[ Upstream commit ff04f3b6f2e27f8ae28a498416af2a8dd5072b43 ]
The memory leak addressed by commit fe5186cf12e3 is a false positive:
all allocations are recorded in a linked list, and freed when the
filesystem is unmounted. This leads to double frees, and as reported
by David, leads to crashes if SLUB is configured to self destruct when
double frees occur.
So drop the redundant kfree() again, and instead, mark the offending
pointer variable so the allocation is ignored by kmemleak.
Cc: Vamshi K Sthambamkadi <vamshi.k.sthambamkadi@gmail.com>
Fixes: fe5186cf12e3 ("efivarfs: fix memory leak in efivarfs_create()")
Reported-by: David Laight <David.Laight@aculab.com>
Signed-off-by: Ard Biesheuvel <ardb@kernel.org>
commit fe5186cf12e30facfe261e9be6c7904a170bd822 upstream.
kmemleak report:
unreferenced object 0xffff9b8915fcb000 (size 4096):
comm "efivarfs.sh", pid 2360, jiffies 4294920096 (age 48.264s)
hex dump (first 32 bytes):
2d 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -...............
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<00000000cc4d897c>] kmem_cache_alloc_trace+0x155/0x4b0
[<000000007d1dfa72>] efivarfs_create+0x6e/0x1a0
[<00000000e6ee18fc>] path_openat+0xe4b/0x1120
[<000000000ad0414f>] do_filp_open+0x91/0x100
[<00000000ce93a198>] do_sys_openat2+0x20c/0x2d0
[<000000002a91be6d>] do_sys_open+0x46/0x80
[<000000000a854999>] __x64_sys_openat+0x20/0x30
[<00000000c50d89c9>] do_syscall_64+0x38/0x90
[<00000000cecd6b5f>] entry_SYSCALL_64_after_hwframe+0x44/0xa9
In efivarfs_create(), inode->i_private is setup with efivar_entry
object which is never freed.
Cc: <stable@vger.kernel.org>
Signed-off-by: Vamshi K Sthambamkadi <vamshi.k.sthambamkadi@gmail.com>
Link: https://lore.kernel.org/r/20201023115429.GA2479@cosmos
commit 336af6a4686d885a067ecea8c3c3dd129ba4fc75 upstream.
Without this patch efivarfs_alloc_dentry creates dentries with slashes in
their name if the respective EFI variable has slashes in its name. This in
turn causes EIO on getdents64, which prevents a complete directory listing
of /sys/firmware/efi/efivars/.
This patch replaces the invalid shlashes with exclamation marks like
kobject_set_name_vargs does for /sys/firmware/efi/vars/ to have consistently
named dentries under /sys/firmware/efi/vars/ and /sys/firmware/efi/efivars/.
Signed-off-by: Michael Schaller <misch@google.com>
Link: https://lore.kernel.org/r/20200925074502.150448-1-misch@google.com
Signed-off-by: dann frazier <dann.frazier@canonical.com>
commit ed8b0de5a33d2a2557dce7f9429dca8cb5bc5879 upstream.
"rm -rf" is bricking some peoples' laptops because of variables being
used to store non-reinitializable firmware driver data that's required
to POST the hardware.
These are 100% bugs, and they need to be fixed, but in the mean time it
shouldn't be easy to *accidentally* brick machines.
We have to have delete working, and picking which variables do and don't
work for deletion is quite intractable, so instead make everything
immutable by default (except for a whitelist), and make tools that
aren't quite so broad-spectrum unset the immutable flag.
Signed-off-by: Peter Jones <pjones@redhat.com>
Tested-by: Lee, Chun-Yi <jlee@suse.com>
Acked-by: Matthew Garrett <mjg59@coreos.com>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
commit e0d64e6a880e64545ad7d55786aa84ab76bac475 upstream.
Translate EFI's UCS-2 variable names to UTF-8 instead of just assuming
all variable names fit in ASCII.
Pull x86 fixes from Ingo Molnar:
"EFI fixes, and FPU fix, a ticket spinlock boundary condition fix and
two build fixes"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/fpu: Always restore_xinit_state() when use_eager_cpu()
x86: Make cpu_tss available to external modules
efi: Fix error handling in add_sysfs_runtime_map_entry()
x86/spinlocks: Fix regression in spinlock contention detection
x86/mm: Clean up types in xlate_dev_mem_ptr()
x86/efi: Store upper bits of command line buffer address in ext_cmd_line_ptr
efivarfs: Ensure VariableName is NUL-terminated
Some buggy firmware implementations update VariableNameSize on success
such that it does not include the final NUL character which results in
garbage in the efivarfs name entries. Use kzalloc on the efivar_entry
(as is done in efivars.c) to ensure that the name is always
NUL-terminated.
The buggy firmware is:
BIOS Information
Vendor: Intel Corp.
Version: S1200RP.86B.02.02.0005.102320140911
Release Date: 10/23/2014
BIOS Revision: 4.6
System Information
Manufacturer: Intel Corporation
Product Name: S1200RP_SE
Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com>
Cc: Jeremy Kerr <jk@ozlabs.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
that's the bulk of filesystem drivers dealing with inodes of their own
Call it what it does - "unparse" is plain-misleading.
Signed-off-by: Ricardo Neri <ricardo.neri-calderon@linux.intel.com>
There is no need to keep the module loaded when it serves no function in
case the EFI runtime services are disabled. Return an error in this case
so loading the module will fail.
Also supply a module_exit function to allow unloading the module.
Last, but not least, set the owner of the file_system_type struct.
Cc: Matthew Garrett <matthew.garrett@nebula.com>
Signed-off-by: Mathias Krause <minipli@googlemail.com>
...like other filesystems.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Rename simple_delete_dentry() to always_delete_dentry() and export it.
Export simple_dentry_operations, while we are at it, and get rid of
their duplicates
Instances either don't look at it at all (the majority of cases) or
only want it to find the superblock (which can be had as dentry->d_sb).
A few cases that want more are actually safe with dentry->d_inode -
the only precaution needed is the check that it hadn't been replaced with
NULL by rmdir() or by overwriting rename(), which case should be simply
treated as cache miss.
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
Resolve conflicts for Ingo.
drivers/firmware/Kconfig
drivers/firmware/efivars.c
Now that efivarfs uses the efivar API, move it out of efivars.c and
into fs/efivarfs where it belongs. This move will eventually allow us
to enable the efivarfs code without having to also enable
CONFIG_EFI_VARS built, and vice versa.
Furthermore, things like,
mount -t efivarfs none /sys/firmware/efi/efivars
will now work if efivarfs is built as a module without requiring the
use of MODULE_ALIAS(), which would have been necessary when the
efivarfs code was part of efivars.c.
Reviewed-by: Tom Gundersen <teg@jklm.no>
Tested-by: Tom Gundersen <teg@jklm.no>
