. Signed-off-by: Li Wang <wangli@kylinos.com.cn> Signed-off-by: Yunchuan Wen <wenyunchuan@kylinos.com.cn> Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2012-07-13eCryptfs: Revert to a writethrough cache modelTyler Hicks
A change was made about a year ago to get eCryptfs to better utilize its page cache during writes. The idea was to do the page encryption operations during page writeback, rather than doing them when initially writing into the page cache, to reduce the number of page encryption operations during sequential writes. This meant that the encrypted page would only be written to the lower filesystem during page writeback, which was a change from how eCryptfs had previously wrote to the lower filesystem in ecryptfs_write_end(). The change caused a few eCryptfs-internal bugs that were shook out. Unfortunately, more grave side effects have been identified that will force changes outside of eCryptfs. Because the lower filesystem isn't consulted until page writeback, eCryptfs has no way to pass lower write errors (ENOSPC, mainly) back to userspace. Additionaly, it was reported that quotas could be bypassed because of the way eCryptfs may sometimes open the lower filesystem using a privileged kthread. It would be nice to resolve the latest issues, but it is best if the eCryptfs commits be reverted to the old behavior in the meantime. This reverts: 32001d6f "eCryptfs: Flush file in vma close" 5be79de2 "eCryptfs: Flush dirty pages in setattr" 57db4e8d "ecryptfs: modify write path to encrypt page in writepage" Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Tested-by: Colin King <colin.king@canonical.com> Cc: Colin King <colin.king@canonical.com> Cc: Thieu Le <thieule@google.com>
2012-02-16ecryptfs: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2012-01-25eCryptfs: move misleading function commentsLi Wang
The data encryption was moved from ecryptfs_write_end into ecryptfs_writepage, this patch moves the corresponding function comments to be consistent with the modification. Signed-off-by: Li Wang <liwang@nudt.edu.cn> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-28eCryptfs: Unlock page in write_begin error pathTyler Hicks
Unlock the page in error path of ecryptfs_write_begin(). This may happen, for example, if decryption fails while bring the page up-to-date. Cc: <stable@kernel.org> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-03-28ecryptfs: modify write path to encrypt page in writepageThieu Le
Change the write path to encrypt the data only when the page is written to disk in ecryptfs_writepage. Previously, ecryptfs encrypts the page in ecryptfs_write_end which means that if there are multiple write requests to the same page, ecryptfs ends up re-encrypting that page over and over again. This patch minimizes the number of encryptions needed. Signed-off-by: Thieu Le <thieule@chromium.org> [tyhicks: Changed NULL .drop_inode sop pointer to generic_drop_inode] Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-03-28eCryptfs: Remove ECRYPTFS_NEW_FILE crypt stat flagTyler Hicks
Now that grow_file() is not called in the ecryptfs_create() path, the ECRYPTFS_NEW_FILE flag is no longer needed. It helped ecryptfs_readpage() know not to decrypt zeroes that were read from the lower file in the grow_file() path. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-01-17ecryptfs: remove unnecessary decrypt when extending a fileFrank Swiderski
Removes an unecessary page decrypt from ecryptfs_begin_write when the page is beyond the current file size. Previously, the call to ecryptfs_decrypt_page would result in a read of 0 bytes, but still attempt to decrypt an entire page. This patch detects that case and merely zeros the page before marking it up-to-date. Signed-off-by: Frank Swiderski <fes@chromium.org> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-01-17fs/ecryptfs: Add printf format/argument verification and fix falloutJoe Perches
Add __attribute__((format... to __ecryptfs_printk Make formats and arguments match. Add casts to (unsigned long long) for %llu. Signed-off-by: Joe Perches <joe@perches.com> [tyhicks: 80 columns cleanup and fixed typo] Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2010-05-21switch ecryptfs_get_locked_page() to struct inode *Al Viro
2010-05-21simplify access to ecryptfs inodes in ->readpage() and friendsAl Viro
we can get to them from page->mapping->host, no need to mess with file. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-04-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6: eCryptfs: Turn lower lookup error messages into debug messages eCryptfs: Copy lower directory inode times and size on link ecryptfs: fix use with tmpfs by removing d_drop from ecryptfs_destroy_inode ecryptfs: fix error code for missing xattrs in lower fs eCryptfs: Decrypt symlink target for stat size eCryptfs: Strip metadata in xattr flag in encrypted view eCryptfs: Clear buffer before reading in metadata xattr eCryptfs: Rename ecryptfs_crypt_stat.num_header_bytes_at_front eCryptfs: Fix metadata in xattr feature regression
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-23eCryptfs: Strip metadata in xattr flag in encrypted viewTyler Hicks
The ecryptfs_encrypted_view mount option provides a unified way of viewing encrypted eCryptfs files. If the metadata is stored in a xattr, the metadata is moved to the file header when the file is read inside the eCryptfs mount. Because of this, we should strip the ECRYPTFS_METADATA_IN_XATTR flag from the header's flag section. This allows eCryptfs to treat the file as an eCryptfs file with a header at the front. Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2010-03-23eCryptfs: Rename ecryptfs_crypt_stat.num_header_bytes_at_frontTyler Hicks
This patch renames the num_header_bytes_at_front variable to metadata_size since it now contains the max size of the metadata. Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2010-03-23eCryptfs: Fix metadata in xattr feature regressionTyler Hicks
Fixes regression in 8faece5f906725c10e7a1f6caf84452abadbdc7b When using the ecryptfs_xattr_metadata mount option, eCryptfs stores the metadata (normally stored at the front of the file) in the user.ecryptfs xattr. This causes ecryptfs_crypt_stat.num_header_bytes_at_front to be 0, since there is no header data at the front of the file. This results in too much memory being requested and ENOMEM being returned from ecryptfs_write_metadata(). This patch fixes the problem by using the num_header_bytes_at_front variable for specifying the max size of the metadata, despite whether it is stored in the header or xattr. Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2009-09-23eCryptfs: Propagate vfs_read and vfs_write return codesTyler Hicks
Errors returned from vfs_read() and vfs_write() calls to the lower filesystem were being masked as -EINVAL. This caused some confusion to users who saw EINVAL instead of ENOSPC when the disk was full, for instance. Also, the actual bytes read or written were not accessible by callers to ecryptfs_read_lower() and ecryptfs_write_lower(), which may be useful in some cases. This patch updates the error handling logic where those functions are called in order to accept positive return codes indicating success. Cc: Eric Sandeen <esandeen@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: ecryptfs-devel@lists.launchpad.net Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2009-09-22const: mark remaining address_space_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-22eCryptfs: Fix data corruption when using ecryptfs_passthroughTyler Hicks
ecryptfs_passthrough is a mount option that allows eCryptfs to allow data to be written to non-eCryptfs files in the lower filesystem. The passthrough option was causing data corruption due to it not always being treated as a non-eCryptfs file. The first 8 bytes of an eCryptfs file contains the decrypted file size. This value was being written to the non-eCryptfs files, too. Also, extra 0x00 characters were being written to make the file size a multiple of PAGE_CACHE_SIZE. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2009-01-04fs: symlink write_begin allocation context fixNick Piggin
With the write_begin/write_end aops, page_symlink was broken because it could no longer pass a GFP_NOFS type mask into the point where the allocations happened. They are done in write_begin, which would always assume that the filesystem can be entered from reclaim. This bug could cause filesystem deadlocks. The funny thing with having a gfp_t mask there is that it doesn't really allow the caller to arbitrarily tinker with the context in which it can be called. It couldn't ever be GFP_ATOMIC, for example, because it needs to take the page lock. The only thing any callers care about is __GFP_FS anyway, so turn that into a single flag. Add a new flag for write_begin, AOP_FLAG_NOFS. Filesystems can now act on this flag in their write_begin function. Change __grab_cache_page to accept a nofs argument as well, to honour that flag (while we're there, change the name to grab_cache_page_write_begin which is more instructive and does away with random leading underscores). This is really a more flexible way to go in the end anyway -- if a filesystem happens to want any extra allocations aside from the pagecache ones in ints write_begin function, it may now use GFP_KERNEL (rather than GFP_NOFS) for common case allocations (eg. ocfs2_alloc_write_ctxt, for a random example). [kosaki.motohiro@jp.fujitsu.com: fix ubifs] [kosaki.motohiro@jp.fujitsu.com: fix fuse] Signed-off-by: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: <stable@kernel.org> [2.6.28.x] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Cleaned up the calling convention: just pass in the AOP flags untouched to the grab_cache_page_write_begin() function. That just simplifies everybody, and may even allow future expansion of the logic. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16ecryptfs: convert to use new aopsBadari Pulavarty
Convert ecryptfs to use write_begin/write_end Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24ecryptfs: inode.c mmap.c use unaligned byteorder helpersHarvey Harrison
Fixe sparse warnings: fs/ecryptfs/inode.c:368:15: warning: cast to restricted __be64 fs/ecryptfs/mmap.c:385:12: warning: incorrect type in assignment (different base types) fs/ecryptfs/mmap.c:385:12: expected unsigned long long [unsigned] [assigned] [usertype] file_size fs/ecryptfs/mmap.c:385:12: got restricted __be64 [usertype] <noident> fs/ecryptfs/mmap.c:428:12: warning: incorrect type in assignment (different base types) fs/ecryptfs/mmap.c:428:12: expected unsigned long long [unsigned] [assigned] [usertype] file_size fs/ecryptfs/mmap.c:428:12: got restricted __be64 [usertype] <noident> Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ecryptfs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04eCryptfs: make ecryptfs_prepare_write decrypt the pageMichael Halcrow
When the page is not up to date, ecryptfs_prepare_write() should be acting much like ecryptfs_readpage(). This includes the painfully obvious step of actually decrypting the page contents read from the lower encrypted file. Note that this patch resolves a bug in eCryptfs in 2.6.24 that one can produce with these steps: # mount -t ecryptfs /secret /secret # echo "abc" > /secret/file.txt # umount /secret # mount -t ecryptfs /secret /secret # echo "def" >> /secret/file.txt # cat /secret/file.txt Without this patch, the resulting data returned from cat is likely to be something other than "abc\ndef\n". (Thanks to Benedikt Driessen for reporting this.) Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Benedikt Driessen <bdriessen@escrypt.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06eCryptfs: track header bytes rather than extentsMichael Halcrow
Remove internal references to header extents; just keep track of header bytes instead. Headers can easily span multiple pages with the recent persistent file changes. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fs/ecryptfs/: possible cleanupsAdrian Bunk
- make the following needlessly global code static: - crypto.c:ecryptfs_lower_offset_for_extent() - crypto.c:key_tfm_list - crypto.c:key_tfm_list_mutex - inode.c:ecryptfs_getxattr() - main.c:ecryptfs_init_persistent_file() - remove the no longer used mmap.c:ecryptfs_lower_page_cache - #if 0 the unused read_write.c:ecryptfs_read() Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Pagecache zeroing: zero_user_segment, zero_user_segments and zero_userChristoph Lameter
Simplify page cache zeroing of segments of pages through 3 functions zero_user_segments(page, start1, end1, start2, end2) Zeros two segments of the page. It takes the position where to start and end the zeroing which avoids length calculations and makes code clearer. zero_user_segment(page, start, end) Same for a single segment. zero_user(page, start, length) Length variant for the case where we know the length. We remove the zero_user_page macro. Issues: 1. Its a macro. Inline functions are preferable. 2. The KM_USER0 macro is only defined for HIGHMEM. Having to treat this special case everywhere makes the code needlessly complex. The parameter for zeroing is always KM_USER0 except in one single case that we open code. Avoiding KM_USER0 makes a lot of code not having to be dealing with the special casing for HIGHMEM anymore. Dealing with kmap is only necessary for HIGHMEM configurations. In those configurations we use KM_USER0 like we do for a series of other functions defined in highmem.h. Since KM_USER0 is depends on HIGHMEM the existing zero_user_page function could not be a macro. zero_user_* functions introduced here can be be inline because that constant is not used when these functions are called. Also extract the flushing of the caches to be outside of the kmap. [akpm@linux-foundation.org: fix nfs and ntfs build] [akpm@linux-foundation.org: fix ntfs build some more] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17ecryptfs: fix fsx data corruption problemsEric Sandeen
ecryptfs in 2.6.24-rc3 wasn't surviving fsx for me at all, dying after 4 ops. Generally, encountering problems with stale data and improperly zeroed pages. An extending truncate + write for example would expose stale data. With the changes below I got to a million ops and beyond with all mmap ops disabled - mmap still needs work. (A version of this patch on a RHEL5 kernel ran for over 110 million fsx ops) I added a few comments as well, to the best of my understanding as I read through the code. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ecryptfs: clean up page flag handlingMichael Halcrow
The functions that eventually call down to ecryptfs_read_lower(), ecryptfs_decrypt_page(), and ecryptfs_copy_up_encrypted_with_header() should have the responsibility of managing the page Uptodate status. This patch gets rid of some of the ugliness that resulted from trying to push some of the page flag setting too far down the stack. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: remove unused functions and kmem_cacheMichael Halcrow
The switch to read_write.c routines and the persistent file make a number of functions unnecessary. This patch removes them. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: fix data typesMichael Halcrow
Update data types and add casts in order to avoid potential overflow issues. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: convert mmap functions to use persistent fileMichael Halcrow
Convert readpage, prepare_write, and commit_write to use read_write.c routines. Remove sync_page; I cannot think of a good reason for implementing that in eCryptfs. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: update metadata read/write functionsMichael Halcrow
Update the metadata read/write functions and grow_file() to use the read_write.c routines. Do not open another lower file; use the persistent lower file instead. Provide a separate function for crypto.c::ecryptfs_read_xattr_region() to get to the lower xattr without having to go through the eCryptfs getxattr. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: replace encrypt, decrypt, and inode size writeMichael Halcrow
Replace page encryption and decryption routines and inode size write routine with versions that utilize the read_write.c functions. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: read_write.c routinesMichael Halcrow
Add a set of functions through which all I/O to lower files is consolidated. This patch adds a new inode_info reference to a persistent lower file for each eCryptfs inode; another patch later in this series will set that up. This persistent lower file is what the read_write.c functions use to call vfs_read() and vfs_write() on the lower filesystem, so even when reads and writes come in through aops->readpage and aops->writepage, we can satisfy them without resorting to direct access to the lower inode's address space. Several function declarations are going to be changing with this patchset. For now, in order to keep from breaking the build, I am putting dummy parameters in for those functions. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: remove assignments in if-statementsMichael Halcrow
Remove assignments in if-statements. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: remove header_extent_sizeMichael Halcrow
There is no point to keeping a separate header_extent_size and an extent_size. The total size of the header can always be represented as some multiple of the regular data extent size. [randy.dunlap@oracle.com: ecryptfs: fix printk format warning] Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fs: remove some AOP_TRUNCATED_PAGENick Piggin
prepare/commit_write no longer returns AOP_TRUNCATED_PAGE since OCFS2 and GFS2 were converted to the new aops, so we can make some simplifications for that. [michal.k.k.piotrowski@gmail.com: fix warning] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-31eCryptfs: fix possible fault in ecryptfs_sync_pageRyusuke Konishi
This will avoid a possible fault in ecryptfs_sync_page(). In the function, eCryptfs calls sync_page() method of a lower filesystem without checking its existence. However, there are many filesystems that don't have this method including network filesystems such as NFS, AFS, and so forth. They may fail when an eCryptfs page is waiting for lock. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20fix some conversion overflowsNick Piggin
Fix page index to offset conversion overflows in buffer layer, ecryptfs, and ocfs2. It would be nice to convert the whole tree to page_offset, but for now just fix the bugs. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28zero out last page for llseek/writeMichael Halcrow
When one llseek's past the end of the file and then writes, every page past the previous end of the file should be cleared. Trevor found that the code, as is, does not assure that the very last page is always cleared. This patch takes care of that. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28eCryptfs: fix write zeros behaviorMichael Halcrow
This patch fixes the processes involved in wiping regions of the data during truncate and write events, fixing a kernel hang in 2.6.22-rc4 while assuring that zero values are written out to the appropriate locations during events in which the i_size will change. The range passed to ecryptfs_truncate() from ecryptfs_prepare_write() includes the page that is the object of ecryptfs_prepare_write(). This leads to a kernel hang as read_cache_page() is executed on the same page in the ecryptfs_truncate() execution path. This patch remedies this by limiting the range passed to ecryptfs_truncate() so as to exclude the page that is the object of ecryptfs_prepare_write(); it also adds code to ecryptfs_prepare_write() to zero out the region of its own page when writing past the i_size position. This patch also modifies ecryptfs_truncate() so that when a file is truncated to a smaller size, eCryptfs will zero out the contents of the new last page from the new size through to the end of the last page. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23eCryptfs: delay writing 0's after llseek until writeMichael Halcrow
Delay writing 0's out in eCryptfs after a seek past the end of the file until data is actually written. http://www.opengroup.org/onlinepubs/009695399/functions/lseek.html ``The lseek() function shall not, by itself, extend the size of a file.'' Without this fix, applications that lseek() past the end of the file without writing will experience unexpected behavior. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-17ecryptfs: use zero_user_pageNate Diller
Use zero_user_page() instead of open-coding it. Signed-off-by: Nate Diller <nate.diller@gmail.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] ecryptfs: handle AOP_TRUNCATED_PAGE betterDmitriy Monakhov
- In fact we don't have to fail if AOP_TRUNCATED_PAGE was returned from prepare_write or commit_write. It is beter to retry attempt where it is possible. - Rearange ecryptfs_get_lower_page() error handling logic, make it more clean. Signed-off-by: Dmitriy Monakhov <dmonakhov@openvz.org> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] ecryptfs: check xattr operation support fixDmitriy Monakhov
- ecryptfs_write_inode_size_to_metadata() error code was ignored. - i_op->setxattr() must be supported by lower fs because used below. Signed-off-by: Monakhov Dmitriy <dmonakhov@openvz.org> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] eCryptfs: remove unnecessary flush_dcache_page()Michael Halcrow
Remove unnecessary flush_dcache_page() call. Thanks to Dmitriy Monakhov for pointing this out. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Dmitriy Monakhov <dmonakhov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] eCryptfs: resolve lower page unlocking problemMichael Halcrow
eCryptfs lower file handling code has several issues: - Retval from prepare_write()/commit_write() wasn't checked to equality to AOP_TRUNCATED_PAGE. - In some places page wasn't unmapped and unlocked after error. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] eCryptfs: add flush_dcache_page() callsMichael Halcrow
Call flush_dcache_page() after modifying a pagecache by hand. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
