commit d1e7fd6462ca9fc76650fbe6ca800e35b24267da upstream.
Replace the 32bit exec_id with a 64bit exec_id to make it impossible
to wrap the exec_id counter. With care an attacker can cause exec_id
wrap and send arbitrary signals to a newly exec'd parent. This
bypasses the signal sending checks if the parent changes their
credentials during exec.
The severity of this problem can been seen that in my limited testing
of a 32bit exec_id it can take as little as 19s to exec 65536 times.
Which means that it can take as little as 14 days to wrap a 32bit
exec_id. Adam Zabrocki has succeeded wrapping the self_exe_id in 7
days. Even my slower timing is in the uptime of a typical server.
Which means self_exec_id is simply a speed bump today, and if exec
gets noticably faster self_exec_id won't even be a speed bump.
Extending self_exec_id to 64bits introduces a problem on 32bit
architectures where reading self_exec_id is no longer atomic and can
take two read instructions. Which means that is is possible to hit
a window where the read value of exec_id does not match the written
value. So with very lucky timing after this change this still
remains expoiltable.
I have updated the update of exec_id on exec to use WRITE_ONCE
and the read of exec_id in do_notify_parent to use READ_ONCE
to make it clear that there is no locking between these two
locations.
Link: https://lore.kernel.org/kernel-hardening/20200324215049.GA3710@pi3.com.pl
Fixes: 2.3.23pre2
Cc: stable@vger.kernel.org
commit 16d51a590a8ce3befb1308e0e7ab77f3b661af33 upstream.
When going through execve(), zero out the NUMA fault statistics instead of
freeing them.
During execve, the task is reachable through procfs and the scheduler. A
concurrent /proc/*/sched reader can read data from a freed ->numa_faults
allocation (confirmed by KASAN) and write it back to userspace.
I believe that it would also be possible for a use-after-free read to occur
through a race between a NUMA fault and execve(): task_numa_fault() can
lead to task_numa_compare(), which invokes task_weight() on the currently
running task of a different CPU.
Another way to fix this would be to make ->numa_faults RCU-managed or add
extra locking, but it seems easier to wipe the NUMA fault statistics on
execve.
Signed-off-by: Jann Horn <jannh@google.com>
Cc: Petr Mladek <pmladek@suse.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Will Deacon <will@kernel.org>
Fixes: 82727018b0d3 ("sched/numa: Call task_numa_free() from do_execve()")
Link: https://lkml.kernel.org/r/20190716152047.14424-1-jannh@google.com
commit f612acfae86af7ecad754ae6a46019be9da05b8e upstream.
syzkaller report this:
BUG: memory leak
unreferenced object 0xffffc9000488d000 (size 9195520):
comm "syz-executor.0", pid 2752, jiffies 4294787496 (age 18.757s)
hex dump (first 32 bytes):
ff ff ff ff ff ff ff ff a8 00 00 00 01 00 00 00 ................
02 00 00 00 00 00 00 00 80 a1 7a c1 ff ff ff ff ..........z.....
backtrace:
[<000000000863775c>] __vmalloc_node mm/vmalloc.c:1795 [inline]
[<000000000863775c>] __vmalloc_node_flags mm/vmalloc.c:1809 [inline]
[<000000000863775c>] vmalloc+0x8c/0xb0 mm/vmalloc.c:1831
[<000000003f668111>] kernel_read_file+0x58f/0x7d0 fs/exec.c:924
[<000000002385813f>] kernel_read_file_from_fd+0x49/0x80 fs/exec.c:993
[<0000000011953ff1>] __do_sys_finit_module+0x13b/0x2a0 kernel/module.c:3895
[<000000006f58491f>] do_syscall_64+0x147/0x600 arch/x86/entry/common.c:290
[<00000000ee78baf4>] entry_SYSCALL_64_after_hwframe+0x49/0xbe
[<00000000241f889b>] 0xffffffffffffffff
It should goto 'out_free' lable to free allocated buf while kernel_read
fails.
Fixes: 39d637af5aa7 ("vfs: forbid write access when reading a file into memory")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Cc: Thibaut Sautereau <thibaut@sautereau.fr>
commit 3756f6401c302617c5e091081ca4d26ab604bec5 upstream.
gcc-8 warns about using strncpy() with the source size as the limit:
fs/exec.c:1223:32: error: argument to 'sizeof' in 'strncpy' call is the same expression as the source; did you mean to use the size of the destination? [-Werror=sizeof-pointer-memaccess]
This is indeed slightly suspicious, as it protects us from source
arguments without NUL-termination, but does not guarantee that the
destination is terminated.
This keeps the strncpy() to ensure we have properly padded target
buffer, but ensures that we use the correct length, by passing the
actual length of the destination buffer as well as adding a build-time
check to ensure it is exactly TASK_COMM_LEN.
There are only 23 callsites which I all reviewed to ensure this is
currently the case. We could get away with doing only the check or
passing the right length, but it doesn't hurt to do both.
Link: http://lkml.kernel.org/r/20171205151724.1764896-1-arnd@arndb.de
Suggested-by: Kees Cook <keescook@chromium.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Serge Hallyn <serge@hallyn.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: Aleksa Sarai <asarai@suse.de>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Frederic Weisbecker <frederic@kernel.org>
commit da029c11e6b12f321f36dac8771e833b65cec962 upstream.
To avoid pathological stack usage or the need to special-case setuid
execs, just limit all arg stack usage to at most 75% of _STK_LIM (6MB).
commit 98da7d08850fb8bdeb395d6368ed15753304aa0c upstream.
When limiting the argv/envp strings during exec to 1/4 of the stack limit,
the storage of the pointers to the strings was not included. This means
that an exec with huge numbers of tiny strings could eat 1/4 of the stack
limit in strings and then additional space would be later used by the
pointers to the strings.
For example, on 32-bit with a 8MB stack rlimit, an exec with 1677721
single-byte strings would consume less than 2MB of stack, the max (8MB /
4) amount allowed, but the pointers to the strings would consume the
remaining additional stack space (1677721 * 4 == 6710884).
The result (1677721 + 6710884 == 8388605) would exhaust stack space
entirely. Controlling this stack exhaustion could result in
pathological behavior in setuid binaries (CVE-2017-1000365).
[akpm@linux-foundation.org: additional commenting from Kees]
Fixes: b6a2fea39318 ("mm: variable length argument support")
Link: http://lkml.kernel.org/r/20170622001720.GA32173@beast
Cc: Qualys Security Advisory <qsa@qualys.com>
commit 64b875f7ac8a5d60a4e191479299e931ee949b67 upstream.
When the flag PT_PTRACE_CAP was added the PTRACE_TRACEME path was
overlooked. This can result in incorrect behavior when an application
like strace traces an exec of a setuid executable.
Further PT_PTRACE_CAP does not have enough information for making good
security decisions as it does not report which user namespace the
capability is in. This has already allowed one mistake through
insufficient granulariy.
I found this issue when I was testing another corner case of exec and
discovered that I could not get strace to set PT_PTRACE_CAP even when
running strace as root with a full set of caps.
This change fixes the above issue with strace allowing stracing as
root a setuid executable without disabling setuid. More fundamentaly
this change allows what is allowable at all times, by using the correct
information in it's decision.
Fixes: 4214e42f96d4 ("v2.4.9.11 -> v2.4.9.12")
commit 613cc2b6f272c1a8ad33aefa21cad77af23139f7 upstream.
If you have a process that has set itself to be non-dumpable, and it
then undergoes exec(2), any CLOEXEC file descriptors it has open are
"exposed" during a race window between the dumpable flags of the process
being reset for exec(2) and CLOEXEC being applied to the file
descriptors. This can be exploited by a process by attempting to access
/proc/<pid>/fd/... during this window, without requiring CAP_SYS_PTRACE.
The race in question is after set_dumpable has been (for get_link,
though the trace is basically the same for readlink):
[vfs]
-> proc_pid_link_inode_operations.get_link
-> proc_pid_get_link
-> proc_fd_access_allowed
-> ptrace_may_access(task, PTRACE_MODE_READ_FSCREDS);
Which will return 0, during the race window and CLOEXEC file descriptors
will still be open during this window because do_close_on_exec has not
been called yet. As a result, the ordering of these calls should be
reversed to avoid this race window.
This is of particular concern to container runtimes, where joining a
PID namespace with file descriptors referring to the host filesystem
can result in security issues (since PRCTL_SET_DUMPABLE doesn't protect
against access of CLOEXEC file descriptors -- file descriptors which may
reference filesystem objects the container shouldn't have access to).
Cc: dev@opencontainers.org
Reported-by: Michael Crosby <crosbymichael@gmail.com>
Signed-off-by: Aleksa Sarai <asarai@suse.de>
commit f84df2a6f268de584a201e8911384a2d244876e3 upstream.
When the user namespace support was merged the need to prevent
ptrace from revealing the contents of an unreadable executable
was overlooked.
Correct this oversight by ensuring that the executed file
or files are in mm->user_ns, by adjusting mm->user_ns.
Use the new function privileged_wrt_inode_uidgid to see if
the executable is a member of the user namespace, and as such
if having CAP_SYS_PTRACE in the user namespace should allow
tracing the executable. If not update mm->user_ns to
the parent user namespace until an appropriate parent is found.
Reported-by: Jann Horn <jann@thejh.net>
Fixes: 9e4a36ece652 ("userns: Fail exec for suid and sgid binaries with ids outside our user namespace.")
This removes the 'write' and 'force' from get_user_pages_remote() and
replaces them with 'gup_flags' to make the use of FOLL_FORCE explicit in
callers as use of this flag can result in surprising behaviour (and
hence bugs) within the mm subsystem.
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu
Pull m68knommu updates from Greg Ungerer:
"This series is all about Nicolas flat format support for MMU systems.
Traditional m68k no-MMU flat format binaries can now be run on m68k
MMU enabled systems too. The series includes some nice cleanups of
the binfmt_flat code and converts it to using proper user space
accessor functions.
With all this in place you can boot and run a complete no-MMU flat
format based user space on an MMU enabled system"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu:
m68k: enable binfmt_flat on systems with an MMU
binfmt_flat: allow compressed flat binary format to work on MMU systems
binfmt_flat: add MMU-specific support
binfmt_flat: update libraries' data segment pointer with userspace accessors
binfmt_flat: use clear_user() rather than memset() to clear .bss
binfmt_flat: use proper user space accessors with old relocs code
binfmt_flat: use proper user space accessors with relocs processing code
binfmt_flat: clean up create_flat_tables() and stack accesses
binfmt_flat: use generic transfer_args_to_stack()
elf_fdpic_transfer_args_to_stack(): make it generic
binfmt_flat: prevent kernel dammage from corrupted executable headers
binfmt_flat: convert printk invocations to their modern form
binfmt_flat: assorted cleanups
m68k: use same start_thread() on MMU and no-MMU
m68k: fix file path comment
m68k: fix bFLT executable running on MMU enabled systems
Some systems are memory constrained but they need to load very large
firmwares. The firmware subsystem allows drivers to request this
firmware be loaded from the filesystem, but this requires that the
entire firmware be loaded into kernel memory first before it's provided
to the driver. This can lead to a situation where we map the firmware
twice, once to load the firmware into kernel memory and once to copy the
firmware into the final resting place.
This creates needless memory pressure and delays loading because we have
to copy from kernel memory to somewhere else. Let's add a
request_firmware_into_buf() API that allows drivers to request firmware
be loaded directly into a pre-allocated buffer. This skips the
intermediate step of allocating a buffer in kernel memory to hold the
firmware image while it's read from the filesystem. It also requires
that drivers know how much memory they'll require before requesting the
firmware and negates any benefits of firmware caching because the
firmware layer doesn't manage the buffer lifetime.
For a 16MB buffer, about half the time is spent performing a memcpy from
the buffer to the final resting place. I see loading times go from
0.081171 seconds to 0.047696 seconds after applying this patch. Plus
the vmalloc pressure is reduced.
This is based on a patch from Vikram Mulukutla on codeaurora.org:
https://www.codeaurora.org/cgit/quic/la/kernel/msm-3.18/commit/drivers/base/firmware_class.c?h=rel/msm-3.18&id=0a328c5f6cd999f5c591f172216835636f39bcb5
Link: http://lkml.kernel.org/r/20160607164741.31849-4-stephen.boyd@linaro.org
Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org>
Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
Cc: Vikram Mulukutla <markivx@codeaurora.org>
Cc: Mark Brown <broonie@kernel.org>
Cc: Ming Lei <ming.lei@canonical.com>
This copying of arguments and environment is common to both NOMMU
binary formats we support. Let's make the elf_fdpic version available
to the flat format as well.
While at it, improve the code a bit not to copy below the actual
data area.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Reviewed-by: Greg Ungerer <gerg@linux-m68k.org>
Signed-off-by: Greg Ungerer <gerg@linux-m68k.org>
If a process gets access to a mount from a different user
namespace, that process should not be able to take advantage of
setuid files or selinux entrypoints from that filesystem. Prevent
this by treating mounts from other mount namespaces and those not
owned by current_user_ns() or an ancestor as nosuid.
This will make it safer to allow more complex filesystems to be
mounted in non-root user namespaces.
This does not remove the need for MNT_LOCK_NOSUID. The setuid,
setgid, and file capability bits can no longer be abused if code in
a user namespace were to clear nosuid on an untrusted filesystem,
but this patch, by itself, is insufficient to protect the system
from abuse of files that, when execed, would increase MAC privilege.
As a more concrete explanation, any task that can manipulate a
vfsmount associated with a given user namespace already has
capabilities in that namespace and all of its descendents. If they
can cause a malicious setuid, setgid, or file-caps executable to
appear in that mount, then that executable will only allow them to
elevate privileges in exactly the set of namespaces in which they
are already privileges.
On the other hand, if they can cause a malicious executable to
appear with a dangerous MAC label, running it could change the
caller's security context in a way that should not have been
possible, even inside the namespace in which the task is confined.
As a hardening measure, this would have made CVE-2014-5207 much
more difficult to exploit.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
Acked-by: James Morris <james.l.morris@oracle.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
setup_arg_pages requires mmap_sem for write. If the waiting task gets
killed by the oom killer it would block oom_reaper from asynchronous
address space reclaim and reduce the chances of timely OOM resolving.
Wait for the lock in the killable mode and return with EINTR if the task
got killed while waiting. All the callers are already handling error
path and the fatal signal doesn't need any additional treatment.
The same applies to __bprm_mm_init.
Signed-off-by: Michal Hocko <mhocko@suse.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
remove_arg_zero() does free_arg_page() for no reason. This was needed
before and only if CONFIG_MMU=y: see commit 4fc75ff4816c ("exec: fix
remove_arg_zero"), install_arg_page() was called for every page != NULL
in bprm->page[] array. Today install_arg_page() has already gone and
free_arg_page() is nop after another commit b6a2fea39318 ("mm: variable
length argument support").
CONFIG_MMU=n does free_arg_pages() in free_bprm() and thus it doesn't
need remove_arg_zero()->free_arg_page() too; apart from get_arg_page()
it never checks if the page in bprm->page[] was allocated or not, so the
"extra" non-freed page is fine. OTOH, this free_arg_page() can add the
minor pessimization, the caller is going to do copy_strings_kernel()
right after remove_arg_zero() which will likely need to re-allocate the
same page again.
And as Hujunjie pointed out, the "offset == PAGE_SIZE" check is wrong
because we are going to increment bprm->p once again before return, so
CONFIG_MMU=n "leaks" the page anyway if '0' is the final byte in this
page.
NOTE: remove_arg_zero() assumes that argv[0] is null-terminated but this
is not necessarily true. copy_strings() does "len = strnlen_user(...)",
then copy_from_user(len) but another thread or debuger can overwrite the
trailing '0' in between. Afaics nothing really bad can happen because
we must always have the null-terminated bprm->filename copied by the 1st
copy_strings_kernel(), but perhaps we should change this code to check
"bprm->p < bprm->exec" anyway, and/or change copy_strings() to ensure
that the last byte in string is always zero.
Link: http://lkml.kernel.org/r/20160517155335.GA31435@redhat.com
Reported by: hujunjie <jj.net@163.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Highlights:
- A new LSM, "LoadPin", from Kees Cook is added, which allows forcing
of modules and firmware to be loaded from a specific device (this
is from ChromeOS, where the device as a whole is verified
cryptographically via dm-verity).
This is disabled by default but can be configured to be enabled by
default (don't do this if you don't know what you're doing).
- Keys: allow authentication data to be stored in an asymmetric key.
Lots of general fixes and updates.
- SELinux: add restrictions for loading of kernel modules via
finit_module(). Distinguish non-init user namespace capability
checks. Apply execstack check on thread stacks"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (48 commits)
LSM: LoadPin: provide enablement CONFIG
Yama: use atomic allocations when reporting
seccomp: Fix comment typo
ima: add support for creating files using the mknodat syscall
ima: fix ima_inode_post_setattr
fs: fix over-zealous use of "const"
selinux: apply execstack check on thread stacks
selinux: distinguish non-init user namespace capability checks
LSM: LoadPin for kernel file loading restrictions
fs: define a string representation of the kernel_read_file_id enumeration
Yama: consolidate error reporting
string_helpers: add kstrdup_quotable_file
string_helpers: add kstrdup_quotable_cmdline
selinux: check ss_initialized before revalidating an inode label
selinux: delay inode label lookup as long as possible
selinux: don't revalidate an inode's label when explicitly setting it
selinux: Change bool variable name to index.
KEYS: Add KEYCTL_DH_COMPUTE command
This section of code initially looks redundant, but is required. This
improves the comment to explain more clearly why the reset is needed.
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
This patch is based on top of the "vfs: support for a common kernel file
loader" patch set. In general when the kernel is reading a file into
memory it does not want anything else writing to it.
The kernel currently only forbids write access to a file being executed.
This patch extends this locking to files being read by the kernel.
Changelog:
- moved function to kernel_read_file() - Mimi
- updated patch description - Mimi
Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@huawei.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Reviewed-by: Luis R. Rodriguez <mcgrof@kernel.org>
Pull x86 protection key support from Ingo Molnar:
"This tree adds support for a new memory protection hardware feature
that is available in upcoming Intel CPUs: 'protection keys' (pkeys).
There's a background article at LWN.net:
https://lwn.net/Articles/643797/
The gist is that protection keys allow the encoding of
user-controllable permission masks in the pte. So instead of having a
fixed protection mask in the pte (which needs a system call to change
and works on a per page basis), the user can map a (handful of)
protection mask variants and can change the masks runtime relatively
cheaply, without having to change every single page in the affected
virtual memory range.
This allows the dynamic switching of the protection bits of large
amounts of virtual memory, via user-space instructions. It also
allows more precise control of MMU permission bits: for example the
executable bit is separate from the read bit (see more about that
below).
This tree adds the MM infrastructure and low level x86 glue needed for
that, plus it adds a high level API to make use of protection keys -
if a user-space application calls:
mmap(..., PROT_EXEC);
or
mprotect(ptr, sz, PROT_EXEC);
(note PROT_EXEC-only, without PROT_READ/WRITE), the kernel will notice
this special case, and will set a special protection key on this
memory range. It also sets the appropriate bits in the Protection
Keys User Rights (PKRU) register so that the memory becomes unreadable
and unwritable.
So using protection keys the kernel is able to implement 'true'
PROT_EXEC on x86 CPUs: without protection keys PROT_EXEC implies
PROT_READ as well. Unreadable executable mappings have security
advantages: they cannot be read via information leaks to figure out
ASLR details, nor can they be scanned for ROP gadgets - and they
cannot be used by exploits for data purposes either.
We know about no user-space code that relies on pure PROT_EXEC
mappings today, but binary loaders could start making use of this new
feature to map binaries and libraries in a more secure fashion.
There is other pending pkeys work that offers more high level system
call APIs to manage protection keys - but those are not part of this
pull request.
Right now there's a Kconfig that controls this feature
(CONFIG_X86_INTEL_MEMORY_PROTECTION_KEYS) that is default enabled
(like most x86 CPU feature enablement code that has no runtime
overhead), but it's not user-configurable at the moment. If there's
any serious problem with this then we can make it configurable and/or
flip the default"
* 'mm-pkeys-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (38 commits)
x86/mm/pkeys: Fix mismerge of protection keys CPUID bits
mm/pkeys: Fix siginfo ABI breakage caused by new u64 field
x86/mm/pkeys: Fix access_error() denial of writes to write-only VMA
mm/core, x86/mm/pkeys: Add execute-only protection keys support
x86/mm/pkeys: Create an x86 arch_calc_vm_prot_bits() for VMA flags
x86/mm/pkeys: Allow kernel to modify user pkey rights register
x86/fpu: Allow setting of XSAVE state
x86/mm: Factor out LDT init from context init
mm/core, x86/mm/pkeys: Add arch_validate_pkey()
mm/core, arch, powerpc: Pass a protection key in to calc_vm_flag_bits()
x86/mm/pkeys: Actually enable Memory Protection Keys in the CPU
x86/mm/pkeys: Add Kconfig prompt to existing config option
x86/mm/pkeys: Dump pkey from VMA in /proc/pid/smaps
x86/mm/pkeys: Dump PKRU with other kernel registers
mm/core, x86/mm/pkeys: Differentiate instruction fetches
x86/mm/pkeys: Optimize fault handling in access_error()
mm/core: Do not enforce PKEY permissions on remote mm access
um, pkeys: Add UML arch_*_access_permitted() methods
mm/gup, x86/mm/pkeys: Check VMAs and PTEs for protection keys
x86/mm/gup: Simplify get_user_pages() PTE bit handling
This patch defines kernel_read_file_from_fd(), a wrapper for the VFS
common kernel_read_file().
Changelog:
- Separated from the kernel modules patch
Acked-by: Luis R. Rodriguez <mcgrof@kernel.org>
The kernel_read_file security hook is called prior to reading the file
into memory.
Changelog v4+:
- export security_kernel_read_file()
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
This patch defines kernel_read_file_from_path(), a wrapper for the VFS
Changelog:
- revert error msg regression - reported by Sergey Senozhatsky
- Separated from the IMA patch
To differentiate between the kernel_read_file() callers, this patch
defines a new enumeration named kernel_read_file_id and includes the
caller identifier as an argument.
Subsequent patches define READING_KEXEC_IMAGE, READING_KEXEC_INITRAMFS,
READING_FIRMWARE, READING_MODULE, and READING_POLICY.
Changelog v3:
- Replace the IMA specific enumeration with a generic one.
For a while it was looked down upon to directly read files from Linux.
These days there exists a few mechanisms in the kernel that do just
this though to load a file into a local buffer. There are minor but
important checks differences on each. This patch set is the first
attempt at resolving some of these differences.
This patch introduces a common function for reading files from the kernel
with the corresponding security post-read hook and function.
Changelog v4+:
- export security_kernel_post_read_file() - Fengguang Wu
v3:
- additional bounds checking - Luis
v2:
- To simplify patch review, re-ordered patches
Reviewed-by: Luis R. Rodriguez <mcgrof@suse.com>
For protection keys, we need to understand whether protections
should be enforced in software or not. In general, we enforce
protections when working on our own task, but not when on others.
We call these "current" and "remote" operations.
This patch introduces a new get_user_pages() variant:
Which is a replacement for when get_user_pages() is called on
non-current tsk/mm.
We also introduce a new gup flag: FOLL_REMOTE which can be used
for the "__" gup variants to get this new behavior.
The uprobes is_trap_at_addr() location holds mmap_sem and
calls get_user_pages(current->mm) on an instruction address. This
makes it a pretty unique gup caller. Being an instruction access
and also really originating from the kernel (vs. the app), I opted
to consider this a 'remote' access where protection keys will not
be enforced.
Without protection keys, this patch should not change any behavior.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dave Hansen <dave@sr71.net>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: jack@suse.cz
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/20160212210154.3F0E51EA@viggo.jf.intel.com
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
Today proc and sysfs do not contain any executable files. Several
applications today mount proc or sysfs without noexec and nosuid and
then depend on there being no exectuables files on proc or sysfs.
Having any executable files show on proc or sysfs would cause
a user space visible regression, and most likely security problems.
Therefore commit to never allowing executables on proc and sysfs by
adding a new flag to mark them as filesystems without executables and
enforce that flag.
Test the flag where MNT_NOEXEC is tested today, so that the only user
visible effect will be that exectuables will be treated as if the
execute bit is cleared.
The filesystems proc and sysfs do not currently incoporate any
executable files so this does not result in any user visible effects.
This makes it unnecessary to vet changes to proc and sysfs tightly for
adding exectuable files or changes to chattr that would modify
existing files, as no matter what the individual file say they will
not be treated as exectuable files by the vfs.
Not having to vet changes to closely is important as without this we
are only one proc_create call (or another goof up in the
implementation of notify_change) from having problematic executables
on proc. Those mistakes are all too easy to make and would create
a situation where there are security issues or the assumptions of
some program having to be broken (and cause userspace regressions).
architectures
On architectures where the stack grows upwards (CONFIG_STACK_GROWSUP=y,
currently parisc and metag only) stack randomization sometimes leads to crashes
when the stack ulimit is set to lower values than STACK_RND_MASK (which is 8 MB
by default if not defined in arch-specific headers).
The problem is, that when the stack vm_area_struct is set up in fs/exec.c, the
additional space needed for the stack randomization (as defined by the value of
STACK_RND_MASK) was not taken into account yet and as such, when the stack
randomization code added a random offset to the stack start, the stack
effectively got smaller than what the user defined via rlimit_max(RLIMIT_STACK)
which then sometimes leads to out-of-stack situations and crashes.
This patch fixes it by adding the maximum possible amount of memory (based on
STACK_RND_MASK) which theoretically could be added by the stack randomization
code to the initial stack size. That way, the user-defined stack size is always
guaranteed to be at minimum what is defined via rlimit_max(RLIMIT_STACK).
This bug is currently not visible on the metag architecture, because on metag
STACK_RND_MASK is defined to 0 which effectively disables stack randomization.
The changes to fs/exec.c are inside an "#ifdef CONFIG_STACK_GROWSUP"
section, so it does not affect other platformws beside those where the
stack grows upwards (parisc and metag).
Signed-off-by: Helge Deller <deller@gmx.de>
Cc: linux-parisc@vger.kernel.org
Cc: James Hogan <james.hogan@imgtec.com>
Cc: linux-metag@vger.kernel.org
Cc: stable@vger.kernel.org # v3.16+
This prevents a race between chown() and execve(), where chowning a
setuid-user binary to root would momentarily make the binary setuid
root.
This patch was mostly written by Linus Torvalds.
Signed-off-by: Jann Horn <jann@thejh.net>
We set sig->notify_count = -1 between RELEASE and ACQUIRE operations:
spin_unlock_irq(lock);
if (!thread_group_leader(tsk)) {
for (;;) {
sig->notify_count = -1;
write_lock_irq(&tasklist_lock);
There are no restriction on it so other processors may see this STORE
mixed with other STOREs in both areas limited by the spinlocks.
Probably, it may be reordered with the above
sig->group_exit_task = tsk;
sig->notify_count = zap_other_threads(tsk);
in some way.
Set it under tasklist_lock locked to be sure nothing will be reordered.
Signed-off-by: Kirill Tkhai <ktkhai@parallels.com>
Oleg cleverly suggested using xchg() to set the new mm->exe_file instead
of calling set_mm_exe_file() which requires some form of serialization --
mmap_sem in this case. For archs that do not have atomic rmw instructions
we still fallback to a spinlock alternative, so this should always be
safe. As such, we only need the mmap_sem for looking up the backing
vm_file, which can be done sharing the lock. Naturally, this means we
need to manually deal with both the new and old file reference counting,
and we need not worry about the MMF_EXE_FILE_CHANGED bits, which can
probably be deleted in the future anyway.
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Reviewed-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
There are several areas in the kernel that create temporary filename
objects using the following pattern:
int func(const char *name)
struct filename *file = { .name = name };
return 0;
... which for the most part works okay, but it causes havoc within the
audit subsystem as the filename object does not persist beyond the
lifetime of the function. This patch converts all of these temporary
filename objects into proper filename objects using getname_kernel()
and putname() which ensure that the filename object persists until the
audit subsystem is finished with it.
Also, a special thanks to Al Viro, Guenter Roeck, and Sabrina Dubroca
for helping resolve a difficult kernel panic on boot related to a
use-after-free problem in kern_path_create(); the thread can be seen
at the link below:
* https://lkml.org/lkml/2015/1/20/710
This patch includes code that was either based on, or directly written
by Al in the above thread.
CC: viro@zeniv.linux.org.uk
CC: linux@roeck-us.net
CC: sd@queasysnail.net
CC: linux-fsdevel@vger.kernel.org
Signed-off-by: Paul Moore <pmoore@redhat.com>
This patchset adds execveat(2) for x86, and is derived from Meredydd
Luff's patch from Sept 2012 (https://lkml.org/lkml/2012/9/11/528).
The primary aim of adding an execveat syscall is to allow an
implementation of fexecve(3) that does not rely on the /proc filesystem,
at least for executables (rather than scripts). The current glibc version
of fexecve(3) is implemented via /proc, which causes problems in sandboxed
or otherwise restricted environments.
Given the desire for a /proc-free fexecve() implementation, HPA suggested
(https://lkml.org/lkml/2006/7/11/556) that an execveat(2) syscall would be
an appropriate generalization.
Also, having a new syscall means that it can take a flags argument without
back-compatibility concerns. The current implementation just defines the
AT_EMPTY_PATH and AT_SYMLINK_NOFOLLOW flags, but other flags could be
added in future -- for example, flags for new namespaces (as suggested at
https://lkml.org/lkml/2006/7/11/474).
Related history:
- https://lkml.org/lkml/2006/12/27/123 is an example of someone
realizing that fexecve() is likely to fail in a chroot environment.
- http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=514043 covered
documenting the /proc requirement of fexecve(3) in its manpage, to
"prevent other people from wasting their time".
- https://bugzilla.redhat.com/show_bug.cgi?id=241609 described a
problem where a process that did setuid() could not fexecve()
because it no longer had access to /proc/self/fd; this has since
been fixed.
This patch (of 4):
Add a new execveat(2) system call. execveat() is to execve() as openat()
is to open(): it takes a file descriptor that refers to a directory, and
resolves the filename relative to that.
In addition, if the filename is empty and AT_EMPTY_PATH is specified,
execveat() executes the file to which the file descriptor refers. This
replicates the functionality of fexecve(), which is a system call in other
UNIXen, but in Linux glibc it depends on opening "/proc/self/fd/<fd>" (and
so relies on /proc being mounted).
The filename fed to the executed program as argv[0] (or the name of the
script fed to a script interpreter) will be of the form "/dev/fd/<fd>"
(for an empty filename) or "/dev/fd/<fd>/<filename>", effectively
reflecting how the executable was found. This does however mean that
execution of a script in a /proc-less environment won't work; also, script
execution via an O_CLOEXEC file descriptor fails (as the file will not be
accessible after exec).
Based on patches by Meredydd Luff.
Signed-off-by: David Drysdale <drysdale@google.com>
Cc: Meredydd Luff <meredydd@senatehouse.org>
Cc: Shuah Khan <shuah.kh@samsung.com>
Cc: Rich Felker <dalias@aerifal.cx>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
We no longer need mpx.h in exec.c. This will obviously also
break the build for non-x86 builds. We get the MPX includes that
we need from mmu_context.h now.
Link: http://lkml.kernel.org/r/20141118003608.837015B3@viggo.jf.intel.com
This is really the meat of the MPX patch set. If there is one patch to
review in the entire series, this is the one. There is a new ABI here
and this kernel code also interacts with userspace memory in a
relatively unusual manner. (small FAQ below).
Long Description:
This patch adds two prctl() commands to provide enable or disable the
management of bounds tables in kernel, including on-demand kernel
allocation (See the patch "on-demand kernel allocation of bounds tables")
and cleanup (See the patch "cleanup unused bound tables"). Applications
do not strictly need the kernel to manage bounds tables and we expect
some applications to use MPX without taking advantage of this kernel
support. This means the kernel can not simply infer whether an application
needs bounds table management from the MPX registers. The prctl() is an
explicit signal from userspace.
PR_MPX_ENABLE_MANAGEMENT is meant to be a signal from userspace to
require kernel's help in managing bounds tables.
PR_MPX_DISABLE_MANAGEMENT is the opposite, meaning that userspace don't
want kernel's help any more. With PR_MPX_DISABLE_MANAGEMENT, the kernel
won't allocate and free bounds tables even if the CPU supports MPX.
PR_MPX_ENABLE_MANAGEMENT will fetch the base address of the bounds
directory out of a userspace register (bndcfgu) and then cache it into
a new field (->bd_addr) in the 'mm_struct'. PR_MPX_DISABLE_MANAGEMENT
will set "bd_addr" to an invalid address. Using this scheme, we can
use "bd_addr" to determine whether the management of bounds tables in
kernel is enabled.
Also, the only way to access that bndcfgu register is via an xsaves,
which can be expensive. Caching "bd_addr" like this also helps reduce
the cost of those xsaves when doing table cleanup at munmap() time.
Unfortunately, we can not apply this optimization to #BR fault time
because we need an xsave to get the value of BNDSTATUS.
==== Why does the hardware even have these Bounds Tables? ====
MPX only has 4 hardware registers for storing bounds information.
If MPX-enabled code needs more than these 4 registers, it needs to
spill them somewhere. It has two special instructions for this
which allow the bounds to be moved between the bounds registers
and some new "bounds tables".
They are similar conceptually to a page fault and will be raised by
the MPX hardware during both bounds violations or when the tables
are not present. This patch handles those #BR exceptions for
not-present tables by carving the space out of the normal processes
address space (essentially calling the new mmap() interface indroduced
earlier in this patch set.) and then pointing the bounds-directory
over to it.
The tables *need* to be accessed and controlled by userspace because
the instructions for moving bounds in and out of them are extremely
frequent. They potentially happen every time a register pointing to
memory is dereferenced. Any direct kernel involvement (like a syscall)
to access the tables would obviously destroy performance.
==== Why not do this in userspace? ====
This patch is obviously doing this allocation in the kernel.
However, MPX does not strictly *require* anything in the kernel.
It can theoretically be done completely from userspace. Here are
a few ways this *could* be done. I don't think any of them are
practical in the real-world, but here they are.
Q: Can virtual space simply be reserved for the bounds tables so
that we never have to allocate them?
A: As noted earlier, these tables are *HUGE*. An X-GB virtual
area needs 4*X GB of virtual space, plus 2GB for the bounds
directory. If we were to preallocate them for the 128TB of
user virtual address space, we would need to reserve 512TB+2GB,
which is larger than the entire virtual address space today.
This means they can not be reserved ahead of time. Also, a
single process's pre-popualated bounds directory consumes 2GB
of virtual *AND* physical memory. IOW, it's completely
infeasible to prepopulate bounds directories.
Q: Can we preallocate bounds table space at the same time memory
is allocated which might contain pointers that might eventually
need bounds tables?
A: This would work if we could hook the site of each and every
memory allocation syscall. This can be done for small,
constrained applications. But, it isn't practical at a larger
scale since a given app has no way of controlling how all the
parts of the app might allocate memory (think libraries). The
kernel is really the only place to intercept these calls.
Q: Could a bounds fault be handed to userspace and the tables
allocated there in a signal handler instead of in the kernel?
A: (thanks to tglx) mmap() is not on the list of safe async
handler functions and even if mmap() would work it still
requires locking or nasty tricks to keep track of the
allocation state there.
Having ruled out all of the userspace-only approaches for managing
bounds tables that we could think of, we create them on demand in
the kernel.
Based-on-patch-by: Qiaowei Ren <qiaowei.ren@intel.com>
Cc: linux-mips@linux-mips.org
Link: http://lkml.kernel.org/r/20141114151829.AD4310DE@viggo.jf.intel.com
... rather than doing that in the guts of ->load_binary().
[updated to fix the bug spotted by Shentino - for SIGSEGV we really need
something stronger than send_sig_info(); again, better do that in one place]
mm initialization on fork/exec is spread all over the place, which makes
the code look inconsistent.
We have mm_init(), which is supposed to init/nullify mm's internals, but
it doesn't init all the fields it should:
- on fork ->mmap,mm_rb,vmacache_seqnum,map_count,mm_cpumask,locked_vm
are zeroed in dup_mmap();
- on fork ->pmd_huge_pte is zeroed in dup_mm(), immediately before
calling mm_init();
- ->cpu_vm_mask_var ptr is initialized by mm_init_cpumask(), which is
called before mm_init() on both fork and exec;
- ->context is initialized by init_new_context(), which is called after
Let's consolidate all the initializations in mm_init() to make the code
look cleaner.
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Cc: Christoph Lameter <cl@linux.com>
Applying restrictive seccomp filter programs to large or diverse
codebases often requires handling threads which may be started early in
the process lifetime (e.g., by code that is linked in). While it is
possible to apply permissive programs prior to process start up, it is
difficult to further restrict the kernel ABI to those threads after that
point.
This change adds a new seccomp syscall flag to SECCOMP_SET_MODE_FILTER for
synchronizing thread group seccomp filters at filter installation time.
When calling seccomp(SECCOMP_SET_MODE_FILTER, SECCOMP_FILTER_FLAG_TSYNC,
filter) an attempt will be made to synchronize all threads in current's
threadgroup to its new seccomp filter program. This is possible iff all
threads are using a filter that is an ancestor to the filter current is
attempting to synchronize to. NULL filters (where the task is running as
SECCOMP_MODE_NONE) are also treated as ancestors allowing threads to be
transitioned into SECCOMP_MODE_FILTER. If prctrl(PR_SET_NO_NEW_PRIVS,
...) has been set on the calling thread, no_new_privs will be set for
all synchronized threads too. On success, 0 is returned. On failure,
the pid of one of the failing threads will be returned and no filters
will have been applied.
The race conditions against another thread are:
- requesting TSYNC (already handled by sighand lock)
- performing a clone (already handled by sighand lock)
- changing its filter (already handled by sighand lock)
- calling exec (handled by cred_guard_mutex)
The clone case is assisted by the fact that new threads will have their
seccomp state duplicated from their parent before appearing on the tasklist.
Holding cred_guard_mutex means that seccomp filters cannot be assigned
while in the middle of another thread's exec (potentially bypassing
no_new_privs or similar). The call to de_thread() may kill threads waiting
for the mutex.
Changes across threads to the filter pointer includes a barrier.
Based on patches by Will Drewry.
Suggested-by: Julien Tinnes <jln@chromium.org>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Reviewed-by: Andy Lutomirski <luto@amacapital.net>
Since seccomp transitions between threads requires updates to the
no_new_privs flag to be atomic, the flag must be part of an atomic flag
set. This moves the nnp flag into a separate task field, and introduces
accessors.
perf tools like 'perf report' can aggregate samples by comm strings,
which generally works. However, there are other potential use-cases.
For example, to pair up 'calls' with 'returns' accurately (from branch
events like Intel BTS) it is necessary to identify whether the process
has exec'd. Although a comm event is generated when an 'exec' happens
it is also generated whenever the comm string is changed on a whim
(e.g. by prctl PR_SET_NAME). This patch adds a flag to the comm event
to differentiate one case from the other.
In order to determine whether the kernel supports the new flag, a
selection bit named 'exec' is added to struct perf_event_attr. The
bit does nothing but will cause perf_event_open() to fail if the bit
is set on kernels that do not have it defined.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/537D9EBE.7030806@intel.com
Cc: Dave Jones <davej@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: linux-fsdevel@vger.kernel.org
perf_event_comm() assumes that set_task_comm() is only called on
exec(), and in particular that its only called on current.
Neither are true, as Dave reported a WARN triggered by set_task_comm()
being called on !current.
Separate the exec() hook from the comm hook.
Reported-by: Dave Jones <davej@redhat.com>
Link: http://lkml.kernel.org/r/20140521153219.GH5226@laptop.programming.kicks-ass.net
[ Build fix. ]
Specify the maximum stack size for arches where the stack grows upward
(parisc and metag) in asm/processor.h rather than hard coding in
fs/exec.c so that metag can specify a smaller value of 256MB rather than
1GB.
This fixes a BUG on metag if the RLIMIT_STACK hard limit is increased
beyond a safe value by root. E.g. when starting a process after running
"ulimit -H -s unlimited" it will then attempt to use a stack size of the
maximum 1GB which is far too big for metag's limited user virtual
address space (stack_top is usually 0x3ffff000):
BUG: failure at fs/exec.c:589/shift_arg_pages()!
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: John David Anglin <dave.anglin@bell.net>
Cc: stable@vger.kernel.org # only needed for >= v3.9 (arch/metag)
Pull vfs updates from Al Viro:
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
Starting from commit c4ad8f98bef7 ("execve: use 'struct filename *' for
executable name passing") bprm->filename can not go away after
flush_old_exec(), so we do not need to save the binary name in
bprm->tcomm[] added by 96e02d158678 ("exec: fix use-after-free bug in
setup_new_exec()").
And there was never need for filename_to_taskname-like code, we can
simply do set_task_comm(kbasename(filename).
This patch has to change set_task_comm() and trace_task_rename() to
accept "const char *", but I think this change is also good.
This patch is a continuation of efforts trying to optimize find_vma(),
avoiding potentially expensive rbtree walks to locate a vma upon faults.
The original approach (https://lkml.org/lkml/2013/11/1/410), where the
largest vma was also cached, ended up being too specific and random,
thus further comparison with other approaches were needed. There are
two things to consider when dealing with this, the cache hit rate and
the latency of find_vma(). Improving the hit-rate does not necessarily
translate in finding the vma any faster, as the overhead of any fancy
caching schemes can be too high to consider.
We currently cache the last used vma for the whole address space, which
provides a nice optimization, reducing the total cycles in find_vma() by
up to 250%, for workloads with good locality. On the other hand, this
simple scheme is pretty much useless for workloads with poor locality.
Analyzing ebizzy runs shows that, no matter how many threads are
running, the mmap_cache hit rate is less than 2%, and in many situations
below 1%.
The proposed approach is to replace this scheme with a small per-thread
cache, maximizing hit rates at a very low maintenance cost.
Invalidations are performed by simply bumping up a 32-bit sequence
number. The only expensive operation is in the rare case of a seq
number overflow, where all caches that share the same address space are
flushed. Upon a miss, the proposed replacement policy is based on the
page number that contains the virtual address in question. Concretely,
the following results are seen on an 80 core, 8 socket x86-64 box:
1) System bootup: Most programs are single threaded, so the per-thread
scheme does improve ~50% hit rate by just adding a few more slots to
the cache.
| caching scheme | hit-rate | cycles (billion) |
| baseline | 50.61% | 19.90 |
| patched | 73.45% | 13.58 |
2) Kernel build: This one is already pretty good with the current
approach as we're dealing with good locality.
| baseline | 75.28% | 11.03 |
| patched | 88.09% | 9.31 |
3) Oracle 11g Data Mining (4k pages): Similar to the kernel build workload.
| baseline | 70.66% | 17.14 |
| patched | 91.15% | 12.57 |
4) Ebizzy: There's a fair amount of variation from run to run, but this
approach always shows nearly perfect hit rates, while baseline is just
about non-existent. The amounts of cycles can fluctuate between
anywhere from ~60 to ~116 for the baseline scheme, but this approach
reduces it considerably. For instance, with 80 threads:
| baseline | 1.06% | 91.54 |
| patched | 99.97% | 14.18 |
[akpm@linux-foundation.org: fix nommu build, per Davidlohr]
[akpm@linux-foundation.org: document vmacache_valid() logic]
[akpm@linux-foundation.org: attempt to untangle header files]
[akpm@linux-foundation.org: add vmacache_find() BUG_ON]
[hughd@google.com: add vmacache_valid_mm() (from Oleg)]
[akpm@linux-foundation.org: adjust and enhance comments]
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Reviewed-by: Michel Lespinasse <walken@google.com>
Tested-by: Hugh Dickins <hughd@google.com>
uselib hasn't been used since libc5; glibc does not use it. Support
turning it off.
When disabled, also omit the load_elf_library implementation from
binfmt_elf.c, which only uselib invokes.
bloat-o-meter:
add/remove: 0/4 grow/shrink: 0/1 up/down: 0/-785 (-785)
function old new delta
padzero 39 36 -3
uselib_flags 20 - -20
sys_uselib 168 - -168
SyS_uselib 168 - -168
load_elf_library 426 - -426
The new CONFIG_USELIB defaults to `y'.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
... and don't skip on sanity checks. It's *not* a hot path, TYVM
(a couple of calls per a.out execve(), for pity sake) and headers of
random a.out binary are not to be trusted.
Convert all compat system call functions where all parameter types
have a size of four or less than four bytes, or are pointer types
to COMPAT_SYSCALL_DEFINE.
The implicit casts within COMPAT_SYSCALL_DEFINE will perform proper
zero and sign extension to 64 bit of all parameters if needed.
