path: root/fs/efs/dir.c
2013-02-22new helper: file_inode(file)Al Viro
2009-06-17get rid of BKL in fs/efsAl Viro
Only readdir() really needed it, and that's easily fixable by switch to generic_file_llseek() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-23efs: move headers out of include/linux/Christoph Hellwig
Merge include/linux/efs_fs{_i,_dir}.h into fs/efs/efs.h. efs_vh.h remains there because this is the IRIX volume header and shouldn't really be handled by efs but by the partitioning code. efs_sb.h remains there for now because it's exported to userspace. Of course this wrong and aboot should have a copy of it's own, but I'll leave that to a separate patch to avoid any contention. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] struct path: convert efsJosef Sipek
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
